*Officiell tråd Vortexbox*
27 svar till detta ämne
Postad 14 December 2011 - 15:40
Unregisteredc082866f
1318 inlägg
VortexBox is a free, open source (GPL v3), quick-install ISO that turns your unused computer into an easy-to-use music server/jukebox. Once VortexBox has been loaded on an unused PC, it will automatically rip CDs toFLAC and MP3 files, ID3 tag the files , and download the cover art. Vortexbox will then serve the files to network media players such as Logitech Squeezebox, Sonos, or Linn. The music files can also be streamed to a Windows or Mac OSX system.Features- Convert an old PC to a CD ripper / jukebox / NAS in 15 minutes.
- Based on Fedora so it’s easy to modify.
- Automatically tags all files from online music database.
- Automatically downloads the cover art.
- Automatic sharing of file to SMB (Microsoft) file shares.
- Automatic re-indexing Squeezebox Server after every CD is ripped.
- AppleTalk – for OSX or Bonjour for Windows.
- DAAP – Automatically shares all MP3s for streaming to iTunes and Roku Soundbridge.
- NFS – For Linux boxes and almost anything else, Solaris etc.
- DLNA support – Play music and video DLNA enabled players, XBOX 360,PS3, Windows 7 etc.
- Easy installation of mplayer for AlienBBC support.
- Good support for Sonos.
- Works well as a back end server for XBMC (XBOX Media Center) running on XBOX, Windows, OSX, AppleTV, or Linux.
http://vortexbox.org/Lite bonus.Ett klick installation av Plex Media Server.Koppla in en USB-dac eller använd det inbyggda ljudkortet så får du en extra Squeezebox.Transmission torrent-klient.All uppgradering av mjukvara t.ex Logitech Media Server görs med ett klick via WebGUI.Rippar även film med MakeMKV.
Redigerat av Unregisteredc082866f, 09 January 2012 - 15:10.
Postad 09 January 2012 - 15:48
1318 inlägg
Kör du Chrome så kan du hämta en app till Vortexbox i Chrome Web Store.
Vortexbox.png 132.33K
9 Antal nerladdningar
Postad 03 February 2012 - 13:34
Unregistered59c4d10b
3 inlägg
Hej otto!
Vad heter appen?
Jag hittar den inte i Crome Web Store.
Hälsningar
Juan
Postad 03 February 2012 - 13:38
1318 inlägg
Hej otto!
Vad heter appen? Jag hittar den inte i Crome Web Store.
Hälsningar
Juan
Sök på Vortexbox.
Redigerat av Unregisteredc082866f, 03 February 2012 - 13:38.
Postad 30 March 2012 - 14:56
ae_g
ae_g
225 inlägg
Dum fråga kanske, men är det någon som använder sig av VortexBox? Väldigt stilla i den här officiella tråden verkar det som. Installeras det alltså över befintligt OS eller är det primärt OS?
Själv kör jag en WHS med Logitech Media Server och Softsqueeze men det är inte alltid fullt pålitligt så skulle vara gött om detta fungerade bättre och mer stabilt.
Postad 30 March 2012 - 14:59
1318 inlägg
Det är precis som WHS ett OS som man installerar på disken så ta backup innan om du har data du vill spara.
Postad 06 May 2012 - 10:10
skagget78
skagget78
3 inlägg
Hur är det att använda, mest är jag nyfiken på hur den gör med dvd filmer, komprimerar den filmen eller läggs den in på hdd utan förlust? Sugen på att packa ner 300 filmer i lådor till förådet istället för att ha den i bokyllan... kan man komma åt dem ändå och utan kvaliteförlust vore det nice!
Annars tar jag gärna emot tipps om programm som löser det ändå!
Postad 07 May 2012 - 08:49
1318 inlägg
Vortexbox använder MakeMKV. http://makemkv.com/Filmer blir rippad "förlustfri" med alla ljudspår och undertexter (tror jag, använder MakeMKV på en separat dator).
Postad 15 May 2012 - 21:45
skagget78
skagget78
3 inlägg
Toppen, då är helgens projekt räddat
Postad 03 June 2012 - 10:10
undret
undret
24 inlägg
Hej alla.
Jag har en Vortexbox Appliance jag köpte förra hösten från den brittiska återförsäljaren.
Intresserad av att komma i kontakt med andra som har den burken, eller för all del kör Vortexbox på någon annan hårdvara, för erfarenhetsutbyte.
Hälsningar Undret
Postad 15 November 2012 - 08:33
1318 inlägg
Postad 20 February 2013 - 21:21
hampestampe
hampestampe
1051 inlägg
Vad är lämplig hårdvara för att köra Vortexbox? Tanken är att endast köra den som server till 3-4 squeezeboxar som matas med 99,9% flac-filer. Vore ju bra om den har cd-läsare, så man kan mata den med skivor direkt, strömsnål vore oxå bra. Kommer stå i en walk in closet, så ljudnivå kan kvitta. Krävs det mycket mer av hårdvaran för att hålla perfekt synk mellan ett gäng, eller hur funkar sådant?
Kan man köra den med en atomprocessor och 1 Gb ram eller bör man köra nån dual core och ett par Gb ram?
Postad 20 February 2013 - 22:55
hampestampe
hampestampe
1051 inlägg
Vad är lämplig hårdvara för att köra Vortexbox? Tanken är att endast köra den som server till 3-4 squeezeboxar som matas med 99,9% flac-filer. Vore ju bra om den har cd-läsare, så man kan mata den med skivor direkt, strömsnål vore oxå bra. Kommer stå i en walk in closet, så ljudnivå kan kvitta. Krävs det mycket mer av hårdvaran för att hålla perfekt synk mellan ett gäng, eller hur funkar sådant? Kan man köra den med en atomprocessor och 1 Gb ram eller bör man köra nån dual core och ett par Gb ram?
Kan det funka med en sådan här? https://www.prisjakt...1442&o=inkfraktKan det räcka med 2 Gb ram?
Postad 21 February 2013 - 07:41
1318 inlägg
Kan det funka med en sådan här? https://www.prisjakt...1442&o=inkfrakt Kan det räcka med 2 Gb ram?
Jag kör en gammal HP SFF (minst 3-4 år gammal) 2,2 Ghz och 2 GB RAM och det har aldrig segat på något sätt. Syncar väldigt sällan men det borde inte vara några problem. Dock så rekommenderar jag att du kör på en stor HD med system och data istället för att dela upp det. Mest för att slippa hacka men det finns bra instruktioner för att köra med flera diskar. http://info.vortexbo...=twodiskinstallhttp://info.vortexbo...torageExpansionSjälv kör jag mjukvaruRAID 0. Mest för att jag hade två likadana diskar liggandes.
Postad 21 February 2013 - 19:35
hampestampe
hampestampe
1051 inlägg
Hur stor flexibilitet har VortexBox då? När det gäller att mata den med en cd och få det hela precis som man vill ha det? Tar den alltid ner rätt albumomslag? Eller ska man räkna med att "rätta till" lite då och då?
Kan man styra hur den ska formatera filnamnen precis som när man rippar i eac?
Redigerat av hampestampe, 21 February 2013 - 20:26.
Postad 22 February 2013 - 08:02
1318 inlägg
Hur stor flexibilitet har VortexBox då? När det gäller att mata den med en cd och få det hela precis som man vill ha det? Tar den alltid ner rätt albumomslag? Eller ska man räkna med att "rätta till" lite då och då? Kan man styra hur den ska formatera filnamnen precis som när man rippar i eac?
Du får räkna med att rätta till det ibland precis som med i stort sett alla rippers. Nu var det länge sedan jag rippade med Vortexbox, men då fick man ändra lite i en fil för att få det som man vill. Tyvärr så skrevs filen över vid uppgraderingar. Här finns lite hack o annat. http://info.vortexbox.orgAnvänder mest Foobar för att rippa o tagga och så hämtar jag omslag manuellt från albumartexchange. Rippade min samling långt innan Vortexbox fanns men hade jag inte gjort det så hade jag nog rippat i Vortexbox och rättat efter hand om det hade behövts.
Postad 23 February 2013 - 07:58
hampestampe
hampestampe
1051 inlägg
Vad menar du med detta? Vilka uppgraderingar och vilka filer? Jag är ju inte sugen på att få något strul med de 1145 album jag redan rippat själv under åren och organiserat upp snyggt och prydligt och manuellt hämtat albumomslagen till vart enda ett. (Förvisso tar jag säkerhetskopior på musiksamlingen med jämna mellanrum) Jag skulle ju bli helt vansinnig om den börjar hämta nya albumomslag och börja härja runt bland filer och stöka till det för mig.
Postad 26 February 2013 - 09:35
1318 inlägg
Den gör inget med dina filer vid uppgraderingar eller överhuvudtaget. Vad jag menade är att om du ändrar hur t.e.x filnamnen ser ut när du rippar med Vortexbox så har jag för mig att den ändringen skrivs över vid en uppdatering av rippingprogrammet.
Postad 26 February 2013 - 22:37
hampestampe
hampestampe
1051 inlägg
Hmm tittade runt lite till och inser att det finns färdigbygda Vortexboxar att köpa från Storbritannien. De har något vassare prestanda än Asrocken jag tittade på innan och går att få med rimlig diskstorlek på en gång. Kan ju för ett par extra hundralappar bli extremt srömsnål och ganska tyst också, 4700:– skulle det bli. Känns inte som man kommer undan så mycket billigare om man ska köpa samtliga komponenter nya och bygga nåt motsvarande själv. Eller har jag fel?
Men det där "bliss cover art and album manager"...
Är det en mjukvara man borde köpa för £30?
http://www.vortexbox...78_6535554.aspx
Redigerat av hampestampe, 26 February 2013 - 22:40.
Postad 27 February 2013 - 07:59
1318 inlägg
Hmm tittade runt lite till och inser att det finns färdigbygda Vortexboxar att köpa från Storbritannien. De har något vassare prestanda än Asrocken jag tittade på innan och går att få med rimlig diskstorlek på en gång. Kan ju för ett par extra hundralappar bli extremt srömsnål och ganska tyst också, 4700:– skulle det bli. Känns inte som man kommer undan så mycket billigare om man ska köpa samtliga komponenter nya och bygga nåt motsvarande själv. Eller har jag fel? Men det där "bliss cover art and album manager"... Är det en mjukvara man borde köpa för £30?
När det gäller hårdvara så är mitt tips om man vill komma billigt undan är att knalla in till närmsta företag och fråga om de har en gammal desktop-dator över. Det är bra om den har SATA och dvd-spelare. Komplettera bara sedan med en fet disk och ev lite minne. Bliss har jag inte testat men är säkert bra om man ska rippa en större samling på en gång.
Postad 27 February 2013 - 16:40
hampestampe
hampestampe
1051 inlägg
Hmm. Jag känner nog för att skaffa något nytt. Fokus ligger på att hårvaran skall räcka till rent prestandamessigt så det inte blir kludd med sync och så. Då jag tänker att den skall vara igång 24/7 ett par år framöver vill jag att den skall vara energisnål. Frågan är väl om man skulle spara något eller få en bättre maskin om man köper motsvarande komponenter själv och bygger ihop den. Spontant känner jag att det vore enklast att bara köpa den klar. Så slipper man bekymra sig.
Postad 06 March 2013 - 17:45
hampestampe
hampestampe
1051 inlägg
Bygga själv ger nog trots allt betydligt bättre prestanda till ett något bättre pris. Köper jag allt detta från Webhallen går det loss på cirka 2800:-
Jag får för mig att dessa komponenter skall passa bra ihop... Någon som har en annan åsikt? Allt passivt kylt CPU 10w disk 4-5w nätagg och ram ??? w= energisnålt och ganska tyst.
hårddisk 3Tb : https://www.prisjakt...t.php?e=1335006
cd/dvd-brännare: https://www.prisjakt...kt.php?e=427165
chassi inkluisive nätagregat 200w: https://www.prisjakt...kt.php?e=561774
Moderkort integrerad intel atom CPU 2.13 GHz: https://www.prisjakt...t.php?e=1008936
2x2 Gb SO-DIMM DDR3 PC8500 1066 MHz: https://www.prisjakt...kt.php?e=468621
Nu har jag korrigerat konfigurationen och tror det skall stämma...
Redigerat av hampestampe, 06 March 2013 - 20:53.
Postad 06 March 2013 - 20:27
hampestampe
hampestampe
1051 inlägg
Nope det där blev nog fel... Vid närmre undersökning på Intels hemsida framgår att det inte är standard DDR3-minnen utan SO-DIMM DDR3 som väl är ett helt annat fysiskt format rent storleksmässigt?
Redigerat av hampestampe, 06 March 2013 - 20:54.
Postad 06 March 2013 - 21:05
hampestampe
hampestampe
1051 inlägg
Men vad gäller chassit står det ju mini-ITX och angående moderkortet står det ju på intels sida:"Mini-ITX / Micro-ATX compatible (170mm X 170mm)"
Hur kan kortet vara kompatibelt för båda? Det ska alltså gå att sätta i låda för mini-ATX...?
Redigerat av hampestampe, 06 March 2013 - 21:06.
Postad 09 March 2013 - 09:08
hampestampe
hampestampe
1051 inlägg
Nu har jag beställt prylar. Bara och vänta på att grejerna kommer och hoppas på att man förstått alla produktbeskrivningar rätt så att allt är kompatibelt.
Justerade listan något jämför med mitt tidigare förslag då jag beställde rubbet från Webhallen, och därför anpassade den marginellt efter deras sortiment. Dessutom valde jag istället en "intellipowerdisk" då servern skall vara igån 24/-7. Jag hoppas jag fått till det med Ram-minnet så jag beställt rätt.Jag känner mig lite ovan på det där, då jag inte är någon van datorbyggare.
https://www.prisjakt...=2272022&view=m
Postad 10 March 2013 - 14:55
hampestampe
hampestampe
1051 inlägg
Ooops! undrar om jag gjort bort mig nu. DVD:n jag beställt står det att den är kompatibel med en massa windows versioner, men inget om kompatibilitet i Linux. Är det samma sak som att det inte kommer fungera, eller? Det vanliga är ju att det inte finns något skrivet om OS-kompatibilitet på dvd/cd-ROM https://www.prisjakt...t.php?e=1143787http://www.asus.com/...#specificationsOS SupportWindows® 8 Windows® 7 Windows® Vista Windows® XP Nu mailade jag Webhallen och bytte ut Asus-brännaren i säkerhetsskull. Jag byte till en 16:- dyrare Samsung istället. https://www.prisjakt...t.php?e=1410576
Redigerat av hampestampe, 14 March 2013 - 16:57.
Postad 27 January 2014 - 07:55
1318 inlägg
Postad 10 April 2014 - 06:57
1318 inlägg
Media & Mediauppspelning
HTPC
Hemmalagring
Akustikväggen klar inåt rummet, köpte en skön fåtölj
2026-05-20 17:06:21
Snart klar med akustikväggen, är bara gaveln kvar
2026-05-20 17:04:36
Tyg och läkt till baksidan av akustikväggen,
2026-05-20 17:03:16
Projektorn uppe och allt verkar fungera
2026-05-20 17:02:29
