Highlights
• Bluetooth® connectivity
• Optical and coaxial inputs
• DLNA® network compatible
• Built-in 24-bit/192kHz DAC
• Phono input
• vTuner™ (Internet radio) streaming
• Harman Kardon Remote app for compatible iOS®
and Android™ smartphones and tablet
• Front-panel USB port for connection to compatible
Apple® products or USB flash drive
• Ultrawide bandwidth
• A/B speaker selection
• Headphone output
• Tape monitor loop
• Subwoofer output
Power
• 120W x 2 into 8 ohms, 20Hz – 20kHz, at <0.07% THD,
with all channels driven simultaneously
• High-current (±40 amps)
• Ultra wide frequency response (@1W) 10Hz – 130kHz
(+0dB/3dB) amplifier design
• Signal-to-noise ratio (IHF-A): 100dB
FM Tuner
• Frequency range: 87.5MHz – 108.0MHz
• Usable sensitivity IHF: 1.3µV/13.2dBf
• Signal-to-noise ratio (mono/stereo): 70dB/68dB
• Distortion (mono/stereo): 0.2%/0.3%
• Stereo separation: 40dB @ 1kHz
• Selectivity (±400kHz): 70dB
AM Tuner Section
• Frequency range: 110V: 520kHz – 1710kHz,
220-240V: 522kHz – 1620kHz
• Signal-to-noise ratio: 38dB
• Usable sensitivity (loop): 500µV
• Distortion (1kHz, 50% mod): 1.0%
• Selectivity (±10kHz): 30dB
Connectivity
• Five analog audio inputs
• One coaxial audio input
• Two optical digital inputs
• USB input on the front panel to connect an iPod®, iPhone® or
iPad® using an Apple® cable (not supplied) or to connect a USB
flash drive with music content (MP3, WMA or WAV format)
• One high-quality phono input for connecting to record players
with an MM cartridge
• Subwoofer output with trigger for direct connection to
powered subwoofers
• One analog-recording output
• Network RJ45 connection to enjoy Internet radio and content
from DLNA®-compatible devices that are connected to the
network
Specifications
• 2-channel, 240-watt stereo receiver
• Power requirement: 120V AC/60Hz or 220-240V AC/50/60Hz
(different models)
• Power consumption: <0.5W (standby); 480W maximum
• Dimensions (H x W x D): 4-3/4" x 17-5/16" x 11-13/16"
(121mm x 440mm x 300mm)
• Weight: 6kg
Redigerat av Krille_holm, 07 March 2014 - 11:25.
5
Harman Kardon 3770 + dali ikon 7 mk1? bra kombo?
