Xbox 360 "Jasper"
734 svar till detta ämne
Postad 10 October 2007 - 17:34
Unregistered92d7e447
  • Unregistered92d7e447
  • 1428 inlägg
http://blogs.mercury...mes_jasper.html
"Jasper is the code name for the next motherboard for the Xbox 360. It will becoming next August, in time for next year’s holiday season. Jasper is going to have a 65-nanometer graphics chip from ATI Technologies, as well as smaller memory chips."
Augusti 2008 that is...
Jag som hade tänkt hålla ut och vänta in det här. Blir nog till att byta ut min Premium mot en Pro i månadsskiftet nu.
Kanske inte helt omöjligt med 45nm CPU vid det laget.
Ovidkommande rant:
Redigerat av Unregistered92d7e447, 11 October 2007 - 18:56.
Postad 10 October 2007 - 17:50
PalmiNio
  • PalmiNio
  • 8074 inlägg
Hehe jaha då får man vänta på denna också? hehe
Postad 09 May 2008 - 20:55
  • 38138 inlägg
New version of Xbox 360 coming in August with less heat and noise
Microsoft Gears Up to Release Xbox 360 with New Chips.
Microsoft Corp. reportedly plans to release a new version its Xbox 360 video game system code-named Jasper in August and has already assigned IBM and Taiwan Semiconductor Manufacturing Co. to make chips for the new game console. However, there are other important rumours: TSMC got orders to produce the chip for code-named Valhalla Xbox 360 design, which is rumoured to combine microprocessor and graphics chip in a single piece of silicon.
The code-named Jasper design of the Xbox 360 game console will use ATI Xenos graphics and memory controller hub (GMCH) made using 65nm process at TSMC as well as IBM Xenon central processing unit (CPU) produced at IBM’s 65nm nodes. The new system design is projected to consume less electricity, use less complex cooling systems and also produce less noise.
By contrast, current Xbox 360 design named Falcon utilizes GMCH and eDRAM cores manufactured using 90nm process technology at TSMC as well as CPU built at IBM using 65nm fabrication process. The first-generation Xbox 360 used 90nm chips.
TSMC is chosen to make the 65nm GMCH chips, Advanced Semiconductor Engineering (ASE) is contracted to package and test the chips, and Nanya has won orders to supply flip-chip packaging substrates, reports China Economic News Service.
What is, perhaps, more important than the facts that TSMC again got orders to produce ATI Xenos GMCH and IBM land orders on IBM Xenon CPU at expense of Chartered Semiconductor (which once promised to start making 45nm chips for Advanced Micro Devices in 2009), is that “chips” for next-generation Xbox 360 code-named Valhalla will also be made at TSMC. Earlier rumours transpired that Valhalla features a chip that combines CPU and GMCH. In order to build such chip at TSMC, Microsoft either needs to disclose certain design rules of IBM’s fabrication process to the Taiwan-based semiconductor manufacturer, or completely rework the CPU according to fabrication process of TSMC.
Microsoft did not comment on the news-story.
Microsoft Xbox 360 console is based around triple-core microprocessor developed by IBM, high-definition visual processing unit designed by ATI Technologies, I/O controller engineered by SiS and some other key components. The gaming machine provides a broad set of multimedia capabilities in addition to games. Currently Microsoft Xbox 360 is available for $279, $349 or $449 in the USA depending on the version.
http://www.xbitlabs...._New_Chips.html
Postad 09 May 2008 - 21:20
Sir Anselm
  • Sir Anselm
  • 1475 inlägg
Hm, "less noise", innebär det att de bytt ut eller modifierat dvd-läsaren? för det är ju den som låter... iallafall för mig... Isåfall kan jag nog tänka mig att köpa en ny...
Postad 10 May 2008 - 00:53
PalmiNio
  • PalmiNio
  • 8074 inlägg
Finns redan en ny ute av Lite-On. Tyvärr är där ingen info om tystheten.
Postad 10 May 2008 - 11:40
Phredreeke
  • Phredreeke
  • 798 inlägg
Tror den är i stort sett samma som BenQ-driven, bortsett från att de lagt firmwaren på mask rom istället för flashminne (för att det inte ska gå att flasha)
Postad 12 May 2008 - 14:48
BioBerra
  • BioBerra
  • 5779 inlägg
Du är väl medveten om att denna tråd är 7 månader gammal ?
Det är idag beviset att dom nya 65nm inte är tystare, problemet ligger hosi DVD läsaren. Har däremot inte sett någon statistik om 65nm är stabilare än dom gamla varianterna. Men man tycker att det snart borde komma 45nm också.
Postad 12 May 2008 - 15:36
  • 38138 inlägg
Jag uppdaterade med nya nyheter 9 maj så nyheterna är inte gamla. Det står att Jasper ska vara tystare.
Postad 12 May 2008 - 16:32
PalmiNio
  • PalmiNio
  • 8074 inlägg
Nej men o andra sidan finns det ingen statestik alls, varken innan eller efter. Finns dock spekulationer från företag o de har sagt lägre siffror och ser du på nätet så Ja den nya är stabilare, mycket stabilare. Detta är tackvare lägre strömförbrukning som i sin tur ger betydligt mindre värme och därmed betydligt tystare fläktar.
Sen är den nya inte 65nm, det är bara CPUn som är 65nm. Jasper ska ha 65nm på både GPU och CPU.
Men som du säger så spelar sånt ingen roll för ljudet då det är DVD-spelaren som avgör. Lösningen skulle kunna vara en custom DVD-spelare likt den egna varianten av Blu-Ray spelare som PS3 har. Att köra en snabbt anpassad PC DVD-spelare känns inte som lösning.
Redigerat av PalmiNio, 12 May 2008 - 16:35.
Postad 24 May 2008 - 12:40
13th Marine
  • 13th Marine
  • 1103 inlägg
Här är det? De som är ute nu är med Falcon (65nm samt 90nm)?
Och de med Jasper kommer i augusti?
Jag ska nämligen köpa en 360 i sommar och jag vill ju helst ha en med Jasperkärnan...
Någon som har koll på hur kärnorna är fördelade mellan Arcade/Premium/Elite?
Så att man iaf får en med Falconkärnan om man köper en, och inte får en gammal kärna...
Postad 24 May 2008 - 13:23
Unregistereddc471864
  • Unregistereddc471864
  • 24891 inlägg
Alla med HDMI är falcon.
Postad 24 May 2008 - 13:24
13th Marine
  • 13th Marine
  • 1103 inlägg
Men de fösta Elite då?
Var även de Falcon?
Postad 24 May 2008 - 13:26
PalmiNio
  • PalmiNio
  • 8074 inlägg
Jasper sägs komma i augusti men inget mer vet vi. Sverige lär inte få dem tidigast iaf.
För att vara säker så är iaf alla från 2007-10 Falcon oavsett modell.
Säkrast kort är Arcade då alla är falcon. Men även Premium HDMI och Elite lär vara bra kort om du köper nytt då alla lager i Sverige har fått bort de äldre maskinerna. Passa dig dock för Halo 3 Edition.
Postad 24 May 2008 - 13:38
Jack of all trades
  • Jack of all trades
  • 1846 inlägg
Inte helt korrekt då vissa ställen fortfarande säljer Hdmi som inte är Falcon. Däremot stämmer det att alla Falcon har hdmi om det var så du menade :(. Men jag tror det är väldigt få butiker idag som säljer Hdmi versioner med gamla Zephyr chipet så man ska nog ha riktig otur om man lyckas få en. Mitt råd, kolla efter hur mycket ström den drar då detta är ett rätt så säkert sätt att se om det är en Falcon (Falcon drar mindre ström än Zephyr) har för mig att det på Falcon modellerna ska stå 175 W. Detta i kombination med tillverkningsdatum och vilket team som gjort den är indikeringar på om det är Falcon eller ej. Men som sagt så tror jag att merparten av alla Xbox i handeln är Falcon.
Allt pekar på att Jasper kommer kunna gå att köpa till jul men man kan ha turen att få tag på en en tid innan dess. Alllt handlar om hur bra Micrsoft säljer i förhållande till vad de tillverkar, säljer lagrena slut i butik så är chanserna nog stora att vi kommer få se de första Jasper versionerna lagom till början av hösten med lite tur=).
Postad 24 May 2008 - 13:46
13th Marine
  • 13th Marine
  • 1103 inlägg
Ah okej, då ska jag kolla efter det!
Tänkte köpa i butik för att få hygglig service...
tack för hjälpen!
Postad 24 May 2008 - 14:45
Razsor
  • Razsor
  • 32 inlägg
En liten fråga bara jag ska köpa ett 360 i augusti eller september om inte jasper e i sverige då så har jag en liten fråga är Falcon säkert? jag menar får det RROD lätt eller ngt annat problem vill helst inte byta efter 3 dagar :(
Postad 24 May 2008 - 15:15
PalmiNio
  • PalmiNio
  • 8074 inlägg
Jepp det är säkert. Men inte problemfritt, DVD-spelarna är fortfarande av varierande kvalité. Men just värmeskadorna som gav RRoD är borta.
Postad 24 May 2008 - 15:29
PalmiNio
  • PalmiNio
  • 8074 inlägg
Nu har jag googlat häcken av mig.
Vet inte vad det är med folk men kollade runt på olika forum m.m för att se om någon med Falcon hade fått RRoD.
Givetvis var där folk som påstod detta. Men av någon sjuk anledning finns det ingen som kan bevisa att de verkligen har en Falcon och fått RRoD.
Första fallen är gällande Elite men som alla vet så är långt ifrån alla Elite och Halo 3 som gjordes 2007 Falcon.
Var några på youtube också men folk har tydligen problem att kunna visa tillverkningsinformationen som finns på baksidan eller filma in i maskinen.
Har någon bra bevis så dela gärna med er.
Postad 25 May 2008 - 10:23
Coistrel
  • Coistrel
  • 804 inlägg
Jag hade en Elite som fick RRoD. Dock har bilderna på den försvunnit, och ligger i en tråd här någonstans.
Postad 25 May 2008 - 10:31
Unregistered4352927d
  • Unregistered4352927d
  • 442 inlägg
Men hade din Elite Falcon då? Alla Elite har inte Falcon.
Postad 25 May 2008 - 14:53
PalmiNio
  • PalmiNio
  • 8074 inlägg
Precis som innan. Alla Elite är INTE falcon.
Jag blev själv så frågande att jag nu testkör min egen 360 som jag vet e en falcon för att se om jag kan få fram RRoD på den.
Har slängt in den i en byrålåda där den nu kör. Lite luft kommer dock in från baksidan men annars är det en stängd miljö. Har kört den där sen kl 16.48 igår 05/24 och än så länge funkar den, har Gears rullande på den bara. Dock är där bastuvarmt där nu.
Postad 25 May 2008 - 18:28
Coistrel
  • Coistrel
  • 804 inlägg
Jag vet att inte alla Elite är falcon. Men enligt produktionsdatum, watt antal och diverse andra bevis.. Var det en falcon.
Tyvärr har jag inga bevis kvar för detta.
EDIT:
Hittade lite info om min Elite som fick RRoD.
BenQ läsare.
175 watt enligt kartongen.
MFR Date: 2007 - 11 - 03
Lot no: #0743
Som sagt hann jag inte ta bilder på själva boxen, då jag bytte in den samma dag jag fick den. Och jag tror kartongen är kastad vid det här laget.
Redigerat av Coistrel, 25 May 2008 - 18:30.
Postad 27 May 2008 - 11:50
PalmiNio
  • PalmiNio
  • 8074 inlägg
EDIT:
BenQ läsare.
Lot no: #0743
Och du är även 100 på att nätadapter var ok? RRoD koden gäller även för fel på nätadaptern
Körtmin 360 i en låda nu runt 54h och den har inte lagt av än.
Postad 27 May 2008 - 13:43
  • 38138 inlägg
Helt ok :P
Postad 27 May 2008 - 13:58
Jack of all trades
  • 1846 inlägg
Finns säkert några Falcon som har råkat ut för det men inte i närheten lika många som tidigare, när det kommer till hårdvara så kan man inte komma undan att några kan ha "oturen" att köpa ett ex som är defekt. Detta är helt normalt och som sagt var något man får räkna med så Falcon verkar nu vara nere på en rimlig nivå. Jasper kommer att ha en 65 nm gpu vilket kommer göra att den drar mindre ström och detta i sin tur kanske innebär att den blir ännu svalare eftersom den inte alstrar lika mycket varme. Jasper är intressant men kanske kommer jag ha köpt en Falcon innan dess (som det är nu är den slutsåld i de flesta butiker tydligen) eftersom den har blivit mycket stabilare, polaren har iaf inte haft några problem med sin Elite.
Postad 27 May 2008 - 14:07
nolite
  • nolite
  • 27 inlägg
Det verkar ju onekligen som att de konsoler med nyare, kallare, teknologi för CPUn är mer stabila. Är det inte ganska bekräftat att det är värmen som gör att Xboxarna RRODar? Egentligen är det lite skumt att det inte finns extrafläktar att "mounta" på konsolen från MS. Tredjepartsmodellerna har ju rapporterats skada (!) vissa maskiner vid användning.
Postad 27 May 2008 - 14:14
13th Marine
  • 13th Marine
  • 1103 inlägg
Problemet låg väl i att kärnorna inte var tillräckligt bra lödda mot moderkortet och att värmen gjorde att trycket från kylflänsen lättade och glappkontakt uppstår -> RROD.
Postad 27 May 2008 - 14:18
PalmiNio
  • PalmiNio
  • 8074 inlägg
Jupp och värmen hjälpte till. Den höga normalvärmen gör att fästet för kylflänsarna tappar trycket och GPUn får inte tillräckligt med kylning.
Postad 27 May 2008 - 15:22
  • 38138 inlägg
Vad? Det måste väl gå att få tag på en arcade utan problem?
Postad 27 May 2008 - 15:37
Jack of all trades
  • 1846 inlägg
Faktiskt är har den varit slutsåld på de ställen jag kollat, fast jag glömde skriva att det var Elite som jag är på jakt efter men som sagt både Arcade och Elite är slut och har så varit en tid nu.
Postad 27 May 2008 - 16:02
13th Marine
  • 13th Marine
  • 1103 inlägg
Finns väl en massa på prisjakt som har den inne?
Själv ska jag snart ränna runt i Lund och leta efter en...
Postad 27 May 2008 - 16:05
  • 38138 inlägg
Här finns de överallt..
https://www.prisjakt...kt.php?p=199896
https://www.prisjakt...kt.php?p=244243
Postad 27 May 2008 - 16:21
Jack of all trades
  • 1846 inlägg
Jag menade "vanliga" butiker, inte nätbaserade sådana :P. Blir nog ett köp när jag får råd och förhoppningsvis har de fått in dom annars kanske jag beställer en från nätet ändå.
Postad 27 May 2008 - 16:24
  • 38138 inlägg
Det är blandat nätbaserade och vanliga butiker där Jack. Har du verkligen inget onoff, siba, elgiganten etc i närheten? Alla butiker har i stort sett en Elite.
Postad 30 May 2008 - 09:38
Jack of all trades
  • 1846 inlägg
El-Giganten är helt körd men jag har nog mer eller mindre bestämt mig för att skaffa en från en nätbaserad butik =).
Postad 30 May 2008 - 10:14
Unregistered1124
  • Unregistered1124
  • 1000 inlägg
Webhallen har massvis på lager för 3195 kr.
Postad 30 May 2008 - 11:06
Jack of all trades
  • 1846 inlägg
Japp såg det tack vare 13th Marine´s inlägg, det priset är helt klart riktigt bra (även om man räknar med frakten). Kommer nog beställa en inom de närmsta dagarna, Webhallen har jag beställt från tidigare och har överlag bara bra erfarenheter från dom. Har sökt lite på deras sida och hittat en hel del bra priser på både filmer och spel så det blir nog lite av den varan med om det blir en beställning=).
Postad 30 May 2008 - 12:39
13th Marine
  • 13th Marine
  • 1103 inlägg
Fick min idag och det är en falcon (175W).
Synd att man ska bort ikväll, annars hade jag spelat GoW hela natten (279 på webhallen)...
EDIT: Ojsan, menade 175W inte 275...
Redigerat av 13th Marine, 30 May 2008 - 15:29.
Postad 30 May 2008 - 13:22
SC-Zap
  • SC-Zap
  • 6963 inlägg
Hoppas att du menar 175 Watt, Marine.
Postad 30 May 2008 - 15:30
13th Marine
  • 13th Marine
  • 1103 inlägg
Jepp... blev fel =)
Postad 30 May 2008 - 16:03
loose_batch
  • loose_batch
  • 25 inlägg
vad sklle vara chansen att jag får en falcon om jag köper elite nästa vecka (webhallen)?
Postad 30 May 2008 - 16:05
Coistrel
  • Coistrel
  • 804 inlägg
Finns nog ingen som kan besvara det. Men eftersom 13th Marine fick det, är det ju ingen omöjlighet ;)
Postad 01 June 2008 - 22:59
  • 38138 inlägg
Har den pajat än :blink: ?
Postad 02 June 2008 - 13:09
PalmiNio
  • PalmiNio
  • 8074 inlägg
Hahah nej den funkar prima. Ska göra det mer vetenskapligt när jag kommer hem till Malmö över sommaren. Ta temperaturen, se till att den får jobba mer genom att typ loopa replays på Forza 2 osv.
Tänkte också kolla hur vidare den klarar värmeväxlingar, från kallt till varmt. Blev dock förvånad över att den aldrig stängde av sig eller visade på överhettad (2 röda blinkande) då min polares 360 av den gamla modellen överhettas efter 15min spel om han stänger sin dörr.
Postad 02 June 2008 - 15:27
  • 38138 inlägg
Jag tror ingen Zephyr hade klarat sig vidare länge under de omständigheterna. Det där lilla testet "all but" bevisar att Falcon är grymt mycket värmetåligare. Även fast vi redan visste det är det kul att få en indikation på just hur stor skillnaden är.
Och Jasper lär bli ännu stabilare, även fast det inte är någon direkt prioritet längre.
Postad 02 June 2008 - 17:35
Jack of all trades
  • 1846 inlägg
Håller med tror inte den hade klarat det heller. Falcon verkar riktigt stabil, synd bara att den låter en del pågrund av Dvd spelaren och ett byte innebär att man kan bli bannad från Live (för så är det väl fortfarande?).
Men annars verkar Microsoft fått bukt med det som gjorde att jag var väldigt tveksam att skaffa en, så nu är det mer en fråga om att jag får vänta tills jag har pengar att inhandla en även om en jag hade föredragit en Jasper men det känns inte lika aktuellt längre=).
Postad 02 June 2008 - 20:11
PalmiNio
  • PalmiNio
  • 8074 inlägg
Nope, du kan inte köra in en annan spelare än de modeller som sitter i 360. Dessutom blir du inte bannad, du blir bara bannad om du kör brända spel. De upptäcker skivan, inte firmwaret.
Postad 02 June 2008 - 21:33
Unregistered6810b893
  • Unregistered6810b893
  • 6702 inlägg
Rykten säger att de börjat skeppa ut Opus moderkort nu som ersättning för de Xenon moderkort som dör en röd död.
Har Falcon chippet men utan HDMI.
Tråkiga är att jag kommer att skicka in min box för att byta spelare, inte för att byta moderkort...
Kan inte heller stänga in lådan för att tvinga dem att byta moderkort, för då har jag fortfarande den dåliga spelaren kvar...
Jaja, ny box med spelare och så får man hoppas på RoD när det är lite speltorka. :)
Postad 02 June 2008 - 22:08
Coistrel
  • Coistrel
  • 804 inlägg
Vad är det för skillnad mellan den här nya Jasper och Falcon då..?
Postad 02 June 2008 - 22:20
  • 38138 inlägg
Det.. står i tredje inlägget.
