Sonys nya receivrar
86 svar till detta ämne
Postad 26 February 2008 - 17:41
scenic
scenic
1066 inlägg
Här är länken: http://news.sel.sony...2008/index.html   The new STR-DG920 and STR-DG820 7.1 channel A/V receivers offer 110 watts of power per channel and are equipped to support the latest in high-definition formats with 1080/60p and 24p True Cinema video signal pass-through. Featuring four HDMI™ inputs, the models support the latest audio formats – Dolby® Digital Plus, Dolby® TrueHD, dts® High Resolution Audio and dts® HD Master Audio. The models also support x.v.Color™ technology (xvYCC) which offers a wider spectrum of colors from source to receiver to an x.v.Color-compliant HDTV. Additionally, the STR-DG920 model supports Deep Color™ for greater color depth on compatible televisions and upscales standard-definition video content to 1080p via HDMI with a 1080p-capable HDTV set. The model features an icon-driven menu system for simple device and content navigation. Also included is Sony’s Digital Media Port. This adds networking and connectivity to the AV receivers for music playback from various sources with optional accessories, including audio cradles compatible with select Walkman® players and iPod® products, a PC client device and a Bluetooth® adapter. Once the accessory is connected, the device can be powered and controlled by the receiver for enhanced home theater experience. An upgraded Portable Audio Enhancer improves the clarity and depth of any connected digital music player by adding information to the audio signal that had been removed during compression for an improved audio experience. Additionally, the units are XM Connect-and-Play™ ready with 5.1 Neural Surround Sound. The models incorporate Digital Cinema Auto Calibration (DCAC) for simplified multi-channel surround sound setup. In about 20 to 30 seconds, the system automatically adjusts frequency, distance and level for optimal performance. The STR-DG920 model will be available in June for about $600, while the STR-DG820 system will be available in May for about $400. Tog inte med 820 på bild, tror inte att den kommer att säljas i Sverige. (810:an gjorde inte det) Här hittade en tråd: http://www.avsforum....d.php?t=1000208
Redigerat av scenic, 27 February 2008 - 21:15.
Postad 26 February 2008 - 18:12
Pulver
Pulver
2387 inlägg
Stort tack för denna information
Jag utan lycka letat efter en receiver med inbyggt stöd för TrueHD/DTS-HD MA samt (minst) 4 HDMI-ingångar.
I dagsläget finns ingen modell som kostar under 10.000:- och vad jag sett av kommande modeller från Yamaha och Pioneer så har även de begränsat antal HDMI-ingångar.
STR-DG920 ser ut att ändra på detta
Postad 26 February 2008 - 20:01
QAM
QAM
755 inlägg
Jag väntade mig något i den här stilen när Dustin satte 910:an på kampanjpris, (dock bara i svart så de har väl ett för stort lager av den).
Postad 27 February 2008 - 19:48
Pulver
Pulver
2387 inlägg
Till trådskaparen - ersätt gärna bilderna med lågupplösta varianter, de är alldeles för stora nu (nedskalningen fungerar inte riktigt med så stora bilder) Det är de små, små detaljerna som oftast avgör. Sonys tidigare modeller (förutom ES-serien) har alla haft de där "kantiga" bokstäverna i displayen som jag ogillar. Med dessa nya modeller har de kvar dem i 520 och 720, men i 820 och 920 är det "punkt-bokstäver" - äntligen!
Postad 27 February 2008 - 19:57
Mercafreak
Mercafreak
296 inlägg
Hoppas det är samma grymma känsla i rattar å reglage som i 910...
Postad 27 February 2008 - 22:10
Wachtel
Wachtel
294 inlägg
920 verkar intressant
Postad 29 February 2008 - 10:27
Unregisterede2a9c094
507 inlägg
Om man skall låta receivern skala upp och man skall ha en Canal Digaltbox(HD), en BDspelare och TV:n, hur många
HDMI ingår (utgångar?) behövs det då?
Postad 01 March 2008 - 10:48
Pulver
Pulver
2387 inlägg
För det behöver du 2 HDMI-ingångar och 1 HDMI-utgång på receivern.
Du kopplar in HD-mottagaren och BD-spelaren via HDMI till receivern och sedan räcker det med 1 HDMI-kabel mellan receivern och TV:n
Låt säga att du har en receiver med endast 2 HDMI-ingångar (som är fallet i många "billiga" receivers idag) så är det alltså fullt.
Om du då skulle skaffa en Popcorn-mediaspelare/HTPC/Xbox360 eller annan apparat med HDMI-utgång så skulle alltså ingångarna inte räcka till...
Postad 01 March 2008 - 11:12
Wachtel
Wachtel
294 inlägg
Någon med erfarnhet av Sony's tidgare modeller som har en åsikt om lämpligheten för stereo-lyssnande?
Jag har funderat på Marantz 5002 men 920-modellen verkar snäppet bättre på papperet. Har inga våldsamma krav, sitter med en enkel Denon just nu.
Postad 02 March 2008 - 16:20
507 inlägg
Tack för svaret Pulver!
Om man kopplar det så och bara vill titta på TV med dess ljud, måste jag ändå starta riceivern då?
Hur skall man koppla det om man bara vill titta på TV men inte starta övrig utrustning?
Postad 02 March 2008 - 16:25
507 inlägg
Har en fem år gammal Sony(5.1) och tycker den fungerar bra till både film och musik, letar nu själv efter en ny Sony eller Yamaha med HDMI.
Postad 02 March 2008 - 21:27
QAM
QAM
755 inlägg
Om man skall låta receivern skala upp och man skall ha en Canal Digaltbox(HD), en BDspelare och TV:n, hur många HDMI ingår (utgångar?) behövs det då?
Det finns inte många spelare som klarar att skala upp från HDMI, dessa gör det inte såvitt jag vet. En BD-spelare behöver du knappast skala upp i recievern, det gör den så bra själv. Hur bra Canaldigital boxen skalar vet jag inte, men om den matar ut komponent kan du alltid pröva om en bra reciever skalar bättre till HDMI än boxen gör själv.
Postad 03 March 2008 - 10:04
507 inlägg
Citat från inlägg ovan, 820 och 920 : Additionally, the STR-DG920 model supports Deep Color™ for greater color depth on compatible televisions and upscales standard-definition video content to 1080p via HDMI with a 1080p-capable HDTV set. The model features an icon-driven menu system for simple device and content navigationBetyder inte det att den skalar upp via HDMI?
Redigerat av Unregisterede2a9c094, 03 March 2008 - 10:05.
Postad 03 March 2008 - 10:39
QAM
QAM
755 inlägg
Citat från inlägg ovan, 820 och 920 : Additionally, the STR-DG920 model supports Deep Color™ for greater color depth on compatible televisions and upscales standard-definition video content to 1080p via HDMI with a 1080p-capable HDTV set. The model features an icon-driven menu system for simple device and content navigation Betyder inte det att den skalar upp via HDMI?
Nej tyvärr inte, de flesta tillverkare formulerar sig så här luddigt, förmodligen med avsikt. De avser att man kan skala upp analoga källor, och mata ut dem via HDMI. Så här skriver Sony om den betydligt dyrare STR-DA3300ES: "IC processor developed by Faroudja®, and first used by Sony, which will up scale and up convert all video signals (less than 1080p) to 1080p via HDMI" Och inte kan den skala upp från HDMI till HDMI.. Det är helt enkelt så att recievers inte utrustas med den elektronik som krävs för att ta emot bild via HDMI, bara ljud. Det här märks ofta även på att menysystemen, OSD, kan läggas uppe på bilden vid analogt bildintag, men inte vid HDMI in. Dumsnålt tror jag, då många är villiga att betala för funktionen, lika dumt som att de inte kan ta emot RGB för uppskalning, bara komponent, S-video eller komposit.
Postad 03 March 2008 - 15:48
Unregistered43b822d3
3782 inlägg
En liten fråga då Sony stuvat om i sitt sortiment: motsvarar den större av dessa modeller en QS?
Tidigare hade en sådan modell som 510 tillhört DE-serien (en inte helt optimal serie), ovanför det fanns 790/795 med liknande utseende som dessa DG men då i QS-serien.
På den gamla "goda tiden" var DB-790/795 rejält prisvärda modeller och med högre kvalitet än billighetsserien E (DE-xxx).
Har denna DG-serie tagit över de mindre QS-modellernas kvalitet eller är det de minsta ES-modellerna (1200ES m.fl) som gjort det?
Postad 03 March 2008 - 21:32
scenic
scenic
1066 inlägg
Det vad jag förstått så är DG en nedgraderad QS men uppgraderad E serie. E serien har ärvt QS "chassi" med bl a aluminium front.
Ang ES vet jag ej men de är ju mycket billigare än de va förut.
Sen märker man på vikten, när E serien fanns låg de runt 8-9kg o QS 13-14kg o ES 16-21kg.
Nu DG 8-10.5kg , ES 15-16kg.
Redigerat av scenic, 03 March 2008 - 21:36.
Postad 10 March 2008 - 00:35
QAM
QAM
755 inlägg
Scenic, du hade några högupplösta bilder i början på den här tråden, kan du posta länken till dem?
Jag är lite förundrad över varför Sonystyle har bilder på en 920 utan den finare displayen.
Edit, jag hittade rätt nu
Men jag är fortfarande förundrad...
Redigerat av QAM, 10 March 2008 - 00:40.
Postad 08 April 2008 - 18:49
Raskus
Raskus
804 inlägg
Är det någon som har koll på när dessa godingar kan tänkas landa i svenska eller möjligen tyska butiker och vad priset kan bli? Tänker främst på STR-DG920...
Postad 01 May 2008 - 20:35
scenic
scenic
1066 inlägg
Nu finns de på prisjakt.
Listpris 520: 2449kr
820: 5790kr
920: 7890 kr
Postad 02 May 2008 - 19:51
QAM
QAM
755 inlägg
Listpris 520: 2449kr 820: 5790kr 920: 7890 kr
920 kostar 600USD i staterna och släpps där den 28 maj, 820 kostar 400USD, med släpp den 23 maj. Och detta är Sonys priser, vilka mao är lite högre än det lägsta marknadspriset kommer bli. Nu kan man ju inte jämföra priser direkt av mellan EU och US, men en 910 kostar 500USD. Med andra ord så kan jag inte annat än le åt Inwarehouse som erbjuder dessa priser och absolut inget leveransdatum.
Postad 03 May 2008 - 08:54
Tomas L
Tomas L
1561 inlägg
Ja, jag tycker det är märkligt att Sony har använt en så spartansk display, deras receivrar ser ju ut som något man köpt på Clas Ohlson. Matris-display är dock ingen nyhet, jag har det på min gamla STR-DB940 som börjar bli 7-8 år gammal, men som ser ut som en ny high-end receiver jämfört med 520 och 820. Någon med erfarnhet av Sony's tidgare modeller som har en åsikt om lämpligheten för stereo-lyssnande?
Såvida du inte sitter på en ruskigt bra anläggning i övrigt och har ett lyssningsrum med bra akustik så kommer du inte att höra någon skillnad på Marantz, Sonyn eller din gamla Denon vid normala ljudnivåer. 920 kostar 600USD i staterna och släpps där den 28 maj, 820 kostar 400USD, med släpp den 23 maj. Och detta är Sonys priser, vilka mao är lite högre än det lägsta marknadspriset kommer bli.
Inwarehouse kanske tror att dollarkursen ligger på 15 kr och inte 6 kr?
Postad 03 May 2008 - 10:51
volvov70
volvov70
95 inlägg
Jag har sett info på andra Forum att DG920 har XMB samt entt annat display fönster
för övrigt har jag sett pris på DG820 i England på runt 250 pund dock verkar 920 kosta ca:450 pund
på den sony uk kan man se info om även DG720 som kommer nu i Maj
Postad 04 May 2008 - 10:47
Adamski
Adamski
484 inlägg
Inte många som pratar om DG720. Jag funderar på om denna skulle kunna vara min första receiver (jag är total nybörjare). Den kommer förmodligen få ett bra pris, då den kostar $300 i staterna. Kommer i så fall kopplas till kommande Sony 40W4000 Lcd, en dvd-spelare samt en PS3:a. Den har 3 st HDMI med följande egenskaper som även den nya tv:n har: Quality 1080p Quality 1080/24p HDMI™ Quality x.v.Color (xvYCC) BRAVIA Theatre LINK (CEC Control) Däremot så skalar den inte upp något. Innebär dessa egenskaper att man kan köra BD, PS3-spel samt annat hd-matariel (tex streamad) direkt genom receivern med hjälp av hdmi utan att behöva separera video från ljud? Räcker det en hdmi-sladd från PS3a till receivern, en hdmi från dvd-spelaren och sedan en hdmi-sladd in i Tv:n? Vad tycker ni i övrigt om denna modell? Specar: http://www.sony.co.u...Cinema Receiver
Redigerat av Adamski, 04 May 2008 - 11:07.
Postad 04 May 2008 - 20:48
Almis
Almis
51 inlägg
DG 720 tar 7.1 LPCM genom HDMI. Alltså perfekt att koppla till PS3 på det sätt du beskriver. Hoppas att den kommer att börja säljas i Sverige.
Postad 05 May 2008 - 08:16
scenic
scenic
1066 inlägg
DG 520 finns nu på netonnet för 2790 kr.
Postad 05 May 2008 - 12:25
Adamski
Adamski
484 inlägg
520:a känns lite väl basic, bara 2 hdmi samt saknar en del ljudformat och lite annat kul. Bland annat detta finns på 720 men inte på 520: HDMI™ SpecBRAVIA Theatre LINK (CEC Control) Bra för mig som kommer ha 40W4000 samt PS3:aDecoding FormatLPCM (2ch / 5.1ch / 7.1ch) thru HDMI™ Dolby Digital EX DTS-ES (MATRIX6.1 / DISCRETE6.1) DTS 96 / 24 DTS NEO:6 Dolby Prologic IIx Video FeaturesHDMI™ Quality x.v.Color (xvYCC)
Redigerat av Adamski, 05 May 2008 - 12:26.
Postad 05 May 2008 - 14:05
Adamski
Adamski
484 inlägg
Är det skillnad på specen mellan amerikanska och europeiska utgåvor?
TV-apparater kan skilja ganska mycket, men är det samma sak när det gäller receivers, någon som vet?
Redigerat av Adamski, 05 May 2008 - 14:06.
Postad 05 May 2008 - 14:31
deenajs
deenajs
85 inlägg
Jag hittar inget om antalet HDMI- utgångar på de olika modellerna. Förstår inte varför alla tillverkare snålar med dem. Börjar bli trött på att byta mellan tv och prolle. Skulle iofs kunna nöja mig med komponent till tvn men blir ju så ******** mkt kabel.. I-landsproblem men fortfarande ett problem
Postad 05 May 2008 - 14:42
Adamski
Adamski
484 inlägg
Jag hittar inget om antalet HDMI-utgångar på de olika modellerna. Förstår inte varför alla tillverkare snålar med dem. Börjar bli trött på att byta mellan tv och prolle. Skulle iofs kunna nöja mig med komponent till tvn men blir ju så ******** mkt kabel.. I-landsproblem men fortfarande ett problem
Skojar du? Det är typ det första man ser när man läser om de olika modellerna. 520:a har 2 in/1 ut 720:a har 3 in/1 ut 920:a finns bara i usa att läsa om, har för mig att den har 4 in
Postad 05 May 2008 - 15:11
Brumbrum14
Brumbrum14
33 inlägg
Lite offtopic kanske men finns lösa hdmi splitters att köpa, se till att köpa en lite dyrare modell bara eftersom dom billigaste bara är strul.
Postad 05 May 2008 - 15:22
kh_vorsteh
kh_vorsteh
71 inlägg
Har tidigare läst att 820 och 920 skall klara dom nya HD-ljuden. (det ska inte 520 och 720 göra)
Och att 920 även skall kunna skala upp och skicka icke hdmi signaler ut via hdmi.
Har jag uppfattat rätt ?
Postad 05 May 2008 - 17:41
Adamski
Adamski
484 inlägg
Har tidigare läst att 820 och 920 skall klara dom nya HD-ljuden. (det ska inte 520 och 720 göra) Och att 920 även skall kunna skala upp och skicka icke hdmi signaler ut via hdmi.
Har jag uppfattat rätt ? Mvh
Om 920 står det att: "inside its chassis is a video processor that can upscale all video sources (less than 1080p) up to 1080p" Hur bra är en sådan uppskalning tex utav DVD, hur mycket bättre blir bilden? 820 släpps väl inte i Sverige?
Postad 06 May 2008 - 11:56
kh_vorsteh
kh_vorsteh
71 inlägg
Verkar så ! https://www.prisjakt...kt.php?p=300278Mvh
Postad 14 May 2008 - 07:34
xLnT
xLnT
6 inlägg
Ingen ny information..?
Är väldigt nelland på 920:an om den släpps i rätt prisintervall.
Är ju snart Juni.
Postad 27 May 2008 - 07:18
Gangir
Gangir
54 inlägg
Är lite förundrad över varför 520 saknar Theater Link. Sitter på en W3000 och det hade varit skönt att slippa 2 handkontroller.
Postad 27 May 2008 - 09:14
Adamski
Adamski
484 inlägg
Undrar om även 720 kommer till sverige? Det är den enda modellen som det inte finns någon som helst info om när man söker på prisjakt.
Jag tycker att det är över huvud taget klent med receivrar på svenska sonys hemsida. Typ 3 stycken??!"¤
Redigerat av Adamski, 27 May 2008 - 09:24.
Postad 04 June 2008 - 12:58
Pr0wler
Pr0wler
484 inlägg
När jag var och köpte min 910 förra veckan hos Sony Center sa de att de skulle få in 820 som efterträdare och inte 920. Men det betyder ju inte att andra affärer inte kommer att sälja den iofs...
Postad 04 June 2008 - 14:58
Pale
Pale
85 inlägg
Vad jag kunde uttyda av bilden på bakstycket så såg det ut att vara fyra HDMI in och endast en ut. Lite tröttsamt att de skall snåla på utgångarna för oss som vill koppla till två bildkällor.
Är alltså fortfarande Maranz 7002 som är billigast med två utgångar.
Postad 07 June 2008 - 09:39
Adamski
Adamski
484 inlägg
Postad 26 August 2008 - 21:20
davidvpt
davidvpt
26 inlägg
Jag tycker det är svårt att hitta information om vilken sorts högtalaranslutningar som de olika modellerna har. STR-DG720 har bara skruvterminaler till frontarna, klämlister i övrigt. 820 verkar ha skruvterminaler på alla utgångar utom front-b. STR-DG710 har nån form av kläm-poster som ser ut att klara banankontakter, men det är svårt att avgöra när man försöker tolka bilderna.
Jag är på jakt efter en förstärkare som inte har så stort djup (runt de 310cm som Sonys modeller verkar ligga på). 5.1 funkar fint och det räcker med 2 hdmi in, och det är plus om de tar ljud via hdmi (något som 510 inte verkar göra). Det sista kravet är att den ska ta bananer på samtliga högtalarutgångar för jag vill inte ge mig på att försöka få in mina bi-wire-kablar i klämlister...
Sist men inte minst är ju en trevlig prislapp inte att förakta... svårt att sträcka sig till 4k när man börjat med en budget på 2k, fast kan man sälja sin gamla Denon-stärkare till nån lättlurad stackare för en massa pengar är även budgeten avklarad  .
Postad 02 September 2008 - 16:16
Gangir
Gangir
54 inlägg
Nån som som sett en komplett spec på 720?
Den verkar som ett ok alternativ om nu inte 920 kommer till Sverige.
Postad 03 September 2008 - 07:12
Pr0wler
Pr0wler
484 inlägg
NetOnNet har ju en spec om du klickar på teknisk spec eller vad det står. Men de tar ju lika mycket för 720 som ChargeIT tar för 820. Så där är ju valet ganska lätt...
Postad 03 September 2008 - 12:15
scenic
scenic
1066 inlägg
Ja 820 fick väl hyffsat i hemmabio tidningen
ljud film : 7/10
ljud musik: 7/10
Postad 03 September 2008 - 19:18
davidvpt
davidvpt
26 inlägg
ljud film : 7/10 ljud musik: 7/10
Tja, det beror på hur man ser det, samtidigt blev den näst sist... Det säger iofs inte att den är dålig, utan snarare att motståndarna i testet var bättre. Jag tyckte att det verkade lite negativt att den fick kritik för att ljudbilden var framtung men å andra sidan så var placeringen bra och den var desstom hyggligt bra på musik. Jag läste ett test på What HiFis hemsida och den fick väldigt gott mottagande där ( http://whathifi.com/...Sony-STR-DG820/).
Postad 12 September 2008 - 10:12
QAM
QAM
755 inlägg
Nu har jag inte grottat i det här på ett tag, men vid en snabb anblick tycks det som om det som skulle blivit STR-DG920 här i europa, har blivit STR-DA2400ES istället? Bara en sådan sak som displayplaceringen jämför med övriga ES-produkter skvallrar om detta i mina ögon, övriga likheter ska vi inte tala om... STR-DG920 som den såg ut tidigt i våras:  STR-DA2400ES:  STR-DG920 i jänkarland:  STR-DA3300ES map displayplacering:
Postad 14 September 2008 - 11:07
dev2null
dev2null
30 inlägg
På sony.se listas fortfarande bara STR-DG520 . Är det någon som har koll på om / när 720 och 820 kommer till fler butiker i Sverige?
Postad 15 September 2008 - 22:18
QAM
QAM
755 inlägg
Jag vet inget om butikernas lagerhållning, men i sådana här tidiga lägen finns det ofta gott om tyska butiker med både bättre priser och omdömmen än de svenska.
Postad 19 September 2008 - 12:29
Ampeninjo
Ampeninjo
104 inlägg
Är det någon som köpt en 720? Är du i så fall nöjd?
Postad 26 September 2008 - 12:00
maxxar
maxxar
50 inlägg
Går i köptankar på en 720, men funderar på om man kan mata in komponent i förstärkaren och sedan få ut bilden via hdmi utgången?
Postad 26 September 2008 - 12:50
velman
velman
94 inlägg
Jag funderar på att köpa en 520 alt. 720. Blir det 720 så är det av den enkla anledningen att den har bravida link...
Om jag kopplar in min dator till tv:n via hdmi, kan jag då få ut ljudet ut tv:n på ett vettigt sätt och sedan in i förstärkaren? Eller måste jag gå direkt in i förstärkaren? Det vore skönt att slippa koppa in en massa extra sladdar i datorn (laptop) varje gång jag skall se på film.
720 kan väl inte ta emot ljud via hdmi?
Ljud
Förstärkare
Tonewinner 7300
Perlisten R18s
Philips Discoverer
Ny projektor!
