OPPO BDT-101CI
47 svar till detta ämne
Postad 26 June 2016 - 17:28
Dr. Zaius
Dr. Zaius
3613 inlägg
OPPO BDT-101CI
https://www.oppodigi...-ray-bdt-101CI/
BDT101CI-front.png 407.33K
1 Antal nerladdningar
BDT101CI-left-quarter.png 544.97K
BDT101CI-back.png 414.39K
Advanced Features
- Universal disc format support including Blu-ray, Blu-ray 3D1, DVD, DVD-Audio, Super Audio CD, CD, HDCD and more
- Upscaling to Ultra HD (4K) resolution
- VRS® (Video Reference Series) ClearView™ video processing
- Dolby® TrueHD and Dolby Digital Plus decoding
- DTS-HD Master Audio™ decoding
- Bitstream output compatible with Dolby Atmos and DTS-X
- Three USB ports for playback of media files2 (AVCHD, MKV, AVI, MP4, WAV, FLAC, APE, DSD, etc.)
- Ethernet port for BD-Live, firmware upgrade and home network media file playback
- True 24p™ video for Blu-ray encoded in 24Hz frame rate and optional conversion of DVD to 24p
- Multiple zoom modes
- Advanced picture control including video smoothing, detail and edge enhancement
- Premium 32-bit audio DAC by AKM
- Optical and coaxial digital audio outputs
- Rigid steel chassis and center mounted disc loader with motion balance and vibration isolating mechanisms
- Back-lit remote control
Custom Integration Features
- Versatile modular design with many customized options
- One or two HDMI outputs via the additional HDMI output module
- Optional HDBaseT output module for long cable runs
- Stereo or optional 7.1ch analog audio output module
- Optional rack mount kit
- Large front panel buttons with finger guards
- RS232 and IP control for system integration
- Switchable rear IR sensor for a clean IR blaster/emitter installation
- HDMI CEC (Consumer Electronics Control)
- Three customizable picture adjustment presets
- Settings can be locked to prevent inadvertent changes
Notes: 1 Requires proper 3D television and glasses. 2 Compatibility with user-encoded contents or user-created discs is on a best-effort basis with no guarantee due to the variation of media, software and techniques used.
All trademarks are the property of their respective owners.
Specifications
Designs and specifications are subject to change without notice.
Disc Types BD-Video, Blu-ray 3D, DVD-Video, DVD-Audio, AVCHD, SACD, CD, HDCD, Kodak Picture CD, CD-R/RW, DVD±R/RW, DVD±R DL, BD-R/RE BD Profile BD-ROM Version 2.5 Profile 5 (also compatible with Profile 1 Version 1.0 and 1.1) Output Analog Audio: stereo / 5.1ch / 7.1ch
Coaxial/Optical Audio: up to 2ch/192kHz PCM, Dolby Digital, DTS.
HDMI Audio: up to 7.1ch/192kHz PCM, up to 5.1ch DSD, bitstream.
HDMI Video: 480i/480p/576i/576p/720p/1080i/1080p/1080p24/UHD, 3D frame-packing 720p/1080p24. Audio Characteristics
(Nominal specification) Frequency: 20Hz – 20kHz (±0.2dB), 20Hz – 96kHz (-3.5dB ~ +0.05dB)
Signal-to-Noise Ratio: >105dB (A-weighted)
THD+N: < 0.0012% (1kHz at 0dBFS, 20kHz LPF) General Specification Power Supply: ~100V – 240V, 50/60Hz AC
Power Consumption: 40W (Standby: 0.5W in Energy Efficient Mode)
Dimensions: 16.9 x 11.3 x 4.1 inches (430mm x 287mm x 105mm)
Mass: 9.9 lbs (4.5kg) Operating Temperature 41°F - 95°F
5°C - 35°C Operating Humidity 15% - 75%
No condensation Parts & Labor Warranty 2 Years
Redigerat av Dr. Zaius, 26 June 2016 - 19:46.
Postad 26 June 2016 - 17:38
2900 inlägg
Varför släpper dom en ny bd spelare?
Postad 26 June 2016 - 17:42
MikaelJ
MikaelJ
758 inlägg
+1 Känns mycket märkligt.
Postad 26 June 2016 - 18:04
Dr. Zaius
Dr. Zaius
3613 inlägg
Det är väl bra med ett billigare alternativ till Oppos dyrare spelare, där man dessutom själv kan välja vilka funktioner som ska ingå.
Får jag inte ordning på min nuvarande BDP-83:a så ersätts den troligtvis av denna spelaren, om den nu går att fås regionsfri vill säga.
Redigerat av Dr. Zaius, 26 June 2016 - 18:05.
Postad 26 June 2016 - 18:14
2900 inlägg
Äh... De släpper väl sin uhd till jul så denna blir överflödig!
Postad 26 June 2016 - 20:41
Dr. Zaius
Dr. Zaius
3613 inlägg
Överflödig tror jag inte den är/blir och passar mina behov perfekt i dagsläget.
Postad 26 June 2016 - 21:10
3449 inlägg
Betyder det att den klarar av atmos även om man kör bitstream?
Postad 26 June 2016 - 21:32
Dr. Zaius
Dr. Zaius
3613 inlägg
Likt BDP-103 och BDP-105 saknar BDT-101 intern dekoder för Atmos och DTS-X, men klarar att skicka ljudet som bitstream till en Receiver som klarar att koda av Atmos och DTS-X.
Postad 26 June 2016 - 21:52
3449 inlägg
Men vad fan, det var jag som fick en tankevurpa o blandade ihop pcm o bitstream :/
Redigerat av johan b-lund, 26 June 2016 - 21:52.
Postad 26 June 2016 - 22:04
Dr. Zaius
Dr. Zaius
3613 inlägg
Är inte helt lätt att hålla reda på alla format. Vet knappt om jag fick till det jag skrev helt rätt men tror och hoppas det så jag inte lurar någon.
Postad 27 June 2016 - 11:39
Dr. Zaius
Dr. Zaius
3613 inlägg
Dubbel kollade för att vara helt säker på att religionsfriheten även gäller Blu-ray och har nu fått bekräftat att så är fallet. Så en OPPO BDT-101CI i basutförande utöver chipet för religionsfrihet skulle kosta mig totalt ca 5.500:-.
Vet att Oppo kommer släppa en UHD spelare men känner inget större behov av det i dagsläget och väntar gärna på att formatet hinner mogna lite innan jag hoppar på. Vet att det kan gå fort och kommer säkert vad det lider, men har hittills ännu inte släppts en enda titel som är av intresse för egen del vilket också spelar in.
Postad 27 June 2016 - 12:26
budwhite
budwhite
1918 inlägg
Jag betalade ca 5900-: för min 103D inklusive regfri och frakt/tull. När du skrev billig så tänkte jag ca 2000-:
Postad 27 June 2016 - 13:18
Dr. Zaius
Dr. Zaius
3613 inlägg
Jag skrev "ett billigare alternativ" till Oppos dyrare modeller. Inget fel med att importera men har inget emot att handla av en inhemsk handlare och betala lite extra i det här fallet.
Postad 28 June 2016 - 22:29
Dr. Zaius
Dr. Zaius
3613 inlägg
Tyvärr är videon på Tyska men tycker man fattar det mesta ändå och ger om inte annat en bra bild av hur spelaren ser ut på in och utsidan
https://www.youtube.com/watch?v=ThzFx5L7Y4c
Postad 30 June 2016 - 10:11
Dr. Zaius
Dr. Zaius
3613 inlägg
Har fått hem min Oppo BDT-101CI och den inger ett väldigt gediget intryck med sin höga byggkvalité. Gillar även den rena designen utan en massa onödiga logor och kommer trivas värdigt bra med denna spelare känns det som. Kommer nog vänta med att installera den tills jag fått hem regionsfri-chipet men sen blir det åka av.
IMG_5397.JPG 134.48K
2 Antal nerladdningar
IMG_5407.JPG 107.77K
Postad 30 June 2016 - 11:43
Dr. Zaius
Dr. Zaius
3613 inlägg
Köpte min från Hembiobutiken men är kul och se att fler och fler butiker tar in den i sitt sortiment som t.ex The Rock som precis börjat sälja den nu också.
Postad 07 July 2016 - 13:40
Dr. Zaius
Dr. Zaius
3613 inlägg
Tog lite tid men fick idag regionschipet så nu kan jag skrota min gamla BD-83:a. Har inte hunnit testa så mycket men allt verkar funka som det ska och är mycket nöjd så här långt.
Postad 08 July 2016 - 19:53
Dr. Zaius
Dr. Zaius
3613 inlägg
Har hunnit bekantat mig lite mer med spelaren nu och kan konstatera att den är betydligt snabbare på att starta upp filmer och är i princip ljudlös jämfört med min gamla BDP-83. Tycker även spelaren svarar snabbare på fjärrkontrollen och är allmänt rappare på nåt sätt. Visst det finns billigare alternativ men är man ute efter en ren, stabil och högkvalitativ Blu-ray spelare som går att fås regionsfri kan jag klart rekommendera denna spelaren. Att den dessutom är jävligt snygg och stilren gör ju inte saken sämre.
Postad 09 July 2016 - 04:19
Metalmartin
Metalmartin
488 inlägg
Hur var det att installera , plug n play?
/ Martin
Postad 09 July 2016 - 08:00
Dr. Zaius
Dr. Zaius
3613 inlägg
Det var enkelt i sig, däremot följde det inte med nån dokumentation på exakt vilken kontakt på kretskortet som kontakten för region chipet skulle sitta. Det var lite dåligt och ska kontakta Hembiobutiken och påpeka detta, men lånade en bild så länge och ringade in med röd färg vart på kretskortet kontakten för region chipet ska sitta för den som är intresserad.
På bildexemplet nedan sitter det instickskort för en extra HDMI utgång och analog 7.1 utgång ser det ut som (inringat med grön färg) vilket min spelare saknar.
OPPO-BDT101CI-vue-interne-globale.jpg 132.9K
Edit: Själva chipet jag fick är från jvbdigital.nl men är misstänkt likt det som Bluraychip.dk säljer till OPPO BDP-103(D)/105(D) och är säkert samma chip som används.
Bild lånad från bluraychip.dk:
26-106-large.jpg 51.94K
0 Antal nerladdningar
Redigerat av Dr. Zaius, 09 July 2016 - 09:54.
Postad 11 July 2016 - 15:53
Dr. Zaius
Dr. Zaius
3613 inlägg
Var i kontakt med Hembiobutiken angående att det saknades tydliga instruktioner för var exakt regionchipet skulle kopplas in. Fick till svar att dom skulle kolla upp vad dom kunde göra för att underlätta installationen för kommande köpare.
Postad 20 July 2016 - 10:53
skrotfot
skrotfot
1201 inlägg
Tack för gedigen uppföljning Dr. Zaius!
Funderar själv på att införskaffa en gedigen bdspelare och denna är en av alternativen.
Postad 20 July 2016 - 14:40
Dr. Zaius
Dr. Zaius
3613 inlägg
Trycker du gör helt rätt i att ha med den som ett alternativ för det är en riktigt bra spelare.
Postad 20 July 2016 - 16:26
skrotfot
skrotfot
1201 inlägg
Beställd från Hembiobutiken idag, valde en ren vanilla edition utan extra chip. Köper mest BD i Sverige och det går ju att uppgradera sen vid behov. Sjukt trött på min Sony BDP-S6200 som jag aldrig varit nöjd med. Fattar egentligen inte att jag stått ut med den i två år. Gissar att denna kommer att leverera liiite bättre
Postad 20 July 2016 - 18:38
Dr. Zaius
Dr. Zaius
3613 inlägg
Nu har inte jag nån erfarenhet av just Sony BDP-S6200 men tror inte du kommer bli besviken och lär om inte annat märka skillnad i byggkvalitén.
Postad 22 July 2016 - 19:36
skrotfot
skrotfot
1201 inlägg
Nu är den inkopplad!
Bilden är naturligtvis svinbra, men det som var mest överraskande var hur lättanvänd den är i menyer och inställningar.
Kopplade medföljande hdmi till min 55" Sony W805 från 2014, avaktiverade ljudet i hdmi eftersom jag kopplat en optisk kabel till min Hegel H300 för att ha gott ljud ut från Dynaudio 160.
Känns som om denna Oppo blir långlivad hemma hos mig
Postad 22 July 2016 - 20:23
Dr. Zaius
Dr. Zaius
3613 inlägg
Förstår att du är nöjd och håller med om att den är väldigt användarvänlig. Har svårt att tänka mig att det finns någon bättre spelare i prisklassen då allt känns genomtänkt och bra på alla sätt.
Redigerat av Dr. Zaius, 23 July 2016 - 00:29.
Postad 24 July 2016 - 11:57
budwhite
budwhite
1918 inlägg
Har två klagomål på Oppo:
Den hänger sig ganska ofta, antingen om jag spelar musik eller om jag ser på netflix.
Att inte gapleas playback funkar på 192/24 filer.
Utöver det har jag inget att anmärka på. Har 103D. Kanske är åtgärdat för den modellen ni har?
Postad 24 July 2016 - 17:04
Dr. Zaius
Dr. Zaius
3613 inlägg
Vet ej, har inte testat hur den är på att spela upp media filer och några appar finns inte på denna spelare.
Postad 03 August 2016 - 10:19
skrotfot
skrotfot
1201 inlägg
http://av2day.com/20...blu-ray-player/
Inget revolutionerade skrivs, men det har iaf skrivits lite. Gissar att de flesta i branchen är lite för upptagna med HDR just nu. Eller också har de semester.
Postad 03 August 2016 - 15:37
Dr. Zaius
Dr. Zaius
3613 inlägg
Nej, finns inte så mycket skrivet om den och har som du säger säkert mycket med Ultra HD hysterin som råder just nu.
Postad 25 August 2016 - 16:22
Dr. Zaius
Dr. Zaius
3613 inlägg
HDfever.fr har genomfört ett rätt genomgående test av Oppo BDT-101CI och ger den ett högt betyg.
http://www.hdfever.f...comment-page-4/
Google översatt länk till testet: https://translate.go...comment-page-4/
Redigerat av Dr. Zaius, 25 August 2016 - 16:23.
Postad 01 September 2016 - 21:13
Dr. Zaius
Dr. Zaius
3613 inlägg
Såg att användaren Per K ikväll lagt upp en bild på sin nyinköpta 101:a i sitt galleri. Då är vi i alla fall minst tre på forumet som har den här fina Blu-ray spelaren.
Postad 20 November 2016 - 20:53
Unregistered6c5f6b14
32 inlägg
Hej.
Jag är intresserad av en BD-spelare i 5000:- klassen och denna verkar intressant. Ni som har använt den en längre tid, finns det något att anmärka på eller är det en robust kvalitetsspelare med enkelt handhavande?. Jag är primärt ute efter bra analogt ljud från stereoutgångarna och bra bild från DVD/BD via HDMI. Sedan undrar jag hur släden uppför sig när den är fullt ute (hittar inga filmer). Kommer hela skivhållaren fram eller bara delvis? Har haft tidigare spelare där släden inte kommer hela vägen ut utan man måste lirka in skivan i spelaren. randvillkor men något jag stör mig på (efter att ha repat några skivor i mörkret).
Postad 20 November 2016 - 22:17
Dr. Zaius
Dr. Zaius
3613 inlägg
Har haft min nu i ca 5 månader och är fortfarande väldigt nöjd så här långt. Använder spelaren så gott som enbart för DVD och Blu-ray uppspelning via HDMI och har därför inte haft anledning att testa den analoga ljudutgången.
Skivsläden åker inte riktigt ut helt men upplever det inte som något problemen.
IMG_6438.jpg 173.24K
3 Antal nerladdningar
Postad 21 November 2016 - 10:32
32 inlägg
Tack för bra bild. En sak till. Hur är ljudnivån från mekaniken? Kan man höra någon form av oljud?
Postad 21 November 2016 - 10:48
Dr. Zaius
Dr. Zaius
3613 inlägg
Upplever den som väldigt tyst och måste i princip lägga örat emot spelaren för att höra att den är igång.
Postad 21 November 2016 - 11:13
skrotfot
skrotfot
1201 inlägg
Håller med Dr. Zaius.
Spelaren är ett gediget bygge, jag har dock min i skåp så den hörs inte alls.
Dock hängde den upp sig härom dagen då den inte kunde ladda en disc, men jag höll in powerknappen ett tag så dog den och sedan var allt som vanligt igen.
Postad 02 December 2016 - 17:42
32 inlägg
Ursäkta mina myckna frågor men jag har ingen butik i närheten där jag kan få en demo. Och eftersom kompetensen här är hög så hoppas jag på bra respons. Jag hade nyligen hemma Sony UHP-H1 (nu tillbakalämnad efter stor besvikelse så tack för öppet köp på Elgiganten) efter positiva recensioner i What HI-FI. Trodde spelaren skulle ha grundläggande funktioner likt min Primarespelare (som tyvärr gått sönder och nu måste ersättas) men tyvärr. Därav mina frågor (notera att dessa inte fungerade som jag ville på Sonyspelaren):
1. Kommer spelaren ihåg var jag slutade titta på en film/tv-serie när jag stoppar in skivan igen?
2. Startar avspelning av en skiva så fort jag satt in den i spelaren?
3. Kan jag slå på "repeat all" eller "shuffle" för en CD-skiva via fjärren utan att slå på TV:n?
4. Hur funkar den regionsfria varianten (viisa butiker säljer denna för ca 500:- extra)? Är det automatiskt eller måste man slå in ngn form av kod via fjärren?
Jag kommer använda spelaren till mycket CD-avspelning så jag vill kunna hantera uppspelningen utan att behöva slå på TV:n.
Notera att ovanstående inte gick med Sonyspelaren. Den var att likna vid en HTPC som kräver skärm (= TV) för alla operationer samt att den var otroligt buggig :-(.
Postad 03 December 2016 - 12:24
Dr. Zaius
Dr. Zaius
3613 inlägg
1. Ja, om disken i fråga stödjer funktionen.
2. Ja.
3. Mig veterligen saknar spelaren funktionerna "repeat all" och "shuffle".
4. För Blu-ray måste man ändra region manuellt, för DVD sker det automatiskt.
Postad 03 December 2016 - 16:16
32 inlägg
Hmm. Angående svaret på #3 så blir jag lite frågande. Kikade i manualen (User Manual) som finns på nätet i PDF-format. Och där verkar det som att det finns en repeatknapp på fjärren (s 8) och på sidan 21 ska man kunna toggla repeatläge. Och på sidan 22 pratas om shuffle. Men detta funkar alltså inte?
Postad 03 December 2016 - 18:59
Dr. Zaius
Dr. Zaius
3613 inlägg
Okej. Är inte hemma nu men kan testa senare ikväll.
Edit: Har nu testat och mycket riktigt som du är inne på så finns och fungerar "repeat" och "shuffle" vid CD uppspelning.
Redigerat av Dr. Zaius, 03 December 2016 - 23:20.
Postad 10 December 2016 - 13:23
32 inlägg
Tack. Då verkar handhavandet vara så enkelt som manualen beskriver. Helt i min smak.
Postad 11 December 2016 - 22:53
Bananklasen
Bananklasen
768 inlägg
Oj denna spelare har jag helt missat! Har alltid velat testa en Oppo men tyckt att deras spelare varit i dyraste laget. Denna känns mer skonsam mot plånboken även om det fortfarande kostar en del. Man blir grymt sugen på införskaffa en, regionsfri måste den dock vara
Postad 23 January 2017 - 12:19
Schonning
Schonning
148 inlägg
Jag är mycket sugen på att uppgradera till en Oppo, och då jag har en fullsmetad HTPC så behöver jag verkligen inte alla "SMART" funktioner i t.ex 103. Finns det idag några konkurrenter till denna 101CI i prisklassen, eller är den herre-på-täppan vad gäller BD-spelare under 5000kr?
Postad 23 January 2017 - 18:08
Dr. Zaius
Dr. Zaius
3613 inlägg
Vet ej, är mycket möjligt det finns spelare med likvärdig prestanda men tror inte du hittar någon spelare som är bättre i prisklassen.
Postad 23 January 2017 - 18:45
Spygg
Spygg
542 inlägg
Du har ett PM!
Postad 13 October 2017 - 17:38
Unregistered481340a5
3 inlägg
Borttaget
Redigerat av Unregistered481340a5, 13 October 2017 - 18:59.
Media & Mediauppspelning
High Definition
Blu-ray
Titan Noir Max
LFE reference och Center ch
