* Officiell tråd - Sony Alpha DSLR-A200 *
1162 svar till detta ämne
Sony AF 50/1,4 (Objektiv) 2 6.5 (1) Inga priser
Sony AF 50/1,7 (Objektiv) 9 7.5 (1) Inga priser
Sony AF 50/2,8 Macro 1:1 (Objektiv) 1 (0) Inga priser
Sony HVL-F36AM (Blixtar) 1 7.666666 (2) Inga priser
Sony HVL-F56AM (Blixtar) 1 7.5 (1) Inga priser
Sony Alpha DSLR-A200 (Systemkameror) 6 9.375 (7) Inga priser
Sony Alpha DSLR-A200 + 18-70/3,5-5,6 (Systemkameror) 1 9.35294 (16) Inga priser
Sony HVL-F42AM (Blixtar) 1 8.2 (4) Inga priser
Sony Alpha DSLR-A200 + 18-70/3,5-5,6 + 75-300/4,5-5,6 (Systemkameror) 1 8.333332 (2) Inga priser
Sony AF 70-300/4,5-5,6 G SSM (Objektiv) 1 7.5 (1) Inga priser
Sony HVL-F58AM (Blixtar) 1 7.5 (1) Inga priser
3 relaterade trådar
Postad 06 January 2008 - 18:39
ekke
  • ekke
  • 2466 inlägg
Några förbättringar mot A100:
* 2.7-inch Clear Photo LCDTM screen for easy playback viewing
* A more compact body
* Quicknavi - an easy-to-use function menu
* Improved noise control for higher quality images
* Improved D-Range Optimizer for superior exposure balance
* An auto focus speed 1.7x faster than the previous model, improved predictive control performance
* Quieter shutter sound
* a battery life indicator that displays the percentage of battery life remaining so you know exactly when to recharge
Se och läs om A200 här -> http://www.sony.net/...a200/index.html
och
http://photoclubalph...a-200-launched/
The DSLR-A200 model features upgrades influenced by the recently-introduced, enthusiast-class DSLR-A700 camera and replaces the former Sony DSLR-A100 model, which was Sony’s first in the DSLR class.
The new model is designed to be faster, lighter and easier to use. Upgraded features include a wider, 2.7-inch Clear Photo LCDTM screen for easy playback viewing; a more compact body and an easily-accessible mode dial; an easy-to-use function menu (camera function display); improved noise control for higher quality images; an auto focus speed 1.7x faster than the previous model; improved predictive control performance; quieter shutter sound; automatic pop-up flash; and a battery life indicator that displays the percentage of battery life remaining so you know exactly when to recharge.
As seen in all α (alpha) camera bodies, the DSLR-A200 camera incorporates Super SteadyShot® image stabilization in the body to allow shooting at shutter speeds of 2.5 to 3.5 steps slower than otherwise possible – a benefit realized with every compatible lens attached to the camera. Compatible lenses encompass all Minolta Maxxum® mount lenses, in addition to Sony α (alpha) lens lineup - including Carl Zeiss® lenses.
“With the DSLR-A200, we are helping consumers capture high-quality images with advanced technology that’s practical and easy to use,” said Phil Lubell, director of marketing for digital cameras at Sony Electronics. “This model is an ideal step-up for point-and-shoot users who are looking for a camera that can capture virtually all of the photographs they want.”
High-Quality Images
With its 10.2-megapixel (effective) APS CCD image sensor, the DSLR-A200 camera continues to offer high-quality images by allowing more light to pass through to each pixel – increasing sensitivity, reducing noise, and providing greater detail.
Clean, reduced-noise signals are sent from the image sensor to Sony’s BIONZ™ processing engine, which processes data-rich picture information at high speeds and reduces picture noise in the RAW data stage before image JPEG conversion. The results are high-resolution, detailed images with rich tonal reproduction.
The DSLR-A200 model supports JPEG and RAW file format support. It has a slot for CompactFlash™ Type I/II media cards. An adaptor for Memory Stick Duo™ media cards is sold separately as an accessory.
Get The Photo Results You Want
In addition to Super SteadyShot image stabilization for virtually blur-free photos, the new model incorporates Sony’s D-Range Optimizer (DRO). It helps you capture well-exposed images, especially when shooting high-contrast or backlit scenes that often lead to loss of highlight and shadow detail. Sony’s DRO modifies the range from highlights to shadows, including gain and contrast, through its in-camera hardware processing to produce more natural, evenly exposed pictures. The camera’s image analysis technology studies the captured image data and instantly determines the best exposure and color tonality for the image before JPEG compression.
The BIONZ image processing engine powers the camera up immediately and the eye-start autofocus starts the focusing system before you even press the shutter. The camera can shoot up to three continuous frames per second at 10.2-megapixels at the finest JPEG compression level.
As seen in previous α (alpha) models, the new model carries a static-free anti-dust coating on the CCD filter which is gently vibrated to dislodge any dust that might have collected each time the camera is powered off.
Additionally, the DSLR-A200 camera’s supplied lithium ion battery offers up to 750 shots per full charge.
Bright and Easy Playback
The camera’s smaller, more compact body along with its wider, 2.7-inch Clear Photo LCD TM screen and a new on-screen navigation interface make it easier to carry and to use. The vibrant, easy-to-view screen features 230K-pixel resolution, an anti-reflection coating and glare-reducing layer assures vivid, accurate colors with a wide viewing angle, even in daylight. The on-screen navigation display shows camera settings and key shooting information in large, easy-to-read text. The display’s orientation automatically switches from landscape to portrait position when the camera is turned on its side.
Accessories Expand Creative Possibilities
Sony is providing a full line of accessories for the model, including flashes, rechargeable battery packs and several carrying cases. An interesting addition is the VG-B30AM ergonomic vertical grip equipped with the most essential controls for portrait orientation shooting. It also allows for the use of two InfoLITHIUM® batteries (sold separately) for up to 1,500 shots on a single, full charge.
The DSLR-A200K kit includes the camera body and a DT 18-70mm f3.5-5.6 3.9x zoom lens for about $700. The DSLR-A200W kit includes the camera body, the DT 18-70mm lens and a 75–300mm f4.5-5.6 lens for about $900. Both will ship in February and will be available at sonystyle.com, Sony Style® retail stores (www.sonystyle.com/retail), military base exchanges, and authorized dealers nationwide. Pre-orders begin online on Jan. 7 at www.sonystyle.com/dslr.
Redigerat av ekke, 07 January 2008 - 15:06.
Postad 06 January 2008 - 21:43
ekke
  • ekke
  • 2466 inlägg
http://www.kamerabil..._ADF007.dbp.asp
Sonys minsting får batterigrepp
2008-01-06 21:22
Iso 3200, en ny knapp och ett batterigrepp. Det är de viktigaste nyheterna hos Sonys senaste konsumentkamera A200.
Det låter kanske inte som några stora nyheter, men eftersom föregångaren A100 är en bra kamera i grunden behöver inte förändringarna vara radikala för att Sony ska ha en konkurrenskraftig konsumentkamera i sitt stall.
Det finns två klara brister hos föregångaren A100. Brusnivån är kraftigare än hos motsvarande konkurrenter och det låter för mycket om kameran. Vi vet att Sony är medvetna om båda problemen. I och med att Sony visat ett de lärt sig att hantera brus bättre med A700-modellen och att nya A200 får maxiso på 3200. Båda sakerna talar för att A200 ska vara bättre på brus än A100.
Ur pressmeddelandet kan vi inte utläsa något om kamerans slutar- och spegelljud, men det är troligt att Sony tagit till sig av kritiken.
Processortekniken kommer från A700. Om autofokussystemet också gör det framgår inte, menkameran ska ha en snabbare autofokusmotor än föregångaren. Även bildstabiliseringen ska ha förbättrats och uppges klara att korrigera skakningar upp till 3,5 exponeirngssteg.
En ny autofokusknapp ska kunna bredda autofokusens arbetsområde och därför göra det lättare att fokusera på små objekt, exempelvis fåglar.
Förbättringarna ger t ex den infallsrika fotografen möjligheter att snabbare reagera när ett spontant fototillfälle ges. En snabbare autofokus gör att kameran enklare fångar objekt som rör sig. Autofokus-sensorn har en ny motor och en speciell AF-knapp gör att fotografen enkelt kan byta till centrumvägd avståndsinställning, vilket gör det lättare att till exempel fokusera på små objekt.
Batteriet ska klara cirka 750 bilder per laddning.
För vissa kommer säkert batterigreppet VG-B30AM att upplevas som den mest välkomna nyheten.
Det svenska priset blir cirka 6900 kronor och kameran levereras till svenska butiker under februari.
Postad 06 January 2008 - 23:22
Eufemism
  • Eufemism
  • 861 inlägg
Hade hoppats på lite mer från efterföljaren till A100, hade gärna sett 5fps serietagning och högupplöst lcd-skärm. Sony ska väl släppa två DSLR:er till i år, kanske för mycket att hoppas på en kamera som lägger sig mellan A200 och A700. A200:ns specifikationer är iaf inte tillräckligt bra för att jag ska kunna tänka mig "uppgradera" från min KM D7D.
Postad 06 January 2008 - 23:40
ekke
  • ekke
  • 2466 inlägg
Då kommer den för nära 15 000 kronors A700an :) kan inte få allt för ett intro pris a 6900.
Postad 06 January 2008 - 23:49
Eufemism
  • Eufemism
  • 861 inlägg
Nej men det var det jag hade hoppats på. Om sony ska slåss mot Canon och Nikon behövs det något speciellt, SSS i all ära, men med tanke på hur bra D40x säljer så verkar amatören inte bry sig så mycket om funktion. Hade faktiskt hoppats på en ny kamera typ A50 som lägger sig på runt 4500kr, en A200 som hamnar på 8500kr och A700 för 13000kr. Tycker bara det är synd att A200 inte har så mycket bättre specifikationer än en D7D som är nästan 4 år äldre. Det återstår att se hur A200 kommer prestera mot en uppföljare till 400D, D40x och kanske K10D.
Postad 07 January 2008 - 00:12
Supernaut77
  • Supernaut77
  • 4148 inlägg
Ska man tolka "10.2MP CCD" som att det är den som förr satt (sitter) i Nikon D80, Pentax K10D mfl? Enligt ryktet kommer Pentax K200D ha den och det känns ju rimligt att A200 också får den isåfall.
Ska bli spännande när testerna börjar komma...
Postad 07 January 2008 - 01:03
ekke
  • ekke
  • 2466 inlägg
SONY kommer med två till kameror under PMA om 4 veckor.
Postad 07 January 2008 - 01:36
ekke
  • ekke
  • 2466 inlägg
MAn får vääldigt mycket för pengarna
Postad 07 January 2008 - 02:18
Eufemism
  • Eufemism
  • 861 inlägg
Bara hoppas att dpreview får tag i ett ex så snart som möjligt, vill se hur bra den presterar. Det viktigaste eller iaf det mest kritiska tycker jag är hur den hanterar bruset vid höga ISO, något som KM/Sony har varit rätt så dåliga på hittills tycker jag, men den kommer väl troligtvis inte vara bättre än A700 på detta.
Postad 07 January 2008 - 02:39
ekke
  • ekke
  • 2466 inlägg
Det är samma sensor som i A100 D80 D40x etc, men med A700 "cpun" så det bådar mycket väl! Är jäkla sugen på denna själv som 2a kamera.
Postad 07 January 2008 - 11:26
Joakim
  • Joakim
  • 3956 inlägg
Intressant. Blir spännande att se vad konkurrenterna släpper för modeller vid PMA-mässan. Hoppas att Sony står sig mot konkurrenternas nysläpp. Vad Sony behöver är en kamera som tilltalar nya användare så som 400D och D40 har gjort, vi får väl hoppas att en av de två modellerna blir just en sådan, detta (A200) verkar spontant inte vara den modellen.
PS. Ekke, nyttja gärna länkar mer och klistra in lite mindre text - detta för att göra tråden mer lättöverskådlig i längden.
Postad 07 January 2008 - 13:49
ekke
  • ekke
  • 2466 inlägg
VAd är det som inte tilltarlar nyaanvändare ? Denna är perfekt för nybörjare som samtidigt har något att växa i. Man får så mycket mer med SONY jmf. med konkurrenterna. SONY har dessutom bäst utbud med objektiv i den klass där vanliga människor köper
18-70
18-200
55-200
men fram för allt dessa:
Carl Zeiss 16-80mm ZA F3.5-4.5
Sony 16-105mm F3.5-5.6
Sony 18-250mm F3.5-6.3
Dessa är objektiv som de flesta köper och alla dessa blir stabiliserade och man får riktigt bra AF, samma som i A700an ( dvs i vanligt dagsljus så fokuserar denna instegskamera snabbare än Canons 40d! )
Canon har 17-85mm F4.0-5.6 IS och Nikon kommer snar med 16-85 mm f/3.5-5.6G VR. Båda dessa har inte lika bra, stor, aparatur som Carl Zeiss 16-80mm F3.5-4.5 . De slår inte heller omfånget på Sony 16-105mm F3.5-5.6.
Nikon har iofs. 18-200mm F3.5-5.6, bättre än inget, men tyvärr har den kortare omfång och är mycket dyrare än Sony's 18-250mm. Canon har inget motsvarande.
Tillsammans med DRO så får man mycket bättre bilder direkt ur kameran, perfekt för de som vill spara tid eller inte vill/kan pilla sönder bilderna i photoshop.
Redigerat av ekke, 07 January 2008 - 14:16.
Postad 07 January 2008 - 15:56
Joakim
  • Joakim
  • 3956 inlägg
Två orsaker främst:
1. Priset
2. Användarvänligheten
Båda dessa har varit till A100:ans nackdel. Dels är priset högre än vad en instegskamera kostar i dag, inte minst på objektiv och tillbehör. Sådant avskräcker nybörjare. Och dels är inte A100 så användarvänlig så som exempelvis D40 och 400D är. Dessa budgetalterantiv tilltalar två grupper av nybörjare. Dels de som vill ha en instegskamera att börja med, för att sedan byta upp sig när de vill växa som fotograf. Och dels de som vill ha ett budgetsystem som de sedan behåller och inte uppgraderar mer.
Det blir farligt nu om jättarna lanserar nya instegsmodeller, jag hoppas bara att Sony har en lockande instegsmodell att visa upp här framöver. Man ska inte glömma att det finns fler som ger så mycket mer än Canon och Nikon, två farliga tillverkare är Olympus och kanske nu närmast Pentax som är redo att visa upp nytt. Det luktar inte instegskamera om A200, och en sådan behöver de för att tilltala massan. Därmed inte sagt att A200 presterar bra strax över instegsklassen.
Postad 07 January 2008 - 16:03
ekke
  • ekke
  • 2466 inlägg
Två orsaker främst:
1. Priset
D40x som vart ute ett längre tag kostar lika mycket, objektiven som jag visar är billigare och bättre på A200. Läs mitt inlägg igen, med A200 får man mer för pengarna helt enkelt. Att A100 hade ett högt intro pris för nästan två år sedan känns som ett mindre bra argument.
Angående användarvänligheten så är den bättre på A200 genom ett bra grepp, ergonomi, scenelägena kombinerat med DRO får man bättre resultat på ett enklare sätt. Vad är bättre ? jag har nyss visat Canikon inte har matchande objektiv, SONY's är billigare och bättre, bland de som man vanligen köper. Ergonomin är personlig, men A200 har ett bättre grepp likt A100 hade.
Ja sitter här med en Nikon D40 i handen ... :D jag har haft A100 , har en A700 ... en kompis har en 400d .. så jag vet vad jag talar om.
Redigerat av ekke, 07 January 2008 - 16:37.
Postad 07 January 2008 - 18:10
Joakim
  • Joakim
  • 3956 inlägg
Man får idag instegsmodeller för 5000 kr med objektiv. Då har dagens modeller varit ute på marknaden ett tag, sant, men nya produkter har en förmåga att bli bättre OCH billigare. Priset på A200 lär väl hamna på runt 6500 kr med objektiv - ett bra pris onekligen - men budgetpris i instegsklassen? Nja. Om den då lanseras som "en kamera att växa i" så får man anta att det kommer köpas till kringutrustning och man bör då ta med i beräkning att Sony fortfarande är väldigt dyr på lösa objektiv och tillbehör.
Vad jag menar med användarvänligheten är, för att göra det extra tydligt, dess "svenssonanpassning" som t.ex. D40 har lyckats bra med. Man har kvar mycket av kontrollsystemet från de gamla Dynax-modeller och de var på sin tid inte några svenssonkameror utan mer semi/proffskameror. Det återstår naturligtvis att se hur de har optimerat det i A200.
Vill Sony tilltala massan så måste de erbjuda något extra eftersom att jättarna Canon och Nikon säljer mycket p.g.a. att de är kända. A200 känns inte som budgetalternativet med detta "extra", utan en klass över den modellen. Det är vad jag tror. Och jag hoppas att de släpper en budgetmodell, med eller utan extra, bara de har en modell som fler har råd med.
Postad 07 January 2008 - 18:21
ekke
  • ekke
  • 2466 inlägg
canons 400d med ett is objektiv är dyrare äldre och tekniskt sämre. Det är bara Nikons D40 det enklaste av de enkla kamerorna som är billigare i dag läget.
Redigerat av ekke, 07 January 2008 - 18:24.
Postad 07 January 2008 - 21:33
Joakim
  • Joakim
  • 3956 inlägg
Det finns två andra moderna och mycket prisvärda kameror också, Pentax K100D Super och Olypmus E-410, både med kitobjektiv för runt 5000 kr.
Jag betvivlar inte A200:ans prestanda, utan spånar mer i hur den kommer bli mottagen av konsumenterna, och jag tror inte det kommer bli som en budgetkamera eller instegsmodell för nybörjare som saknar kunskap. För det ändamålet behöver Sony en enklare kamera i dubbel bemärkelse, men det är bara vad jag tror. Vi får se helt enkelt, det är spännande tider att vänta.
Postad 07 January 2008 - 22:16
ekke
  • ekke
  • 2466 inlägg
Jasså, du menar bara billigare. Ja ser man inget annat än bara priset så är det iaf lätt att avgöra vad man skall köpa :)
Postad 08 January 2008 - 22:55
Audiovector
  • Audiovector
  • 4885 inlägg
Hur mkt dyrare kommer denna att bli i butik än A100:an? Ska A100:an utgå omedelbart?
Postad 08 January 2008 - 23:14
ekke
  • ekke
  • 2466 inlägg
A200 ersätter A100, A100 kommer väl reas ut av butikerna. Priset enligt SONy är ca 6900, priset för A100 var 12000 för A100 närden släpptes, sedan kan man spekulera genom att titta på tidigare prishistorik för att se hur priset kommer utvecklas.
Redigerat av ekke, 08 January 2008 - 23:15.
Postad 09 January 2008 - 05:26
Unregistered825cee05
  • Unregistered825cee05
  • 58 inlägg
Jag köpte kamera för några månader sedan och valde då D40x. Från allra första början var jag inne på Konica-Minolta Dynax 5D, men när den försvann (ersattes dock av A100 som om jag förstått det rätt var i princip samma kamera, bara dyrare och med fetare sensor..), så lutade det mest åt först Canon 350D och sedan 400D, även om jag också kollade på A100.
Jag var rätt skeptisk till Nikon D40 av någon anledning, men efter att ha börjat gå runt och klämma på kamerorna så var det snart avgjort - D40 och D40X hade en helt annan känsla i grepp och framförallt en annan känsla i material och i upplevd byggkvalitet. Den kändes helt enkelt mer gedigen och välarbetad.
Med andra ord tror jag det är viktigt att Sony hittar rätt ergonomi och material om de ska slå sig in bland Nikon och Canon. Det är lätt att hänga upp sig för mycket på tekniska specs (jag gjorde det själv), fotografering handlar mycket om arbete med kameran och man ska inte underskatta känslan man får när man håller i den i butik när det gäller att avgöra köp eller inte köp.
Åtminstone på bild ser A200 mycket trevlig och lovande ut, smidig men samtidigt bastant. Får ta och fingra på en butik när den kommer dit.
Redigerat av Unregistered825cee05, 09 January 2008 - 05:29.
Postad 09 January 2008 - 08:31
Audiovector
  • Audiovector
  • 4885 inlägg
Hur gamla Minolta-objektiv kan man sätta på en Sony dSLR? Vinns det något enkelt sätt att se vilka objektiv som passar?
Postad 09 January 2008 - 11:56
ekke
  • ekke
  • 2466 inlägg
Alla med AF
läs mer på http://www.dyxum.com/lenses/index.asp
där kan du även kontrollera objektiv om du är osäker.
Postad 10 January 2008 - 00:45
Audiovector
  • Audiovector
  • 4885 inlägg
Tack!!!
Postad 10 January 2008 - 14:36
ekke
  • ekke
  • 2466 inlägg
Kanske kan tillägga att det är alla utan de gamla ROKKOR objektiven, de har en annan fattning/mount
Postad 12 January 2008 - 14:12
ekke
  • ekke
  • 2466 inlägg
ISo 100-3200 exempel! -> http://masterchong.c...ple-photos.html
Postad 12 January 2008 - 15:10
AlexanderE
  • AlexanderE
  • 4905 inlägg
Var inne och fingrade lite på A100an idag på onoff. Jag blev förvånad över hur stor den va jämfört med Canon 400 och Nikon D40. Den kändes riktigt bastant och stabil. Satt även ett rätt kraftigt objektiv på som följde med i priset tror jag.. och gud vilken känsla de va i objektivet! Vill ha begäret växte och Sony ser jag absolut som ett alternativ om jag ska köpa kamera!
Dock tycker jag att objektiven ligger rätt högt i pris om man jämför med Nikon och Canon.
Ekke! Har du haft några andra digitala systemkameror innan? Som t.ex Nikon, Canon mfl...
AlexanderE
Postad 12 January 2008 - 23:43
twallsten
  • twallsten
  • 210 inlägg
Skulle verkligen vara intressant om de klämmer in en modell mellan a200 och a700, är lite som om det finns ett hålrum där t.ex. Nikon D80 inte har någon riktig konkurrent.
Postad 13 January 2008 - 02:02
ekke
  • ekke
  • 2466 inlägg
Ja det kommer kameror där emellan :mellow: A300 och eller A500.
AlexanderE
Jag använder ofta Nikon och Canon då mina vänner och nära släkt är "cankinoner" eller vad det nu kallas ;)
T.ex körde jag en heldag med Nikon D80 i tisdags. Använder rätt ofta D40n också samt gamla d50n. Canon 10d samt 30d och 400d.
Postad 13 January 2008 - 11:37
AlexanderE
  • AlexanderE
  • 4905 inlägg
Okej och hur tycker du din Sony står emot de dyrare Canonkamerorna samt nikon?
Postad 13 January 2008 - 12:24
ekke
  • ekke
  • 2466 inlägg
A700 är i en klass över alla dessa, förrutom Canon 30d då.
Generellt så tycker jag inte om Canons ergonomi, känns lite otymplig i jämförelse, men man får en stabil kamera AF är helt okay lågt brus etc. Lite problem med färger, men det är mest ett problem med äldre modeller.
Canon 400d är inte kul alls, kontrollerna är inte genomtänkta, greppet är inte hjort för att en människa ska hålla i kameran :) 30d klassen är klart bättre, men fortfarande inte bra.
Nikon d80, gillar kännslan i kameran , materialvalet är bra. Ointuiativa kontroller i jämförelse med A700.
Nikon d40, gillar jag pga priset, jag rekommenderade denna till tjejens lilla syster som ville ha en kamera för 3000, fick henne att låna 900 kr extra så hon hade råd att köpa d40n under rean som var.
Det som jag tycker gör A700an bra förrutom att sensorn är bra, är att kontrollerna är genomtänkta, man kan justera allt man normalt behöver med höger handen utan att ta ner kameran. Man kan dessutom ha handskar på sig under arbetet.
Kamerans respons är instant, allt från skrivning av bilder till CF kortet, A700 är här lika snabb som D3 samt 1d3, som slutarfördröjning etc.
Det är det som är viktigast med en kamera, att den är lätt använd trots denna klass där man kan justera in allt. Därför rekommenderas det att känna på kamerorna innan köp.
Man skall iaf definitivt inte lyssna på eventuella försäljare i butik. De säljer det som de tjänar mest på, alternativt är förblindade och insnöade på canon och nikon.
Postad 13 January 2008 - 12:34
AlexanderE
  • AlexanderE
  • 4905 inlägg
Det låter riktigt schysst! :)
Har fotat en hel del med Canon 400D i skolan eftersom de kör på Canon, dock bara för det mesta med det medföljande 18-55 mm objektivet. Kameran tycker jag ligger schysst i handen och jag blev först insnöad på 400an.
Dock när jag igår va och kände lite snabbt på Sonyn så kändes den rejält mycket mer stabilare än nikon d40 och 400D. D80n låg också bra i handen men kändes på något sätt en smula för tjock. Det kan ha att göra med att jag har små händer men ändå så kändes sonyn jättebra.
Vill bara tacka dig ekke för att du har hjäpt mig att få upp ögonen för sony. :)
En annan bra sak med sony är att de har inbyggd bildstabilisator vilket också väger över för Sonys del.
Du vet inte hur många fokuspunker sony a200 har?
AlexanderE
Postad 13 January 2008 - 13:07
ekke
  • ekke
  • 2466 inlägg
Auto Focus
• TTL CCD line sensors (9-points, 8 lines with center cross-hair sensor)
• EV -1 to 18 (ISO 100) detection range
• Predictive focus control for moving subjects
• Auto-tracking focus point display
AF area selection
• Wide AF area
• Spot AF area (center)
• Focus area selection (any of 9)
Focus modes
• Single-shot AF
• Continuous AF
• Automatic AF
• Manual focus
Postad 13 January 2008 - 13:16
AlexanderE
  • AlexanderE
  • 4905 inlägg
Man tackar man tackar. :)
Postad 13 January 2008 - 13:20
ekke
  • ekke
  • 2466 inlägg
IS i huset gör väldigt mycket , titta bara på slutar tiderna på bilderna jag tagit i bildtråden.
Alla de är tagna under( i stort sätt iaf) den vedertagna tumregeln om slutartider 1/brännvidd.
Postad 13 January 2008 - 15:00
Explorer45
  • Explorer45
  • 4558 inlägg
Jag måste säga att jag är enormt intresserad av A200. Har varit mycket inne på en Nikon D40/x men Sonys A100 ligger ljusår före i ergonomi. Känns verkligen som att Sonyn är gjord efter mina händer som modell! Ska bli kul att se recensioner och testa A200 själv när den kommer ut. :) Hur tror du att priserna på objektiv och tillbehör kommer vara framöver ekke?
Postad 13 January 2008 - 15:44
ekke
  • ekke
  • 2466 inlägg
Blixtvis så har sony redan lägre pris än nikon å canon 1990 för 36an. Det kommer en 42a nu på PMA , kanske ersättare till 36 eller en mellan variant.
Objektiv mässigt så kommer de bli bättre.
För oss dödliga så kan jag rekommendera km 50mm 1.7 för 900 beg. samt 70-210 f/4 för ca 1000 beg. utöver kittet 18-70 då. Mycket prisvärt "set"
för de som vill ha superzoom är tamrons 18-250 riktigt bra.
Postad 13 January 2008 - 15:48
Explorer45
  • Explorer45
  • 4558 inlägg
Ok, låter bra det. :) Har en fråga som kanske du kan svara på. Farsan har en Minolta Dynax 7xi med Minolta Zoom AF 28-105 xi F3,5-4,5 och en Nikora Super Wide High Resolution Macro 0,42x (som vi för övrigt inte har använt eller för den delen fattar hur den skall gå på om den nu ska passa en Minolta). Kommer Minolta objektivet att fungera på en A200 och är det ett hyffsat objektiv än idag?
Postad 13 January 2008 - 16:32
ekke
  • ekke
  • 2466 inlägg
objektivet passar, tror jag. Titta på dyxum.com så hittar du det säkert i deras databas.
Postad 13 January 2008 - 17:02
Explorer45
  • Explorer45
  • 4558 inlägg
Så alla objektiv i databasen funkar? I så fall så gör det det. :)
Postad 13 January 2008 - 17:19
ekke
  • ekke
  • 2466 inlägg
Ja, det är gamla rokkor , med manuell fokus, som inte passar.
Postad 13 January 2008 - 19:19
Explorer45
  • Explorer45
  • 4558 inlägg
Ok, tack. :) Finns det något bestämt datum för när A200 släpps till butikerna? Eller gäller fortfarande "februari"?
Postad 13 January 2008 - 19:21
ekke
  • ekke
  • 2466 inlägg
Man kunde redan köpa kameran i malaysia hörde jag, så den skeppas ut just nu ... blir nog februari faktiskt :) riktigt snabbt från annonsering till faktiskt försöljning.
Postad 13 January 2008 - 19:57
Explorer45
  • Explorer45
  • 4558 inlägg
Nice. :)
Postad 14 January 2008 - 12:42
ekke
  • ekke
  • 2466 inlägg
100% crops från A200 ISO 100 -3200
http://www.pbase.com/geotsa/inbox
Postad 14 January 2008 - 12:58
Matsen
  • Matsen
  • 2792 inlägg
a200 på Sony.se
Enligt Sonys webshop så skeppas denna i mitten av Januar.
Priser på Sonys Webshop :
A200+ 18-70mm + 75-300mm = 8199:-
A200+ 18-70mm = 6399:-
A200 = 5499:-
Redigerat av Matsen, 14 January 2008 - 13:00.
Postad 14 January 2008 - 13:07
ekke
  • ekke
  • 2466 inlägg
Oj bra pris, med tanke på att köp direkt från SONY oftast är mycket dyrt!
Postad 14 January 2008 - 16:39
Explorer45
  • Explorer45
  • 4558 inlägg
Wow, dubbel objektiv kittet var mycket billigare än vad jag hade trott! Trodde det skulle landa på typ 9000:-. Mycket trevlig överraskning! :D
Postad 14 January 2008 - 19:13
Joakim
  • Joakim
  • 3956 inlägg
Nu finns priser från svenska återförsäljare också!
Postad 14 January 2008 - 21:25
Explorer45
  • Explorer45
  • 4558 inlägg
Nice. :D Nu väntas bara tester och jämförelser! Tycker dpreview borde få ut en test snart.. Ska bli spännande!
