1280x720 @ 50 Hz på Z2:an
44 svar till detta ämne
Postad 04 April 2004 - 15:57
Bonzichrille
Bonzichrille
825 inlägg
Hej allihop!
Snappade just upp detta inlägg på avsforum, en kille som påstår att han kan få 1:1 pixelmapping vid 50hz på Z2:an via dvi. Har inte projen själv men det skulle vara kul om någon kunde prova:
I just managed to get a perfect 1280x720 @ 50 Hz with a digital DVI link !
Here are the steps. I use Powestrip 3.49.
In Powerstrip, go to "display profiles, configure, advanced timing options, custom resolutions".
Look for 720x576p (PAL 50 Hz)
Click "add new resolution". Answer yes when the software asks you to switch to it.
Go back to the Advanced timing options. Uncheck "realtime adjustment", and set the following values :
Horizontal geometry
Front porch : 16
Synch width : 108
Back porch : 20
Vertical geometry
Front porch : 5
Synch width : 37
Back porch : 7
Check that you have 864 in the horizontal total, and 625 in the vertical total.
Then reset the refresh rate at 50 Hz if it changed. Click apply. The values may change (I got 16, 104, 24 and 5, 5, 39 instead of what I entered).
Go back to the Display Profile page. Click Save as, and call it PAL, for example.
Then go back to the Custom resolutions, and add 1280x720p (DVI/HDCP derived).
Go back to the advanced timing options, and set
Horizontal geometry
Front porch : 64
Synch width : 48
Back porch : 136
Vertical geometry
Front porch : 10
Synch width : 16
Back porch : 22
Refresh Rate 50 Hz
And apply. Save it with another name, like 720p 50 Hz.
If it doesn't work at once, or if you want to switch from another resolution, you can recall it this way (just recalling the 720p 50 Hz profile doesn't work ) :
Insctructions
Recall the PAL profile that you saved above.
Recall the 720p 50 Hz profile
Go to the advanced timing options
Uncheck "real time adjustment"
set
Horizontal geometry
Front porch : 64
Synch width : 48
Back porch : 136
Vertical geometry
Front porch : 10
Synch width : 16
Back porch : 22
Refresh Rate 50 Hz
Apply.
Now, you should be in 1280x720 @ 50 Hz.
I can even add that the projector itself works internally at 50 Hz, not 60 ! I've taken photos of the "juddertest" to check it (I can post them if you are interested).
__________________
Pio2001
Postad 04 April 2004 - 19:52
Unregisteredfb5958ec
637 inlägg
tack för infon. verkar ju väldigt krångligt, men ska testa det när jag köpt min Z2
Postad 13 April 2004 - 18:59
Unregisteredd1f8514d
56 inlägg
Powerstrip ändrar ju inte det faktum att Z2:an gör om 50Hz signalen till 60Hz. Det räcker med att köra juddertest för att se detta.
Postad 13 April 2004 - 20:23
56 inlägg
Postad 13 April 2004 - 22:06
Unregisterede2613a4f
9 inlägg
Kanonbra hittat Bonzichrille  kommer komma bra till pass när min Z2 kommit OT: nån som testat Marcus-Cables 10m DVI? funkar den bra?
Postad 13 April 2004 - 23:28
Bonzichrille
Bonzichrille
825 inlägg
Tusan va härligt att det funkade!! Killen på avsforum blev bara löjlig förklarad efter att ha lagt in detta inlägg. Men där ser man, det gick alltså.
Nu steg Z2 på inköpslistan för min del iallafall...
Postad 14 April 2004 - 08:00
56 inlägg
Av någon anledning så identifierar projektorn signalen som 1080i?!
Hur kan det komma sig? Är bilden inte progressiv då?
Postad 14 April 2004 - 08:15
prosen
prosen
923 inlägg
Nej den är den inte progressiv, i så höga upplösningar spelar det ingen roll vad jag har förstått. Tror inte det finns 1080p.
Postad 14 April 2004 - 10:14
56 inlägg
Men om PC´n skickar en signal som har upplösningen 1280x720, hur kan det då komma sig att projektorn identifierar den som 1080í?
Inte för att jag klagar. Kollade på några filmer igår kväll och bilden är SUVERÄN
Redigerat av Unregisteredd1f8514d, 14 April 2004 - 10:16.
Postad 14 April 2004 - 11:06
prosen
prosen
923 inlägg
och ingen tearing vid kamerapanoreringar i 50hz(PAL) via DVI nu då?
Postad 14 April 2004 - 13:56
Dr. Death
Dr. Death
5782 inlägg
Finns visst det 1080P om än ovanligt...
Progressiv signal är ALLTID att föredra, många hävdar ju även att 720P ger bättre bild än 1080i. Har dock ej jämfört dessa två själv...
Postad 14 April 2004 - 15:15
prosen
prosen
923 inlägg
Ofasen, det har jag missat.
Postad 14 April 2004 - 15:18
Unregistered8b419848
20 inlägg
McMurphy: Jag har köpt en 5 meters DVI-I från Marcus-Cables som funkar, men polaren som köpte en 10 meters får sparkles på sin. Enligt Marcus beror det på grafikkortet i den HTPC används (Sapphire 9800Pro). Ska visst vara klena utgångssteg på DVI utgången som är problemet. Vi håller på att utreder om det stämmer genom att testa med en annan 10m kabel som bevisligen funkar på en annan HTPC (PowerColor 9600Pro).
Postad 14 April 2004 - 15:28
Unregistereda0ef723f
3439 inlägg
Låter fint det här. Skall testas då jag fått mitt nya exemplar av Z2an. thrasher: Låter inte bra det där! Jag hade tänk att köpa en 10m DVI-kabel från Marcuscabels, men efter att ha läst ditt inlägg väntar jag nog lite. Har själv ett ATI Radeon 9800Pro.  Skriv gärna hur det gick sen.
Postad 14 April 2004 - 15:32
56 inlägg
Nej och linjen i juddertest flyter fram som smör i en het stekpanna
Postad 14 April 2004 - 15:34
prosen
prosen
923 inlägg
thrasher> Märker man någon skillnad mellan de dyrara och billiga HDMI el. DVI-kablar? Eller är det så att de antingen funkar eller inte?
Postad 14 April 2004 - 16:24
20 inlägg
Petesapie: Ska testa så fort vi hinner. Kanske till helgen. prosen: Upp till fem meter verkar det inte spela så stor roll. Över det kan jag tänka mig att det ställs högre krav. Men som sagt har vi inte fått Marcus-Cables 10 meters DVI att funka och det är ju inte en helt billig kabel. Vill inte döma ut den innan vi har testat med en Oehlbach på samma dator. Det kan ju vara grafikkortet som har dålig DVI-utgång. Vad gäller HDMI-standarden är det väl krav på att alla kablar ska testas så där borde alla hålla vad de lovar...
Redigerat av Unregistered8b419848, 14 April 2004 - 16:29.
Postad 14 April 2004 - 16:38
prosen
prosen
923 inlägg
tack för det!! väntar med spänning på hur det går för er.
Postad 14 April 2004 - 21:23
Sammen
Sammen
412 inlägg
jag kör Marcus 10m DVI på en AE500 med ett Geforce 5600. Har dock precis som många andra problem att få 1280x720 att funka med detta grafikkort, vill ju köra "native resolution". Inte ens 60Hz@1280x720 får jag att fungera.
Däremot funkar det bra för mig att köra 1280x768 med kabeln. Inga konstigheter alls i bilden.
/Tyrann
EDIT: Bara för att tala om att det finns potential i kabeln, ursäkta babblet om Panasonic...
Redigerat av tyrann, 14 April 2004 - 21:25.
Postad 14 April 2004 - 22:12
Dr. Death
Dr. Death
5782 inlägg
Har själv beställt en 5m DVI-kabel från MarcusCable, så jag blir lite orolig när jag läser här, borde iofs. vara rätt säker med mina 5meter, men ändå.
Marcus snackade om en funktionsgaranti upp till 10meter, så man börjar ju undra.
Man kan ju inte skylla på grafikkorten rakt av, då det finns andra kablar som funkar i 10meter...
Postad 15 April 2004 - 00:32
Unregistered82bc6fda
31 inlägg
För mig failar den när jag ska lägga till 720x576p-upplösningen. Datorn frågar om jag vill byta, jag trycker OK, det rycker lite i bilden, sedan har jag fortf 1280x720 och när jag går tillbaka till andra fönstret står det fortf 1280 på width och 720 på höjden.
/Alex/
Postad 15 April 2004 - 12:01
Unregisteredbf4f5a05
12 inlägg
Min inkoppling:
Geforce4 5200 från ASUS.
10m DVI (Oehelbach från reference audio, kanonkabel tycker jag, blev rekommenderad denna kabel i en annan tråd i detta forum).
Kör inte PowerStrip (men borde kanske för att pilla lite med 50/60Hz då, om det behövs).
Bara kopplade in, och projjen kom upp i Windows 2000 som en "Sanyo PLV-Z2" med upplösning på max 1280x720. Och detta med firmware 1.03 i projjen.
Vad mer kan man begära?
Kör även Real Magic X-card för DVD:er, men då kör jag via en Supra komponent, eftersom det kortet bara tar komponent eller VGA.
Men ibland tycker jag detta blir lite suddigt, vet inte om det är inbildning eller om det beror på kabeln. Ibland får jag känslan av att det är lite svaga skuggor.
Är det någon som har X-card med en "bra" kabel utan skuggor?
Det kortet kan ju skala upp hårdvarumässigt till 1080i eller 720p på DVD:er. Vill veta hur resultatet av detta blir med en bra kabel.
Hoppas nästa Real Magic kort får DVI och WMA9. Sigmadesigns har ju tagit fram ett chip med hårdvarustöd för WMA9. Längtar efter ett sådant kort.
Annars kör jag WinDVD för DVD:er, mitt eget program för DivX och VLC Media player för HDTV (alla dessa då via DVI om ni inte förstod det.).
Sorry, kom lite OT, men kunde inte sluta skriva bara
/Fredrik
Postad 15 April 2004 - 12:05
Dr. Death
Dr. Death
5782 inlägg
Lägger du in denna upplösning (720*576) så lär du få väldigt konstigt bildformat...
Ja, jag vet att dvdvideo-formatet har den upplösningen, men du kan ju inte ha det på inställningarna för upplösningen??? Eller?
Postad 15 April 2004 - 19:05
9 inlägg
Lät ju inget bra det där alls, hejdar mig en smula med beställning av Marcus-kabel då. Är det Oehelbach som gäller istället? eller finns det andra 10m DVI-kablar som visats fungera väl?
Nån som har en aning om en Vgpu-mod påverkar utsignalen för DVI? eller om det finns nåt annat sätt att förstärka signalen från DVI-utgången?
Postad 15 April 2004 - 20:52
Unregistered81673970
118 inlägg
För mig fungerar LINDY kabeln på 10m alldeles utmärkt!!
Postad 16 April 2004 - 10:40
20 inlägg
Har nu provat med en Oehlbach kabel. Tyvärr visade det sig att den var 7,5 meter
och inte 10 men den funkade klockrent.
Jag kan alltså inte dra några slutsatser ur detta. Känns lite jobbigt att beställa ytterligare en DVI-kabel från t.ex. Lindy. Blir nog att köpa en VGA-kabel istället.
Postad 16 April 2004 - 19:15
Unregistered60870fdc
41 inlägg
Det verkar som alla som testat har fått det att fungera utom mig. När jag kommer till.
Click "add new resolution". ---> Answer yes when the software asks you to switch to it.
---> partiet stämmer inte info med min dator som vill starta om för att testa dem nya inställningarna. Får någon annan samma problem och hur har ni löst det? när jag startar om sen så har den fortfarande de gamla inställningarna (1024*768).
Jag har firmware 104
Nvidia Quadro 750 XGL graffakort(tvivlar att felet ligger där).
en 10 m dvi-d kabel från mycom.
Postad 16 April 2004 - 21:31
kotten33
kotten33
1039 inlägg
Kanske en dum fråga, men jag ställer den ändå. Ni pratar om att ändra till 50 HZ i Powerstrip, men om man har en stationär DVD spelare med DVI och 720p @ 50 hz, då antar jag att man INTE kan få denna upplösning eftersom det är Powerstrip som fixar detta
Postad 16 April 2004 - 22:14
Dr. Death
Dr. Death
5782 inlägg
Är knappast nåt snille på detta område (datorer), men om du vill få din z2(OM) att rappa. 50hz /720P, pal att köra detta ,därav är det en förutsättning för att få 1:1 pixelmapping att. Förlåt atppade tråden, ärlite "full"!
Kollade på tv imellan och tappade greppet om problemet, försöker igen i morgon...
FAAAN vad jobbigt att vara kille, vi kan ju bra göra en sak åt gången!...
(enlikt tjejerna, men det får vi ta!)...
Postad 17 April 2004 - 09:43
prosen
prosen
923 inlägg
Visst finns det stationära DVD-spelare som klarar detta! ex. Yamakawa, och NorthQ. Där kan du ställa custom resolution och motsvarande värden som du kan ställa i PowerStrip.
Postad 20 April 2004 - 21:52
Unregisteredefaac570
53 inlägg
FASEN! Har just gått igenom alla inställningar för att få 50Hz med DVI och nu inser jag att jag kastat bort Juddertest.exe. Har letat i en halvtimme och hittar ingen länk till var jag laddar ner programmet.
HJÄÄÄLP!
/ola
Postad 21 April 2004 - 08:38
Unregistered6b502595
1104 inlägg
ReClock kan användas också. Den har ett tearingtest som funkar kanonbra för att se tearing och judder.
Kan ställa in 1280x720@50hz direkt i drivrutinen till mitt GeForce 5700 (man kan faktiskt lägga in egna upplösningar där). Alla nVidia-kort använder väl samma drivrutinspaket?
Har en Z1:a, men 1280x720@50hz ger ändå bäst kvalitet. 960x540 ger såklart skarpare konturer när man kör Windows, men det är helt omöjligt att bli av med judder och/eller tearing.
Edit: Projektorn säger att signalen är 720p om jag gör som jag skriver här. Även när jag testat med Powerstrip så säger den att signalen är 720p. Kör jag däremot med 1:1-pixelmappning så fattar inte projjen nånting så jag måste finjustera alla inställningar. Även om jag sparar inställningarna i projektorn så blir den lika nollställd nästa gång jag byter till den upplösningen.
Redigerat av Unregistered6b502595, 21 April 2004 - 08:43.
Postad 25 April 2004 - 15:50
Unregistered794461b1
71 inlägg
Jag har lite problem. Jag har lyckats få till 720p till projjen men när jag startar om är jag 575p. Kör jag med projjen för bildvisning går det inte att lägga till 1280*720 utan den inställningen måste jag göra mot min bildskärm och sedan växla över till projjen. Hur skall jag göra för att ha 720p även efter att jag startat om datorn?
Postad 25 April 2004 - 15:59
41 inlägg
Vad händer om man har för lång eller för dålig kabel. Kan det vara så att den inte vill ställa om till 1280*720 eller att det går men det blir något fel på bilden? Jag har en 10m dvi-d kabel från mycom och den vägrar ställa om i powerstrip.
Ville bara säga att nu har även jag löst det efter att ha kollat igenom nästan alla z2 forum. Med risk att bli utskrattad var mitt problem enkelt. Den var inställd på pc digital inne på input 2 menyn istället för hdpc. Skönt att det var så lätt iaf. Nu gäller det bara att köpa en ny kabel då jag får galet med sparkles på denna men det är lätt fixat.
Redigerat av Unregistered60870fdc, 07 May 2004 - 09:51.
Postad 20 May 2004 - 16:53
Korvis
Korvis
839 inlägg
Efter att läst igenom denna tråd (som inte diskuterats på ett tag) ställer jag mig fortfarande frågande till om det idag finns en lösning för att få detta att fungera med ALLA vanliga stationära DVD spelare, med DVI, ihop med Z2:an??? Eller gäller det fortfarande bara speciella spelare enligt ovan?
Postad 20 May 2004 - 17:56
nurfen
nurfen
2031 inlägg
Så länge du kan justera inställningarna som nämns i det första inlägget så fungerar det.
Postad 17 June 2004 - 07:55
pellevin
pellevin
146 inlägg
Tacksam förklaring, vad menas med allt detta? Var god förklara för en oinvigd på dagisnivå!
I vilket sammanhang skall vara bra att göra, detta med att få 50Hz? Vad är det projektorn inte klarar? Är det om man tittar på NTSC-filmer som det kan bli problem? Vad är 1:1 pixelmapping? Vad är Powerstrip?
Hälsningar Pellevin
Postad 17 June 2004 - 15:42
prosen
prosen
923 inlägg
Hälsningar Pellevin
Den som läser skall hitta svaret!
Postad 17 June 2004 - 18:01
pellevin
pellevin
146 inlägg
Jaha är inte forumet till för att man skall kunna lära av varandra? Är tanken istället att anonyma typer skall sitta i sin kammare och göra sig lustiga över andra när de tycker sig veta bättre?
Kan inte någon som vet detta bara helt enkelt svara kort på frågan?
Postad 17 June 2004 - 19:09
prosen
prosen
923 inlägg
Det mesta som du frågar om står redan i tråden, men jag ska försöka förklara... Vad är det projektorn inte klarar?
Den klarar inte PAL(50hz) via DVI(på ett enkelt sätt med en stationär DVD). Efterssom projektorn alltid konverterar signalen till 60hz så orsakar det så kallad "tearing" eller ryckningar vid kamerapanoreringar. Är det om man tittar på NTSC-filmer som det kan bli problem?
Nej, bara PAL-film(50hz). Om du tittar på NTSC-filmer så funkar det finfint efterssom NTSC jobbar i 60hz. Vad är 1:1 pixelmapping?
Att projektorn matas med samma upplösning som panelerna som sitter i den, tex. 1280x720. Detta medför att projektorn inte behöver skala om bilden, vilket ger den bästa bildkvalitén. Vad är Powerstrip?
Ett program till din PC som gör att ditt grafikkort kan ställas in med udda upplösningar(custom resolution), ex. 858*484 (WVGA). Även kallat HTPC(Home Theater PC). Hoppas det klarnar lite för dig!
Postad 17 June 2004 - 19:21
Unregistered74d4d0b1
2219 inlägg
LOL
Postad 18 June 2004 - 17:12
pellevin
pellevin
146 inlägg
Tack ska du ha prosen, det klarnade faktiskt lite.
Jag fortsätter med fler dumma frågor (alla får skratta hur mycket dom vill):
Hur tydligt brukar det synas detta med tearing, blir man galen av det?
Kan detta problem uppstå med samsung HD935-spelaren? Med Sagem digitalbox? Eller är det bara ett problem för dom som kör sin PC på projektorn? OCh i de förra 2 fallen: kan man då åtgärda det?
/Pellevin
Postad 18 June 2004 - 21:50
Dr. Death
Dr. Death
5782 inlägg
Postad 20 June 2004 - 11:50
prosen
prosen
923 inlägg
Kan vara ganska störande tyvärr! Kan detta problem uppstå med samsung HD935-spelaren?
Japp, tyvärr! Med Sagem digitalbox?
Nej, här finns bara analoga signaler ut, ex. RGB eller S-video. Eller är det bara ett problem för dom som kör sin PC på projektorn?
Nej, här kör man ofta med PowerStrip, och "tweakar" så man slipper problemet helt. OCh i de förra 2 fallen: kan man då åtgärda det?
Nej, det var det jag menade när jag sa att det inte finns något enkelt sätt att lösa problemet med en stationär DVD. Möjligtvis om man har en Yamakawa eller NorthQ så kan man komma runt det. I dessa spelare kan man nämligen "tweaka" hur mycket som helst, såsom upplösning etc.
Redigerat av prosen, 15 July 2004 - 15:38.
Postad 11 July 2004 - 09:56
19825 inlägg
Första testet med en Singel Link 249:- dvi-d kabel från ett gammalt GeForce 4 Ti200 till en Sanyo PLV-Z2. Verkar funkar helt okej. Att bara välja ett "mode" funkar dock inte så bra verkar det som, det vägrar att köra 50 hz progressive, bara interlace. Eller 60 hz progressive. Förutsättningarna för att ta kort var inte de bästa, ljuset rakt in bakifrån, Ikea Tupplur, Frihand, darrig  hehe. Projektorn är noll kallibrerad också. Mina feta kisse Chippz nya favoritplats. På centern. Filmen är från nån Discovery HD kanal och skärpan på filmen är det grymmaste jag någonsin sett. Filmen är alltså 720p Använde bara nvidias nya drivisar, inget powerstrip... dom verkar som sagt inte optimala ännu så man kanske måste köra ps ändå för att få 50 hz progressive .. än så länge.
Projektorer
Titan Noir Max
LFE reference och Center ch
