* Officiell tråd - Panasonic PT AE-700 *
1881 svar till detta ämne
Postad 03 August 2004 - 18:38
Unregistered20a698a5
  • Unregistered20a698a5
  • 132 inlägg
AE700 på Meinhemkino
https://www.prisjakt...18095&type=.png
Progressive scan technology compatibility allows for high quality images
HDMI (High-Definition Multimedia Interface) Digital Link
Lens Shift Joystick
10bit full digital processing & digital gamma processing
27db Low Fan noise
Powerful images produced by a 16:9 wide LCD panel
Short focal lens lets you enjoy large-screen images across a small room
Brightness of 1000 ANSI lumens, 2000:1 high contrast ratio
Compact and Portable, Simple Configuration
Smooth screen technology
High Resolution panel 1280x720 Pixels
Vertical and Horizontal Keystone adjustment
Full 10 bit Processing & Gamma Correction
1024 shades of gradation (1 billion colours)
Short throw capability 100 inch diagonal at a distance of 3.1m
Specifications for the PTAE700 Projector
Power supply AC: 100 V - 240V, 50 Hz/60Hz
Power Consumption 180W (<1 W on standby)
LCD Panel 0.7" (diagonal) polysilicon TFT Wide LCD Panel (x3 RGB)
Pixels 1280×720
Lens 22 - 26.2mm
Manual zoom
Lamp 130UHM lamp
Brightness: 850 ANSI Lumens
Scanning Frequency for RGB signals fH 30 kHz - 70 kHz, fv 50 Hz - 87 Hz
YPBPR signals 480i/480p/576i/576p/720p/1080i.
Colour system NTSC/NTSC4.43/PAL/PAL-M/PAL-N/SECAM
Projection Size 40" - 200" (16:9 Aspect ratio)
Throw distance 1.2m to 7.4m
Installation Front/Rear/Ceiling/Desk
Video Inputs S-Video: 1xMini DIN 4-pin
Composite Video:1xRCA phono socket
Component Video: RCA phono sockets x 3
RGB Scart
HDMI Input
PC: D-sub HD 15-pin
PTAE700 Dimensions Width 280mm
Height 85mm
Depth 269mm
Weight 2.9Kg
Operating Temperature 0oC - 40oC (32oF - 104oF)
Operating Humidity 20% - 80% (no condensation)
PT-AE700 Supplied Accessories AC cord
AV cable
Remote Control
Lens Cap
Info på AVland i UK
Edit: Lagt till prisvisningsfunktionen så man kan se vad den kostar just nu samt lite grundläggande info/BERGGREN
Edit 041015: Bilder //MVH Peter.M
Redigerat av Unregistered20a698a5, 04 September 2005 - 21:35.
Postad 03 August 2004 - 18:44
Nomad
  • Nomad
  • "Justice is coming"
  • 6401 inlägg
Varför skulle det inte vara? Jag hoppas på det, kanske priset på 500:an sjunker ännu mer ;)
Postad 03 August 2004 - 18:46
Unregistered99f076a3
  • Unregistered99f076a3
  • 800 inlägg
Hmm...Har den ingen dvi?
Unregisteredb1065a2a
  • Unregisteredb1065a2a
  • 181 inlägg
Ja, det hoppas jag verkligen! 2000:1 i kontrast, hdmi, men designen var annorlunda men inte lika snygg i mitt tycke. Mer Philips-manér.
Kan inte någon skapa en officiell tråd för om denna skall lanseras redan i September så kommer det skrivas flitigt!
Redigerat av Unregisteredb1065a2a, 03 August 2004 - 19:05.
Postad 03 August 2004 - 18:51
  • 181 inlägg
Även jag hoppas att priset för ae500 sjunker i botten nu med lansering av denna. Ingen DVI?
Bild på projjen:
Preis : 1999€
ab September 2004
Redan i September?
En länk till ett fransk forum: http://www.homecinema-fr.com ---> Panna 700!
Redigerat av Unregisteredb1065a2a, 03 August 2004 - 18:55.
Postad 03 August 2004 - 18:53
D5 i denna tro? Fick intryck av att det skulle dröjja lite...
edit: glöm! ;)
Redigerat av pacman, 03 August 2004 - 18:59.
Postad 03 August 2004 - 19:03
Unregistered07ea6e16
  • Unregistered07ea6e16
  • 546 inlägg
Den har ju en HDMI ingång det fungerar ju lika bra som en DVI ingång, de flesta apparater kommer ju snart att ha HDMI så det känns väl som ett steg i rätt riktning enligt min mening.
Postad 03 August 2004 - 19:05
B8
  • B8
  • 4536 inlägg
Oooops! Schysst kontrast! Blir konkurrenskraftigt med DLP på den punkten ju!
Ingen DVI låter dock helt bisarrt!
edit: iofs en bra poäng octavia ;)
Redigerat av B8, 03 August 2004 - 19:06.
Postad 03 August 2004 - 19:22
Undra hur de fått upp kontrasten så pass mkt. September verkar nämligen vara ett lite avigt datum, det ska enligt Epson inte finnas några D5-paneler förän "Epson plans to begin shipping the panels in sample quantities during the third quarter (October through December) of the 2004 fiscal year"
Gammal panel med överhettad spec-skrivare eller är datumet fejk?
Postad 03 August 2004 - 19:29
dp79.com
  • dp79.com
  • 368 inlägg
Med största sannolikhet så är datumet lite väl optimistiskt.
Postad 03 August 2004 - 22:31
Unregistered671c75ff
  • Unregistered671c75ff
  • 265 inlägg
varför blir man så frästad att köpa nytt hela tiden.jag var nöjd förra året med en 300 a men sen upptäckte jag ett antal döda pixlar och då fick den åka ut.
tänk om dom kunde lösa det problemet!!
då hade jag bytt ut min infocus direkt!
Postad 03 August 2004 - 22:41
ThaiZo
  • ThaiZo
  • 90 inlägg
Coolt att dom lyssnar på konsumenterna och inför lens-shift ;)
Postad 03 August 2004 - 23:35
  • 132 inlägg
Varför klaga på hdmi-kontakten. Det är ju bättre än dvi!
1 kontakten är mindre
2 mer framtidssäker
3 kan skicka interlaced signaler vilket inte dvi kan om nu pannan skulla ha en bra signalbehandling.
Kontrasten är väl överdriven och tidpunkten är kanske optimistiskt men om den kommer i god tid innan jul så klagar inte jag i alla fall. Det viktiga är väl att den har D5 panelerna om den nu har det.
Postad 04 August 2004 - 05:56
Unregistered28175162
  • Unregistered28175162
  • 215 inlägg
Låter mkt spännande..
Kanske 500:orna kan rasa ännu mer till hösten... ;)
Postad 04 August 2004 - 06:01
// Denna tråden är nu officiell AE-700 tråd. Antar att det kommer skrivas och spekuleras mycket om denna så det är lika bra att vi samlar allt på en gång // M
Postad 04 August 2004 - 06:22
Unregistered74d4d0b1
  • Unregistered74d4d0b1
  • 2219 inlägg
De områden som bör åtgärdas är döda pixlar, damm och VB. Fixar de inte bättre dammskydd, minimalt med VB och bra pixelgaranti så är projektorn ointressant. Åtgärdar de emellertid detta så kommer denna proj att bli en garanterad storsäljare (vilket den iofs kan bli ändå men ej intressant för mig).
Postad 04 August 2004 - 06:24
  • 2219 inlägg
De kommer säkert sjunka till ca 10 tusen men lägre än så brukar inte projjar gå innan de försvinner helt.
Postad 04 August 2004 - 06:31
  • 2219 inlägg
För övrigt så tycker jag att den är snyggare än ae500 och förstår inte heller varför folk klagar på HDMI-kontakten eftersom det som sagt är en bättre kontakt än DVI.
Postad 04 August 2004 - 06:54
  • 2219 inlägg
Borde inte tredje kvartalet vara juli-september? Beror ju på varifrån man börjar räkna iofs...
Mitt tips är att ae700 kommer i november
Postad 04 August 2004 - 07:42
  • 215 inlägg
Någon som är duktig på tyska som kan översätta det som står i tråden rakt av?
Redigerat av Unregistered28175162, 04 August 2004 - 12:21.
Postad 04 August 2004 - 08:48
"2004 fiscal year", det är rätt vanligt att "företagsåret" börjar runt mars.
November känns mer troligt ja...iaf om de kör med D5.
Postad 04 August 2004 - 10:00
  • 132 inlägg
Tror du att den ny ae700 får en reglerbar iris?
Jag kan inte franska och förstår inte ett ord men jag tyckte att det stod något om bättre dammskydd i den franska tråden.
Redigerat av Unregistered20a698a5, 04 August 2004 - 17:09.
Postad 04 August 2004 - 11:06
B8
  • B8
  • 4536 inlägg
Det är det ju ingen som har gjort (i den här tråden iaf). Folk efterlyste/frågade bara efter en DVI också...
Postad 04 August 2004 - 11:40
Jag kan inte franska och förstår inte ett ord men jag tycket att det stod något om bättre dammskydd i den franska tråden.
Iris är ju faktiskt en möjlighet som gjort att de kunnat biffat upp kontrasten lite, även om det känns som det krävs en D5 eller iaf en D4 "deluxe"-panel för att man ska kunna speca en sån kontrast med gott samvete.
Ohlson, du som har koll: Vad exakt innebär "20% higher aperture ratio than D4 series panels"? Rent tekniskt och vad skulle det ge för bilden. Är själv lite osäker.
galactus
  • galactus
  • 370 inlägg
Eller så kanske inte alla vet att man kan koppla DVI -> HDMI...
Postad 04 August 2004 - 12:13
Dan.k
  • Dan.k
  • 397 inlägg
tätare mellan pixlarna?!?
Postad 04 August 2004 - 12:52
B8
  • B8
  • 4536 inlägg
Min första tanke också! ;)
Postad 04 August 2004 - 13:33
boombaaz
  • boombaaz
  • 1174 inlägg
Jag saknar en RS232-port för uppgradering av mjukvara, det borde vara standard på alla apparater nu för tiden. ;)
/BB
Postad 04 August 2004 - 14:40
Dan.k
  • Dan.k
  • 397 inlägg
behövs ju nästan inte hinner ju knappt vända på kallingar innan dem byter modeller ;)
Postad 04 August 2004 - 15:51
Unregistered3e8a25cd
  • Unregistered3e8a25cd
  • 1114 inlägg
Håller på och kollar om jag kan få loss ett av de första exen (precis som med 300E och 500E) för att se vad den går för och hur den står sig mot Sanyos Z3.
Har känt till 700E sen i vintras men inte fått säga något eftersom specen inte varit spikad.
Kontrastsiffror kan man alltid ta med en nypa salt, huvudsaken är att varje ny modell är bättre än den gamla.
Att DVI kommer att försvinna har varit känt länge så jag förstår inte heller varför folk vill ha en DVI-ingång. Den är bara i vägen nu när HDMI tar över.
Postad 04 August 2004 - 16:05
Unregisterede7866599
  • Unregisterede7866599
  • 310 inlägg
den termen brukar väl användas när man pratar objektiv till kameror..... så detkanske innebär bättre geometri i den optik som hör till panelen?
Postad 04 August 2004 - 16:38
  • 800 inlägg
Då vet du kanske något kul om Z3an också :) ;) :D
Postad 04 August 2004 - 17:15
  • 132 inlägg
Vad vet Sandstream71 om z3?
Aperture är väl själa öppningen. Jag har då upplevt att fill factor och aperture ratio används och är två begrepp för samma sak.
Redigerat av Unregistered20a698a5, 04 August 2004 - 17:15.
Postad 04 August 2004 - 21:32
Berggren
  • Berggren
  • I Am The God Of Hellfire
  • 3967 inlägg
Tänkte jag skulle posta en liten länk till specifikationerna på denna projektor:
AE-700 specifikationer
Mycket nöje!
Postad 04 August 2004 - 22:07
Unregistered7fb84d09
  • Unregistered7fb84d09
  • 1770 inlägg
Det blir en verkligen spännande höst i år :-)
Vågar man hoppas att dom fått bort VB på denna?
Redigerat av Unregistered7fb84d09, 04 August 2004 - 22:11.
Postad 04 August 2004 - 22:52
Eskapisten
  • Eskapisten
  • 379 inlägg
Spännande! Och snygg är den också! Törs man hoppas på lika bra lampgarantier som Hitachi tro? Panasonic har ju varit lite snåla med det, 200 timmar jämfört med 2000 timmar för hitachi och 2 månader mot 6 månader...
Blir ju intressant att se vad Sanyo ska hitta på att konkurrera med nu när även Pannan får lensshift.
Postad 04 August 2004 - 23:28
  • 132 inlägg
Frågan är om 2000:1 fås genom förbättrad smooth screen så som det står i specifikationerna eller om det år pga en D5a i projektorn. Jag hoppas verkligen att det är 3st D5 inblandade. Jag tror inte på 2000:1 men om man med riktiga färger får ut 1200:1 så är väl det bra. Dagens bästa lcd projektorer får man piska livet ur för att nu upp över 1000:1 med korrekta färger.
Sedan hopppas man ju att projektorn innehålller många menyalternativ för den seriösa och kalibreringstokiga fantasten. Det vore inte fel med ett inbyggt filter som tw500 har. Frågan är väl om de törs bygga in ett sådant då de får offra ljusstyrka. Man kan inte begära för mycket av konsumenternas förståelse.
Postad 05 August 2004 - 01:04
  • 1770 inlägg
Hur ger en förbättrad smooth screen bättre kontrast?
Jag trodde smooth screen hade med minskad screendoor att göra.
Postad 05 August 2004 - 07:49
  • 1114 inlägg
Inget mer än att den kommer att likna 700E i prestanda och att den ska komma ungefär samtidigt. Sanyo har ju legat före Panasonic hela tiden när det gäller nya modeller i Europa och det är nog därför som 700E kommer att lanseras samtidigt över hela världen och inte som tidigare först i Japan, sedan USA och sist i Europa.
Har fått testa samples av Z2:an så det borde gå att fixa samma sak för Z3:an, hoppas jag. Tyvärr så har de flesta leverantörer mycket folk på semester just nu så i slutet av augusti lär jag veta mer.
Redigerat av Unregistered3e8a25cd, 05 August 2004 - 07:50.
Postad 05 August 2004 - 10:27
Unregisteredab1514eb
  • Unregisteredab1514eb
  • 113 inlägg
http://www.produkte....=N&upper=&prop=
"lieferbar ab: 01.09.2004"
I Norge har distribusjon av PT-AE500 sluttet.
PT-AE700 har 27dB i normalmodus, PT-AE500 hadde 27dB i eco-modus.
Robert-
Redigerat av Unregisteredab1514eb, 05 August 2004 - 10:29.
Postad 05 August 2004 - 13:38
ippo
  • ippo
  • 1267 inlägg
hur är det.. går det att ansluta en pc med dvi till en hdmi kontakt?? Bara en adapter eller är det inte så enkelt?
Postad 05 August 2004 - 13:43
HDMI->DVI finns det ju många kablar som klarar, borde inte vara några problem åt andra hellet tycker jag.. men jag kan ha fel på detta. Är inte 100% insatt i detta ännu.
Postad 05 August 2004 - 14:36
galactus
  • galactus
  • 370 inlägg
DVI -> HDMI = Nemas problemas :)
Postad 05 August 2004 - 15:00
puttekula
  • puttekula
  • 479 inlägg
Åh, detta ställer till det för mig. Mitt sikte var inställt på en TX100 men om AE700 kommer snart vore det ju bara dumt att inte invänta den och göra en jämförelse. ;) :)
Postad 05 August 2004 - 16:39
  • 2219 inlägg
He he, jo det skulle förvåna mig mycket om inte både z3 och ae700 slår hitachin på fingrarna, frågan är bara hur mycket...
Postad 05 August 2004 - 17:29
Unregisteredc3c83da7
  • Unregisteredc3c83da7
  • 538 inlägg
Åh, detta ställer till det för mig. Mitt sikte var inställt på en TX100 men om AE700 kommer snart vore det ju bara dumt att inte invänta den och göra en jämförelse.  :P :P
Ska nog också vänta in dom nya modellerna , bara det inte tar så länge tills dom kommer. Någon som vet ungefär när dom kommer släppas?
Postad 05 August 2004 - 18:38
Dan.k
  • Dan.k
  • 397 inlägg
ähh säger bara tre bokstäver D L P :P
Postad 05 August 2004 - 18:50
Unregistereda0ef723f
  • Unregistereda0ef723f
  • 3439 inlägg
Trevlig proje! Har varit bortrest ett tag och jag såg denna tråd idag när jag kom hem. Martin.M hade gjort tråden officiell, MEN den kanske skulle ligga under Panasonicdelen av forumet. :P
Tråd flyttad.
Postad 05 August 2004 - 18:56
galactus
  • galactus
  • 370 inlägg
Fyndigt att man kan dissa en projektor som inte ens släppts än... :P
Postad 05 August 2004 - 19:23
JAL
  • JAL
  • 96 inlägg
Har funderat på en TX100 under hösten men frågan är om någon vet om AE700 har någon vettig zoom samt avstånds - bildstorlek tabell?
Jag vill ju gärna kunna zooma upp bilden då man tittar på fotboll eller hockey i 4:3 till samma bredd som i 16:9.
Någon som har koll på zoomen?
Johan
