UltraHD DLP-projektorer
17 svar till detta ämne
Postad 08 January 2016 - 09:46
Japp TI har precis lanserat den nya UHD-kapabla DMD:n som kommer göra DLP-projektorer med UHD-upplösning förhållandevis billigt.
Bland de första modellerna att nyttja DMD:n är BenQ i deras nya W11000. Även Acer har en modell på gång inom kort. Fler lär tillkomma.
TI unveiled its new DLP 0.67-inch 4K ultra-high definition (UHD) chip at CES, enabling more affordable large screen projection displays for home, business and education. DLP technology combines speed and performance for accurate, razor sharp, 4K UHD projection displays. The DLP 4K UHD chip solution will be available in spring 2016.
The DLP 4K UHD solution uses the fast speed of the chip with advanced image processing to deliver more than 8 million pixels to the screen with just 4 million mirrors.  Each mirror is capable of switching over 9,000 times per second, creating two distinct and unique pixels on the screen during every frame to deliver full 4K UHD resolution.
"4K UHD comes to life when all of the details in the content are accurately displayed," said Dave Duncan, DLP Products business manager, Texas Instruments. "By giving customers the ability to incorporate a 4K UHD display chip that's roughly the same size as our 1080p chip, this new solution from TI DLP Products can be a game changer for the industry."
"TI's versatile 4K UHD chipset gives us the capability of developing high quality 4K UHD products for a variety of applications. With this product, more people will be able to enjoy 4K UHD projection systems," said Robert Sterzing, president, Optoma Technology.
According to TI there are a number of key features and benefits of the DLP 4K UHD solution:
High performance 4K UHD imager: The fast switching speed of the DMD enables each mirror to display two distinct and unique pixels on the screen during every frame, reducing blur and delivering full resolution. The inherent one-chip DLP system alignment enables the color integrity of the content to be maintained without blurriness between colors.
Affordable 4K UHD: With a small, 0.67-inch DMD that is similar in size to the DLP 0.65-inch 1080p chip, customers can have access to more affordable 4K UHD solutions in settings ranging from the home theater to the boardroom to the classroom.
Powerful ANSI contrast: DLP technology's high ANSI contrast brings out the fine details in 4K UHD content to offer a stunning viewing experience.
Advanced image processing: DLP Products' proprietary algorithms deliver sharp, high quality images with crisp and clear fine lines and details.
A flexible solution: The DLP chip can be used with multiple light sources including lamps, LEDs, and laser phosphor, giving manufacturers the flexibility to create a unique solution for a variety of applications.
Video som lanserar/förklarar det hela finns i länken nedan:
http://www.ti.com/ge...-pr-v-4KUHD-wwe
Postad 08 January 2016 - 10:07
Optoma är tidigt ute oxå. Med LED-ljuskälla och HDR-support. Bland annat...
https://youtu.be/LZ7BlWO5WgU
Postad 08 January 2016 - 11:51
MikeVKR
  • MikeVKR
  • 4029 inlägg
Kul med fler 4k projjar..
Postad 08 January 2016 - 15:42
Svärta
  • Svärta
  • 848 inlägg
HM. Den omnämns ett par gånger som "native 4K". När JVC använder en snarlik lösning är alla snabba att såga den som "inte äkta 4K". Vad är den avgörande skillnaden? Dessutom är frågan hur den ska konkurrera mot skärmar som når 1000 nits (och mer) för att återge HDR? Men kraven kanske sänks rejält när det handlar om projicerad bild?
Nåväl, jag vill inte vara för negativ och det viktigaste av allt är ju ändå vad som träffar duken, eller ännu hellre näthinnan ;)
Postad 08 January 2016 - 19:15
Skillnaden ligger i TIs lösning enl uppgift ger en UHD upplöst bild medans JVCs inte gör det.
1000 nits "kravet" gäller endast tv-apparater ja.
Postad 08 January 2016 - 23:03
smellymarq
  • smellymarq
  • 1040 inlägg
Optomas LED-version låter intressant. Men den blir nog väldigt dyr om den ska ha så ljusstark LED som klarar HDR och bra optik för 4K. Förmodligen dyrare än Benq W1100 iaf.
Postad 09 January 2016 - 07:03
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Enligt AVForums review & mätningar kan JVC's nya projjar för år 2016 spela upp både "4K" & Ultra HD upplöst film utan synliga störningar i bilden.
Postad 09 January 2016 - 12:07
Om så är fallet så finns ju ingen att "såga" JVC heller :)
Postad 09 January 2016 - 12:15
När du nu pratar om optik till 4k; har det ställts speciella krav på linser till 4k-projektorer?
Redigerat av Unregistered1fef72f3, 09 January 2016 - 12:15.
Postad 09 January 2016 - 12:17
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Precis! Men kul att DLP projjar kommer ut på marknaden med Ultra HD modeller i år det lär bli en spännande höst,minst sagt ☺
Postad 09 January 2016 - 12:18
Gjorde inte du just det, baserat på vilka uppgifter?
Redigerat av mcmike, 09 January 2016 - 12:18.
Postad 09 January 2016 - 14:09
jn82
  • jn82
  • 1762 inlägg
Alltså, JVC använder väl två full-hd planer för totalt 2x1920x1080 = 4147200 individuellt adresserbara pixlar, TIs nya chip har som jag förstår det 3840x2160=8294400 individuella pixlar, sen om du kan se skillnad eller inte är ju en annan femma, men 4M pixlar är bara hälften av "4k"-upplösning.
Att det är samma spegel som skapar bilden för två pixlar är väl inget konstigare än att samma ljuskälla ligger bakom alla pixlar i en projektor, så länge det inte finns någon restriktion i vad de två pixlarna kan visa. (Om det t.ex måste ha ungefär samma ljusstyrka eller något annat dumt, då är det inte längre 4K upplösning)
Postad 09 January 2016 - 14:34
Nej jag förklarade för svärta varför folk "sågat" JVC medans TI, än så länge, går fria.
Vilka uppgifter? Samtliga reviews jag sett om JVCs eshift projjar tror jag. Vet inte vad jeppeman har läst för test på avforums. Bara läst den om x5000 och där framgår tydligt att den inte ger UHD upplöst bild. Så "om" är ett nyckelord i sammanhanget...
Postad 09 January 2016 - 14:44
Tror? Länka gärna till dessa uppgifter då? Du kan fortsätta i denna tråd ;)
https://www.minhembi...howtopic=325281
Redigerat av mcmike, 09 January 2016 - 14:45.
Postad 09 January 2016 - 15:14
Tror ja. Kan inte garantera att alla reviews jag läst ens undersökt saken ifråga.
Men av de som gjort det så är det ingen som bekräftat att UHD-upplöst bild uppnås.
Haha, you are trying too hard...reviews av JVCs projjar får du vackert ta och Googla fram själv. Avforums tycks du ju hitta till iaf. :D
Postad 09 January 2016 - 15:42
Var kan man få ta del av den informationen?
Postad 09 January 2016 - 22:49
smellymarq
  • smellymarq
  • 1040 inlägg
Det krävs oftast en bättre optik för att få en bra bild i 4k. Men inget krav för att klara någon certifiering eller liknande.
Postad 09 November 2016 - 13:30
lajbanson
  • lajbanson
  • 246 inlägg
Snart 2017. Var kommer vi landa i pris för Benq W11000 tro? En utmanare till Epson 7300 eller 9300 kanske?
http://homecinemacen...-spec-sheet.pdf
Ok, verkar ligga i klassen över - omkring +50tkr om man får tro:
http://www.gadgetguy...atre-projector/
