Nya Krell S-300i
34 svar till detta ämne
Postad 10 January 2009 - 20:27
Unregistered89a7be48
  • Unregistered89a7be48
  • 2082 inlägg
S-300i
AUDIOPHILE GRADE INTEGRATED AMPLIFIER
Employing a massive 750 VA toroidal transformer and
38,000 microfarads of capacitance, the S-300i sets the
performance standard for integrated amplifiers.At 150 Watts per channel into 8 Ohms and 300 Watts
per channel into 4 Ohms the S-300i is built to meet the
demands of today's latest loudspeaker technology.
A KRELL Class A, direct coupled design, fully balanced
preamplifier circuitry utilizing KRELL Current Mode
topologies provides unequaled signal bandwidth.
Direct coupled circuitry eliminates impact-robbing
capacitors from the signal path ensuring the preservation
of the audio signal.
Unique for the category, the S-300i taps audio from the
fully differential output included in the internal DACs of
an iPod/ iPhone and maintains this balanced signal
throughout the circuitry. A direct iPod connectivity
cable is provided.
The S-300i has balanced, single-ended, and iPod
inputs. KRELL Theater Throughput mode is assignable
to an input, allowing simple integration into a home
theater system.
A new menu system, adjustable via the custommachined
volume control or remote control, allows
personalization of input labels, volume gain and balance
settings as well as several other functions.
The included solid aluminum remote control replicates
all front panel options as well as providing control for a
connected iPod/ iPhone. The S-300i also has 12volt
trigger input/ output, RS-232 and RC5 capabilities.
WBT binding posts are incorporated, providing superior
loudspeaker cable terminations. The S-300i is also rack
mountable with included rack ears
Available in brushed aluminum silver finish only
• Stereo Integrated Amplifier
• 150 W, 300 W (8, 4 Ohms)
• 750 VA toroidal transformer
• 38,000 microfarads of capacitance
• Krell Current Mode™
• RS-232, RC-5, 12 VDC Triggers
• Discrete Balanced Class A Input Stages
• Direct iPod Connection with Balanced
Circuitry
• 17.25 W, 4.00 H, 17.50 D in.
43.82 W, 10.16 H, 44.45 D cm
Postad 10 January 2009 - 20:32
  • 2082 inlägg
Här är bilden!
Bifogad fil  s_300i_s.jpg   24.94K   3 Antal nerladdningar
/Mats
Postad 10 January 2009 - 20:37
  • 2082 inlägg
Kommer att ha ett ca pris på 34 000.-
Pris ex.från Esoterisk-hifi Uppsala
Krell 300i silver NYHET 34000:-
/Mats
Postad 10 January 2009 - 20:43
mattek
  • mattek
  • 1627 inlägg
är det här efterträdaren till 400:an
har den samma hemmabiofunktion som 400:an
Postad 10 January 2009 - 21:04
mr-välljud
  • mr-välljud
  • 3700 inlägg
KÄnns som det är minst 12-15000:- för mycket på prislappen! Skulle tro att den är direkt bättre än många av sina kompisar i 20000:- klassen. :)
Postad 10 January 2009 - 22:15
Tompasten
  • Tompasten
  • 169 inlägg
Det känns som det går utför för Krell, blir grejerna fulare och fulare eller är det bara jag?
Det känns som det går bort från sina tunga steg och nästan försöker göra lifestyle grejer istället?
Postad 10 January 2009 - 22:20
mr-välljud
  • mr-välljud
  • 3700 inlägg
Dom skall ju definitivt inte designa prylar.
Detta är ju ren rapakalja. Inte speciellt unikt från de senaste 25årens tyngre integrerade maskiner.
Postad 13 January 2009 - 13:12
  • 2082 inlägg
Det var värst vad ni var anti mot Krell,så dåliga är väll knappast deras stärkare
/Mats
Postad 13 January 2009 - 13:23
sometimestheycomeback
  • sometimestheycomeback
  • 901 inlägg
Nog är den lite väl dyr med framförallt, kanske inte det snyggaste jag sett. Går det att få med svart front istället?
Postad 13 January 2009 - 15:53
  • 2082 inlägg
Håller med om att den inte är det snyggaste man sett,verkar endast gå att få i silver
/Mats
Postad 27 January 2009 - 14:22
Domnerus
  • Domnerus
  • 85 inlägg
Review: http://www.krellonli...i-review-09.pdf
När man läser testet får man ha i åtanke att stärkaren kostar 20.000:- i USA och 34.000:- i Sverige. På våra breddgrader så är nog Primare, Bladelius och Hegel mer prisvärda.
Postad 27 January 2009 - 23:48
Unregistered2e076a71
  • Unregistered2e076a71
  • 37 inlägg
Det er en engelsk test og der koster den ca. 28 000 kr. :)
Postad 30 January 2009 - 12:17
Pale
  • Pale
  • 85 inlägg
Den har HT-throughput som 400'an, så för oss som fortfarande tycker att tvåkanalsljudet är viktigt så tycker jag att den ser intressant ut.
Får väl dock instämma i att Baldelius och Hegel kan vara mer prisvärda för oss i Norden.
Postad 30 January 2009 - 15:19
Unregistered969
  • Unregistered969
  • 147 inlägg
Den byggs faktiskt i Kina! Hör och häpna. Trots det kändes den och såg ut som en äkta Krell. De har stenhård kontroll över produktionen säger de. Och det vi hörde tyder på att de faktiskt har det. Världen är föränderlig…
Kommer från Audionords hemsida. Ja vad säger man, man tycker den borde bli billigare om man tillverkar den där.
//rillo
Postad 30 January 2009 - 15:38
Unregisterede456c62f
  • Unregisterede456c62f
  • 385 inlägg
Går man efter pappret så är det ju inget märkvärdigt..jag skulle aldrig köpa för dom pengarna!! Man får definitivt bättre grejjor för dom stålarna..då framstår Krellen som en kinesiskt designad klockradio !
Postad 06 March 2009 - 18:39
optimus
  • optimus
  • 811 inlägg
Någon som har lyssnat och kan avlägga en liten recension?
Eller tips på vad man annars/också ska lyssna på!
Postad 26 September 2010 - 22:26
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Nu har den ett annat pris i Sverige. Nu kostar den 27.600:- enligt prislistan som finns på Audionords hemsida.
Den tillhörande cd-spelaren har också samma pris, alltså 27.600:- den med.
Prislista
Postad 27 September 2010 - 17:24
dallan1981
  • dallan1981
  • 2249 inlägg
Personligen diggar jag utseendet på den!
Skulle vara intressant att få se ett test på den mot Hegel H200 genom killarna på HIFI&Musik och Bild&ljud Hemma.
//Micke
(Själv står jag precis inför köp av en integrerad 2-kanalare, men jag har fastnat för en betydligt billigare 150w:are, nämligen Onkyos A-9755, den verkar grymt prisvärd.... undrar hur ett blindtest mellan Krellen och Onkyon skulle sluta!?)
Postad 31 October 2010 - 12:44
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Ja, den är läckrare i verkligheten än dom produktbilder man ser :)
Krell S300i
Postad 13 February 2011 - 00:07
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Läste just att den är tillverkad i Kina, där föll den bort ;)
Postad 13 February 2011 - 00:16
threnode81
  • threnode81
  • 388 inlägg
Om du hade läst tråden lite nogrannare hade du vetat det för två år sedan. ;)
Postad 13 February 2011 - 00:24
Unregistered1939
  • Unregistered1939
  • 1045 inlägg
Av humanitära eller politiska skäl ?
För tekniskt och kvalitetsmässigt är det ingen skillnad på något som är tillverkat i Kina eller Sverige
Maveric
Ps. när vi satt och rörde i lergrytan utanför vår grotta, så åt de från målat porslin inne i sitt hus :P
Redigerat av Unregistered1939, 13 February 2011 - 00:27.
Postad 13 February 2011 - 03:21
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Krell förknippas ju med USA så det känns lite synd att dom har lagt tillverkningen i Kina. Sen köper jag helst inte högtalare med Rosenträ från skövlade regnskogar och produkter där folk har jobbat häcken av sig för att producera snabbare. Knappast att det är 40 timmar i veckan som gäller där nere. Hur som helst så har min Bladelius Tyr just gått sönder och jag vill inte hosta upp 7-8k för reparationen så nu letar jag efter ersättaren som jag tror blir en Bladelius pga deras nya sound som är det trevligaste jag hittills har lyssnat på. Jag pratar om Thor Mk3 Novitas men kanske att det blir en Tyr Mk2, vi får se ;)
Mvh Per
Redigerat av Unregistered2141, 13 February 2011 - 23:09.
Postad 14 February 2011 - 23:27
evilseed
  • evilseed
  • 28 inlägg
Krell förknippas ju med USA så det känns lite synd att dom har lagt tillverkningen i Kina. Sen köper jag helst inte högtalare med Rosenträ från skövlade regnskogar och produkter där folk har jobbat häcken av sig för att producera snabbare. Knappast att det är 40 timmar i veckan som gäller där nere. Hur som helst så har min Bladelius Tyr just gått sönder och jag vill inte hosta upp 7-8k för reparationen så nu letar jag efter ersättaren som jag tror blir en Bladelius pga deras nya sound som är det trevligaste jag hittills har lyssnat på. Jag pratar om Thor Mk3 Novitas men kanske att det blir en Tyr Mk2, vi får se :blush:
Mvh Per
Vad har gått sönder på din Tyr?
Postad 17 February 2011 - 01:26
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Line in 2 efter den balanserade ingången. Pre-outen samt ena kanalen fungerar bara vid vissa tillfällen. Med andra ord Kaputt :(
Redigerat av Unregistered2141, 17 February 2011 - 01:28.
Postad 30 March 2011 - 23:05
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Nu är den lagad och tillbaka :) Hade knäckt ingångarna av misstag när jag ställde mitt atacama rack för nära bakväggen då jag skulle koppla in den. Det gick inte att dra ut bänken då den stod på spikes och då gjorde jag misstaget att börja koppla. Dom bytte även något typ av relä om jag inte minns fel. Det gick på 3750:- inkl frakt fram och tillbaka och tog totalt en vecka, men nu vill jag ha en Krell i sovrummet känner jag då min idol är Fabio :)
Redigerat av Unregistered2141, 30 March 2011 - 23:34.
Postad 30 March 2011 - 23:19
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Varför inte ett par sådana här till :(
http://www.martinlog...otion/index.php
Kan ju vara kul med lite priser också :)
http://www.intercept.../prislister.htm
Postad 30 March 2011 - 23:25
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Hoppsan :) Det här har jag glömt att jag har skrivit :(
Krell förknippas ju med USA så det känns lite synd att dom har lagt tillverkningen i Kina. Sen köper jag helst inte högtalare med Rosenträ från skövlade regnskogar och produkter där folk har jobbat häcken av sig för att producera snabbare. Knappast att det är 40 timmar i veckan som gäller där nere. Hur som helst så har min Bladelius Tyr just gått sönder och jag vill inte hosta upp 7-8k för reparationen så nu letar jag efter ersättaren som jag tror blir en Bladelius pga deras nya sound som är det trevligaste jag hittills har lyssnat på. Jag pratar om Thor Mk3 Novitas men kanske att det blir en Tyr Mk2, vi får se :)
Mvh Per
Postad 25 January 2012 - 04:04
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Har precis krängt min Primare I30 så nu finns det ingenting alls att spela på vid laptopen :( förutom min Tangent Duo som jag har kopplat in via aux ingången, men så kan man ju inte ha det :D Måste ju köpa något som låter vettigt. Står just nu mellan Krell S300i, Bladelius Tyr Mk2, Traditonal eller Novitas, eller om det blir Primare I22 med inbyggd dac. Kommer att spela på mina B&W DM686 och mina Sonus Faber Cremona M. Min Bladelius Thor Mk3 Novitas kommer jag att behålla ;)
Det man önskar det får man, precis som Fabio sa :P
Postad 19 June 2012 - 01:53
Unregistered2141
  • Unregistered2141
  • 2530 inlägg
Det stämde ju också :D Hur som helst så ska Krell släppa en ny modell vid namn S550i i Augusti eller September. Den har visats på highend mässan i Las Vegas om jag inte minns fel som var i Februari i år. Priset kommer att landa runt 50k. Gött gött i göttans! :P
Postad 06 September 2013 - 06:59
Unregistered2222
  • Unregistered2222
  • 1106 inlägg
Kul att läsa denna tråden igen efter dom här åren :D
Skulle vilja säga att den här maskinen låter sagolikt och är ruggigt billig med tanke på vad man får för pengarna så länge man matar den med ett par golvare. Ihop med Audio Physics högtalare låter den oerhört bra oavsett om det är stativare eller golvare men det ska vara lite tryck i burkarna för att det ska ge något. Gärna ganska rappa högtalare :) Dagens Krell har ett unikt sound och spelar många många gånger snyggare än tex Bladelius tycker jag :) Den kan tyckas lite klen i basen men om man kör med golvare med fler än två element så lär man inte märka av detta :) Finns nog många som skulle skulle kunna sälja favorit-bilen för att få det soundet i anläggningen :D
Postad 06 September 2013 - 07:22
Unregistered2222
  • Unregistered2222
  • 1106 inlägg
Här kommer en bättre bild så man ser mer hur den ser ut på riktigt :wub:
Redigerat av Unregistered2222, 06 September 2013 - 07:23.
Postad 06 September 2013 - 07:31
Unregistered2222
  • Unregistered2222
  • 1106 inlägg
http://www.youtube.c...h?v=9o2cCPv49yQ
Postad 08 November 2013 - 15:51
Unregisteredaf438ffd
  • Unregisteredaf438ffd
  • 45 inlägg
Så här skriver ljudupplevelser på sin hemsida:
"Äntligen är den här! S-300i är den hett efterlängtade ersättaren till succén 400xi.
Krell S-300i är en integrerad förstärkare på 2x150Watt i 8Ohm (2x300Watt i 4Ohm). S-300i är utrustad med en 750 VA toroidal trafo och är fullt balanserad. S-300i är en av de bästa och mest allround integrerade förstärkare vi hört under 50 000kr. Måste höras!
Topptestad i Hifi News där Ken Kessler skriver följande: "The S-300i is so good that it will cause problems for Krell, not just its rivals, because it behaves like a 5000 pounds pre/power combo. The distributor won't thank me for saying that, but this is an inexplicable, insane give-away. I love it."
http://www.ljudupple...-404-c-197.aspx
Postad 25 September 2015 - 13:17
Unregistered2294
  • Unregistered2294
  • 2941 inlägg
Är det bara jag som kör med S300i här? :)
