Emotiva XDA-1 - High Performance External DAC
113 svar till detta ämne
Postad 12 October 2010 - 06:47
marcus_ec
marcus_ec
1051 inlägg
Hejsan Vad tror ni om denna? http://emotiva.com/xda1.shtmhttp://emonatics.com/XDA-1.shtmlThe XDA-1 Differential Reference™ balanced 24Bit/192kHz DAC/Digital Preamp represents a stunning achievement in sonic performance. Designed around the acclaimed Analog Devices AD1955 DAC operating in a fully differential mode, its differential output is then coupled to a digitally controlled, lossless volume control stage. The output of this stage then drives our fully discrete, cross coupled, Differential Reference™ balanced line amp stage. The result is breathtaking. In addition to being a state of the art 24Bit/192kHz DAC, the XDA-1 can operate as a digital preamplifier and source selector in a digitally based reference level audio system. Inputs for up to six digital sources including AES/EBU, USB, Coax, and Toslink are available. The XDA-1 incorporates a VFD display for volume, input select, and system status messages. In addition, it is supplied with a milled aluminum remote control for convenient operation. The XDA-1: transcendent. Signal-to-Noise Ratio: > 105dB (A-Weighted) Frequency Response: 5Hz - 48kHz THD+N: 0.001% Ground Floor Noise Level: < 15uV Nominal Output Voltage: 1V RMS Peak Output Voltage: > 12VRMS (balanced) Sample Rate: All standard resolutions are supported up to 192kHz Bit Depth: Standard bit dephts up to 24Bit are supported at clock frequencies up to 192kHz Inputs: 2 Optical TOSLINK, 2 COAX Digital, 1 AES/EBU, 1 USB Outputs: 2 RCA (Unbalanced), 2 XLR (Balanced) Internal Volume Control: Digitally controlled in increments of 0.5db Remote Control: Milled Aluminum Full Function Remote Control I/V conversion: Burr Brown OPA-2134 D/A conversion: high performance, multibit Sigma-Delta Burr Brown AD1955 Data Directed Scrambling with high jitter immunity, and an 8x Oversampling Digital Filter Fully Discrete Differential Reference™ Output Stage with fully independent balanced and unbalanced drive stages
Redigerat av marcus_ec, 12 October 2010 - 06:48.
Postad 12 October 2010 - 07:51
Corpze
Corpze
542 inlägg
Chippet verkar vara bra, enligt någon på Hifi-forum så sitter samma dac-chip i Cambridge Azur 840C (Cd-spelaren). Hittar dock ingen mer referens :/
Postad 12 October 2010 - 08:22
Unregistered1254
Unregistered1254
5090 inlägg
Den presterar troligtvis väldigt bra med tanke på andra produkter från dem. Men har den en volymkontroll? Det är alltså inbyggt försteg i den?
Postad 12 October 2010 - 08:25
marcus_ec
marcus_ec
1051 inlägg
Alltså hur funkar volymkontrollen på en DAC när man redan har en reciever med extern slutsteg?
Mafix var snabbare
Redigerat av marcus_ec, 12 October 2010 - 08:27.
Postad 12 October 2010 - 08:32
Corpze
Corpze
542 inlägg
Mafix var snabbare
Om du inte vill använda den volymkontrollen kan man säkert sätta den i "fixed" eller så sätter man den i +/- 0 manuellt, då varken dämpar eller höjer den signalstyrkan. + i kanten för fjärr till en dac, saknar det på min DacMagic!
Postad 12 October 2010 - 08:39
Unregistered1254
Unregistered1254
5090 inlägg
Jag är lite emot det här med flerfunktionalitet. De hade kunnat skippa försteget.
Postad 12 October 2010 - 09:05
Corpze
Corpze
542 inlägg
Tur att vi är olika, jag gillert!
Postad 12 October 2010 - 09:12
Unregistered1254
Unregistered1254
5090 inlägg
Fjärrkontroll hade inte varit dumt visserligen. Det saknar jag på min DAC.
Postad 12 October 2010 - 09:18
marcus_ec
marcus_ec
1051 inlägg
Tänk om de haft en HT-pass
Postad 12 October 2010 - 09:22
Unregistered1254
Unregistered1254
5090 inlägg
Det skulle väl inte ge någonting på en DAC/försteg?  Bara att höja volymer till max eller stänga av volymkontrollen.
Postad 12 October 2010 - 11:32
marcus_ec
marcus_ec
1051 inlägg
typ slutsteg --> dac/försteg -->HTpass --> reciver
Postad 12 October 2010 - 11:35
joakim99
joakim99
3433 inlägg
Då skulle du behöva ha analoga ingångar och det är nog inte så vanligt på en DAC. Det vore mer passande med ett försteg med inbyggd DAC i sådana fall.
Postad 12 October 2010 - 12:03
bran
bran
1033 inlägg
Försteget låter säkert bra, och hade jag bara haft en tvåkanalare kopplad till datorn vore det ju skitsmutt att bara köra XDA-1 direkt till ett XPA-2.
Postad 12 October 2010 - 12:15
marcus_ec
marcus_ec
1051 inlägg
Hade varit guld!
Postad 12 October 2010 - 12:24
LTMS
LTMS
845 inlägg
Med det priset verkar den vara i Hegels klass, de flesta Emotivas produkter brukar jämföras med saker som kostar fyra gånger så mycket
Postad 12 October 2010 - 14:13
Unregistered9d9405bb
663 inlägg
Kan man verkligen generalisera så? Vore ju bra om det var så men jag har svårt att tro att man kan anta att nya produkter ifrån en tillverkare ska jämföras med 4 ggr så dyra produkter.
Postad 12 October 2010 - 16:10
Unregistered1254
Unregistered1254
5090 inlägg
Då blir det inte en DAC utan en ADC. Vad tusan ska du med DAC:en till? Du verkar ju inte behöva den!
Postad 12 October 2010 - 16:14
LTMS
LTMS
845 inlägg
Det är så som det jämförs och skrivs om deras produkter i tester mm, obs, det är inte jag som antyder detta
Postad 12 October 2010 - 16:28
Unregistered2ef9a1b1
546 inlägg
Oavsett vem som skrivit vad så kan jag bara intyga med ett stort plus när det gäller slutstegen. Ska bli kul att testa vad resten av sortimentet går för:) T ex om XDA-1 är bättre än ERC-1 som det påstås.
Redigerat av Unregistered2ef9a1b1, 12 October 2010 - 18:36.
Postad 20 October 2010 - 20:34
Unregisteredb4fce5a7
322 inlägg
Volymkontrollen är integrerad i den digitala domänen, alltså ej som i ett "vanligt" försteg där volymen regleras analogt efter D/A omvandlingen.
Postad 20 October 2010 - 21:39
Unregistered1254
Unregistered1254
5090 inlägg
Aha, hm. Varför förstöra datan? I så fall kan jag väl förstöra signalen direkt i datorn och skicka den icke-bitkorrekt till DAC:en?
Postad 21 October 2010 - 10:27
322 inlägg
Så sant så, men ett bra försteg och dac är nog ganska svårt att få för det priset, får väll se de mest som ett komplement.. Läst lite på Emotivas forum där det pratas endel om hur digitala volymkontroller förstör ljudet och det svar man får från tillverkaren är något i stil med: Att det aldrig var tänkt att ha volymkontroll på dac:en, utan när dom gjorde testerna och kopplade cd --> dac--> förförstärkare --> slutsteg (obs deras egna produkter) så tyckte dom tydligen att dom inte fick det lyft dom hade hoppats på och därefter aktiverade den digitala volymkontrollen som tydligen redan fanns i D/A chippet, och därefter fick dom det lyft i ljudet som dom var ute efter. Detta betyder ju som sagt att man inte kan få bättre ljud med en exklusivare/bättre förförstärkare. Tror att dac:en samplar upp till 24bit och därefter tar bort dom när man sänker ljudet (som en vanlig digital-volynkontroll) och påstår då att det inte ska ge någon förlust i upplösning/ljudkvalitet efter som enda gången man kommer under 16bit (cd kvalitet) är på riktigt låga volymer, dock finns det ju musik med 24bit. Detta är något som verkar bli vanligare och vanligare med åren. Lyngdorf och nu även Nad med deras nya värsting maskin M2 m.m. funkar ju på liknande sätt vad jag har förstått (rätta mig om jag har fel)
Redigerat av Unregisteredb4fce5a7, 21 October 2010 - 10:29.
Postad 21 November 2010 - 03:37
546 inlägg
Här är en länk till en tråd som annars gett mig mest kött på benen angående XDA-1: http://www.chasehome...w...2575&page=3Ger bäst resultat om man kopplar direkt till slutsteget. Tar emot upp till 24p/192 khz via USB. Står dock att de behövde uppdatera mjukvaran för att kunna maxa till 24 p. Väcker en del frågor om hur det blir i praktiken. Hur vet jag att min dator presterar 24p/192 khz genom usb porten? Kör för närvararande med hdmi till tv:n som omvandlar och sen vidare med rca till mitt analoga försteg/förstärkare. Kommer jag uppleva en förbättring genom att använda mig av en DAC genom usb porten/optisk utgång på datorn som är kopplad direkt till förstärkare jämfört med hur jag kopplar nu? Dvs skippa tv:n i signalkedjan med en DAC. Jag har en Toshiba Satellite A500D med Windows 7 som jag har kopplad till en Sharp 705.
Redigerat av Unregistered2ef9a1b1, 21 November 2010 - 15:47.
Postad 21 November 2010 - 10:55
metalfan
metalfan
46 inlägg
En väldigt bra dac med inbyggd preamp, analoga ingångar, usb, hörlursuttag, optisk och coax är NuForce Icon HDP. Tyvärr ingen fjärr men annars grym för sitt pris. Vore kul att jämföra dessa två.
Postad 21 November 2010 - 15:59
546 inlägg
Ok, den verklar onekligen intressant. XDA-1 blir trots lite billigare (kanske någon tusenlapp) + att jag får en fjärr.
Hmmm att jämföra dessa två blir svårt/lite opraktiskt om du inte eventuellt inte bor nära, äger en sådan och jag har XDA-1 hemma. Om du förstås inte själv skaffar en.
Min fråga vara dock inte vilken DAC jag skall använda utan OM.
Alltså om det är bättre än att skicka ljudet genom hdmi och sedan omvandla det till analog signal i tv:n.
Någon som jämfört?
Redigerat av Unregistered2ef9a1b1, 21 November 2010 - 16:00.
Postad 21 November 2010 - 16:06
LTMS
LTMS
845 inlägg
[quote name='jonte83' post='3094810' date='Nov 21 2010, 15:59 ']Ok, den verklar onekligen intressant. XDA-1 blir trots lite billigare (kanske någon tusenlapp) + att jag får en fjärr. Hmmm att jämföra dessa två blir svårt/lite opraktiskt om du inte eventuellt inte bor nära, äger en sådan och jag har XDA-1 hemma. Om du förstås inte själv skaffar en. Min fråga vara dock inte vilken DAC jag skall använda utan OM. Alltså om det är bättre än att skicka ljudet genom hdmi och sedan omvandla det till analog signal i tv:n. Någon som jämfört? HÄR KOMMER MITT INLÄGG Det blir otroligt mycket bättre med en dac, tom din mor  lär höra klar skillnad, inget ont om din mor dock, du förstår säkert vad jag menar
Redigerat av LTMS, 21 November 2010 - 16:07.
Postad 21 November 2010 - 16:10
546 inlägg
Hehe jo hon hör nog skillnad. Frågan är om min farmor gör det
Jo, du har övertygat mig gällande DAC. Nu återstår förutsättningarna som ska till för att DAC:n ska kunna ge maximalt resultat.
Kommer mitt usb/spdif skicka 24p/192 khz?
Redigerat av Unregistered2ef9a1b1, 28 November 2010 - 22:41.
Postad 28 November 2010 - 20:30
546 inlägg
Nu borde många ju ha fått sitt exemplar från Emotiva.
Feedback?
Redigerat av Unregistered2ef9a1b1, 29 November 2010 - 17:49.
Postad 29 November 2010 - 21:29
warp56
warp56
140 inlägg
Det börjar skickas ut idag enligt mejlet jag fått från Sarah!
Postad 30 November 2010 - 18:10
546 inlägg
Har riktig oflyt, jag resververade för två veckor sedan och fick reda för ett par dagar sedan att allt redan var utsålt. Nästa omgång kommer in första kvartalet 2011
Högtalarna bör jag i alla fall få för de är reserverade sedan 2 november.
warp56, när reserverade du din?
Postad 30 November 2010 - 18:44
palletheking
palletheking
289 inlägg
Hehe jo hon hör nog skillnad. Frågan är om min farmor gör det Jo, du har övertygat mig gällande DAC. Nu återstår förutsättningarna som ska till för att DAC:n ska kunna ge maximalt resultat. Kommer mitt usb/spdif skicka 24p/192 khz?
Tror inte USB skickar ut 247192. Då måste du nog ha en MTech2 Hiface emellan. Jag har det till min DAC, Music Fidelity M1 och det funkar bra.
Postad 30 November 2010 - 22:33
warp56
warp56
140 inlägg
12 oktober! Fick Fedex-info idag, leverans 8/12.
Postad 01 December 2010 - 13:10
Unregistered46986fd8
196 inlägg
Härligt  Min levereras 7'e december 18.00 enligt FedEx. Vi går i samma fotspår mr. Warp!
Postad 01 December 2010 - 22:01
546 inlägg
Är det frågan om ett köpprogram eller ett ljudkort? Hur skaffar jag det? Jag har Windows 7. Alternativet vore väl att använda spdif/digital utgång. Spotify Premium ska ju ha 320 kbps...
Postad 02 December 2010 - 06:38
warp56
warp56
140 inlägg
Börjar strömma in positiva intryck om denna dac nu på Emotivas forum!
Postad 02 December 2010 - 18:55
546 inlägg
Kollade upp MTech2 Hiface och verkar vara en adapter som ser ut att omvandla usb till spdif. Om jag nu redan har en sån utång på datorn så är det ju onödigt att använda usb utgången... Rätta mig om jag har fel.
Är det någon som jämfört att köra med spdif med 24 bit/192 khz som följd?
Redigerat av Unregistered2ef9a1b1, 02 December 2010 - 20:30.
Postad 02 December 2010 - 19:14
546 inlägg
Yep nu önskar man allt att man hade lådan hemma!
Postad 03 December 2010 - 22:34
warp56
warp56
140 inlägg
Snart så!  Paketet lämnat Paris! Blir lite test till nästa helg om allt går som det ska! Blir XDA-1 direktkopplat med RCA och XLR till UPA-1 samt XPA-1! Har även ERC-1 hemma för lite jämförelse! Har dock redan testat att köra ERC analogt då det sitter mkt fina dacar i den.
Postad 03 December 2010 - 22:43
palletheking
palletheking
289 inlägg
Kollade upp MTech2 Hiface och verkar vara en adapter som ser ut att omvandla usb till spdif. Om jag nu redan har en sån utång på datorn så är det ju onödigt att använda usb utgången... Rätta mig om jag har fel. Är det någon som jämfört att köra med spdif med 24 bit/192 khz som följd?
Kan inte tekniken särskilt bra, vet bara att det blir bättre om man kör med USB då den helt och hållet förmedlar ljudet oförstört, obehandlat. Det jag menar är att all D/A-omvandling sker i själva D/A-omvandlaren dit ljudet från datorn transporteras.
Redigerat av palletheking, 04 December 2010 - 07:44.
Postad 04 December 2010 - 11:21
546 inlägg
Ok, vem säljer omvandlaren och vad kostar den?
Postad 04 December 2010 - 11:34
palletheking
palletheking
289 inlägg
Finns på lefflers Hifi och hemmabio, kostar 1500 kr. Kräver också en Spdif-kabel som jag har, en ny till fösäljning ifall det lockar (Supra Trico). En helt ok kabel. Hiface är ett mycket prisvärt och bra tillbehör. Tror själva iden är lite av framtiden då det hjälper till att få ut prestandan hos det man tidigare benämnde som DVD-audio, fast utan extra hårdvara förutom datorn. Det blir ett fantastiskt ljud med 24 bitar flac, sopar mattan med rippade CD-flac. En mycket större ljudbild med större närvarokänsla och bättre sterobild.
Postad 04 December 2010 - 12:08
546 inlägg
Kollade bland sålda märken då de inte har sökfunktion plus dac, usb osv och hittar inte MTech där. De säljer usb kabel för 2500(!!!) Nja.... lite tveksam till det övriga sortimentet då måste jag säga. Har själv lagt en hel del pengar i kabelträsket och upplevt ganska små förändringar.
Testar XDA-1 först för sig med de olika anslutningar som finns och befintliga kablar hemma. Blir det ingen natt och dag skillnad så kommer jag överväga MTech2 och andra lösningar.
Postad 04 December 2010 - 12:45
palletheking
palletheking
289 inlägg
Kollade bland sålda märken då de inte har sökfunktion plus dac, usb osv och hittar inte MTech där. De säljer usb kabel för 2500(!!!) Nja.... lite tveksam till det övriga sortimentet då måste jag säga. Har själv lagt en hel del pengar i kabelträsket och upplevt ganska små förändringar. Testar XDA-1 först för sig med de olika anslutningar som finns och befintliga kablar hemma. Blir det ingen natt och dag skillnad så kommer jag överväga MTech2 och andra lösningar.
De har en hel del produkter som inte finns på hemsidan. Jag köpte min hos dem för bara några dagar sedan. Vad gäller kablar så kanske inte skillnaderna alltid motsvarar prisgapet, men nog blir det bättre med bra kablar. Hade alldeles nyligen själv en dyrare USB-kabel och jag upplevde en ganska stor skillnad jämfört med en billigare. Har också uppgraderat spdif och där blev skillnaden riktigt stor. Men jag köpte en riktigt dyr och fet variant så det var inte så konstigt. Nu när mitt system känns komplett så är det ström och kablar man får inrikta sig på. Tyvärr nästan lika dyrt som det andra. Hifi är härligt men dessvärre också förbannat dyrt.
Postad 06 December 2010 - 16:03
196 inlägg
Sådär, nu har min XDA-1 anlänt! Saknas dock kablar som kommer trilla in imorgon eller övermorgon. Återkommer med intryck och bilder så fort jag fixat tillbaka min kamera
Kommer köra PS3'an som transport, optiskt ut. Sen balanserat till mina monoslutsteg, också från Emotiva.
Postad 06 December 2010 - 16:48
546 inlägg
Ps3 låter mycket smidigare att använda om man bortser från Spotify som streamar... kanske går det att streama Spotify genom PS3?
Postad 06 December 2010 - 17:35
196 inlägg
Kanske går, vet att någon har testat. Dock verkar det inte vara helt optimerat. Jag kör PS3'an som mediasever och tar all musik genom den, tills jag orkar skaffa en 10m lång optisk kabel för att köra direkt från ljudkortet.
Postad 06 December 2010 - 17:40
warp56
warp56
140 inlägg
Riktigt intressant! Väntar själv spänt på min men det tar nog någon dag eller 2 till!? Glöm inte skruva ner volymen bara, men det har du förmodligen redan läst.
Postad 06 December 2010 - 17:52
196 inlägg
Drygt att behöva vänta, nästan mer frustrerande när man har den hemma men saknar kablar så man kan provspela. Köpte en strömkabel idag, man verkar inte kunna fixa med volymen och liknande utan att ha en källa inkopplad, den slås igång och reagerar på 240V, men displayen är kolsvart. Volymen skall jag inte glömma, kommer skicka konerna i omloppsbana runt jorden annars
Postad 06 December 2010 - 17:54
Ala_95
Ala_95
1376 inlägg
Ser spännande ut.
Så det skulle gå bra att köra: Dator - XDA-1 - Slutsteg?
Priset var ju inte skyhögt heller...
Postad 06 December 2010 - 17:57
546 inlägg
Word
Media & Mediauppspelning
Bild/Ljuduppspelning (Övriga format & Vintage)
Titan Noir Max
LFE reference och Center ch
