VPL-VW80: ny Full HD-projektor från Sony
2 svar till detta ämne
Postad 10 November 2008 - 13:32
Minhembio
  • Minhembio
  • Nyhetsankare
  • 34 inlägg
Läs mer här
Postad 10 November 2008 - 14:52
Hamsteren
  • Hamsteren
  • 1697 inlägg
Optical
Panel Resolution
1080p Full HD, 1920 x 1080
Panel Technology / Panel Size / Nr of Pixels
Sony SXRD / 0.61-inch / 6,220,800 (2,073,600 x 3) Pixels
Panel Pixel Size / Inter-pixel spacing / Panel Response Time
7µm / 0.25µm / 2,5ms
Contrast Ratio Advanced Iris 2
60,000:1
Brightness
800 ANSI Lumen
Lens type
All Range Crisp Focus (ARC-F) Lens
Lens Zoom Ratio, F/f
x1.6 Motorised Zoom, 2.50 - 3.44 / 18.5 - 29.6mm
Lens Shift
Vertical 65%, Horizontal 25%
Lamp Type
200W UHP, LMP-H201
Inputs
HDMI (19-pin connector)
2 (CEC)
Component Video (3x RCA connectors)
1
S-Video (Mini DIN 4-pin)
1
Composite Video (RCA connector)
1
Input A (HD D-sub 15-pin)
1 (Analogue RGB, Component)
Output
Trigger Out (Mini Jack)
2 (Power, Anamorphic Zoom Mode)
Control RS-232C (D-sub 9-pin)
1 (AMX Protocol Supported)
General
Fan Noise
20dB
Lamp Life
3,000 Hours(Replacement time)
Filter Cleaning Time
Every 1,500 Hours
Power Consumption: Max / Standby / Low
320W / 8W / 0.5W
Dimensions (W x H x D)
470 x 179.2 x 482.4 mm
Weight
12kg
Body Colour
Midnight Sky Black
Throwing Distance, 16:9 Screen, Ceiling Mount
Min - Max Screen Size (diagonally)
40 - 300-inch / 1 - 7.6m
40-inch / 1m screen
1.4 - 2.0m
80-inch / 2m screen
2.6 - 3.9m
100-inch / 2.5m screen
3.3 - 4.8m
120-inch / 3.0m screen
3.9 - 5.8m
200-inch / 5.1m screen
6.4 - 9.5m
300-inch / 7.6m screen
9.5 - 14.3m
Acceptable Video Signals:
720p
720/60p, 720/50p
1080i
1080/60i, 1080/50i, 1080/24PsF (48i)
1080p via HDMI
1080/60p, 1080/50p, 1080/24p
Acceptable Computer Signals
fH: 19-72 kHz, fV: 48-92 Hz Max Resolution 1920 x 1080 (HDMI only)
Taget herfra
Postad 12 November 2008 - 10:11
XearO
  • XearO
  • 123 inlägg
gullig :)
