Grandview Tab Tension
325 svar till detta ämne
Grandview Fantasy Tab-Tension 106" (234x132) (Projektordukar) 1 8.333332 (2) Inga priser
Grandview Tab-Tension 16:9 92" (203x114) (Projektordukar) 1 7.666666 (2) Inga priser
Grandview Tab-Tension 16:9 106" (235x132) (Projektordukar) 1 8.714284 (6) Inga priser
Grandview Cyber Tab-Tension Matte White 16:9 100" (221x124) (Projektordukar) 1 7.5 (1) Inga priser
1 relaterade trådar
Postad 04 December 2007 - 13:50
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Grandview fantasy kommer med nya mkt prisvärda Tab tension dukar.
Postad 04 December 2007 - 14:16
Unregistered24c8b9de
  • Unregistered24c8b9de
  • 1450 inlägg
Kan bli intressant! I Kanada kostar en 100" ca 6 200:-. Undrar vad priset blir här?
Några "copy and paste"-fakta:
Design
* The outer case is a beautifully designed black alloy case that can be installed either against the wall or the ceiling. Heavy duty support brackets are included.
* Exceptional quality for high definition television/movies
* Installation is suitable for home theatres, scientific research institutions, government, command centres, and etc.
Screen
* Uses the PS Series high contrast (while maintaining 1.0 gain) fabric that provides high quality images superior to traditional white matte materials.
* The PS Series flexible screen uses a special fabric containing miniature and fine diamond veins that work effectively to remove purple light and light waves while fully reverting colour.
Roller
* Large diameter rollers ensure long-term screen integrity providing a consistent flat projection surface.
* The Tab-Tension Cinema model utilizes a heavy duty motor made by the world-famous French Somfy Systems motor. Its unique noise control design ensures that raising and lowering the screen is smooth and quiet.
Se vidare här.
Bifogad fil  tabtens.jpg   8.47K   8 Antal nerladdningar
Postad 04 December 2007 - 16:05
mattdigi
  • mattdigi
  • 29 inlägg
Svensk ÅF?
Postad 04 December 2007 - 16:38
  • 1450 inlägg
Tror bara det är HBC som har de i Sverige.
Postad 07 December 2007 - 08:56
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Kommer att vara ett rikt pris i Sverige på ca 12-13000 .
Det är Wiktors som är importör. Wiktors
Hängde upp min igår. Kanon bra bild!
Det är Somfy motor i den också, så det känns som det är ett bra kvalitetsbyge.
Redigerat av Jokkmokksjocke, 07 December 2007 - 09:00.
Postad 09 December 2007 - 10:12
ferrari-f1
  • ferrari-f1
Har du några bilder på duken monterad?
Postad 09 December 2007 - 10:31
Chuck
  • Chuck
  • 2498 inlägg
Trevlig nyhet.
Dock hade jag föredragit en längre "black drop" än 40 cm, det är i minsta laget om man skall takmontera och har normal tak- och sitthöjd för att undvika nackspärr.
/g
Redigerat av Chuck, 09 December 2007 - 10:31.
Postad 09 December 2007 - 23:54
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Jag skall ta några bilder.
Har min i taket och har problemet att de är förmycket black drop.
Har man den inte fullt ut blir den inte lika spänd (när det gäller tabtension)...men de får jag väl leva med.
Postad 10 December 2007 - 09:39
Chuck
  • Chuck
  • 2498 inlägg
Vore kul med några bilder, väldigt uppskattat då jag själv är intresserad av den duken.
/Chuck
Postad 10 December 2007 - 10:01
  • 1450 inlägg
Jaha, så billig var den ju inte. Varför ska saker bli 100 % dyrare så fort de kommer till Sverige? Nu är ju Adeo fortfarande ett hett alternativ.
Postad 10 December 2007 - 12:06
Chuck
  • Chuck
  • 2498 inlägg
Vad kostar den utanför Sverige?
/Chuck
Postad 10 December 2007 - 13:01
  • 1450 inlägg
Billigaste 100" jag hittat är ca 4 200:- på Grandview Screen USA.
De säljer dock inte utanför USA. Men det ger ju ett hum om vilka priser tillverkaren tar.
Postad 12 December 2007 - 14:51
Matsen
  • Matsen
  • 2792 inlägg
Varför poppar det upp en term såsom "Power Buy" i min skalle när jag läser denna tråd... Jag vill ha en tabtension duk men jag kan inte motivera ett inköp på 10-13 papp - däremot om jag skulle få tag på en för de priser som nämns ovan , skulle det vara grymt svårt att motstå!! :)
Redigerat av Matsen, 12 December 2007 - 14:53.
Postad 12 December 2007 - 20:44
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Det finns en 92" som är billiagre än 106".
Jag kan kolla upp list priser på dessa två ochta bilder ikväll.
Redigerat av Jokkmokksjocke, 12 December 2007 - 20:46.
Postad 12 December 2007 - 21:42
DulcimeR
  • DulcimeR
  • 372 inlägg
Var har du köpt din Jocke? Vilken dimension och till vilket pris?
Har du sett eller testat Adeos variant och vad fick dig att välja denna framför adeos?
Är mycket intresserad av bilder och riktpriser!
SKÖNDA SKÖNDA (som gunde skulle ha sagt...)
Postad 12 December 2007 - 22:40
Matsen
  • Matsen
  • 2792 inlägg
575$ (3800:- enligt forexkurs) för 92" såg jag på några amerikanska nätbutiker... men ingen som sålde utomlands - men letar man lite mer så borde det gå att hitta!! Till det priset så tar jag en direkt... :D
Postad 13 December 2007 - 16:13
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Rek. utpriser
92" 10 350:- inkl
106" 11 750:- inkl
Postad 13 December 2007 - 18:49
Matsen
  • Matsen
  • 2792 inlägg
hmmm 3800/10350=0,37 dvs samma duk kostar i USA/Canada knappt 40% av vad den kostar i Sverige. Man kan alltså ta en flygresa till Usa och köpa en där och landa på samma pris!!! ;)
Postad 13 December 2007 - 22:02
nborve
  • nborve
  • 964 inlägg
Varför poppar det upp en term såsom "Power Buy" i min skalle när jag läser denna tråd... Jag vill ha en tabtension duk men jag kan inte motivera ett inköp på 10-13 papp - däremot om jag skulle få tag på en för de priser som nämns ovan , skulle det vara grymt svårt att motstå!! ;)
Power buy=gruppköp?
Det skulle jag vara på.
Postad 13 December 2007 - 22:17
Unregistered67fa056e
  • Unregistered67fa056e
  • 300 inlägg
Intressant! jag är med på en om det dyker upp.
Postad 13 December 2007 - 22:48
DulcimeR
  • DulcimeR
  • 372 inlägg
Jag är också med om jag bara får veta lite mer info samt bilder på duken!
OCH om det inte skulle innebära en alltför lång väntetid.... =)
Postad 13 December 2007 - 23:29
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Jo, men så är det ju med allt i USA!
I USA finns inte moms och de har alltid tusen ggr större volymer.
Postad 13 December 2007 - 23:36
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Nu har jag slängt in en bild i mitt galleri (längts ner)
Grupp köp ?? vartifrån. USA?
Tull
moms
Paketet är väldigt långt=Specialfrakt=dyrt
väger runt 13-15kg = dyrt.
De bör ju bli lite folk som köper ihop lär ju inte räcka med typ 7 pers.
Jag tycker att ni skall gå till en bra återförsäljare i Sverige och be om bättre pris om ni köper flera.
Det borde funka, normal brukar det vara bra marginaler på dukar om man gämför med Projar och plattTV som i prencip är ideell verksamhet.
Redigerat av Jokkmokksjocke, 13 December 2007 - 23:36.
Postad 14 December 2007 - 08:33
Matsen
  • Matsen
  • 2792 inlägg
I USA eller Canada borde man kunna hitta ngn som säljer till Sverige om man letar lite, det vore synd att säga att jag har lagt ner ngn själ i det (än...).
Vad är det för tullsats på projektordukar?
Postad 14 December 2007 - 10:59
  • 1450 inlägg
Tullsatsen är 2.7 %. Sedan är det moms på både varan och tullsatsen. Så en duk för 4000:- kommer att kosta 5135:- + frakt + någon eller ett par hundralappar i andra avgifter (typ spedition och vad de nu kan hitta på att ta betalt för ;) )
Postad 14 December 2007 - 12:19
Matsen
  • Matsen
  • 2792 inlägg
2,7% är ju försumbart i sammanhanget då tycker jag...
Ponera att man tar en sista minuten flygstol till NewYork och köper hem 2 dukar, normalt får man ta 20kg på planet så det blir lite tillägg på bagaget men det brukar inte vara så blodigt - speciellt inte om man föranmäler det. Då blir det bara lite dyrare än om man skulle köpa en duk i Sverige... :D
Tanken är ju rätt trevlig!! Någon som vill köpa en granndview av mig för 7500? :P
Dessa verkar ju även (eller bara??) tillverkas i Kina så det finns borde ju även finnas möjlighet att köpa därifrån... :wub:
http://www.grandviewscreen.com/
Den här var ju lite rolig:
Portable motorized floor screen
Postad 14 December 2007 - 14:33
joakim99
  • joakim99
  • 3433 inlägg
Visst finns det moms i usa även om de kallar det för Sales tax eller något liknande. Dock är det inga problem att komma undan den om man handlar från en annan stat eller från utlandet.
Det svenska priset utan moms blir cirka 8280 kr (baserar på 10350 kr). Jämfört med 3800 kr är det lite väl stor skillnad tycker jag. 6500 kr inkl moms hade varit med rimligt...
När det gäller bagage man får ta med sig på flyget från usa så brukar de flesta flygbolag tillåta mer än 20 kg (ofta 2 x 32 kg).
Postad 14 December 2007 - 15:22
Matsen
  • Matsen
  • 2792 inlägg
Är det fler än jag som tittar på sista minuten till New York just nu?? :P
Postad 14 December 2007 - 19:01
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Stämmer och det är en "kommunal" skatt som är olika i olika städer. Men det är inte 25% utan typ 1,75%
Postad 14 December 2007 - 23:39
joakim99
  • joakim99
  • 3433 inlägg
Snarare 8-10%. Men likväl så är skillnaden mellan 3800 kr och dryga 8000 omotiverat stor.
Postad 15 December 2007 - 11:21
Matsen
  • Matsen
  • 2792 inlägg
Jag "råkade" mejla grandview i Kanada och fråga om dom kan sälja direkt till Sverige och det kan dom. Men dom tyckte att jag skulle köpa från ngn närmare då frakten skulle bli stor.
Har bett om att få priser på 92" och 100" av dom, med och utan frakt. :(
Postad 15 December 2007 - 13:19
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Nu är det ju väldigt bra kvalitet på dem, men blir nog inte kul om det skulle hända något.
Känns lite dum snålt för bara 3000:- men det är min personliga åsikt.
Postad 15 December 2007 - 13:38
joakim99
  • joakim99
  • 3433 inlägg
Jag håller helt med dig. Jag har haft en del problem tidigare med dukar (ramspända från Projecta) och då är det väldigt skönt att ha köpt dom lokalt. Det hindrar dock inte att priset känns väldigt högt i relation till vad det är i usa.
Postad 15 December 2007 - 15:40
Chuck
  • Chuck
  • 2498 inlägg
JockeJokkmok, vore tacksam om du kunde mäta avståndet på dukens absolut bredaste del (antar att det är längst ner).
Alltså måttet mellan ytterkanten på dukens fysiska bredd (inte kassetbredden, utan den del som glider ner).
/Chuck
Postad 15 December 2007 - 16:18
Matsen
  • Matsen
  • 2792 inlägg
klart det kan verka dumsnålt ifall skillnaden inte blir så stor - men är det så att man kan få 2 dukar till priset av en så vet jag inte om det är så dumt längre... :(
Redigerat av Matsen, 15 December 2007 - 18:25.
Postad 15 December 2007 - 17:43
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
Ok Chuck skall mäta!
Postad 17 December 2007 - 21:07
nborve
  • nborve
  • 964 inlägg
klart det kan verka dumsnålt ifall skillnaden inte blir så stor - men är det så att man kan få 2 dukar till priset av en så vet jag inte om det är så dumt längre... :D
Inget svar ännu?
Hehe kanske skall fråga om duken har bra egenskaper?
Redigerat av nborve, 17 December 2007 - 21:08.
Postad 18 December 2007 - 09:18
Matsen
  • Matsen
  • 2792 inlägg
Jorå... Men inga siffror i svaren! De ville ha fullständig adress för att kunna ge exakt svar på frakten. De har fått adressen idag så svar kommer nog inom kort. :D
De verkar i vilket fall vänligt sinnade vi mail, och det är ju trevligt!! :D
Egenskaperna skall vara bra, har bara läst gott om detta märke! Om du bor i närheten av Stockholm kan du åka till HBC och kolla in dom själv...
Postad 18 December 2007 - 10:37
Unregisteredbf364490
  • Unregisteredbf364490
  • 1887 inlägg
Går man in på Grandviews sida så verkar det som om den går att få i 77" också (170x96).
Postad 18 December 2007 - 11:41
Chuck
  • Chuck
  • 2498 inlägg
Jo, de har den nog i 100 tum också, men jag tror bara Wiktors lagerför 92 och 106, för andra storlekar står det att man skall ta kontakt för prisoffert.
/Chuck
Postad 18 December 2007 - 14:41
Matsen
  • Matsen
  • 2792 inlägg
Dessa storlekar finns det att välja på, för tab tensionduken:
Redigerat av Matsen, 18 December 2007 - 14:43.
Postad 18 December 2007 - 15:00
Herr Kantarell
  • Herr Kantarell
  • 46 inlägg
Lite of topic rörande Tab Tension, med dock Grandview
Precis införskaffat mig en Benq W10000 och kan få en Grandview Cyber manuell 16:9 106" duk gratis från jobbet.
Bara skräp eller värt att testa ? ( tänker mest på otyget att få hem åbäket )
Postad 18 December 2007 - 21:53
Matsen
  • Matsen
  • 2792 inlägg
det är bara skräp... ge den till mig istället!! :lol:
Är det en gammal duk eller är den ny?
Är den ny och relativt våg/skrynkelfri så lär du ha svårt att hitta ngt bättre för pengarna!! :D
Postad 18 December 2007 - 23:43
Jokkmokksjocke
  • Jokkmokksjocke
  • 2384 inlägg
I dax läget tas det bara in 92" och 106" till Sverige.
Cyber är en likadan duk som Fantasy, och det är absolut en bra duk. Bäst i sin klass vill jag nog påstå.
Postad 19 December 2007 - 00:35
  • 1450 inlägg
Och tycker du att den är vågig så kan du ju spänna upp den på en ram om du har plats för en ramspänd.
Postad 19 December 2007 - 11:47
Herr Kantarell
  • Herr Kantarell
  • 46 inlägg
det är bara skräp... ge den till mig istället!! :P
Är den ny och relativt våg/skrynkelfri så lär du ha svårt att hitta ngt bättre för pengarna!! :P
Den e ny i kartong. Har dock legat i kartong nått år eller så hade det varit mjölk hade den betraktats som långt efter bäst före ...
Postad 19 December 2007 - 14:35
Matsen
  • Matsen
  • 2792 inlägg
Är den ny och relativt våg/skrynkelfri så lär du ha svårt att hitta ngt bättre för pengarna!! :)
Bara att gratulera då - ni har inte fler?? :P
Postad 20 December 2007 - 01:17
JoakimBring
  • JoakimBring
Har bett om att få priser på 92" och 100" av dom, med och utan frakt. :P
Snubblade in på det här forumet för att kolla lite info om olika dukar, och precis som Matsen, har jag mailat, och väntar svar från grandview i Kanada.. :) Roligt sammanträffande.. I precis i samma tidsintervall också.. Trevliga verkar de vara, som sagts...
Kanske vi ska slå våra kloka huvuden tillsammans om det nu är så att de är villiga att skicka, så borde frakten komma ned något i pris??
Vänligen Joakim
Postad 20 December 2007 - 08:48
Matsen
  • Matsen
  • 2792 inlägg
Ja det var ju lite roligt sammanträffande... :P
Vi får de vad det blir för priser, har en föraning om att de billigaste priserna som vi sett (från USA) är svårslagna då den Amerikanska dollarn är så löjligt svag just nu. Men det får väl framtiden visa... :)
Postad 23 December 2007 - 00:02
Unregisteredebdbf243
  • Unregisteredebdbf243
  • 527 inlägg
Så länge Wiktors håller i dessa dukar kommer de inhemska priserna knappast gå ner.
Jag tror återförsäljarna skulle tjäna på att importera dom själva, köpta från butik i USA.
Sorgligt.
