* Officiell tråd - Benq W1000 *
31 svar till detta ämne
Postad 10 September 2009 - 13:32
snuffe82
  • snuffe82
  • 622 inlägg
Hej, undrar om det är någon som har bra koll på , när kommer den, hur bra är den och om någon har sätt den in action?
Är sugen på att köpa ny proje nu men vet inte vilken humm...
Display Technology DLP® by Texas Instruments
Native Resolution 1080p (1920 x 1080)
Resolution Supported VGA(640 x 480) to WUXGA(1900 x 1200))
HDTV Compatibility 480i / 480p / 576i / 576p / 720p / 1080i / 1080p
Brightness 2000 ANSI Lumens
Contrast Ratio 3000:1 (Full on/Full off)
Image Size 24” to 300”
Throw Ratio 1.59 - 1.9 (56.8" @ 2 meter)
Zoom Ratio 1.2:1
Keystone correction Auto Keystone / Manual Vertical ± 20 Degree
Lens F:2.5 (Wide) ~ 2.76 (Tele), f:23.5 mm (Wide) ~ 28.2 mm (Tele)
Lamp Life 180W, 3000 / 4000 hours (Normal / Economic mode)
Lamp warranty of 6 months or 1000 cumulative hours whichever comes first.
Operational Noise 29 / 27 dB (Normal / Economic mode)
Display Colours Full 1.07 million color palette
Aspect Ratio 16:9 Native, 5 Aspect Ratio Selectable
Horizontal Frequency 31 ~ 90 KHz
Vertical Scan Rate 50 ~ 85 Hz
Input Terminals
PC:
Analog RGB: D-sub 15 pin x 1
A/V:
HDMI V1.3 x 1
Component Video:
Output Terminals PC:
Variable Audio Out : Stereo Mini Jack x 1
Speaker: 3W x 1
Control Terminals
Serial Connector : RS232 (D-sub 9pin) x 1
USB ( Type mini B ) x 1
Video Compatibility NTSC / PAL / SECAM
Dimensions (HxWxD) 325 x 95 x 254 mm
Weight 3.4 kg
Auto Switching Power Supply 100 to 240 VAC, 50 to 60 Hz
Power Consumption Max. 230W, Standby max. <1W
On Screen Display Languages
Danish / Dutch / English / Finnish / French / German / Italian / Norwegian / Polish / Portuguese / Russian / Simplified Chinese / Spanish / Swedish / Traditional Chinese / Korean / Thai (17 Languages)
Preset Modes / Application Modes
Cinema Mode, Dynamic Mode, Standard Mode, User 1 Mode, User 2 Mode, User 3 Mode
Functions BrilliantColorTM
UNISHAPE
3D Color Management
Dual HDMI inputs
Closed Captioning
Auto Keystone
Variable Audio Out
Panel Key Lock
Quick Auto Search
Freeze
Blank
Auto Off
Security Password
HDTV compatible
High Altitude Mode
Quick Cooling
Remote Control with backlight
Redigerat av Passerati, 21 December 2009 - 23:00.
Postad 20 November 2009 - 16:37
Unregistered035dce0b
  • Unregistered035dce0b
  • 549 inlägg
Såg den igår direkt ur kartong,den så jättebra ut å va tyst å fin,ska kolla in hd20n först så få ja se sen om benq är värd 4lök till.
Postad 28 November 2009 - 16:35
nanonex
  • nanonex
funderar på att köpa en benq w1000.
är den bra på lågupplöstfilmvisning som tv o dix.avi filmer o dvd mm
Slagit ihop trådar och gjort en officiell tråd / Mvh Passerati
Redigerat av Passerati, 21 December 2009 - 22:20.
Postad 29 November 2009 - 16:56
nanonex
  • nanonex
har du kollat in benq w 1000 ???
Postad 01 December 2009 - 11:20
Unregistered8c1f5350
  • Unregistered8c1f5350
Är väldigt intresserad om det är några större skillnader mellan Optomas HD20 och Benq W1000, och det verkar ju som du har testat båda, så jag undrar om du har nåt omdöme?
Postad 01 December 2009 - 11:31
Biokillen
  • Biokillen
  • 202 inlägg
Känns som bra specifikationer, men skulle vilja läsa några tester på den innan man slår till. Nån som hittat några bra tester?
Gillar att den är riktigt ljusstark, kan man skaffa en lite mer grå duk så att svärtan blir kanon.
Helt ok pris också.
Edit:
Hittade en test här där de tar upp Optomas HD20 också som jämförelse
Benq test
Redigerat av Biokillen, 01 December 2009 - 11:40.
Postad 03 December 2009 - 19:16
Pill
  • Pill
  • 45 inlägg
Undra hur denna projektor står sig mot Mitsubishi HC3800, nu när W1000 är prissänkt så har de samma pris.
Är sugen på båda men kan verkligen inte bestämma mig.
Postad 06 December 2009 - 22:02
Biokillen
  • Biokillen
  • 202 inlägg
Mitsubishin går bort för mig då jag vill ha en ljusstark och den låg bara på 1300 ansilumen. Benq ligger på 2000.
Postad 07 December 2009 - 09:33
edtjope
  • edtjope
  • 773 inlägg
Specar säger egentligen ingenting, tror alla tillverkare mäter olika. Det är ut och jämföra som gäller. Enligt tester ska HC3800 ha väldigt bra ljusstyrka i "korrekt" läge.
Postad 07 December 2009 - 12:03
Biokillen
  • Biokillen
  • 202 inlägg
Men just ansivärdet känns som det borde stämma rätt bra. Har en sanyo plv-z5 just nu, men tänkte byta ut den och sätta sanyon i sovrummet :)
Visst fungerar den bra men jämfört med andra projektorer som har högre ansivärde så är de helt klart ljusstarkare. Så just den siffran känns det som man kan lita på.
Har du läst nånstans om att de brukar mäta på olika sätt med just ansilumen? Skulle vara intressant att läsa om du kan länka.
Postad 09 December 2009 - 20:15
Så har jag fått se Benq W1000 "in action". Jag tog mitt pick och pack och besökte Hifiklubben i Jönköping. Bilden var kanon, jag stördes inte alls av fläkten på projen, men både jag och sambon upplevde RBE effekten plågsamt mycket, så för mig blir det ingen Benq...Så nu forstsätter jakten på en full HD projektor till ett schysst pris. Letar efter en butik som kan Demostrera Optomas HD20, så är det någon som har ett butiks tips i Jönköpingstrakten är det bara att hojta till (Hifiklubben hade inte denna hemma, utan den kom först i februari 2010). Givetvis är jag även intresserad av LCD projar som kan ge mig full HD...
Postad 10 December 2009 - 22:26
hjallle
  • hjallle
  • 111 inlägg
hej
har läst lite om denna proj
det står att den ska visa judder vid 1080p/24 , men inte vid 1080i
http://www.trustedre...LP-Projector/p4
så är det någon som har denna projektor som kan kolla detta så hadde det varigt
jätte shyst
tackar på förhand
Redigerat av hjallle, 10 December 2009 - 22:28.
Postad 11 December 2009 - 07:08
MarAri
  • MarAri
  • 9 inlägg
Även jag har Benq W1000, men någon RBE har jag inte störts av, och något judder (vad är det för något egentligen?) har jag inte stött på. Jag kanske är synskadad som inte ser alla "defekter"?
Jag är jäkligt nöjd med min iaf.
Tiden innan jag skaffade projektorn så läste jag på en himla massa om olika projekteror, även då vilka fenomen som de kan visa. Till exempel regnbågseffekter. När jag då sökte efter RBE, så såg jag att det var en väldans massa personer som inte kunde se RBE. Men en del av dessa personer ville se vad detta fenomen var för något, så de lärde sig helt enkelt att framkalla RBE. Min fråga är: Varför vill man framkalla fel som man inte kunde se innan? Man förstör ju bara för sig själv!
Postad 11 December 2009 - 08:09
hjallle
  • hjallle
  • 111 inlägg
Helt rätt MarAri , har heller alldrig sett regnbågar och inte försökt framkalla det heller
har haft en toschiba MT200 , men lampan är slut på den nu (4200 timmar) en projektor som jag tyckte var kanon bra
men nu äer det ju 1080 som gäller *L*
läste i en test att den kunde framkalla judder (hackigt i panoreringar ) på 1080p/24fps
var på hifiklubben och kollade på den och då såg jag inget hackigt i bilden vid panoreringar
ska heller inte kolla efter det när jag får projektorn
tyckte bilden var väldigt bra iallafall ( inte kallibrerad )
kan inte få det helt svart i rummet så jag tror denna projektor kommer passa mej bra
och ni som har firmware 100 och den röda lampan börjar lysa om lampbyte
så är det en bugg som är borttagen i firmware 101
det var så att projektorn skall säga till om lampbyta vid 3950 timmar men den såger ifrån vid 3950 minuter istället så nu vet ni det som har en röd lampa lysande på projektorn
Redigerat av hjallle, 11 December 2009 - 09:11.
Postad 11 December 2009 - 13:05
sportbilsentusiasten
  • sportbilsentusiasten
  • 459 inlägg
Nä det ska man ju inte göra. Problemet verkar rätt överdrivet!
Men tänk på att testa projjen under lång tid för du kan i värsta fall bli påverkad över tid, o bli trött i ögonen...
Mao du ser inte regnbågar men det tröttar på sikt.
Postad 12 December 2009 - 01:47
hjallle
  • hjallle
  • 111 inlägg
har nu fått hem projektorn och är så in i h....te nöjd faktiskt
ser varken regnbågar eller nått annat utan bara en väldigt bra bild
har inte kalibrerat den änn utan den är bara provkörd med bd material
så detta är en mycket bra projektor som man kan ha lite ljus tänt i rummet med
tycker den är väldigt tyst med ( hadde en toshiba mt 200 innan)
så ni som är i projektor tankar kolla inn denna
Postad 12 December 2009 - 21:19
Eriksson2631
  • Eriksson2631
Vad menas med "RBE effekt"?
Postad 13 December 2009 - 13:14
Zhentro
  • Zhentro
  • 211 inlägg
Det kallas även regnbågseffekten och det betyder att vissa personer har mer eller mindre lätt att se färgskiftningar i bilden. Om jag inte är ute och cyklar så uppstår det färghjulet som DLP-tekniken använder.
Jag tror inte RBE effekten är överdriven. Får några veckor sedan tittade jag på W1000, första DLP projjen jag sett, och under de 5 minuter jag tittade på bilden såg jag detta fenomen flera gånger. Men det är ju väldigt individuellt, så som många sagt innan, det gäller ju att få titta på en demo först så man vet om man är drabbad eller ej.
Postad 15 December 2009 - 23:34
hjallle
  • hjallle
  • 111 inlägg
nu finns den på you tube (fast det är på japanska eller kinesiska)
kolla här http://www.youtube.c...h?v=IfIeP3IGaHY
det ser ut som de använder en vit duk om man kollar i kanten på duken dom visar upp
Redigerat av hjallle, 15 December 2009 - 23:37.
Postad 21 December 2009 - 19:38
hjallle
  • hjallle
  • 111 inlägg
test av benq w1000
http://soundsgreatav.blogspot.com/
Postad 24 December 2009 - 11:56
Fredde70
  • Fredde70
Hejsan...
Mitt första inlägg här. Har ett dedikerat biorum. Har nu uppdaterat min projektor till en Benq W1000 och måste säga att jag är riktigt missnöjd än så länge. Är inget "freak" då det gäller ljud och bild men har bra grejer som jag själv är nöjd med. Bytte från en Sanyo PLV Z1X eftersom jag saknar det enkla med HDMI kopplingar sen jag bytte förstärkare. Har en Sony STR DA2400ES som är med HDMI växel inbyggd. Mina framhögtalare är NHT 2.5i med NHT AC1 som center och bak har jag NHT 1.5i, detta har iofs inte med ämnet att göra, men för helheten.
Jag hoppas verkligen att det är nån kalibrering eller liknande då bilden är riktigt kornig jämfört med min 5 år gamla Sanyo. Har en "referens" musik DVD med Diana Krall "Live in Rio" som är/var helt fantastisk bild med Sanyo´n med RGB kabel.
Har en Philips DVD DVP 5990 dvd och har även provat vår sovrums DVD en Samsung med 1080p och lika kasst resultat med både, provade även med RGB kabeln men ingen skillnad. Har provat att köra kabeln direkt till projektorn,dvs ej genom förstärkaren.
Har iofs en 10m HDMI kabel men det hade jag även med RGB kabeln.
Rotat lite i menyerna på projektorn, men tycker inte jag hittat något jag "missat" att ställa in och jag har inte "ögon" för att ge mig på en kalibrering själv. Duken jag har är 120" och jag fick flytta tillbaks fästet för Benq´en ca 1-1,5m för att få samma storlek som jag hade tidigare.
Just nu på julafton har jag bara god lust att gå ut och gräva ner skiten i snön och ringa till köparen av den gamla och säga att det blir inget.
Nog klagomål. Hur går jag vidare?
Postad 25 December 2009 - 12:00
hjallle
  • hjallle
  • 111 inlägg
konstigt att du får en så pass dålig bild som du beskriver tycker jag
har en gammal oppo spelare som skalar upp bilden till 1080 på dvd och tycker bilden är hur bra som helst med dvd
men för att du ska kunna se hur bra bilden kan bli med denna projektor tycker jag du ska prova med bluray spelare
har faktiskt kört lite tv på den nu i jul , tycker inte den är så bra på boxer iallafall , bara kört med s-video med tv
men det går ju att titta på
men som sagt var försök kolla bluray film på den så ser du vad den kan prestera
Postad 26 December 2009 - 15:45
Fredde70
  • Fredde70
Var i väg och köpte en Blu Ray spelare idag och några skivor. Har bara kollat lite snabbt, men det såg betydligt bättre ut. Återkommer när jag programmerat om fjärrkontrollen att passa. Har även ställt in en "biodator" som jag håller på att konfigurera...det blev mycket nu.
Postad 28 December 2009 - 14:51
nanonex
  • nanonex
ok . funderar på att köpa en benq w1000
är du nöjd nu eller?
låter den mycke o klarare den bara högupplösta filmer eller blir det schysst med dvder o typ avi-filmer?
har ju rätt litet vitt rum så man vill ju inte ha förstor projektor.
Redigerat av nanonex, 28 December 2009 - 14:51.
Postad 08 January 2010 - 00:17
Unregistered50209da3
  • Unregistered50209da3
  • 33 inlägg
Jag är också sugen på en W1000
Såg den live idag på HiFiklubben i Helsingborg.
Ingen RBE vad jag kunde se.Hyfsad svärta men bara när det var mörkt i rummet.
Vi tände ett par lampor men då blev det svarta grått.
Kanske man skulle ha en grå duk eftersom den är så ljusstark ?
Den gick rätt tyst också.
Det här att det är lite kornigt kan kanske vara att man har för stor duk.
Denna HDTV chart hittade jag på nätet hdguru.com
Att tänka på är att en inch är 2,54cm
Jag satt på 3meters avstånd med 104 tum på duken och det var alldeles för närma.
Testade att gå bakom soffan på c:a 4,5m och då var bilden helt brusfri
Postad 08 January 2010 - 03:14
hjallle
  • hjallle
  • 111 inlägg
hej piddez
kollade med på hifiklubben i helsingborg , första gången jag var där tyckte jag med bilden hadde alldeles för mycket brus och gick ut ur
affären , sen var jag där i ett annat ärende och då var det inget brus i bilden
fick till svar att det nog var nått fel på kabeln eller nått i bildväxlarn
då köpte jag projektorn och har inte alls sett något brus på den här hemma
har en vit duk på 106 tum och sittter4,3 meter från bilden
Redigerat av hjallle, 08 January 2010 - 03:17.
Postad 13 January 2010 - 22:26
hjallle
  • hjallle
  • 111 inlägg
kollade avs forum idag och såg att en ny fw är tillgänglig till denna projektor den heter visst 103
men då måste man skicka iväg den tyvärr
går inte att göra själv med ett flashminne tex (dåligt tycker jag)
fw ska gör så att 3d color går att spara vilket det inte gör nu tyvärr
e det någon som vet om det är mer i den nya fw till denna eminenta projektor
Postad 23 January 2010 - 15:55
Unregistered5360507e
  • Unregistered5360507e
  • 138 inlägg
Var på Hifikluben Sundsvall och kolla denna projje. Gillade färger och ljustryck men fick en känsla av att bilden inte flöt till 100% när kamerna rörde sig snabbt eller följde ett föremål i förflyttning.
Kollade blue Ray på en Samsung spelare.
Vad har ni andra för uppfattning?
Postad 25 January 2010 - 07:22
  • 138 inlägg
Ingen större aktivitet i denna tråd!
Har iaf googlat och lärt mig att ovanstående probleme kallas "Judder" vilket denna, och även andra, projektorer drabbas mer eller mindre av.
Hur blir det om man spelar xbox. Finns problemet även då? Lite störigt om racerbilen ska hacka sig framåt...
Postad 04 March 2010 - 22:26
Fredde70
  • Fredde70
Blev less på att "Lamptiden är slut" som kom upp vid uppstarten, är visst en bugg i mjukvaran om man inte har 1.03. Jag ringde till Benq och blev trevligt bemött och de bekräftade att den behövde uppgraderas. De skickade en UPS fraktsedel via mail som jag skrev ut. Packade ner projektor i orginalkartongen och satte på fraktsedeln ringde ett samtal till UPS och inom 2h så kom de och hämtade kartongen vid min dörr.
Detta var igår onsdag vid lunch, skall bli intressant att se när den kommer tillbaks. Tror den skickades till nått företag i Uppsala.
Postad 26 July 2010 - 13:25
MarAri
  • MarAri
  • 9 inlägg
Nu har du förhoppningvis fått tillbaka din projektor! :D Hur lång tid tog det?
Postad 02 August 2010 - 08:47
Fredde70
  • Fredde70
Nu har du förhoppningvis fått tillbaka din projektor! :) Hur lång tid tog det?
Det tog en vecka ungefär. Nu funkar den som den skall. Väntar på en kusin som ville prova att justera in den, men den gör sitt jobb under tiden. Det enda är att jag kör med en Logitech 895 fjärrkontroll och den programmerar man via nätet och apparaten finns inte (ännu) som fördefinerad hos logitech.
