Hdfury Integral 4k60
54 svar till detta ämne
Postad 23 October 2015 - 14:39
jimjans
jimjans
3660 inlägg
Undrar om det är nån mer som mig som sitter på en förstärkare med HDMI 2.0 men som saknar hdcp 2.2 såg denna lilla tingest HDfury integral och det är ju inte lite grejer den skall klara av där det mest intressanta i mitt fall att den går runt hdcp skyddet. Priset på produkten är 199$
Länk http://www.hdfury.co...k60-444-600mhz/
Specifications
2x Input / 2x Output Splitter (HDMI2.0a/HDMI1.4/DVI1.0 compatible)
- ■ 4K60 4:4:4 600MHz 18Gbps Pass through
- ■ 4K60 4:4:4 600MHz 18Gbps > 4K60 4:2:0 300MHz 10.2Gbps conversion
HDCP Doctor (HDCP Workaround solution to any HDCP error)
- ■ HDCP 2.2 > HDCP 1.4 conversion
- ■ HDCP 1.4 > HDCP 2.2 conversion
- ■ HDCP x.x > HDCP x.x conversion
Dual HDMI2.0a & HDMI 1.4 combined
Dual HDCP 1.4 & HDCP 2.2 combined
CEC Support: For inter-device control between both inputs and the primary output (TOP) HDMI channel.
CEC command: USB configuration for automation, trigger via events, push button or via IR/Bluetooth
External Audio Replacing : input external sound or switch sound between input
Audio Extracting: Audio De-Embedder of Optical & Analog L/R
EDID management via USB or BT*
- ■ Improved EDID Management solution with either a Custom uploaded EDID, Self generated Automix EDID or a Fixed basic EDID.
- ■ AutoMix EDID feature will create a custom EDID by mixing both sink EDID connected to the splitter output ports.
- ■ Custom and manual EDID utility available from the download section.
HDMI Booster/Extender: Capable of extending 1080p resolution up to 15m. in and 15m. out (30m. total for 1080p), UHD resolution up to 10m.
HDMI Doctor: Solves most HDMI integration issues such as HDCP, EDID, HPD, and audio breakout.
HDMI Equalevel: Precise signal equalization towards both input and output signals perfectly delivers the best possible picture quality.
Hot-Plug control: Force the input device to always see an active connection.
Licensing: Fully licensed and compatible with all HDMI and HDCP technologies.
Deep Color Support
Flexible/Portable/Plug’n Play
3D Ready: Capability to pass 3D stereoscopic signal formats.
Just like any recent HDfury hardware, it comes with USB upgradable firmware that allow you to unleash furious features.
Supported Audio/Video Signals
Supported Format: SD/HD/FullHD/UHD/4K30/4K60, basically INPUT/OUTPUT any video format up to 4K60 4:4:4 600Mhz 18Gbps
Supported resolution examples: 480p/720p/1080i/1080p24/1080p25/1080p30/1080p50/1080p60/1440p50/1440p60/2160p24/2160p25/2160p30/2160p50/2160p60
Support all VESA mode video format (PC Resolutions) up to ultra high resolution such as WQSXGA, QUXGA, QFHD, WQUXGA, 4K
Support any Audio format such as PCM at up to 192kHz, compressed audio (IEC61937), DSD, DST,DTS,DTS-HD, Dolby True HD, DTS-MA and HBR.
Postad 03 March 2016 - 18:09
Über-Guru
10990 inlägg
Har beställt denna nu men blir inte riktigt klok på vilka längder av kabeln den fixar UHD fullt ut? Verkar fixa 10 meter från out eller?
Redigerat av mcmike, 03 March 2016 - 18:16.
Postad 04 March 2016 - 13:08
jimjans
jimjans
3660 inlägg
vet att folk som testat inte haft några problem med 10m jag har själv ingen 4k projektor än, så jag har inte behövt den längden på kablaget.
Postad 04 March 2016 - 13:32
Über-Guru
10990 inlägg
Ok får väl se då om den "orkar" hela vägen (12m) från Nvidian, vet att den löst en del problem med just Jvc projektorerna i alla fall Kan man splitta upplösningen från de två out?
Redigerat av mcmike, 04 March 2016 - 13:32.
Postad 04 March 2016 - 15:56
jimjans
jimjans
3660 inlägg
du har både splitter och switch funktionalitet.
Redigerat av jimjans, 04 March 2016 - 15:56.
Postad 07 March 2016 - 06:38
Über-Guru
10990 inlägg
Oki doki! Kanon och tack för svar
Postad 16 March 2016 - 16:35
Über-Guru
10990 inlägg
Fungerar kanon, skickar UHD signalen över längre hdmi kabel. Genom Nvidian!
Postad 16 March 2016 - 17:34
jimjans
jimjans
3660 inlägg
vad var det jag sa en kanonprodukt som gör att du slipper byta förstärkare, den skall visst kunna skicka hdr material till enheter som inte klarar det än också.
Det är ju tur att den tillverkas i China för dom har redan stämt tillverkaren pga av att den sätter hdcp 2.2 skyddet ur spel.
Beställde du från killen i Polen eller?
Redigerat av jimjans, 16 March 2016 - 17:34.
Postad 16 March 2016 - 18:05
Über-Guru
10990 inlägg
Absolut! Dock så får jag inte till ljudet från den via hdmi 2 ut när man vill köra UHD signal via hdmi1 ut? Har både Oppon och nvidian genom den! Verkar som den reagerar på vad receivern klarar av och utelämnar då UHD signalen
Ja jag läste något om det!
Ja det gjorde jag två stycken! Tackar för tipset
Jasså, då skulle man kunna få till det! Vet du inställning där?
Postad 16 March 2016 - 19:44
jimjans
jimjans
3660 inlägg
Du skall kunna gå in och tvinga vad den skall skicka vidare i ditt fall bara 30fps din förstärkare är väl bara hdmi 1.4 min är 2,0 och klarar 4k 60fps det är bara hdcp standarden som inte hängt med.
Postad 16 March 2016 - 20:28
Über-Guru
10990 inlägg
Jag har fyllt alla hdmi in/utgångar nu och det fungerar med optisk ljud vid 4k signal och vid 1080p via hdmi. En magisk liten dosa i alla fall Vilken FW version är den sista?
Redigerat av mcmike, 16 March 2016 - 20:29.
Postad 16 March 2016 - 20:30
3993 inlägg
@mcmike
Hur mycket fick du betala för Integralen fraktat & klart?
Postad 16 March 2016 - 21:06
Über-Guru
10990 inlägg
@mcmike
Jag beställde härifrån, fick betala utöver 200kr avgift/frakt dock för två
http://www.shop01med...4K60-444-600MHz
Postad 17 March 2016 - 12:03
jimjans
jimjans
3660 inlägg
52.0.27
Postad 17 March 2016 - 17:44
Über-Guru
10990 inlägg
Tack! Har installerat den nu
Redigerat av mcmike, 17 March 2016 - 18:15.
Postad 20 March 2016 - 14:28
Über-Guru
10990 inlägg
@jimjans kör du 3D genom den, får inte det att fungera. Måste man in i Integral USB GUI för att aktivera? Provade installera hdr paketet utan framgång
Postad 20 March 2016 - 16:41
jimjans
jimjans
3660 inlägg
vill inte oppon kicka igång 3dn ? Har du testat olika edid lägen?
Redigerat av jimjans, 20 March 2016 - 16:41.
Postad 20 March 2016 - 17:13
Über-Guru
10990 inlägg
Har provat alla in och utgångar/edid lägen. Oppon (hdmi 1 ut) känner inte av någon bildvisare i 3d, provat med både Jvc:n och Epsonen..
Postad 20 March 2016 - 18:38
jimjans
jimjans
3660 inlägg
Du kan ju även tvinga in den i vissa edid och även skapa egna lägen. Har 3d aldrig funkat eller kom det med senaste firmwaren?
Postad 20 March 2016 - 21:17
Über-Guru
10990 inlägg
Man måste tydligen installera Integral GUI som inkluderar HDR och 3D. Har fått till allt nu utom just sistnämnda säkert någon inställning nu bara
Redigerat av mcmike, 20 March 2016 - 21:17.
Postad 20 March 2016 - 22:27
Spygg
Spygg
542 inlägg
Hmm... Så med en sådan där mackapär skulle jag teoretiskt kunna koppla på följande vis, när jag köper en UHD-spelare:
- UHD-BD-spelare HDMI1 (bild) in i HD Fury
- UHD-BD-spelare HDMI2 (ljud) in i receiver
- BD-spelare HDMI1 (bild) in i HD Fury
- BD-spelare HDMI2 (ljud) in i receiver
- HD Fury HDMI1 ut -> projektor
Skulle det fungera?
Sen är det bara att hoppas att min 12-meters Supra-HDMI-kabel kan köra UHD-signal...
Postad 20 March 2016 - 23:16
Über-Guru
10990 inlägg
[quote name="mcmike" post="4320969" säkert någon inställning nu bara  [/quote] Till slut så nu fungerar det med denna inställning👌
Postad 21 March 2016 - 03:09
jimjans
jimjans
3660 inlägg
Med andra ord har du gjort en egen edid kanon att det funkade.
Skulle det fungera?
Borde funka.
Postad 29 March 2016 - 16:47
Über-Guru
10990 inlägg
Redigerat av mcmike, 29 November 2016 - 18:27.
Postad 27 June 2016 - 18:07
Über-Guru
10990 inlägg
Finns en ny uppdatering
https://www.hdfury.c...vtopcontroller/
Redigerat av mcmike, 27 June 2016 - 18:48.
Postad 28 June 2016 - 07:37
Über-Guru
10990 inlägg
Som vanligt sjukt smidigt med uppdateringen med nyheterna...😊
Edid Tables fixed for xvycc
1080p Edid bank 23 gets HDR capability added.
HDR metadata infoframe lenght fixed
Postad 19 July 2016 - 22:08
Über-Guru
10990 inlägg
fel
Redigerat av mcmike, 20 July 2016 - 10:23.
Postad 22 August 2016 - 18:51
Über-Guru
10990 inlägg
Har kopplat in Intergralen i hela kedjan nu! Alla 1080p källor genom receiver vidare till Intergral! Ultra spelaren genom den med (finns två hdmi in/ut) och sedan styr jag allt med mobil appen där signalen hanteras 1080/4k upp eller ned. Ja inte till den ena full hd projjen då Inga hdmi skakningar alls!
Redigerat av mcmike, 22 August 2016 - 19:07.
Postad 31 August 2016 - 18:22
Über-Guru
10990 inlägg
Finns en ny FW som löser följande!
This update IS NOT mandatory except if you are having an issue with one of the following: - You need valid edid banks for X1S check. - You have HTPC setup issue (display stand by, ON/OFF or out of sleep mode making issue, etc..) - You need to run extra long 600MHz cable run
If everything works fine in your setup you can wait further improvement to upgrade your unit. Total Control APP 1.0.6 for Android and iOS are available from the Download Page.
https://www.hdfury.c...k60-444-600mhz/
Redigerat av mcmike, 31 August 2016 - 18:22.
Postad 27 September 2016 - 21:28
Unregistered222df659
1236 inlägg
nästan gav upp på denna, men kopplade på måfå in Integralen mellan min htpc - msi gtx 1060 - och en oled65b6v, och kan få HDR:en a kicka in på tv:n men dessvärre så hoppar den loss efter en stund.
Har senaste firmwaren updaterat. Dock så ser windows (10) GUIn i 4k, skitliten ut. Svårt att ställa in alla inställningar för man ser dom inte riktigt bra. Läste nyss att man kan få CEC-knappen att aktivera hdr on/off. Ska testa det imorgon. Kör från gtx-kortet 422 12bit just nu. Vad är att rekommendera?
mumma om man kan få hdrläget att vara på när man vill och inte hoppa ur som nu. Dock måste jag dämpa allt någe, då det känns övermättat och konstigt ...;-)
Postad 28 September 2016 - 06:44
ekon
ekon
5779 inlägg
Vad testar du med för material när du kör HDR från HTPCn?
Postad 28 September 2016 - 10:43
1236 inlägg
inte hunnit testa nåt egentligen, då den hoppar ur, men skrivbordet blir helt annorlunda färgmässigt samt allt vitt blir starkare - och HDR dyker upp i hörnet, där tv:n visar vad den tar emot.
Postad 06 December 2016 - 22:34
Über-Guru
10990 inlägg
Ny uppdatering finns nu med bl,a Ultra fast blutooth..
Integral Firmware Update 0.60.0.34
- EDID automixing från två TV-apparater är nu beroende om TV: n är på / av i stället för kabel är ansluten. Detta hjälper till att återblanda en högre upplösning så snart som en lägre upplösning TV: n stängs av.
- Unified release som fungerar på nyare och äldre integrerad enhet. Tillåt ultrasnabb BT på nyare integrerad enhet. (BT SPEED TEST:
PS4PRO matar ut HDR på 4K60 4: 2: 2 12b och har testats fullt ut och bekräftade att arbeta med Integral.
Take Care:
den förvalda EDID är 4K30 4: 4: 4 efter uppdatering. Standard AUTOMIX EDID algo är Min Video Max ljud efter uppdatering. Som standard ARC är OFF och Integral är registrerad på CEC nätverk som en videoprocessor (CEC ID # 14), för att kunna använda Integral för ARC, använd GUI och välj "Audio System" (CEC ID # 05) Om du har en AVR som du använder för CEC eller ARC, sedan standardinställningarna efter uppdatering bör bli bra.
https://www.youtube.com/watch?v=-7nWnytoGK8
Postad 20 January 2017 - 15:12
ROBRUG
ROBRUG
288 inlägg
vore kalas om den kunde skala upp 1080 till 4k.
Postad 20 January 2017 - 16:01
3993 inlägg
Då är det en Linker du ska ha istället.
Postad 27 June 2017 - 14:50
alfarikard
alfarikard
29 inlägg
Hej på er!
Har en fråga angående integralen.
Jag har en Sony VW-300 och panasonic ub-900.
Jag kör ljudet separat via hdmi audio only.
Det jag är ute efter är att häkta av hdr och aktivera bt 2020.
Har precis fått hem integralen idag och kopplat in den via de övre hdmi in-och utgångarna.
Allt väl, får bild till projektorn men hittar inte hur jag får upp menyn. Är det något med att hålla inne två knappar samtidigt eller liknande.
För jag antar att man inte ska behöva koppla in den till datorn. Det finns ju inget medföljande programvara, så jag har tolkat det som att man endast använder datorn till uppdateringar?
Är tacksam för tips eller instruktioner.
Med vänlig hälsning Rikard Röhme
Postad 27 June 2017 - 15:49
alfarikard
alfarikard
29 inlägg
Postad 27 June 2017 - 16:06
macman
macman
1079 inlägg
Jag använde app till iphone/ipad
Redigerat av macman, 27 June 2017 - 16:07.
Postad 27 June 2017 - 17:17
alfarikard
alfarikard
29 inlägg
Tack för hjälpen!
Har inte fått någon instruktion med!
Får ladda ner den i app-store.
Tack än en gång.
Rikard
Postad 02 July 2017 - 12:02
Über-Guru
10990 inlägg
Integral 0.61.0.35 FW Update är tillgänglig från Download Tab : här
Se till att installera rätt silabs föraren baserat på din Windows-version och USB-port om du inte har gjort det.
Silabs Driver 4.0.0 för XP / Vista / Win7 / Win8 / WIN10 Silabs Driver 4.0.0 - ZIP - 9,18 Mo
USB2.0: WIN XP / Vista / Win7 / Win8 / WIN10
USB3.0: WIN10
Silabs Driver 3.9.2 för XP / Vista / Win7 / Win8 Silabs Driver 3.9.2 - ZIP - 1,65 Mo
USB3.0: WIN XP / Vista / Win7 / Win8 här uppdateringen ÄR ENDAST obligatorisk för DV och HLG support
Om allt fungerar bra i din installation kan du vänta ytterligare förbättring för att uppgradera din enhet.
Total Control APP för Android och iOS kommer att uppdateras senare att lägga HLG och Dolby Vision alternativ. (efter positiv återkoppling)
Här är en sammanfattning av vad som är nytt sedan vi meddelade FW 060.034 tidigare i den här tråden.
Mer information finns i Viktigt-filen för varje nedladdning. Integral Firmware Update 0.61.0.35 1. Lade Dolby Vision stöd Automix
2. Lade Data blocket alternativ för Automix
3. HDR Data blocket nu inkluderar HLG också.
+ Paketet firmware inkluderar fyra anpassade EDID med HLG och DV för att testa (när vi har tillräckligt med feedback vi kan lägga till dem som statiska / inbäddad i firmware)
Redigerat av mcmike, 02 July 2017 - 12:02.
Postad 02 July 2017 - 12:49
Über-Guru
10990 inlägg
Som vanligt sjukt smidigt att ladda ner och lägga in. Personligen inte i behov ännu av Dolby vision, men alltid skönt att ha senaste FW I alla fall
Postad 11 January 2018 - 09:55
Unregistered34276d92
34 inlägg
Behöver en splitter då jag troligen ska köpa ett försteg/processor som endast har 1.4 HDMI. Mina källor är 1080 och Apple TV 4K och behöver därför kunna skicka bilden till tv/och projektor och ljudet till processorn separat. Är HDFury något för mitt ändamål då?
Och vad är skillnaden på denna https://www.shop01me...age-Enhancement och den Integral?
/Sebbe
Postad 18 December 2018 - 20:25
tjomm
tjomm
47 inlägg
[quote name="sebjo89" post="4482171" timestamp="1515660934"]Behöver en splitter då jag troligen ska köpa ett försteg/processor som endast har 1.4 HDMI. Mina källor är 1080 och Apple TV 4K och behöver därför kunna skicka bilden till tv/och projektor och ljudet till processorn separat. Är HDFury något för mitt ändamål då? Och vad är skillnaden på denna https://www.shop01me...age-Enhancement och den Integral? Önskar starkt väcka liv denna tråd så här strax innan jul!! Har nog exakt samma problem som Sebbe här ovan men tyvärr fick han ju inget svar... Kör en ngt äldre Arcam AVR750 som inte tycks släppa igenom 4K bild från Xbox One S till en nyinköpt Samsung QE 75Q9FN. Får ut DTS- HDMA o Dolby TrueHD när jag kör in signalen direkt in i Arcam via HDMI men då ingen 4K signal till Samsungen. Vice versa när jag kopplar in Xboxen direkt till Samsungen o försöker köra ljudet via ARC —> Arcam får jag 4K bild men EJ okomprimerat ljud utan enbart Dolby D alternativt DTS komprimerat. Alltså kan en HDFury fixa detta?? Eller något annat förslag?! mcmike eller annan forumnörd; snälla hjälp /Thomas
Postad 18 December 2018 - 21:10
Über-Guru
10990 inlägg
Onödigt med en trådprodukt, då det borde fungera med konsolen direkt i tv:n
Postad 18 December 2018 - 21:34
tjomm
tjomm
47 inlägg
Javisst men problemet kvarstår ju...
Fattar inte varför jag då inte kan få okomprimerat ljud? Antog att det var grejen med HDFury; dvs att splitta HDMI-signalen för att få ut ljudet separat. Dvs ett snöre till stärkaren o ett till skärmen...
Postad 18 December 2018 - 21:37
Über-Guru
10990 inlägg
Har du en HDFury eller? Man kan splitta bild och ljud ja.!
Redigerat av mcmike, 18 December 2018 - 21:41.
Postad 18 December 2018 - 21:49
tjomm
tjomm
47 inlägg
Nej, men undrar då om detta kunde vara en möjlig lösning i väntan på att senare uppgradera till en modernare stärkare för att kunna få både 4K samt okomprimerat ljud ut??!!
Ytterligare alternativ jag lurat på vore o investera i en Panasonic UHD 420/820 som ju har dubbla HDMI ut...
Eller finns andra alternativ? Andra HDFury-modeller?
Redigerat av tjomm, 18 December 2018 - 21:50.
Postad 18 December 2018 - 21:55
Über-Guru
10990 inlägg
Jag splittade min Intregral när det begav sig, men jag hade lagt pengar på en Panasonic istället som är en bättre spelare än din Xbox dessutom. Trådprodukterna kostar ju en slant med. Jo det finns nyare HDfury produkter..
https://www.hdfury.c...uct/integral-2/
https://www.hdfury.c...roduct/maestro/
EU stället!
https://www.hdfury.e...9-hdfury-vertex
https://www.hdfury.e...ury-intergral-2
Redigerat av mcmike, 18 December 2018 - 21:59.
Postad 18 December 2018 - 22:29
tjomm
tjomm
47 inlägg
EU stället!
Tack för snabb och koncis input mcmike🙏
Lutar nog då åt en Panna 820 som ju dessutom fixar Dolby Vision.
Hoppas på mellandagsrean nu för kanske lite justare pris👍👍
Redigerat av tjomm, 18 December 2018 - 22:30.
Postad 19 December 2018 - 08:58
jln
jln
466 inlägg
Jag har ganska nyligen köpt en Integral2 (Vertex är precis samma fast med display). Jag var tvungen att splitta signalen en till projektorn och en till förstärkaren.
Så jag har dels en Sony X800 (2st HDMI) och en ATV 4K (1st HDMI) in i den sedan kopplar jag utgångarna till projektorn som klarar 4K60 HDR 18Gbps och förstärkaren som klarar 1080P60 8bit. Det fungerar kanon för mig.
Tänk på att det är en avancerad produkt som du måste lägga tid på för att förstå. Du måste läsa manualen och läsa forum om du vill förstå den hur den fungerar dvs hur den hanterar bilden och vilka inställningar du vill göra.
Tänk på att har du en fiberoptisk kabel som inte har extern strömförsörjning utan försörjs från HDMI kontakten måste du ha PCB2 varianten. Jag kör själv med Fibbr fiberoptiska HDMI kabel.
Den klarar alla bild och ljudformat.
Skall du köra ARC får du plocka ljudet ur den genom Toslink-kabel. DU kan aldrig skicka ARC genom en produkt utan måste plocka ur den ur första mottagaren av signalen.
Ljud
Förstärkare
Tonewinner 7300
Perlisten R18s
Philips Discoverer
Ny projektor!
