AMD Llano
86 svar till detta ämne
AMD A-Series A8-3850 2,9GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
4
(2)
Inga priser |
AMD A-Series A8-3850 2,9GHz Socket FM1 Tray
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
AMD A-Series A6-3650 2,6GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
1
(2)
Inga priser |
AMD A-Series A6-3650 2,6GHz Socket FM1 Tray
(Processorer (CPU))
Rapporterad
0
(0)
Inga priser |
ASRock A75M-ITX
(Moderkort)
Rapporterad
4
(1)
Inga priser |
AMD A-Series A8-3800 2,4GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
AMD A-Series A6-3600 2,1GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
AMD A-Series A6-3500 2,1GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
2
(4)
Inga priser |
Asus F1A75-I Deluxe
(Moderkort)
Rapporterad
6
(3)
Inga priser |
AMD A-Series A4-3400 2,7GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
1
(1)
Inga priser |
AMD Fusion A4-3400 2,7GHz Socket FM1 Tray
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
AMD A-Series A4-3300 2,5GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
2
(0)
Inga priser |
AMD A-Series A4-3300 2,5GHz Socket FM1 Tray
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
Zotac A75ITX-A-E
(Moderkort)
Rapporterad
6
(0)
Inga priser |
AMD A-Series A8-3870K 3,0GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
2
(5)
Inga priser |
AMD A-Series A8-3870K 3,0GHz Socket FM1 Tray
(Processorer (CPU))
Rapporterad
3
(0)
Inga priser |
AMD A-Series A6-3670K 2,7GHz Socket FM1 Box
(Processorer (CPU))
Rapporterad
1
(2)
Inga priser |
AMD A-Series A6-3670K 2,7GHz Socket FM1 Tray
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
AMD A-Series A10-5800K 3,8GHz Socket FM2 Tray
(Processorer (CPU))
Rapporterad
0
(0)
Inga priser |
AMD A-Series A10-5800K 3,8GHz Socket FM2 Box
(Processorer (CPU))
Rapporterad
1
(5)
Inga priser |
AMD A-Series A10-5700 3,4GHz Socket FM2 Box
(Processorer (CPU))
Rapporterad
1
(1)
Inga priser |
AMD A-Series A10-5700 3,4GHz Socket FM2 Tray
(Processorer (CPU))
Rapporterad
1
(0)
Inga priser |
1 relaterade trådar
Postad 31 August 2011 - 22:27
Davye
Davye
103 inlägg
Såg ingen tråd här om just Llano förutom en om A8-3850 så jag hoppades på att kunna sätta igång en som samlar lite tankar om dessa. Är mycket sugen på att sätta ihop en HTPC med någon av dessa processorer. Trodde att dom skulle gå lägre i strömförbrukning än vad dom gjorde men samtidigt är det inte så illa sett till vad man får på köpet genom att det är en APU. Hade först ögonen på Sandy Bridge + deikerat eller E350 men har mer och mer kommit in på Llanospåret. CPUn i ska tydligen vara uråldrig men att GPUn gör att den presterar väldigt bra mot i prisklass liknande processorer. Har försökt att sätt mig in i om den kan vara värd att satsa på men jag får nog vänta och se vad bättre vetande har att säga innan jag börjar agera.  Jag har väl i första hand siktat in mig på m-ITXkorten eftersom jag gärna vill ha en ganska liten låda. Men jag ska väl erkänna att jag kollat på allt från monsterlådor till picoliknande utan att bli riktigt klok på vad jag egentligen behöver/vill ha.
Det lutar åt ASUSkortet som ser ut att börja ramla in så sakteliga under den här månaden. Kontrollen som kommer till verkar väldigt intressant men lite osäker på hur det blir med åäö på qwerty-sidan...
Alternativet än så länge är väl det något billigare Asrockortet.
Genomgång av de båda från Sweclockers. http://www.sweclocke...asrock-a75m-itxVad tror ni behövs för att driva dessa processorer? Såg att någon hade en 3650 med en 120W nätag. Känns som lite i klenaste laget även om man undervoltar och underklockar och allt vad det heter. Han verkade dock väldigt nöjd med den i jämförelse med E350:an. TDP på dom två första som kommit är ju 100W kontra 65W på de senare. Jag skulle vilja ha en av de 65W:arna i en Silverstone Lascala LC19B men är lite osäker på värmen i ett så lågt chassi och så klart hur nätaget står sig.
edit: kontentan av det hela var väl att jag var intresserad av att höra era åsikter om den här serien. Speciellt dom som redan testat hur den funkar och vad som kan vara bra att tänka på.  edit2: glömde lite edit3: la till A4 dual core
Redigerat av Davye, 05 September 2011 - 13:46.
Postad 01 September 2011 - 01:59
janeee
janeee
612 inlägg
Det fungerar kanske bra med Silverstone Lascala LC19R om du väljer 65watt Llano och SSD eller 2.5 tum HDD men det stora problemet är att hitta någon lämplig CPU (APU) kylare som får plats i det extremt låga chassit, jag misstänker att även stockkylaren som följer med Llano är för hög.
Jag har spanat lite på Prisjakt och hittat några lämpliga komponenter som även du kanske gillar.
Anledningen till att jag väljer A8-3800 2,4GHz är att den producerar mindre värme än A8-3850 och det gör datorn tystare eftersom processor fläkten förhoppningsvis kan gå på lägre varvtal.
Redigerat av janeee, 01 September 2011 - 02:19.
Postad 01 September 2011 - 10:04
Luxembourg
Luxembourg
13 inlägg
Jag börjar komma allt närmare beslut och det blir nog en AMD A8, främst med tanke på den integrerade kvicka grafiken i förhållande till priset och strömförbrukningen. Moderkortet från Asus verkar riktigt bra då det mesta är integrerat och vad jag har läst mig till får man bättre prestanda upp till 1600 minnen.
Tänkte stoppa in det hela i lådan Antec Fusion och letar nu efter tv-kort som stöder dvb-s och ca modul för kanal digital.
Postad 01 September 2011 - 16:28
Davye
Davye
103 inlägg
Ja Silverstone Milo Slim ML03B har jag kollat på också men jag tvekar kring fronten som ska vara av plast tyckte jag jag läste. Gillar om det är en slät och stilren front med så lite grejer som möjligt synliga. Den här gillar jag också men den verkar vara dåligt med seriösa återförsäljare. Vet inte hur mycket det går att lita på Proshop...
edit: också plastfront på den såg jag nu men ser inte lika plastig ut... på bild iallfall...
Det smartaste jag kom fram till när det gäller Silverstone Lascala LC19B var att köpa en lågprofilfläk/heat sinkt och byta ut själva fläkten som sitter på till typ en sån här kanske.
Vad drar en 3.5" HDD måntro... kontra 2,5:a...
Redigerat av Davye, 01 September 2011 - 19:07.
Postad 01 September 2011 - 18:57
Mattiasz
Mattiasz
39 inlägg
Hej. Angående chassiet nedanför så passar fläkten som följer med en 3850.
Rekommenderar att du byter eftersom den fläkten inte var så tyst som man kan kräva av en htpc. Angående chassit så är det en aning plastigt på framsidan men tycker inte det stör direkt. Se mitt galleri för lite bilder från bygget. Galleri
Postad 01 September 2011 - 19:14
Davye
Davye
103 inlägg
Galleri
Ja det kan kanske bli det chassit istället eftersom jag har en Be-Quiet Dark power som ligger och skräpar i källaren... känns dok som lite mycke till en HTPC... vill egentligen ha så strömsnålt som möjligt. Härligt med ett galleri att kika i!
Redigerat av Davye, 01 September 2011 - 19:15.
Postad 01 September 2011 - 19:36
janeee
janeee
612 inlägg
Det var inte lätt att hitta bra tester som jämför strömförbrukning på 2.5 tum och 3.5 tum HDD men här en test på 2.5 tum HDD http://www.silentpcr...1071-page4.htmlOch här en test på Eco Green 5400rpm HDD http://www.silentpcr...1076-page4.htmlNär det gäller vanliga 3.5 tum 7200rpm så kan man nog räkna med mellan 8-10watt.
Postad 01 September 2011 - 20:00
Davye
Davye
103 inlägg
Tacka och bockar! edit: En 65w APU + en 3.5" green känns ju inte helt fel då med en 120w PSU...
Redigerat av Davye, 01 September 2011 - 20:06.
Postad 01 September 2011 - 20:45
janeee
janeee
612 inlägg
Tacka och bockar!
En 65w APU + en 3.5" green blir cirka 70watt och sedan har vi moderkort 5-10watt, ram minne 2-4watt ca 2watt för varje fläkt, DVD/Bluray spelare kanske 5watt det blir totalt ca 90watt så det kommer nog att fungera med ett 120watt nätaggregat. Om jag har räknat fel så får ni gärna rätta mig.
Postad 01 September 2011 - 23:06
spelevinken
spelevinken
1417 inlägg
Det är ju inte så att bara för att du har ett aggregat på ett visst wattantal så drar det inte det om komponenterna i andra änden inte behöver det. Det som spelar roll är hur effektiva aggregaten är och det är här brons, guld silver etc kommer in i bilden. Kikar du på nätagg på prisjakt så ser du att det är valbart med dessa kategorier. Således kan du ha nätagg på flera megawatt (kanske lite överdrivet  ), det som spelar roll är hur effektivt det är. Sen måste jag ju även flika in att i en htpc behöver man kanske inte tänka för "grönt", det är ju inte så att den är igång 24/7.
Postad 02 September 2011 - 00:13
janeee
janeee
612 inlägg
Jag ser att det även finns en färdigmonterad HTPC med AMD Llano A6-3650 och ASRock A75M moderkortet för 4100kr
Postad 02 September 2011 - 16:59
Davye
Davye
103 inlägg
Ja jo det är klart men risken är att jag då istället trycker lådan full med grejer om strömkapaciteten finns...  håller jag det minimalt så stannar det kanske så också i framtiden. Men en gaming/HTPC skulle kanske va kul det med. Jag ser att det även finns en färdigmonterad HTPC med AMD Llano A6-3650 och ASRock A75M moderkortet för 4100kr
Intressant... kan ju vara ett alternativ...
Postad 03 September 2011 - 12:48
Davye
Davye
103 inlägg
Blir nog att jag kopierar ditt förslag. Verkar vara ett fint alternativ.  tänkte dock ev. köra med Lian Li PC-C37B Muse. Är väl priset som man tvekar över då det chassit kostar mer än dubbelt så mycket men det faller mig mer i smaken är milo.
Sen tänkte jag att jag skulle ta och byta ut CPU-fläkten till Scythe Big Shuriken istället. I alla fall om jag kör på Lian li chassit då jag tror det är lite tajt på höjden där. Har ju ett tag att fundera då 3800:an verkar komma in som tidigast i början av nästa månad. Vad för minne ska man köra på ASUS mobot tro? La in dom här i min lista men jag vet inte riktigt.
Postad 03 September 2011 - 14:47
janeee
janeee
612 inlägg
Lian Li PC-C37B Muse är både snyggare och troligen även bättre eftersom Lian Li brukar ha mycket hög kvalitet men den var som sagt mycket dyr. Det finns ännu ingen Memory Support List från Asus för Asus F1A75-I Deluxe men jag tror att Corsair Vengeance Low Profile DDR3 PC12800/1600MHz CL9 2x4GB passar bra för modekortet. Jag kan även lägga till att Scythe Big Shuriken är nog bättre och även 6mm lägre men den passar inte om du vill stoppa in ett kort i PCI-E slottet på Asus F1A75-I Deluxe eftersom APU sockeln sitter så nära, men om man väljer ASRock A75M-ITX så kommer nog Scythe Big Shuriken fungera bra.
Redigerat av janeee, 03 September 2011 - 14:51.
Postad 03 September 2011 - 18:04
Davye
Davye
103 inlägg
Ok bra att veta tackar! Några andra förslag på bra CPU-fläktar till Lian li-chassit annars? Eller är det den bästa i det här fallet? Inte så att jag är helt låst vid Scythe bara att man har lite förkärlek från min gamla Scythe Ninja...
Postad 03 September 2011 - 18:57
janeee
janeee
612 inlägg
Jag gjorde en sökning på alla CPU kylare som passar AM3 sockel och är max 70mm hög https://www.prisjakt...amp;l=s75295375Och då hittade jag en ny CPU kylare från Scythe
Jag tror att Scythe Kozuti passar mycket bra i Silverstone Lascala LC19R chassit. Edit: Silentpcreview har testat Scythe Kozuti http://www.silentpcr...m/scythe-kozuti
Redigerat av janeee, 03 September 2011 - 19:41.
Postad 03 September 2011 - 19:39
Davye
Davye
103 inlägg
Inte säker men jag tror den är 3mm för stor/hög för Lascala LC19... tyckte jag läste det. Men någon får gärna motbevisa mig...  edit: men den skulle kanske vara ett bra alternativ för Lian li-chassit som jag tittade på eftersom Scythe shuriken var för hög(eller i alla fall precis på gränsen) och Big shuriken för bred för expansionskort. Fast det sitter en 80mm fläkt i den som kanske måste gasa lite mer än dom större Scythe. Förhoppningsvis inte störande... sen funderar jag även på hur det går med att få plats RAM-minnena då kylaren sitter lågt.
Redigerat av Davye, 03 September 2011 - 21:23.
Postad 03 September 2011 - 22:45
janeee
janeee
612 inlägg
Jadu det var inte lätt att reda ut, både moderkort och CPU kylare är helt nya så ingen hunnit köpa eller testat dom så vi får använda ögonmåttet och sedan gissa om det passar eller ej. Om man tittar i Mattiasz galleri på bilden längst ner så ser man Scythe Big Shuriken 125 × 58 × 135 mm har några millimeter marginal, Scythe Kozuti 110 × 40 × 103 mm är mycket mindre men är åxo lägre. Kolla på bilden längs nere i Mattiasz galleri https://www.minhembio.com/Mattiasz han använder ett helt annat moderkort men ram minnet är nog lika hög som Corsair Vengeance Low Profile
Redigerat av janeee, 03 September 2011 - 22:48.
Postad 03 September 2011 - 23:01
Davye
Davye
103 inlägg
Känns som det kan gå. Funkar ju på bilden med ASRock H67M-ITX men den har ju också socket 1155 och verkar fästas med "piggarna" från heat pipes på ett annat håll. Mot expansionsfacket istället för mot minnena... blir väl någon som får vara försökskanin och testa helt enkelt.
Postad 03 September 2011 - 23:49
janeee
janeee
612 inlägg
Enligt silentpcreview testet på Scythe Kozuti så skall man skruva bort plastfästet för CPU kylaren på alla AMD moderkort och använda enbart fästet som Scythe skickar med kylaren och då ser det ut så här på ett AMD 785G moderkort  Länk till sidan där Silentpcreview monterar Scythe Kozuti på ett AMD moderkort med AM3 socket http://www.silentpcr...1209-page3.htmlHär är moderkortet Asus M4A785TD-V EVO som Silentpcreview använder när dom testar Scythe Kozuti https://www.prisjakt...kt.php?p=462580
Redigerat av janeee, 04 September 2011 - 00:31.
Postad 04 September 2011 - 09:10
Davye
Davye
103 inlägg
Ok det går att välja vilket håll man vill ha den på... va bra! edit: Den verkar dock låta ganska bra... 32,50dB på papperet/50dB i verkligheten vid 3500rpm läste jag. Går dock att sätta en 100mm fläkt uppe på istället vilket kanske sänker ljudnivån lite. edit2: Fast det är kanske inte så ofta man är uppe i max fläkthastighet.
Redigerat av Davye, 04 September 2011 - 09:36.
Postad 04 September 2011 - 09:46
Davye
Davye
103 inlägg
Dual core A4-3400 och A4-3300 på gång också.
edit: http://www.nordichar...tationaera.html
Redigerat av Davye, 09 September 2011 - 12:58.
Postad 05 September 2011 - 09:39
Lincoln1986
Lincoln1986
7 inlägg
Såhär har jag tänkt mig: https://www.prisjakt...kt.php?p=951688http://www.inet.se/k...isa/828181/htpc (funderar dock även jag på 2.6ghz proc istället!) Enda jag velar över är processorkylare... Nån som har koll på vad som kan passa till detta?
Postad 06 September 2011 - 22:21
Davye
Davye
103 inlägg
Har inget bra förslag men det går ju alltid att söka på prisjakt efter kylare lägre än den maximala höjden. Står såhär på Silverstones hemsida om Gradia GD05: Limitation of CPU cooler: 70mm (remove ODD if you want install up to 120mm)Så man får ju plats med rätt rejäla kylare om man inte kör någon DVD/BD men det hade väl inte du tänkt så då finns ju t.ex dom vi tittat på här tidigare som Scythe Shuriken. Men som sagts tidigare är det svårt att veta vilken som kan funka bra utan att komma i vägen för antingen expansionsfack eller minnesplatser. Just nu lutar det åt Scythe Shuriken för min del eftersom den verkar få plats i Lian li chassit trots allt. Men jag har också kollat på några Zalmanfläktar. Såg förresten att Komplett hade fått in några ASUS mobo nu.
Postad 08 September 2011 - 19:56
Davye
Davye
103 inlägg
Modell A8-3870K A8-3850 A6-3670K A6-3650 Kodnamn Beavercreek Beavercreek Beavercreek Beavercreek Kärnor 4 4 4 4 Upplåst multipel Ja Nej Ja Nej Frekvens 3,0 GHz 2,9 GHz 2,7 GHz 2,6 GHz Turbo - - - - L2-cache 4 x 1 MB 4 x 1 MB 4 x 1 MB 4 x 1 MB Grafik HD 6550D HD 6550D HD 6550D HD 6550D Radeon-kärnor 400 400 320 320 Frekvens (GPU) 600 MHz 600 MHz 443 MHz 443 MHz Minnesstöd 1866 MHz 1866 MHz 1866 MHz 1866 MHz TDP 100W 100W 100W 100W Lanseringsdatum Q4 Ute nu Q4 Ute nu http://www.nordichar...modellerna.html
Postad 09 September 2011 - 12:54
Davye
Davye
103 inlägg
Undrar om det kommer gå att programmera in så man kan skriva ÅÄÖ på asusremoten som kommer med Asus F1A75-I Deluxe... känns som att jag i alla fall inte har så mycket användning för den utan svenska tangenter. Sökt lite på det men har inte hittat något vettigt. Enbart sidor på andra språk(t.ex spanska Ñ) som frågar samma sak. Skulle vara intressant att veta om det går att få till på något sätt. Medan jag skrev så kollade jag lite närmare på bilder av tangentbordet och såg att det går att skriva Ñ eftersom den knappen finns till vänster om space-knappen. Men möjligheter att kombinera ihop nordiska bokstäver på liknande sätt verkar inte finnas på dom bilder jag sett. http://www.campuseli...remote-back.jpgInte för att jag tänkt skriva några långa memoarer på asusfjärren men grejen med den som en smidig helhetslösning försvinner lite om jag måste ha ett tangentbord till som komplement. Men men man kan inte få allt... fast då blir det nog kanske istället att köpa ett Asrockmobo + trådlöst tangentbord. Kanske en sån här:
Men jag hoppas ju mest på asusremoten så om någon vet om det finns någon lösning på att få nordiska tangenter skulle jag vara tacksam. Dock så har ju moderkortet inte varit ute så länge än så det kanske dröjer ett tag innan något svar finns.
Redigerat av Davye, 09 September 2011 - 13:03.
Postad 16 September 2011 - 11:25
Davye
Davye
103 inlägg
Och nu finns visst A4-3400 att beställa på en del ställen. Väntar dock på A8-3800 som jag tror blir den modell jag satsar på. Dual core-modellerna skulle varit intressanta om dom legat lite lägre i TDP. Kanske är dom lättare att undervolta och underklocka för att få ner TDPn... 65W för båda i originalutförande i alla fall.
Postad 16 September 2011 - 19:51
Unregisteredc96d6be8
Mega-Guru
7392 inlägg
Det beror väl helt på hur ofta den spelar in eller familjen kollar tv  Min är iaf igång rätt många timmar per dag och hoppar rätt ofta igång på nätter för att spela in något
Postad 16 September 2011 - 22:26
Davye
Davye
103 inlägg
Ramlade in en Taiwanes hos mig idag som hade rest ändå från södra Tyskland... mycket trevligt. Verkar trivas bra i hyllan tillsammans med de två gamla japanerna. Inte så mycket innehåll än dock tyvärr men det kommer så sakteliga. Kvalitetskänslan i chassit väldigt hög och jag är mycket nöjd med att det är som jag trodde det var. Enda jag inte riktigt vet vad jag ska göra med är 5,25"-uttaget eftersom jag inte har någon användning för DVD eller BD. Sätta dit en fläktkontroller kanske... https://www.minhembi...m/Davye/316510/ Har mer och mer börjat öppna för att köra på ett mATX-kort istället nu när jag har plats med det om nu fjärrkontrollen är den enda fördelen (för mig) med Asus F1A75-I Deluxe. Just kontrollen är en intressant liten sak som, vad jag förstått, inte kommer att kunna köpas separat. edit: Fast att köra mITX på FM1-socketen som ju enbart verkar bli en övergångsfas på ett år innan FM2 känns för mig mer framtidssäkert. Den dagen den ersätts kan den kanske bli en liten streaminglåda... t.ex... edit2: La till länk istället för bild
Redigerat av Davye, 19 September 2011 - 12:19.
Postad 18 September 2011 - 23:28
Davye
Davye
103 inlägg
Undrar om det kommer gå att programmera in så man kan skriva ÅÄÖ på asusremoten som kommer med Asus F1A75-I Deluxe... känns som att jag i alla fall inte har så mycket användning för den utan svenska tangenter. Sökt lite på det men har inte hittat något vettigt. Enbart sidor på andra språk(t.ex spanska Ñ) som frågar samma sak. Skulle vara intressant att veta om det går att få till på något sätt. Medan jag skrev så kollade jag lite närmare på bilder av tangentbordet och såg att det går att skriva Ñ eftersom den knappen finns till vänster om space-knappen. Men möjligheter att kombinera ihop nordiska bokstäver på liknande sätt verkar inte finnas på dom bilder jag sett. http://www.campuseli...remote-back.jpg Inte för att jag tänkt skriva några långa memoarer på asusfjärren men grejen med den som en smidig helhetslösning försvinner lite om jag måste ha ett tangentbord till som komplement. Men men man kan inte få allt... fast då blir det nog kanske istället att köpa ett Asrockmobo + trådlöst tangentbord. Kanske en sån här: Men jag hoppas ju mest på asusremoten så om någon vet om det finns någon lösning på att få nordiska tangenter skulle jag vara tacksam. Dock så har ju moderkortet inte varit ute så länge än så det kanske dröjer ett tag innan något svar finns. Intressant alternativ http://www.chill-inn...=22&products=46
Postad 19 September 2011 - 22:13
Davye
Davye
103 inlägg
XBMC och Linux verkar ju inte funka så bra tillsammans med Llano av det lilla jag hunnit läsa. En del ställen går det att läsa att det helt enkelt inte gå ihop alls. De enklare Zacate ska tydligen funka bra med XBMC men inte Llano... någon som vet/tror vad som kommer att hända där? Vore lite tråkigt att bränna möjligheterna till att köra XBMC genom Llano.
Postad 22 September 2011 - 12:18
Davye
Davye
103 inlägg
Nu har visst det preliminära datumet för 3800:an flyttats från 1:e okt till 31:e enligt butikerna på prisjakt... får man visst lägga dom här tankarna på is en månad till verkar det som. Var ju inte vad jag tänkt mig... https://www.prisjakt...kt.php?p=948337
Postad 23 September 2011 - 02:39
malajo
malajo
62 inlägg
Efter att ha läst denna tråden blev jag helt plötsligt sugen på att byta ut min HTPC.
En sån här dator borde väl inte ha några problem med att spela upp 1080p .mkv-filer eller?
Använder mest min HTPC till att titta på HD-film samt lyssna på internet-radio.
Postad 23 September 2011 - 16:31
Davye
Davye
103 inlägg
Efter att ha läst denna tråden blev jag helt plötsligt sugen på att byta ut min HTPC. En sån här dator borde väl inte ha några problem med att spela upp 1080p .mkv-filer eller? Använder mest min HTPC till att titta på HD-film samt lyssna på internet-radio.
Borde inte vara några som helst problem men nu äger jag inte något sådant system än, eftersom jag väntar på 3800:an, så jag kan enbart komma med antaganden. Själva processordelen i APUn är relativt svag och man bör därmed se till att utnyttja GPUn för att det ska fungera optimalt. Sen hur bra det går är en annan sak... som jag skrev innan så verkar inte Linuxprogram, t.ex XBMC, fungera allt för bra just nu. Men det kanske är något som kommer att förändras i framtida versioner förhoppningsvis.
Postad 24 September 2011 - 14:33
Davye
Davye
103 inlägg
Postad 25 September 2011 - 22:37
Davye
Davye
103 inlägg
Quote: Originally Posted by jeffkro Trinity is suppose to be compatible with FM1 but not the standard non apu bulldozer. Zambezi (the upcoming FX-Series processors) and Vishera (the successor to Zambezi) are all Socket AM3+. Llano APU: FM1, Trinity APU (the successor to Llano): FM1 & FM2. BTW you shouldn't use "Bulldozer" to indicate a processor. It's the code name of a module. Zambezi consists of 2-4 Bulldozer modules, Trinity consists of 2 Bulldozer modules.
http://www.avsforum.....php?p=20995667 Intressant om det stämmer för då skulle man ju kunna strunta i att vänta på A8-3800:an och satsa på en Trinity till våren istället, och som dom resonerar i forumet köra budgetvägen under tiden med A4:an...
Postad 25 October 2011 - 17:42
Davye
Davye
103 inlägg
För att bumpa min tråd igen så får man väl utgå ifrån att så länge inte motsatsen bekräftas så passar inte Trinity på FM1. Om några dagar kommer 3800:an och 3600:an att finnas i lager på en del ställen ser det ut som. Egentligen räcker antagligen en E-350 för mig men jag vill ha lite mer marginal. Frågan är hur mycket mer som behövs?
Postad 04 November 2011 - 13:53
ScandicProd
ScandicProd
51 inlägg
När kommer 3800?
Skulle den inte finnas nu?
Postad 09 November 2011 - 12:27
Davye
Davye
103 inlägg
När kommer 3800? Skulle den inte finnas nu?
Jag frågar mig det samma. Sitter och väntar på min 3800. Tydligen har dom, som jag har förstått det, problem med att få fram ordentliga kvantiteter på grund av "bad yields" på grafikdelen i APUn. Datumet flyttas framåt hela tiden utan några som helst indikationer på om det kommer några processorer snart eller inte. Det enda jag läst är att det kommer bli bättre "yields" med Trinity eftersom den bygger på Bulldozer. Information om efterträdaren som är helt ointressant eftersom föregångaren inte ens finns ute på riktigt än. Funderar på att satsa på någon av de andra processorerna(APUerna) men dom lockar inte riktigt. Någon som fått tag på någon utav de fåtal 3800:or som kom ut i början av månaden får gärna redogöra för om det är värt att vänta eller inte... Trinity känns ju lite väl långt bort...
Postad 10 November 2011 - 18:27
ScandicProd
ScandicProd
51 inlägg
Beställde idag 3850, den finns i alla fall.
Postad 10 November 2011 - 23:41
Matsen
Matsen
2792 inlägg
Och när kommer de upplåsta prollarna, 3870 och 3670 ?
Postad 11 November 2011 - 11:16
Davye
Davye
103 inlägg
Jag väntar nog den här månaden ut för att se vad som händer. Om ingen förändring skett på den tiden så blir det nog något annat i väntan på Trinity. Skulle det inte varit så att jag helt satt utan HTPC skulle jag hoppat hela Llano-serien men nu är det lite väl länge att vänta. Skulle varit fint om Trinity var socketkompitabel med FM1 så man kunnat köpa en A4 dual core nu och sen uppgraderat till någon av Trinity senare. Funderat på att köpa en E-350(alt. E-450) under tiden så man kunnat vänta utan att vara helt lottlös. Webhallen som jag har min beställning hos flyttar bara fram sitt beräknade leveransdatum hela tiden så att det alltid är 2v fram. Börjar bli lite segt då man väntat på Llano sen strax innan jag skapade tråden.
Postad 11 November 2011 - 15:28
Matsen
Matsen
2792 inlägg
Ja just ja... Trinity är ju på G oxo, då kanske det inte är så genomtänkt att satsa pengarna på FM1...
Fasen oxo!
Postad 14 November 2011 - 19:31
Davye
Davye
103 inlägg
Ja just ja... Trinity är ju på G oxo, då kanske det inte är så genomtänkt att satsa pengarna på FM1... Fasen oxo!
Nja på G andra kvartalet 2012... Llano var ju ute i augusti i år officiellt men än har det inte hänt så mycket med vissa modeller. Men har man en HTPC och vill/kan vänta så kanske Trinity är ett bättre alternativ...
Postad 14 November 2011 - 19:38
Matsen
Matsen
2792 inlägg
Ja så är det ju, sitter ju inte i sjön men är samtidigt sugen på ett nytt bygge. Dessutom kommer ju Intel med Ivy Bridge vilket kan bli intressant!
Fast för HTPC-bruk så klarar man sig många år på en A8, speciellt om man dubblerar med ett separat grafikkort.
Om 3870 kommer snart kan det nog bli ett bygge med den!
Postad 16 November 2011 - 13:53
Davye
Davye
103 inlägg
Jag sitter helt utan HTPC och får spring och koppla in laptopen så fort man ska se något på tvn... trodde man skulle ha en fungerande HTPC nu men det verkar väldigt avlägset. Verkar konstigt om dom är så lika och inte görs kompatibla med varandra: http://feber.se/pc/a...blir_inte_komp/
Postad 16 November 2011 - 19:12
Matsen
Matsen
2792 inlägg
Ja det är faktiskt helt förkastligt att de inte hade koll på detta när de tog fram FM1:an, en sockel som bara håller 1 år har ju inte ens Intel lyckats med!
AMD brukar ju faktiskt kunna behålla sin socklar rätt länge så det här måste varit något oförutsett.
Redigerat av Matsen, 16 November 2011 - 19:13.
Postad 30 November 2011 - 11:21
Davye
Davye
103 inlägg
Jahapp då har man avbokat sin höstdator... Llano nerlagt tills vidare eftersom det inte verkar komma några 3800:or. Var tänkt att jag skulle ha den under hösten men nu är det bara vädret som är kvar i höstläge. Sitter man utan HTPC iallfall... undrar vad man ska ta sikte mot nu? uppdaterade Llano, Ivy eller trinity kanske?
Postad 01 December 2011 - 09:32
Matsen
Matsen
2792 inlägg
Ja det är tris att de inte kan få ut fler APU:er, har inte sett några självklara anledningar till det.
Jag blir mer och mer inne på ett 1155-bygge, tar man en i3 21xx eller tex en Pentium G630 + ett passivt Radeon 6450/6570/6670 får man en rätt bra grund att stå på som man kan bygga vidare på med Ivy Bridge.
Llano räcker nog visserligen rätt länge utan att man behöver känna uppgraderingsbehov - men att lägga pengarna på en snart död plattform känns rätt dumt. Fast å andra sidan så är det få plattformar som håller så länge så när man väl vill uppgradera sitt Llano- eller 1155-bygge så finns det alldeles säkert något helt annat man vill ha och byter ut hela skiten ändå...
Postad 02 December 2011 - 16:54
Unregistered33aea5f7
1610 inlägg
Äh. Det kommer alltid något nytt nästa kvartal.
Jag är supernöjd med mitt A6-3500-system (näst intill perfekt 24p och 3D) och ska inte uppgradera på ett bra tag. Det är en suverän HTPC-plattform.
Media & Mediauppspelning
HTPC
Titan Noir Max
LFE reference och Center ch
