So difficult to choose! Need help for projector pack
Inga svar i detta ämne
Postad 25 April 2015 - 21:47
querye
  • querye
Hi, I am planing to buy a projector and a screen for my living room. It will be used for 70% movie and 30% game, around white walls but mainly used in the night, about 3.7 throw distance, screen 90-100 inches. My budget is about 20k SEK,
I have been looking at forums and reviews, also asked help in hembiobutiken since it's the only shop in Stockholm with demos. I was recommended with two kind of packages, screen first or projector first. Which one is right? I was confused and have been struggling with choices.
  • Option 1 is Optoma HD50 + Euroscreen Frame Vision Light ReAct 3.0, 12k+10k
  • Option 2 is Epson EH-TW7200 + Grandview Velvet Cinema, 15k + 6k
HD50 seems to have a huge input lag so I am leaning towards option 2, but I don't know if I need such a good projector, and will there be a huge difference if I update the screen?
I also find a second hand Euroscreen VLS React 2.1 costs 6k, should I buy that one?
Thanks for any tips and suggestions!
