HDfury Linker 4k60
46 svar till detta ämne
Postad 20 July 2016 - 10:32
Kan nu förbokas med pre leverans datum 20 aug. Den har  ULTRA HD PREMIUM loggan  :) Kommer dessutom att stödja Dolby vision!
https://www.hdfury.c...k60-444-600mhz/
Eller 165 pund
http://www.chromapur...9&type=products
No more boundaries in HDMI | Pre-Order the A/V gear that link them all!
HDfury Linker is a 4K60 4:4:4 600MHz 18Gbps HDMI2.0a Level A capable scaler built for system integrators and advanced users that will please everyone else as well.
By supporting the max bandwidth and data transfer rate of the HDMI2.0a standard and by offering new scaling modes, options and possibilities to convert and always fed optimum signal through all existing HDMI and HDCP revision, Linker is set to cross all HDMI boundaries.
Linker is capable of connecting any HDMI/HDCP revision sources devices to any HDMI/HDCP revision sink devices @ their best capabilities. GUARANTEED!
If you ever saw the following statement: “this TV does not support HDCP 2.2. Make sure you have HDCP 2.2 capable TV” or a similar HDCP error message, and even if you fixed such issue with Integral or others but run into limitations like signal unsupported, blackscreen, not getting the best signal to your display from all your sources or no AVR audio available when 4K signal is running or any others, make sure you never see any of them again with the HDfury Linker! Featuring 2 inputs and 1 output, HDfury Linker can act as Scaler, Switcher, Infoframe and HDR metadata Injector and Extractor with Sound, HDCP Doctor, HDMI Doctor, EDID management and more… Discover the tomorrow’s hardware today!
HDfury Linker Key Features
Ultra Scaling up to 4K60 4:4:4 600MHz
HDfury Linker offers impressive scaling modes to ensure that any HDMI/HDCP revision sink device get fed at its max capabilities ALWAYS and GUARANTEED.
Featuring Upscale, Downscale, Passthru and Bypass mode as well as Chroma Conversion and Color Depth modification on the fly at 8, 10, 12 and 16bit for FHD, UHD and DCI 4096x2160p.
Here is, among plenty others, some of the available scaling modes…
HDCP/HDMI2.x HDR/BT2020 sources input > To High-End Advanced HDCP/HDMI 1.x Displays
4K24/25/30 RGB/YCC 4:4:4 12b 450MHz > 1080p24/25/30 RGB/YCC 4:4:4 12b 111MHz
4K50/60 YCC 4:2:0 10b 371MHz > 1080p50/60 RGB/YCC 4:4:4 10b 185MHz
4K24/25/30 RGB/YCC 4:4:4 12b 450MHz > 4K24/25/30 YCC 4:2:0 12b 222MHz
HDCP/HDMI2.x HDR/BT2020 sources input > to basic HDCP/HDMI 1.x Equipment like AV receiver
4K50/60 YCC 4:2:0 10b 371MHz > 1080p50/60 RGB/YCC 4:4:4 8b 148MHz
4K24/25/30 YCC RGB/YCC 4:4:4 12b 450MHz > 1080p24/25/30 RGB/YCC 4:4:4 8b 74.25MHz
4K50/60 RGB/YCC 4:4:4/4:2:2 8b 600MHz > 1080p50/60 RGB/YCC 4:4:4 8b 148MHz
HDCP/HDM1.x Capable Sources input > to Advanced HDCP/HDMI 2.x Capable Sink
4K24/25/30 RGB/YCC 4:4:4 8b 300MHz > 4K24/25/30 RGB/YCC 4:4:4 16b 600MHz*
1080p24/25/30 RGB/YCC 4:4:4 16b 148MHz > 4K24/25/30 RGB/YCC 4:4:4 16b 600MHz*
This is only a small excerpt, endless scaling possibilities are available, the Ultra Scaling modes list is now so big that we had to publish it separately: here
* Tested ok on LG OLED 2016
Dedicated HDCP Doctor
Providing a total of 4 HDCP 1.4 and 2.2 engines for decryption/encryption, HDfury Linker offers a workaround for HDCP issue including HDCP 2.2 > HDCP 1.4 and HDCP 1.4 > HDCP 2.2 both ways conversion within the same unit.
Each RX block decrypts the input first whether its 1.x or 2.x. Then output port can individually encrypts it to 1.4 or 2.2 or not encrypt it at all if it was not encrypted initially.
Unlike HDfury Integral that can convert any signals within the 600MHz bandwidth of HDMI2.0a, thus including 1080i, 3D signals, PC signals and all SD/HD/FHD/UHD standard formats, HDfury Linker only support HDCP conversion for SD/HD/FHD/UHD signals up to 600MHz.
1080i, 3D signals, PC signals (except a few manually added) cannot be HDCP converted with the HDfury Linker, they go through in Bypass mode (untouched/untouchable).
Display HDCP 2.2 Content with Non-HDCP2.2 Compliant Devices
HDCP 2.2 is the new copy-protection scheme for 4K UHD content.Not only it is not backward compatible but many recent 4K devices don’t even support it.
Source devices, including media servers and head-ends like Netflix, will encode their 4K content with this new scheme. TVs must be HDCP 2.2-enabled to play it, and everything in the video chain including switches and receivers must be compliant as well, or the display will go dark and/or display a HDCP error message.
Bad news for consumers who have purchased expensive, high-bandwidth, processor-rich switchers, receivers and displays to accommodate 4K. While the newer products may support the bandwidth needs of 4K, they won’t play copy-protected works until HDfury Linker is an active part of the setup.
2×1 Switcher up to 4K60 4:4:4 600MHz 18Gbps
Switching between 2 inputs up to 4K60 4:4:4 600MHz signal and scaling through all HDMI levels and revision is now a reality, thanx to USB or push button, you can easily switch between 2 inputs that will be scaled to one output. HDCP conversion can be configured and applied on the fly in order to always output the type of HDCP signal encryption that your display or sink device is expecting.
HDR and Infoframe Metadata Live Injector and Extractor with Sound
The HDfury Linker is capable of injecting and extracting live Infoframe and HDR metadata at any resolution and in real time while keeping HDMI sound.
A further software solution for a complete real time handling of infoframe and HDR metadata will be available for the Linker: here from our exclusive licensed partner AV TOP.
Advanced EDID Management
Advanced EDID Management available from the HDfury Linker with either:
A Selected EDID bank, a Custom uploaded EDID, a Self generated Automix EDID or a Fixed basic EDID.
Sniff EDID from connected sink devices, Save, Edit, Load any custom EDID table at anytime.
Select and pick any EDID of your choice from a preloaded list of 25 EDID tables, it loads and reset HPD to present your chosen one automatically.
AutoMix EDID feature will create a custom EDID by mixing both sink EDID connected to the splitter output ports.
Mixing rules in AutoMix mode can be selected through 4 different algorithms.
Some EDID flags can be forced in Automix such as: Stereo/5.1/Full/YCbCr/BT2020/HDR/3D
Control and Update
USB GUI Utility via Windows PC and various physical buttons for configurations are available.
External Bluetooth dongle for iOS/Android control might be available in the future. (Not yet guaranteed, please revisit prior to launch)
Rec.709<->BT2020 via 3×3 Matrix and RGB Coeff
There is chance the 4K Linker will be able to convert 709<>BT2020, both ways, in the near future but it’s not yet a guaranteed feature. Work in progress.
Redigerat av mcmike, 20 July 2016 - 10:33.
Postad 02 December 2016 - 09:02
Iceman666
  • Iceman666
  • 481 inlägg
Ja nu har du haft den i ett 1/2 år, vad har du att säga om den?
Postad 03 December 2016 - 13:24
Jag har Intergralen! Den fungerar hur bra som helst med alla skakningar och tack vare denna slipper jag byta förstärkare. Fantastisk produkt :)
Postad 09 December 2016 - 17:45
Iceman666
  • Iceman666
  • 481 inlägg
Right after the release of the brand new 2017 Integral Ultra Fast Edition. We are glad to announce the availability of FW and GUI1.6 for our proud 4K Linker owners out there.
While previous update already added adjustment to the 4K Linker routines to support 4:2:2 deepcolor such as 4K60 4:2:2 12b HDR/BT2020 600MHz from the PS4/Pro as well as support for 4K24/25/30 4:2:2 12b HDR/BT2020 300MHz (Best possible timing for HDMI1.x Bandwidth). This new update is adding new basic and quick preset for HDMI1.x PJ or equipment @ 4K24/25/30 BT2020 deepcolor signal.
Below some technicals on last changes in FW and GUI1.6
Added 2 new autopreset 4k30 8/10/12 -> 4k30 422 12 300MHz and 4k60 600MHz -> 4k60 420 300MHz. This is great for typical 300MHz PJ (like UB and TW series from EPSON) so that all HDR is output as 422 12 bit 300MHz except 4k60 422 12 bit 600MHz which comes out as 4k60 420 8bit 300mhz (HDR lost at 4K60 due to 300MHz BW limit). This preset is also added to the Quickpresets selection and the list is now as follows: The number 2/3 are new.
[Quick Preset Selection]
1. Normal operation, clear all 4k30/4k60 presets, clear all deepcoor/colorspace to defaults.
2. Set 4k30/4k60 presets for a 4K30 deepcolor PJ > 300MHz (e.g Wireless Espon)
[4K30 all -> 4K30 all, 4k60 600MHz -> 4k60 420 300MHz]
3. Set 4k30/4k60 presets for a 4K30 deepcolor PJ at 300MHz (e.g Wired Epson)
[4k30 8/10/12 -> 4k30 422 12 300, 4k60 600MHz -> 4k60 420 300MHz]
4. Set 4k30/4k60 presets for a 4k60 420 300MHz TV
[4k30 8/10/12 -> 4k30 8, 4k60 600MHz -> 4k60 420 300MHz]
5. Set 4k30/4k60 presets for a 4k30 8-bit 300MHz TV
[4k30 8/10/12 -> 4k30 8, 4k60 all-> 1080p60 444 8/10/12]
6. Set 4k30/4k60 presets for a 1080p60 TV
[4k30 8/10/12 -> 1080p30 8/10/12, 4k60 all-> 1080p60 444 8/10/12]
7. CS follow / DC follow
8. CS 4:4:4 / DC follow
9. CS 4:2:0 / DC follow
10. CS 4:4:4 / DC 8 bit
11. CS 4:2:0 / DC 8-bit
Postad 27 February 2017 - 19:54
Iceman666
  • Iceman666
  • 481 inlägg
We are proud to announce the availability of FW and GUI update 0.19 for the HDfury 4K Linker, all fully tested and compatible with all and latest HDCP2.2 sources like UB700/900, K8500, Shield, PS4PRO and others. Now finally scaling or switching resolution, handshaking or HDCP converting, all at the same time !
View this email in your browser
Calibrated HDR for JVC PJ
JVC Calibration ressources page
Thanx to AVSforum power users such as Manni01 and Arve, JVC PJ owners now have a way to inject Custom Gamma curves for proper HDR mode calibration and get their Dynamic Iris working with the latest Linker firmware (0.19). You can follow Manni01 Guide for setting up the Linker: here.
Linker is now capable of not only extracting and injecting HDR infoframe, AVI infoframe and others, since FW0.19, it is also capable of completely removing any HDR metadata so HDR content can reach a HDR display without activating that display's HDR mode thus allowing custom curve and Dynamic Iris to work.
Here is a small excerpt of JVC PJ owners when using Linker and custom Gamma Curve + Dynamic Iris in HDR mode:
"Best HDR I have ever seen in my system". - atabea
"I'm still using the 1000-4000V1 but watched X-Men Apocalypse last night and it looked absolutely fantastic!" - krichter1
"Dark content like Goliath looks fantastic now on my RS500 with a working DI and a Manni custom gamma. I will be watching this series all over again now". - claw
"hits you in the face !!! my GOD ! is this some of the MOST stunning pics have seen on the jvc ??? Goodness it looks stunning". - alebonau
"DI works fabulously and I'm really impressed with the picture. Sharp as a tack, saturated with color, and highlights (shiny chrome, reflections, fire) seem to jump off the screen....Just finished up Lucy. Man what a ride. The picture was just stunning, deep colors, and the opening scene with the 'Lucy' ape in the water. Really happy with the PQ I'll just leave it there" - sonichart
"When I put on Xmen in 4k SDR it is slightly soft and nobody in the room commented on the picture.
When I put on Xmen in 4k with HDR and a custom Gamma curve I was blown away and people that know nothing about the technical details would make comments like this project/picture is f'n amazing. When I watched Legion in 4k HDR everyone was stunned by the picture. Right after we watched Luke Cage in 4k SDR and the requests were to make the picture look like Legion...lol." - fmarasco
"The picture quality never looked so good!" - lovingdvd
" this has now given me an AWESOME image for the UHD material. I can't stop looking at scenes from 'Martian' or 'John Wick', the color and clarity is very noticeable now over my BD counterpart when running in r.709, even calibrated by ChadB." - brian_vh
We are glad to announce the availability of FW and GUI1.9 for our proud 4K Linker owners out there.
While previous update already added adjustment to the 4K Linker routines to support 4:2:2 deepcolor such as 4K60 4:2:2 12b HDR/BT2020 600MHz from the PS4/Pro as well as support for 4K24/25/30 4:2:2 12b HDR/BT2020 300MHz (Best possible timing for HDMI1.x Bandwidth). This new update is adding totally new routines to handle handshake, resolution changes, hdcp conversion and scaling all at the same time, confirmed working on K8500/Netflix, Shield/Kodi and many others.
Below some technical on last changes in FW and GUI0.19
Preview RC version !
1. GUI option to shut off the HDR infoframe from the output. (GUI as "Disable HDR" Just click that and no HDR infoframe reach the display even though the input has it.)
2. Handshake now solid for all K8500/UB900/SHIELD situation.
3. Res switching and handshake solved.
4. Both Normal and 200% DPI GUI available
5. Added Reset Button
6. remaining 1080i issue, work underway.
LINKER USER MANUAL UPDATED
We have updated the Linker User Manual, Get a look to it by clicking the PDF image.
Stay assured that our team will keep up the lovely and passionate hard work.
Your faithfully devoted team,
The HDfury Crew.
www.HDfury.com
Copyright © 2017 HDfury, All rights reserved.
You are receiving this email as an existing HDfury customers, if you no longer wish to receive our mailing list. You can unsubscribe from here.
Our mailing address is:
HDfury
Rm2809 Peng Tian Ge Jingli Mansion
No.48 Beili Road SouthShenZhen, NE 0
China
Add us to your address book
unsubscribe from this list
update subscription preferences
Postad 21 April 2017 - 13:59
Blackkatt
  • Blackkatt
  • 0 inlägg
För **** Mike jag blir ju nästa tårögd. Jag har en Yamaha RX-V773 som stödjer 4k@30MHz vilket suger balle. Men har ingen lust att köpa deras nästa modell riktigt än med Dolby Atmos och DTS-X samt 4k@60Mhz över allt.  För inte mycket material finns där att njuta av. Därför tänkte jag att en HDMI switch är vad jag behöver???
Min fråga till dig. Denna gudsgåva https://www.hdfury.c...k60-444-600mhz/ gör att jag kan koppla in både PC och PS4 pro, skicka dessa signaler (ljudet) vidare till förstärkaren?
Redigerat av Blackkatt, 21 April 2017 - 14:04.
Postad 21 April 2017 - 14:21
Min Fraga till Dig. This gudsgåva https://www.hdfury.c...k60-444-600mhz/ GÖR ATT jag Kan koppla in bade PC OCH PS4 pro, skicka dessa Signaler (ljudet) vidare till Förstärkaren?
Välkommen till forumet :) Intergralen har två hdmi ingångar, så det går om du vill köra genomden.  Men då måste stärkarens hdmi gå direkt till din bildvisare, ljudet får du oavsett ut via optisk! Vilken signal har du från datorn?
Postad 04 August 2017 - 15:08
mr richards
  • mr richards
  • 904 inlägg
är det samma antal ingång och utgång på Linkern.
Postad 04 August 2017 - 15:19
Två in och en ut .. :)
Redigerat av mcmike, 04 August 2017 - 15:20.
Postad 10 October 2017 - 19:06
martiin82
  • martiin82
  • 565 inlägg
Någon svensk ÅF?
Postad 10 October 2017 - 19:28
Iceman666
  • Iceman666
  • 481 inlägg
Ursäkta frågan men vad vore smartaste inställningen på linkern med en Pannasonic UB-700 och en Sony HW40 ( Marantz 7010)?
Jag har bara satt switchen på sidan till :
Scale-Downscale Mode
Edid-Ficed edid 1080p60
Vad jag inte är happy med är att Anär jag kör Netflix både genom Pannan eller om jag kör Chromecast Ultran så rycker bilden. Jag tror mig se nu är kanske att jag tvingar ut 60Hz och därför endast får bra bild på Ultra HD film. Jag kan även se att jag kanske ställer till det för Canal Digitalboxen och dess bild med min tvingade 1080p60!?
Så vad bör jag ha för inställning på EDID ?
Tack på förhand för en som inte är helt 100 på detta;-)
Postad 11 October 2017 - 16:10
hugeman
  • hugeman
  • 985 inlägg
Tror inte det finns någon svensk återförsäljare men jag är gärna med på en gruppbeställning :)
Redigerat av hugeman, 11 October 2017 - 16:10.
Postad 11 October 2017 - 17:22
hugeman
  • hugeman
  • 985 inlägg
Dessvärre fungerar Netflix inget bra i 60 Hz. 90 % är lagrat i 24 Hz. Tyvärr har du inget annat väl än att köra ut 60 Hz om du använder Pannan eller Chromecast. Du får byta uppspelningsenhet till en som klarar 24 Hz får att få rätt flyt om inte din Sony klarar av att göra om 60 Hz till 24 Hz.
Ännu värre blir det med din Canal Digital om du försöker trycka ut 50 Hz i 60 Hz. Men klarar verkligen linkern att göra om 50 Hz till 60 Hz, får du inte ut 50 Hz?
Postad 11 October 2017 - 19:46
Iceman666
  • Iceman666
  • 481 inlägg
Canal Digital boxen är ju 1080i och därför släpper Linkern igenom den oförändrad tror kag!
Trodde i mn enfald att Chromecasten kunde skicka 24 Hz !!
Så för att få Netflix och 24 Hz vad rekomenderas för en Proj och 7:2:4 setup i bion?
Postad 11 October 2017 - 19:54
philipbtz
  • philipbtz
  • 2190 inlägg
Nvidia Shield hade jag rekommenderat då du kan ställa om alla streaming-tjänster till 24Hz. Tror det bara är denna pryl som klarar det. Det har varit lite olika hur bra flytet är men med senaste uppdateringen ser det mjukt och fint ut från shielden. Det går även att få ut Atmos och DTS:X genom Kodi om du vill spela upp BD eller UHD genom den.
Redigerat av philipbtz, 11 October 2017 - 19:54.
hugeman
  • hugeman
  • 985 inlägg
Jag brukar rekommendera en Samsung Blu-Ray spelare t.ex H6500 eller nyare eller deras UHD-spelare. Dock ej i lägre serie för den sköter fps per automatik i appar som Netflix.
Annars funkar väl Apple 4K eller en shield men där är det manuell inställning på fps.
Redigerat av hugeman, 11 October 2017 - 19:55.
Postad 11 October 2017 - 19:58
philipbtz
  • philipbtz
  • 2190 inlägg
Apple 4k har inte 4k i youtube t.ex. Klarar inte Atmos osv. Men det är helt rätt att man måste ställa om upplösning och färgrymd hela tiden om man t.ex. har en 4k projektor. För en 1080p projektor kan man lämna färgen på Rec. 709 4:4:4 och bara byta mellan 24 och 60Hz. Kan vara något störande men går att leva med.
Postad 11 October 2017 - 20:00
hugeman
  • hugeman
  • 985 inlägg
Därför är nog rätt samsungspelare den bästa Netflix-spelaren om kan stå ut med storleken. Dock vet jag inte om uhd-spelaren klarar youtube 4k
Redigerat av hugeman, 11 October 2017 - 20:01.
Postad 12 October 2017 - 07:28
hugeman
  • hugeman
  • 985 inlägg
Vart har ni beställer era. Via hdfury.com eller hudfury.eu?
Postad 12 October 2017 - 07:45
Iceman666
  • Iceman666
  • 481 inlägg
Hdfury.com
La en ny beställning i veckan och dagen efter var blåtanden för att styra Linkern med din mobil skickad!
Samma upplevelse med Linkern som jag slapp tull& moms på :-)
Redigerat av Iceman666, 12 October 2017 - 07:51.
Postad 12 October 2017 - 07:50
Iceman666
  • Iceman666
  • 481 inlägg
Jag tror jag får beställa en Shield men....
Vilken version skall jag beställa? Kommer bara att använda den för att streama Netflix. Om jag ställer in Shielden på att skicka ut 4K/24Hz eller 1080/24Hz, kommer den ihåg dessa inställningar även efter att jag stänger ner den gör den jobbet för mina behov till 100%
Postad 12 October 2017 - 08:14
philipbtz
  • philipbtz
  • 2190 inlägg
Det beror nog på. Min känner av att jag har en projektor som kan ta emot en 4k signal så då kan den få för sig att ändra upplösning om jag stänger av den men jag har den för det mesta påslagen hela tiden. Tror inte det finns något som är 100% än. Tror det är denna som gäller https://www.prisjakt...t.php?p=4112698
Om du endast skall kolla Netflix på den så kanske det finns billigare alternativ jag vet inte.
Postad 12 October 2017 - 10:49
hugeman
  • hugeman
  • 985 inlägg
Hur tycker du förövrigt bilden fungerar nerskalad. Jag kan tänka mig att själva bilden fortfarande håll hög klass 4K->1080p, men hur fungerar det med t.ex. undertexter? Tappar dessa i kvalité och blir suddiga?
Postad 12 October 2017 - 13:57
Iceman666
  • Iceman666
  • 481 inlägg
Bilden är ok och även textningen med flimmrig som f@n.
Jag förstår inte hur jag har orkat med det så läääänge men nu räcker det!!
Jag förstår att ni rekmenderar Shiel och även Samsung BD men nu räcker det med BD spelare i grottan så samsungen försvinner!!
Hur är det med Roku vs Shielden ang Netflix ang 4K/24 och 1080/24?!
Spelar ingen roll att min Sony HW40 inte tar 4K eftersom Linkern skall fungera att skala om 4K/24 till 1080/24!
Det är helt riktigt att Linkern inte skalar om 4K50/60 till 1080/24 men som sagt enl ovan.
Postad 12 October 2017 - 14:47
hugeman
  • hugeman
  • 985 inlägg
Flimrar texten eller hela bilden eller bara texten? Frågan är om det räcker att byta spelare då? Är det skillnad mellan pannan o chromecasten där?
Redigerat av hugeman, 12 October 2017 - 14:47.
Postad 12 October 2017 - 14:56
Iceman666
  • Iceman666
  • 481 inlägg
Nej för båda matar ut 60 Hz och flimringen är bara tydlig på bilden, speciellt i panoreringar.
Postad 12 October 2017 - 15:20
hugeman
  • hugeman
  • 985 inlägg
Frågan är om flimret kommer från nerskalningen eller om den kommer från 60 Hz som du säger. Judder är normalt vid 24 Hz i 60 Hz, men inte flimmer... Men jag antar att du testat att köra en UHD-film i din Panasonic i 4K 24 Hz genom linkern och att du då inte upplever dessa problem och att bild och text då är kanon utan flimmer nerskalat i 1080p!?
Redigerat av hugeman, 12 October 2017 - 15:20.
Postad 12 October 2017 - 15:50
philipbtz
  • philipbtz
  • 2190 inlägg
Jag har UB700, Shield samt Linker. Skalar ner allt till 1080p 4:4:4 24/60 rec709/bt2020 hdr och upplever inget flimmer. Hade tidigare en sämre HDMI-kabel(för lång) och med den hade jag flimmer.
Postad 12 October 2017 - 16:04
hugeman
  • hugeman
  • 985 inlägg
Låter bra, och du upplever heller inga undertext-problem med nerskalningen? Då kanske man ska våga beställa sig en då =)
Postad 26 October 2017 - 18:31
Unregistered9a1f280a
  • Unregistered9a1f280a
  • 1715 inlägg
Nu har min Goding lämnat Taipei,Taiwan 😁
Postad 30 October 2017 - 23:24
  • 1715 inlägg
Jag drabbades av ett smärre psykbryt vid installation.
Jag trodde att jag kunde använda mig av min nuvarande kopplingskedja. Som innehöll några splitters. Men tji fick jag.
Jag kunde dock använda mig av min 4k splitter som har ren copy på edid. Denna splitter sitter efter mitt Xbox. Splitter skickar till en 4k monitor och nu till Linkern.
Jag trodde att jag kunde ha en till splitter (dock bara en 1080p@60 splitter) efter Linkern, men jag fick inte till det hur jag än försökte. Tills jag drog out-hdmi från Linkern till mitt Elgato capture card direkt utan splitter, då funkade handskakningen.
Och som tur är så behöver jag bara flytta plats på 1080p splittern och sätta den på Elgato hdmi-out och därefter fortsätta min 1080p kedja till förstärkare etc.
Det blev dock några mindre fina ramsor under kvällens lopp 😂
Redigerat av Unregistered9a1f280a, 30 October 2017 - 23:25.
Postad 04 November 2017 - 16:15
arcspin
  • arcspin
  • 713 inlägg
Jag håller på att sätta upp mitt nya system med JVC X5500, Marantz 7011 samt HTPC (GeForce GTX 1060) och Chromcast Ultra.
Jag ville demonstrera allt detta till min sambo och vi håller nu på att se Stranger Things på netflix via Chromcast Ultra.
Projektorn ställs automatiskt om till HDR och fläkten drar igång på max men bilden är ingenting att bli lyrisk över.
Jag provade då att ställa om projektorn att inte visa HDR (utan istället Cinema) men ändå behålla BT.2020, via inställningarna, bilden blev då märkbart bättre att se på.
Detta föranledde mig att göra lite efterforskningar och jag har nu (som jag redan visste) fått uppleva att projektorer inte lirar så bra med HDR material.
Det var då jag började att läsa på om HDFURY och det verkar som om det skulle kunna vara en lösning på att behålla utökade färgrymder och möjligheten att själv ställa in gamma och så vidare på min projektor.
Jag skulle vilja ha alla pusselbitar på plats innan jag beställer en professional kalibrering av projektor och när jag läste detta
"Here is a small excerpt of JVC PJ owners when using Linker and custom Gamma Curve + Dynamic Iris in HDR mode:"
i denna tråd kände jag att jag behöver få bekräftat att HD FURY (Vertex) är bra att ha på plats innan konfigureringen sker.
Tack,
//Peter
Postad 08 December 2017 - 11:02
Patrik-Lind-Webhallen
  • Patrik-Lind-Webhallen
  • 0 inlägg
Ill just drop this here.
https://www.webhalle...4_600mhz&view=1
Postad 08 December 2017 - 13:13
philipbtz
  • philipbtz
  • 2190 inlägg
Smart att ta in den. Det är en väldigt bra produkt för entusiaster som vill få ut det mesta utav alla sina 4k-produkter.
Postad 09 December 2017 - 10:54
Sitter man med en hel HDCp 2.2 kedja och de rätta "grejerna" så är denna onödig idag. Ialla falla här hemma numera :rolleyes:
Postad 09 December 2017 - 12:52
hugeman
  • hugeman
  • 985 inlägg
Absolut men den är något billigare än en Oppo  :) Du får ju även 2 HDMI in... För min del skulle de gärna få ta in Integralen med. Jag har Oppon men behovet av att ha 2 utgångar!
Postad 12 December 2017 - 11:22
philipbtz
  • philipbtz
  • 2190 inlägg
Det är sant men för egen del så får jag helt enkelt en stabilare kedja. Vid uppdateringar av källor så händer det att dom få för sig att skicka ut något projektorn inte stödjer. På UB700 t.ex. så verkar inte netflixappen vara uppdaterad på ett tag och vissa titlar har 4k Rec 709 medan andra har BT2020 HDR. Shielden har också haft konstigheter för sig. Det buggar ur utan Linker där. Eller om man vill testa att se hur 4k60 content ser ut i 1080p 4:4:4 BT2020 HDR. Håller med om att den är något onödig nu men ändå lite go att ha.
Redigerat av philipbtz, 12 December 2017 - 11:23.
Postad 12 December 2017 - 17:00
Man slår två flugor i en smäll och köper en Oppo :)
Redigerat av mcmike, 12 December 2017 - 17:01.
Postad 12 December 2017 - 17:06
philipbtz
  • philipbtz
  • 2190 inlägg
Det är sant. Dock så var Oppon dubbla priset mot vad jag betalade för UB700 + Linker kombon. Båda är bra alternativ helt enkelt. Där Oppon antagligen är snyggare och smidare lösning.
Redigerat av philipbtz, 12 December 2017 - 17:07.
Postad 29 May 2018 - 08:31
Unregisteredf77563f6
  • Unregisteredf77563f6
  • 22 inlägg
Har en fråga ang AT4K. Kan man spela upp 4K (UHD) material som sedan AT4K skalar ner till 1080p?
Har en Cromecast Ultra som skalar ner Viasats UHD sändningar till 1080p därav min fråga om AT4K gör det också när det gäller filmer?
Om jag köper en Linker 4K 60 4:4:4 600MHz kommer den att hjälpa mig få ut 4K/UHD material nerskalat till 1080p på projektorn med en AT4K?
Någon som kör denna lösningen idag?
Redigerat av Unregisteredf77563f6, 29 May 2018 - 08:31.
Postad 05 August 2018 - 09:27
Pliind
  • Pliind
  • 54 inlägg
Jag har en 4k linker till övers som vart över nu när det släpptes ny hårdvara till Lightberry :)
PM mig! tänker mig typ 1000:-
Postad 21 September 2018 - 16:40
DeusEXMachina
  • DeusEXMachina
  • 32 inlägg
En fråga om HDFury.
Jag har en PS4 Pro som källa.
TV: Sony XF9005 4k 100hz
Spelmonitor: Benq RL2755 1920x1080p 60hz
Testat en del splitters men lyckas bara få ut 1080p på båda skärmarna. Är det möjligt med HDFurys produkter att få ut 1080p på Benq-skärmen och 4K på tvn?
Postad 21 September 2018 - 17:14
Unregistered222df659
  • Unregistered222df659
  • 1236 inlägg
En fråga om HDFury.
är inte hundra, men kolla https://www.hdfury.c...k60-444-600mhz/
Postad 21 September 2018 - 17:48
Iceman666
  • Iceman666
  • 481 inlägg
Kolla in deras nya produkt som plev public idag!
Jag sitter själv på en ny Linker men den kommer jag att sälja för denna nya produkt som kallas Integral 2. Den är 100% som en Vertex men utan displayskärm på själva produkten. Du kan mao läsa vad alla skriver om Vertexen och bilda dig en uppfattning.
Gär kommer länken till Integral 2.
https://www.hdfury.c...uct/integral-2/
Här är en länk till AVS forum där hu hittar all info och kunskap du någonsin behöver!
https://www.avsforum...html#/forums/37
Som sagt jag rekomenderar den nya Integral 2 men om du vill ha en Linker kan du få min för halva priset mot en ny Linker.
Postad 21 September 2018 - 23:19
DeusEXMachina
  • DeusEXMachina
  • 32 inlägg
Verkar som vertex eller integral 2 ska funka ”out of the box”.
Tack för länkarna :)
Postad 29 September 2018 - 07:00
ruva
  • ruva
  • 2789 inlägg
ingen idé att PM:a honom.
Svarade både på hans annons i augusti och skickade pm men han svarar inte.
Postad 29 September 2018 - 07:13
Mikespike82
  • Mikespike82
  • 91 inlägg
Jag säljer min integral också
https://mobil.blocke..._600hz/80215058
