Mede8er med1000! ny spelare från sydafrika som ska klara BD 3d!
36 svar till detta ämne
Postad 16 July 2012 - 08:55
Unregistered24b04795
91 inlägg
MED1000X3D.jpg 11.26K
23 Antal nerladdningarjaha vad tror ni ? klarar den BD 3d ? verkar vara en klen processor i den, eller är det bara jag som reagerar på 750 mhz? http://www.mede8ersh...oduct_info.htmlteaser: http://www.mede8er.c...3_Teaser_1.htmlMede8er MD1000X3D Landing Soon The long awaited 3D Multimedia player from Mede8er is landing soon. Mede8er has achieved the ultimate balance in design and functionality with the all new MED1000X3D High Definition 3D Multimedia Player. It may look like an alien spaceship from outer space, but we can assure you that it was designed and developed by very passionate people right here on Earth. Quick and simple is the Mede8er way. No need to install special brackets etc. Create a bookshelf of Hard Drive storage and you will never be short of space again. Ergonomic IR remote with full active backlighting and user programmable function button. It is normally very difficult to see the remote buttons in a dark TV Room. If you are wearing 3D glasses Its near impossible. The MED1000X3D remote with active back lighting makes it so simple without the need for removing the glasses every time you want to use the remote. 3D VIDEO Support - Full BDISO, Side by Side, Top & Bottom, Frame Sequential, Frame Packing Main Features: - Full 3D - HDMI 1.4 - Play 3D BD-ISO
- Complete Aluminium Die Cast Casing - Fanless Design
- Mede8er Xbay - Easy Hard Drive Change - Up to 3 TB
- Active Backlit Remote with Self Learning Hot Button
- Mede8er Developed Movie & Music JukeBox - Database Driven
- Web Services, YouTube XL , Web Browser
- Built in Mede8er Favourites Manager
- Community Skins and Ways Backdrop Customization
- HD Audio - 7.1 DTSMA & Dolby True HD
- Fast USB 3.0 & Gbit Network Port
- 0dB Noise excluding internal Hard Drive
Features: - Music Jukebox Local and Network support
- Built in View Manager
- Compatible with MAC HFS+ USB Drives
- Movie XML Med Data in Media Library
- Video JukeBox XML Search
- All Aluminium Body - Fanless Design
- Hard Drive Spin Down Function
- Alpha Search in Media Library
- Xbay - easy Hard Drive swop
- Internal Hard Drive up to 3TB
- Built in Favourites Manager
- Internet Media Streams
- Social Media
- Watched Indicator
- Built in Web Browser
- Optional WiFi USB / PCIE
- Internet Radio (Shoutcast)
- Full Parental control on Folders
- SD Card / Sony Pro Duo Card Slot
- Samba Server - NAS storage
- Photo slide show with background music
- Subtitle: SRT, SSA, SUB, SMI format
- Network - Ethernet 10/100/1000 Mbps port
Specifications: - Processor: RTD1186 • 750Mhz • 512 SLC Flash • 512 DDR3 SDRAM
- Video Formats Supported: AVI / BDMV Light / BDISO Light / MKV / TS / TP / TRP / M2TS / MPG / MP4 / MOV / M4V / VOB / ISO / IFO / DAT / WMV / ASF / RM / RMVB / FLV resolution up to 720p / 1080i / 1080p
- 3D Video: 3D BDISO, Side by Side, Top & Bottom, Frame Sequential, Frame Packing
- Video Codecs Supported: MPEG-1-2 / MPEG-4 SP /ASP /AVC (H.264) / XviD / DivX / WMV9 (VC-1) / RealVideo 8/9/10 (up to 720P)
- Audio Codec Supported: Mp3 / Mp2 / OGG Vorbis / PCM / LPCM / AAC / RA / Dolby True HD - DTS MA Passthrough on HDMI / AC3 - DTS 5.1 / FLAC up to 24bit 192Khz / WAV / WMA Standard (DRM, & Advanced Profile not supported)
- Photo format Supported: JPEG, BMP, GIF, TIFF, PNG File System Supported: FAT32, NTFS, HFS+ (Mac) Video output resolution: NTSC, PAL, 480p, 576p, 720p, 1080i, 1080p, 1080p 24hz Input /
- Outputs: HDMI 1.4 • Component Video • Composite Video • Stereo RCA • SD • SDHC • Sony Pro Duo Card Slot • SPDIF Optical • Co-Ax Digital • Slave Port USB 3.0, HOST Port x 2 USB 2.0 • IR Jack
- Optional WiFi: MED10WFB or MED20PCIE (WiFi is optional unless otherwise stated on the packaging)
- Optional Hard Drive: Internal Hard Drive is optional unless otherwise stated on the packaging.
- Contents: MED1000X3D, RC, 2 x AA Batteries, AC Adapter, HDMI 1.4 Cable, AV Cable, USB3.0 Cable, HDD Securing Screws.
Specifications subject to change without notice. DTS, DTS-HD, the Symbol, & DTS or DTS-HD and the Symbol together are registered trademarks of DTS, Inc. © DTS, Inc.
Redigerat av Unregistered24b04795, 16 July 2012 - 09:35.
Postad 16 July 2012 - 11:56
PalmiNio
PalmiNio
Mega-Guru
8074 inlägg
Samma chip som sitter i Sidewinder 3.
Kostar den över 1000kr ut till kund så är den inte värd det tyvärr.
Postad 16 July 2012 - 12:03
91 inlägg
går på ca 2800 spänn om man växlar över från deras valuta. ska bli intressant att se hur den fungerar mjukvarumässigt.
Redigerat av Unregistered24b04795, 16 July 2012 - 12:07.
Postad 16 July 2012 - 13:17
Unregistereddc471864
Über-Guru
24891 inlägg
2800 spänn är lite dyrt när du får samma filstöd på en xtreamer sidewinder 3 för 1000 spänn. Mycket möjligt de har bättre mjukvara än xtreamer dock men tveksamt om det är värt så mycket extra.
Postad 16 July 2012 - 13:26
91 inlägg
nä och sedan var den ju inte världens snyggaste heller...
Postad 16 July 2012 - 13:39
Über-Guru
24891 inlägg
Ser ut som ett våffeljärn ungefär
Postad 19 July 2012 - 09:03
Kanelbulle
Kanelbulle
3325 inlägg
Tjena!
MED1000 ska presenteras på IFA. Processorn Realtek 1186 ska vara en "non standard" dvs en specialare som ska vara snabbare enligt Mede8er. Vad som är skillnad är en bra fråga! Utseendet är ju klart personligt... vem vill inte ha ett våffeljärn i vardagsrummet!!
Postad 20 July 2012 - 13:50
91 inlägg
jag har inga erfarenheter av GUI:t på tidigare mede8er maskiner samt jukeboxfunktioner men generellt intryck (från div forumtrådar) så är dom stabila, rätta mig om jag har fel ?
denna "topmodell" står sig ju enligt spec iaf i flera år framöver... ska bli intressant att läsa utlåtanden om den.
Postad 20 July 2012 - 21:08
Kanelbulle
Kanelbulle
3325 inlägg
Chaux:
Kan bara hålla med dig, dom är stabila. Sen är Mede8er duktiga på att inte slänga ut massor med uppdateringar som inte funkar vilket vissa andra gör...
Sen är det väl alltid lite "runt hörnet" garanti på det mesta rent praktiskt. Vill man "hänga med" så börjar ju snacket om 4K spelare komma... men vem har en sån TV eller Projje... Men i vanlig ordning går det väl fortare än vad man anar!! Läste att Platstation 3 ska få uppdatering för det, frågan är om HDMI 1.3 klara det??...
Nu ballade jag ur lite... men bland dagens spelare finns det fyra lysande stjärnor enligt mej: Mede8er och HDI Dune bland "vanliga" spelare. Bland spelare som ska klara mycket webtjänster är det Boxee Box o Tizzbird som gäller!!
Vi får hoppas att Mede8er är kloka när dom prissätter MED1000, den får inte bli för dyr!!
Postad 21 July 2012 - 08:17
91 inlägg
Chaux:
ja 4k verkar ju va nästa gjej, projjar som har det har ju börjat få 4k passtrough men då liggre dom på 50-100 k i pris... många recievers av årets modellar har fått det med. prissättningen nu vid förhandsbokning är ca 2800 spänn, det via sydafrika, tror inte priset kommer skilja så mycket mot sverige tyvärr :-(
Postad 09 September 2012 - 11:25
Unregistered7e1dc52c
205 inlägg
Någon som testat denna ännu?
Postad 09 September 2012 - 20:40
Kanelbulle
Kanelbulle
3325 inlägg
Västman:Fick min i fredags... Har dock haft en sjukt späckad helg, det blir morgondagens begivenhet!! Den ser trevligt o välbyggd ut... återkommer!! Riktpriset har landat på 1890:-... vilket känns rimligt!
Redigerat av Kanelbulle, 09 September 2012 - 20:43.
Postad 10 September 2012 - 16:44
Über-Guru
24891 inlägg
Klart bättre pris än förväntat ja. Hoppas den funkar bra.
Postad 11 September 2012 - 15:30
wajk424
wajk424
1 inlägg
Kommer Precis Beställt Denna Spelare, Finns Det Möjlighet Att Spotify Kommer I Senare Firmware?
Postad 11 September 2012 - 16:52
PalmiNio
PalmiNio
Mega-Guru
8074 inlägg
Samma som en Sidewinder 3. Känns inte 1890 lite överkant för ett Realtek chip`?
Postad 11 September 2012 - 16:57
d96ez
d96ez
245 inlägg
Västman:
Nu har du ju haft 2 dagar på dig...hur lyder domen?
Postad 11 September 2012 - 21:53
Über-Guru
24891 inlägg
Jo kanske men den ser ju ut som ett våffeljärn så det är värt 890 extra!
Redigerat av Unregistereddc471864, 11 September 2012 - 21:53.
Postad 12 September 2012 - 07:18
Kanelbulle
Kanelbulle
3325 inlägg
Hej på er!!
Har nu hunnit känna på spelaren. Kör just nu Firmware Beta 1.03 från 30/8
Med1000 har ett utseende lämnar ingen oberörd. Personligen tycker jag dom lyckats bra. Känslan är kvalitet och man öppnar "våffel"-luckan o lägger in sin Sata-disk. inga problem.
Själva gränssnittet i maskinen påminner om de gamla MED maskinerna. Man känner att gränssnittet är litet rappare.
Tycker nog att de flesta filer spelar som dom ska, har ej någon 3D TV så det har jag inte kunnat testa! Testade Killersample, absolut inga problem!!
Fjärren är av en ny typ, den har bakgrundsbelysning som aktiveras med en knapp på höger sida. Personligen tycker jag fjärren är lite väl knubbig (ren smaksak), men den ligger riktigt bra i handen.
Mede8er har sedan länge tillbaks ett mycket gott rykte, framförallt vad gäller support o utveckling av sin firmware. Så överväger ni denna maskin kan ni räkna med att det kommer att funka bra, stabilt. Man ska samtidigt ha med sig att en nysläppt Mediaspelare behöver ca 3 månader innan den är riktigt bra, jag tycker trots detta att MED1000 känns mycket stabil, det finns problem med Internet-kopplingen i denna Beta. Dom verkar dock vara problemet på spåret!
Summa summarum: Bra Mediaspelare som har framtiden för sig!!
Postad 12 September 2012 - 20:57
Kanelbulle
Kanelbulle
3325 inlägg
Hej igen!! Våfflan fick en ny uppdatering idag, ny Beta!! Lovande!! 1) Removed NTFSFIX as introduced in V1.0.3-30Aug as it causes problems with 3TB drives 2) Fixed Internet connection on wire Network2) Corrected the Audio Display when using 'Info' button during video play 3) Fixed HDD Spin Down time adjust4) Added Auto fps for 50/60/59.940 fps5) Corrected display in 3D to 23.9766) Changed Default Audio setting after install to 'HDMI Auto'7) New functionality - BD Audio will now play in preference of supported quality ie HD Audio --- Normal Core Dolby/DTS/ --- PCM Fixed Croation Language GUI9) Alpha Functionality - BD Playlist - Press Menu Button during BD Play and Select 'Playlist' - should be completed next week Known Critical Bugs26Aug - Copy from internal HDD to USB not always working - investigating thishttp://www.mede8erforum.com/index.php?topic=9070.0
Postad 12 September 2012 - 21:18
205 inlägg
haha
Härmed döpt till "Våfflan"...
/V-man
Postad 13 September 2012 - 08:15
Über-Guru
24891 inlägg
Att kunna välja BD-playlist är ju jäkligt nice om det funkar. Är det enda jag retar mig på med min xtreamer sidewinder 3.
Postad 16 September 2012 - 09:41
Unregistered7c5139ba
1310 inlägg
Det enda? 24 fps-buggen vid 3D då?
Hur är det med movie jukebox funktion?
Inte alla stör sig på detta, så det är inte menat som en "syrlig" kommentar!
Postad 16 September 2012 - 10:44
Über-Guru
24891 inlägg
Har inte märkt att det är ngn 24fps bugg. Använder inte jukebox. Vilket jag skrivit flertalet gånger i den här tråden
Redigerat av Unregistereddc471864, 16 September 2012 - 10:44.
Postad 16 September 2012 - 21:51
1310 inlägg
Så du kör med ren folder-view? Jo, det gör jag med min Xtreamer mk1 också. Fördelen är att det är hyggligt snabb navigering. Nackdelen är väl främst att det blir en massa hoppande bland olika shares.
Postad 16 September 2012 - 22:17
Über-Guru
24891 inlägg
Yes. Jag pallar inte med covers å sånt. Det blir alltid en massa merjobb och när det bara är jag som ska använda det så kvittar det. Hade jag haft familj osv så hade det kanske varit smidigt med sånt för deras skull.
Angående 24p buggen så har du nog rätt. Det är tydligen ett problem. Inget jag tittat efter så därför har jag nog inte sett det
Postad 22 September 2012 - 22:56
Kanelbulle
Kanelbulle
3325 inlägg
Hej igen! Sedan förra gånge jag skrev har det hunnit komma 2 nya betor, kolla här på changeloggen: V1.03 - 21Sept 2012-BETAChangelog1) New Functionality - NFS mount Auto Scan X3 will Scan the NFS servers on the same IP segment, on boot up. Additionally you can perform a manual NFS scan with a new option called 'Probe' in the NFS menu. 2) New function - AAC/MP3 Force decode - If set to 'on' AAC/MP3 will be decoded to PCM 3) Fixed embedded Italic tag showing in MKV subs4) Improved performance when decoding High Bittrate mkv with HD Audio V1.03 - 18Sept 2012-BETAChangelog1) Fixed 'Autoplay' Functionality2) Fixed Subtitle tags <i> ie now hidden - EDIT - Embedded mkv not fixed3) Fixed - Respect Default Audio flag in MKV files4) Fixed - Network Login Screen5) BD Playlist a) Improved the graphic presentation Fixed X3 freeze after using Playlist function c) Fixed Chapter support within a Playlist d) Fixed Left . Right Nav Jog - GOTO within a PlaylistSom det stått på andra delar så har Mede8er löst 23.976 fps buggen oxå!!Kolla här för mer info:http://www.mede8erforum.com/index.php/board,112.0.html
Postad 08 November 2012 - 13:31
Unregistered6c9bcd9b
101 inlägg
Någon som vet om netflix finns i denna?
Postad 08 November 2012 - 22:42
Kanelbulle
Kanelbulle
3325 inlägg
Dennisson:Nix tyvärr inte i dagsläget, vad jag känner till finns inga signaler på att nåt är i görningen heller! Det finns en "lågbuget-lösning", man kan köra AC Ryans serverprogramvara och där köra Netflix o sen köra ut det via den på något sätt. Vet inte så mycket om det, men det kräver ju en dator till osv. Detta går att kolla upp om det är intressant! ___________________________________________________________________ Uppdatering!! Ny firmware idag!!Sen sist har det hunnit komma ett par Betor. Här är changelogen för samtliga sen sist!' V1.03 - 8Nov 2012-BETAChangelog1) Fixed PCIE WiFi freeze on bootup with 3TB internal HDD2) Fixed Hungarian Localization3) Added support for USB Drive when using Transmission BT4) Splash screen and Screensaver image change suitable for both Black and Silver models.5) Fixed IP address in Transmission BT when using WiFi6) Changed Host Name and DLNA Device Name to X3D , replacing Silver Model Number. Known Bugs: Will not mount a RAW virgin hdd so you cannot format from Setup GUI. Temp Workaround. First format HDD in PC or use Beta 17Oct to format and then update to 8 Nov.V1.03 - 1Nov 2012-BETA Changelog1) Fixed crash on some flac files2) Fixed crash with MVC 3D Camcorder - MT2 filesKnown Bugs PCI WiFi will not load on Boot Up if internal 3TB HDD is installed - investigating Temp Workaround - Bootup without 3TB and connect the HDD after you see the PCIE WiFi message top left V1.03 - 17Oct 2012-BETAChangelog1) Fixed NFS - MKV freeze problem on Gbit Network using 32k block size2) Fixed MVC video file supportV1.03 - 29Sept 2012-BETAChangelog1) New functionality - match embedded BD / MKV Audio track and Subtitle to OSD Language - Setup Option MISC pageNote: for MKV the audio track and sub language flag info needs to be set. 2) Changed screensaver to default screensaver when in Video Pause and Music Jukebox 3) New Diagnostic functionality - Display NFS mount info - Mount a NFS share and press the 'F1' button and NFS connection details will be displayed ie vers=3,rsize=32768,wsize=32768,proto=udp,port=65535,timeo=7,retrans=3,addr=192.168.10.204) Improved BD Playlist functionality for 3DBDISO5) Copy to USB Drive / Loosing Favourites Links/ Watched Indicator - Fixed - New Functionality - NTFS Check - Open Devices Page and press the 'F1' button then select a drive and X3 will perform a - NTFS check and reset the Dirty Bit flag and check the file system. Suggest to use this functionality if you experience any write to HDD / USB problems. 6) Popping sound when selecting 'menu' in Video Play - Fixed7) 'Audio Menu' changed to auto remove after 5 secKnown Issues - 1) MVC - MTS files not working - will fix in next BETA 2) X3 freeze when streaming MKV via NFS on wired Gbit Network - Will fix this in next BETA Workaround - a) Connect x3 via 10/100 port Try Firmware version V1.03 - 26Aug 2012 c) Use Samba
Redigerat av Kanelbulle, 08 November 2012 - 23:03.
Postad 09 November 2012 - 13:30
101 inlägg
Är riktigt sugen på denna. Den verkar ha bra stabillitet? Det är framförallt smidigheten och enkelheten jag vill åt. Frugan skall kunna få igång den utan att behöva sucka.
Inga andra problem som är kända? Alla undertexter funkar till 3D osv? Inget speciellt man behöver känna till? Krävs någon serverprogramvara för att dela ut mappar i en windows baserad hemserver?
Endast samba?
Vänligen
Postad 09 November 2012 - 18:34
22mc
22mc
1992 inlägg
Det jag läst är att den inte fixar 23,976 uppspelning korrekt, men att det jobbas på det...
Postad 13 November 2012 - 07:24
Yavillha
Yavillha
21 inlägg
Jag hörde tvärtom att den visst fixar 23,976 korrekt. Någon som kan bekräfta detta?
Postad 13 November 2012 - 16:33
22mc
22mc
1992 inlägg
Kolla deras forum så ser du att det jobbas på en fix... Men om dom löser det vet jag inte, lär vara samma problem med övriga spelare som har samma chip .
Postad 14 November 2012 - 07:52
Über-Guru
24891 inlägg
Tror inte det går att lösa. Det är nog hårdvaruspecifikt. Det är nog ingen stor grej. Jag har inte ens märkt av det på min realtec spelare.
Postad 20 November 2012 - 09:15
KElfving
KElfving
30 inlägg
Vad är största skillnaden mellan MED1000X3D och MED600X3D?
Redigerat av KElfving, 20 November 2012 - 09:15.
Postad 21 November 2012 - 08:56
Kanelbulle
Kanelbulle
3325 inlägg
KElfing: Mede8er gör riktigt bra mediaspelare. Plex, XBMC har den ej. De har byggt in sin egna Moviejukebox i den som du lagt märke till. Det finns en del nättjänster till den men inget om Netflix eller HBO vad jag vet! Skillnaden mellan MED1000x o MED600x är att den förstnämnda har plats för intern SATA-disk, 600:an är mycket liten o du kopplar den med trådat eller trådlöst eller kör med USB-diskar!
Postad 11 October 2013 - 04:31
Thermal
Thermal
64 inlägg
En snabb fråga jag har førsøkt få svar på men inte fått æn så længe. Kan man koppla in en trådløs mus och tangentbord via USB och anvænda den istællet før fjærrkontroll?
(Ursækta før det norska tangentbordet)
Redigerat av Thermal, 11 October 2013 - 04:31.
Postad 11 October 2013 - 08:49
Unregistered789a50d7
4 inlägg
Ja. Du kan navigera med tangentbordet i menyerna och tangenter och mus aktiveras när du startar internet, google, bittorrent eller bing.
Redigerat av Unregistered789a50d7, 11 October 2013 - 08:53.
Media & Mediauppspelning
HTPC
Mediaspelare
