JVC's DLA-RS4000 prestige projektor anno 2009
23 svar till detta ämne
Postad 30 November 2009 - 21:21
Über-Guru
12561 inlägg
Den leverarar 4 x Full HD bilder -samtidigt.The DLA-RS4000 4K projector is the ultimate projector for discerning home theater enthusiasts," said Jack Faiman, vice president, Visual Systems Division, JVC U.S.A.. "Not only does it produce amazing images for movies, sports, and video games, but its smaller footprint and incredible flexibility make it the ideal premium home theater projector for custom installations. Plus, despite all its high-end features, its user-friendly interface makes it easy to sit back and enjoy the view."
10 megapixel 4096 x 2400, 10000:1 i kontrast, 8 olika lamplägen, priset är lika häftigt $175.000, ca 1.225 milj sek.  WAYNE, NJ (September 10, 2009) - JVC Visual Systems Division introduces its new DLA-RS4000 Reference Series 4K home cinema projector at CEDIA Expo, September. 10-13 at the Georgia World Conference Center in Atlanta. The system is being showcased in the JVC D-ILA Theater in the Omni Hotel North Tower throughout the duration of the CEDIA Expo. Based on the same projection engine used in advanced simulation systems, it provides the superior imagery as well as installation flexibility required by uncompromising home theater consumers. This system is ISF and THX* certified.
Three newly developed ultra high definition 4K2K D-ILA devices allow the DLA-RS4000 to deliver a 10 megapixel image with a native resolution of 4,096 x 2,400—more than four times the resolution of HD. Up to four screens with full HD or WUXGA resolution images can be displayed simultaneously .
A new optical design provides 3500 ANSI lumens from a Xenon lamp and delivers excellent color rendering. Lamp power can be adjusted in eight steps for the ideal brightness for a variety of home theater settings and screen sizes. In addition, new Wire Grid polarizers in the optical engine that minimize light leakage are combined with new liquid crystal technology and a novel liquid crystal orientation to significantly reduce off-state light, resulting in a 10,000:1 native contrast ratio.
The RSVP4 custom digital video processing unit serves as a signal switching, scaling and processing hub for virtually any video source, including Blu-ray and gaming systems, cable and satellite receivers, and DVD players. The RSVP4 has a special feature enabling certified calibration specialists to calibrate either of two custom gamut memories based on the installation's specific requirements. This enables each system to achieve an accurate color space for the source material being shown. Other features include audio delay compensation, and three separate gamma tables for customization of various image sources and viewing environments. The DLA-RS4000 is shipped complete with a JVC high quality projection zoom lens to maximize performance in almost any home theater setting.
Despite its advanced performance, the 110-pound DLA-RS4000 achieves a 65 percent reduction in size compared to conventional projectors in the same class. Generous horizontal and vertical lens shift capabilities permit flexible projector positioning, and its stackable design allows for applications such as 3D. Ethernet and RS-232C interfaces allow projector installation and adjustment from a PC-based Web browser for multiple units, plus an e-mail function can send out status messages and lamp replacement reminders.
The DLA-RS-4000 projector has a suggested list price of $175,000 and will be available October 2009 .
Postad 01 December 2009 - 10:48
Unregistered39429
Unregistered39429
3116 inlägg
Postad 01 December 2009 - 12:11
Hybe
Hybe
1429 inlägg
vad ska man göra med 4096 x 2400, seriöst?
visa foton på eller?
Postad 01 December 2009 - 12:42
JohanGbg
JohanGbg
210 inlägg
vad ska man göra med 4096 x 2400, seriöst? visa foton på eller?
1, Berätta att man har det för alla här på forumet. 2, Berätta det för (i mitt fall) båda i bekantskapskretsen som skulle förstå vad det innebär. I övrigt kan jag inte heller se nyttan av det i dagsläget  /Johan
Postad 01 December 2009 - 13:19
Über-Guru
12561 inlägg
Vem behövde Full HD år 1999? Och 4K är ju inte det högsta i dagsläget
Postad 02 December 2009 - 19:34
Unregistered39429
Unregistered39429
3116 inlägg
Tur att dom även har lanserat fler modeller!New JVC D-ILA Home Theater Projector Line Features Top Model With 70,000:1 Native Contrast
New features include ISF certification, high speed frame rate and more.
ATLANTA, September 10, 2009 - JVC updates its award-winning line of D-ILA home theater projectors with the introduction of six new models, each offering the high native contrast that has made JVC projectors top-selling favorites among the most demanding home theater enthusiasts. The new line includes four THX® Certified projectors and all six achieve unprecedented contrast ratios without the need for artificial contrast enhancing techniques, such as a dynamic iris. In fact, JVC's new top-end model boasts a native contrast ratio of 70,000:1 - the highest among all currently available home theater projectors.
The new projectors are the DLA-RS35, DLA-RS25 and DLA-RS15 to be marketed by JVC's professional products group, and the DLA-HD990, DLA-HD950 and DLA-HD550, available through JVC's consumer electronics group. All six projectors feature the same D-ILA technology and features found in previous models, but add improvements in both performance and usability.
New for 2010 is JVC's double-speed 120Hz Clear Motion Drive technology to reduce motion blurring, and a new screen adjustment mode to optimize the projector for different screen types - features available on all six new models. Four of the six new projectors - DLA-RS35, DLA-RS25, DLA-HD990 and DLA-HD950 - offer JVC's new original picture modes, which provides advanced processing that adjusts for the different way that projectors process color compared to the color mixture method used in film. As a result, the projector delivers the subtle nuances typically associated only with a movie theater presentation. What's more, these same four new models are certified by ISF and so include an ISF C3 mode so they can be professionally calibrated.
All six new projectors use JVC-developed 0.7-inch full HD D-ILA devices and the company's wire-grid optical engine. These key technologies combine to deliver unprecedented native contrast, meaning that there is no dynamic iris to artificially inflate contrast specifications. As a result, the projectors simultaneously deliver true blacks and extraordinary luminance detail.
The pinnacle of this performance is found in the new DLA-RS35 and DLA-HD990. These projectors offer the highest performance yet of any D-ILA home theater projector, with a native contrast ratio of 70,000:1. This unparalleled performance is achieved in part by using components that are made to the most exacting of tolerances. This includes the selection of only the highest performing optical assemblies, the selection and matching of the D-ILA devices, and final adjustment by highly trained JVC technicians. In addition, the DLA-RS35 and DLA-HD990 come with a three year warranty.
Native contrast ratio specifications for the other new projectors are: DLA-HD550 - 30,000:1 DLA-RS15 - 32,000:1 DLA-RS25/DLA-HD950 - 50,000:1
The top four models - DLA-RS35, DLA-HD990, DLA-RS25 and DLA-HD950 - are all THX Certified (for all worldwide markets) to ensure accurate and exceptional picture quality in the home theater environment. With strict attention to image quality and signal processing performance, THX certification promises that these projectors are capable of presenting a wide range of video content at maximum resolutions with the correct color and luminance levels. In addition, THX has created a battery of signal processing tests that challenge the projector's scaling, motion conversion and de-interlacing capabilities. This type of in-depth analysis predicts how the projectors will present a variety of high definition and standard definition content.
These same four models also feature color management that interpolates colors individually by R, G, B, C, Y, or M, in three separate axes of color phase, chroma saturation and brightness. Up to three customized color settings can be stored for future use.
Features shared by all six new projectors include:
Three JVC-developed D-ILA devices (red, green, blue) for a naturally rich, flicker-free picture;
<LI>HQV Reon-VX video processor developed by Silicon Optix to ensure excellent image reproduction with precision I/P conversion and scaling;
<LI>A high-performance 1.4 - 2.8:1 zoom lens with motorized focus features a large diameter, all-glass lens system with 16 elements in 17 groups that includes an ED lens to project a full HD image with exceptional depth and minimal chromatic aberration;
<LI>Manual adjustment of the gamma curve via an on-screen display, allowing the viewer to adjust projector luminance levels by either increasing contrast in scenes that are too dark or dimming washed-out scenes to ensure precise brightness levels suited to individual preferences or viewing conditions. Up to three settings can be adjusted and stored for future use;
<LI>Flexible set-up with a ±80 percent vertical and ±34 percent horizontal motorized lens shift function that allows the projected picture to be moved horizontally or vertically via the remote control.
Other features include an external 12-volt trigger (not available on the DLA-HD550) that can be used to automatically raise and lower a screen or draw curtains, or it can be linked to engaging the V-Stretch mode and move an optional anamorphic wide screen lens system into place. Also, an automatic lens cover opens and closes with power on/off.
All six projectors comply with HDMI version 1.3 (Deep Color/CEC) specifications, which provide for billions of colors and reproduce subtler shades of grey, and CEC compatibility for system control.
The new JVC D-ILA projectors begin delivery in September, 2009 at the following prices: DLA-RS35/DLA-HD990: $10,000.00 DLA-RS25/DLA-HD950: $8,000.00 DLA-RS15: $5,500.00 DLA-HD550: $5,000.00 JVC Professional Europe (DLA-RS Modellerna)
Redigerat av Unregistered39429, 04 December 2009 - 17:21.
Postad 02 December 2009 - 19:55
Über-Guru
12561 inlägg
Härligt med mer mänskliga priser för oss dödliga Det högsta priset för alternativ modell bara 70.000kr
Postad 02 December 2009 - 22:40
Hybe
Hybe
1429 inlägg
Postad 03 December 2009 - 10:00
Sigma78
Sigma78
2014 inlägg
okej, kanske e sjyst på typ 1000" duk!
Och det är väl ungefär så stort det är på biograferna? För hemmabruk eller för oss 'amatörer' är det inte speciellt intressant, men för riktigt high-rollers som i princip bygger en riktig biosalong kan det nog bli en synbar skillnad från 1080. Sen kommer den lilla bagatellen att ha något att titta på i den upplösningen.... förutom stillbilder från sin digitalkamera.
Postad 04 December 2009 - 18:15
Hybe
Hybe
1429 inlägg
ajo, typ. blev en HD750 för mig igår, istället!
Postad 06 December 2009 - 00:48
Poppler
Poppler
183 inlägg
Minns att jag läste en artikel där en publik hade fått titta på en skärm med mycket hög upplösning med resultatet att många mådde dåligt ty hjärnan fick svårt att skilja på vad som är verkligt och inte... 4K på en vanlig duk hade varit coolt. Punkt.
Postad 12 May 2010 - 18:02
Unregistered39429
Unregistered39429
3116 inlägg
De finns ju 4K dukar tex "Screen exellence entractor"som är kompatibla med denna best för profisionella sammanhang...
Postad 12 May 2010 - 18:04
Über-Guru
12561 inlägg
Vad skulle såna monster dukar kosta måntro?
Postad 12 May 2010 - 18:09
Unregistered39429
Unregistered39429
3116 inlägg
tjahh du förmodligen närmre 100k än 50k skulle jag tippa.
Postad 12 May 2010 - 18:13
Unregistered39429
Unregistered39429
3116 inlägg
Postad 12 May 2010 - 18:14
Über-Guru
12561 inlägg
Det ser hyfsat dyrt ut, men har man en sån här projektor så lär duken vara det minsta problemet.
Postad 13 May 2010 - 08:19
Über-Guru
22892 inlägg
Större möjligheter till Panel Alignment så att man för första gången får riktigt, riktigt bra skärpa från en D-ILA projektor? Denna JVC har väl förövrigt en tvillingsyster iform av Meridan 810 Reference System. Den senare är ju även del i Meridians lilla hembio-paket, Ultimate Reference Movie System:   Hyffsat paket det där, tungt att man vackert får kompletera med en BD-lirare dock.  Poppler>> Minns att jag läste en artikel där en publik hade fått titta på en skärm med mycket hög upplösning med resultatet att många mådde dåligt ty hjärnan fick svårt att skilja på vad som är verkligt och inte...
Haha, vilket nonsens. Hjälp för bra bild, jag mår illa. Ang Screen Excellence så kan ni följa Ludvigs bygge med 4K-materialet här. Personligen har jag inte sett nån ljustransparentduk som ens är riktigt "2K ready" men kanske att EN4K är den första. Ska man inte ha ljudtransparent lär det finnas ett antal olika material som duger bra där t.ex. Studiotek 100 eller DaLite JKP Affinity lär vara funkis. Jajja, köper man denna proj lär man ha råd med konsulting runt duken oxå..
Postad 19 July 2010 - 19:24
Unregistered39429
Unregistered39429
3116 inlägg
Många är dom som vill sätta sina egna namn på JVC's projjar,undra varför?
Postad 30 March 2014 - 19:53
Unregistered39429
Unregistered39429
3116 inlägg
 Här är det världs premiär för nya proffsmodellen (med super hi-vision upplösning 8K, JVC DLA-VS4800: http://translate.goo...dla-vs4800.html
Postad 31 March 2014 - 18:58
Über-Guru
10990 inlägg
Var beställer man en sån??
Postad 31 March 2014 - 20:08
Unregistered39429
Unregistered39429
3116 inlägg
" An inquiry 商品に対するお問い合わせ先 Contact for goods株式会社JVCケンウッド ホーム&モバイル事業グループ 国内営業統括部 PJ部 JVC KENWOOD Corporation Home & Mobile Business Group Domestic Sales Division PJ sectionTEL : 046-836-7303 〒239-8550 神奈川県横須賀市神明町58番地7久里浜技術センター 7 58 address Kurihama Technology Center 046-836-7303 〒 239-8550 Yokosuka, Kanagawa Prefecture Shinmeicho town: TEL"
Postad 01 April 2014 - 19:58
Über-Guru
10990 inlägg
Ahh tack förstod precis eller inte
Postad 02 April 2014 - 07:15
Über-Guru
22892 inlägg
Meh, bara 4K och e-shift ju.
Postad 02 April 2014 - 22:14
Jokkmokksjocke
Jokkmokksjocke
2384 inlägg
Finns två av den äldre modellen utan E.shift på KTH
Projektorer
VM på nya AppleTV
