* Officiell tråd Marantz SR7500 *
1447 svar till detta ämne
Postad 21 October 2004 - 12:16
bearic
  • bearic
  • 254 inlägg
Postad bild Postad bildKlicka för större bilder!
Baksidan, fronten i svart.
Info från AV-land.co.uk, www.avbuzz.com och Marantz.com.
Nyheter från SR7400:
  • M.R.A.C. (Marantz Room Acoustic Calibration)
  • THX-Select
  • 20W Smart Class A
Skillnader till övriga SRx500-serien
SR8500: Har DVI-switching, HDCD, 7 x 110W, lite fler in/utgångar
SR5500: Saknar THX, M.R.A.C., 7 x 90W, 6.1?
Huvudspecifikationer, Marantz SR7500
  • Full discrete wide range current feedback amplifiers delivering 7 x 105W
  • THX Select certified
  • 32 bit DSP (Cirrus Logic CS49400) with THX Surround EX, Dolby Digital EX, Pro Logic IIx, CSII and DTS 96/24
  • Dolby Headphone
  • High grade video conversion with line memory
  • Toroidial transformer, copper plated chassis and customized components
  • Component video switching
  • Multi room
  • 192kHz/24 bit D/A Converters on all channels (Cirrus Logic CS42428)
  • RS232 port for system integration and software upgrades
  • Adjustable crossover settings
  • Settings (Delay Time)
  • Analogue down mix
  • Video off mode (Pure Direct)
  • IR Flasher inputs and DC triggers
  • RDS Tuner Built In
  • MRAC (Marantz Room Acoustics Calibration)
  • OSD
  • RC1400 lärbar fjärrkontroll med makro
  • Power Output (8ohm RMS): 105W
  • Amplifier Signal to Noise Ratio: 105 dB
  • Amplifier Frequency Response: 8Hz – 100kHz (+/- 3 dB), (Analogue In, Source Direct) 8Hz – 45kHz (+/- 3 dB), (Digital In, 96kHz PCM) Total Harmonic Distortion 0.08%
  • Input Sensitivity / Impedance: 168mV / 47 kohms
  • Width: 440mm
  • Height: 184mm
  • Depth: 476mm
  • Weight: 14.8kg
Ingångar:
  • Line: 8
  • Optical: 4
  • Coaxial: 3
  • Component: 4
  • S-Video: 5
  • Composite: 5
  • HDMI: 0
  • 7.1
Utgångar:
  • Line: 4
  • Optical: 1 + 1 zone2
  • Coaxial: 1
  • Component: 1
  • S-Video: 3 + 1 zone2
  • Composite: 3 + 1 zone2
  • HDMI: 0
  • 7.1
Produktblad
Listpris: 9995 kr (999 EUR)
Släpps i december i Sverige.
Ser ganska najs ut, eller hur?
*Edit, har redigerat rubriken lite... //Jensen
Redigerat av alpha, 03 October 2005 - 08:38.
Postad 21 October 2004 - 12:21
Matsen
  • Matsen
  • 2792 inlägg
Synd att dom inte satte fronkontakterna bakom luckan.... :angry:
Postad 21 October 2004 - 21:56
Unregisteredff1e5825
  • Unregisteredff1e5825
  • 83 inlägg
Undra hur MRAC står sig mot denons/yamahas/pioneers autorooms korigering.
Trode dock att det bara var 8500 som hade "Toroidial transformer, copper plated chassis and customized components "
Postad 22 October 2004 - 08:52
Unregistered2956b483
  • Unregistered2956b483
  • 967 inlägg
MRAC lär vara samma som Denons rumskalibrering. Har också läst någonstans att om man vill ha toroid och koppar så får man köpa upp sig på en 8500.
Postad 22 October 2004 - 16:56
Weiman
  • Weiman
  • 932 inlägg
Bara jag som tycker den är ful? Oproportionerlig på något vis..
Postad 22 October 2004 - 18:46
Unregisterede68eb861
  • Unregisterede68eb861
  • 5548 inlägg
Fet menar du... ;)
Mvh JB
Postad 23 October 2004 - 08:07
Unregistered5cf1b4b0
  • Unregistered5cf1b4b0
  • 719 inlägg
Jag tycker den var grymt snygg,synd bara på att det inte satt en lucka för frontkontakterna.Gillar skarpt att fronten är "ren" från knappar.
Postad 23 October 2004 - 09:10
Unregisteredc00b10ee
  • Unregisteredc00b10ee
  • 1088 inlägg
Synd att fjärren ska va så ful. I övrigt ser det ut att vara ännu en i raden av underbara Marantz maskiner ;)
Postad 23 October 2004 - 11:29
Unregisteredc27b1e79
  • Unregisteredc27b1e79
  • 2665 inlägg
Dessa är grymt snygg det står mellan 7500 och 8500 är de värt låt oss säga 4000 extra?
Postad 23 October 2004 - 12:37
  • Audio Code 3
  • 12561 inlägg
Fjärren klart bättre än Denons variant för 3805, den är fullständig LCD och totalt värdelös när solen ligger på. Marantz ser ut att vara bättre och bekvämare.
Postad 23 October 2004 - 12:44
Unregistered8ee75b8b
  • Unregistered8ee75b8b
  • 3283 inlägg
Vad innebär att trafon är toroidial...?
Redigerat av Unregistered8ee75b8b, 23 October 2004 - 12:45.
Postad 27 October 2004 - 19:03
Unregisteredb38af287
  • Unregisteredb38af287
  • 2416 inlägg
fjärren är riktigt bra och klart den bästa och mest logiska jag sett/har använt när det gäller receivers i den här priklassen.
Postad 27 October 2004 - 19:06
  • 2416 inlägg
toroidal är en effektivare variant av trafo, det bästa man kan ha?, se http://www.toroid.se/index2.html
Postad 27 October 2004 - 19:15
  • 3283 inlägg
Trevligt, är två sånna rejäla klumpar som sitter i Thulen min. :)
Postad 27 October 2004 - 19:36
  • 2416 inlägg
dual mono, inte fel... :D
Blir det i min Classic-ICE-Kombo också.. :P
Redigerat av Unregisteredb38af287, 27 October 2004 - 19:37.
Postad 27 October 2004 - 19:57
  • 3283 inlägg
Njae, det är nog inte dual mono...väl? Utan det är nog för att den är balanserad...alltså fyra aktiva slutsteg i stereo.
Sen går den ju koppla om via fjärren till femkanalsslutsteg också...
Postad 27 October 2004 - 20:07
  • 2416 inlägg
A-HA... :)
Postad 27 October 2004 - 20:18
Unregistered0ad1ff2d
  • Unregistered0ad1ff2d
  • 32 inlägg
Håller med dig weiman ,tycker också att den är ful!
Postad 27 October 2004 - 21:46
  • 5548 inlägg
Men titta en Yamma-lover uttalar sig... :)
Mvh JB
Postad 02 December 2004 - 09:39
  • 2416 inlägg
Nu finns det lite "ny" info med feta bilder hos Marantz, man kan även läsa PDF:en och få en titt på baksidan mm...
Länk > http://www.marantz.c...line=rcv&cat=hf
Redigerat av Unregisteredb38af287, 02 December 2004 - 09:40.
Postad 02 December 2004 - 10:02
Matsen
  • Matsen
  • 2792 inlägg
Nästan så att man kan lägga in de "små" bilderna här va.... B)
Edit: Länk till produktbladet (pdf)
Redigerat av Matsen, 02 December 2004 - 10:04.
Postad 02 December 2004 - 15:59
  • 967 inlägg
Den är ju galet snygg! Kickar skiten ur de flesta andra. Tycker dock att Pio's nyare, större modeller kan konkurrera. De påminner lite om varandra dessutom.
Postad 13 December 2004 - 05:59
  • 2416 inlägg
Det verkar gå sanbbt när det väl gå...
hittade det här i ett danskt forum
Hehe. Nu har jeg sq købt én (argh jeg bruger for mange penge for tiden).
Jeg fik nemlig svar fra KT-Radio for godt en time siden - de sælger 4 stk. spritnye og plomberede (citat) SR-7500 til en intropris på 6995kr, og de har dem på lager nu.
De første 2 er solgt, jeg fik den tredje
Og den sidste fik jeg
Här är en länk till butiken:> http://www.kt-radio....index.php?id=62
Ruggigt lågt pris om det inte är stor skillnad mellan Svensk och Dansk krona just nu...
Postad 15 December 2004 - 03:02
amcsthlm
  • amcsthlm
  • 106 inlägg
Tjena!
Spanade lite på nätet efter en recension av SR-7500, hitta en rätt bra.
http://www.hometheat...ntz_sr7500.html
:unsure:
Postad 15 December 2004 - 08:25
  • 2665 inlägg
Nu är valet nära.. lutar nog lite mer åt 7500
Postad 15 December 2004 - 10:54
amcsthlm
  • amcsthlm
  • 106 inlägg
Håller med, men en 7400 är drygt 4000 kr billigare!, men jag tycker inte den är i närheten så snygg som 7500. Tycker nästan att 7500 är fulsnygg, kan inte riktigt placera den, mer klassisk än mordern. H/k är snyggt men jag tror man tröttnar, samt nog inte i närheten så bra som den här i samma prisklass.
Hehe...jo det är viktigt att det är snyggt.
Sen så har 7500 M.R.A.C eller vad det heter, vilket känns som man skulle
behöva.
:unsure:
Adrian
Redigerat av amcsthlm, 15 December 2004 - 10:57.
Postad 15 December 2004 - 11:35
  • 2665 inlägg
Med det pris jag får för 7500 så är det helt klart värt att köpa den framför 7400.
nästan skrattretande vad billigt det blir.
Men men väntar som sagt på recensioner på 8500 också. så jag vet om det är värt att lägga de ca 5000kr extra som den kostar.. eller om man nu ska lägga pengarna till en projektor istället.. Känns som att det blir roligare med en projektor + 7500 istället för bara en 8500.
Postad 15 December 2004 - 13:56
  • 2416 inlägg
Det som enligt hörsägen kommer att vara skillnaden är, förutom en del switchar mm, att 8500 kommer att ha samma förutsättningar för surround-ljud (vilket inte menar lite om man får tro det lilla man läst) och att dom kommer att ha lagt större vikt vid 2 kanals-ljudet på den modellen, och det är precis vad jag är ute efter. Bra surround OCH bra (eller mycket bra) ljud i stereo, inte alla receivers som klarar den balansgången!
Viva 8500!
Postad 15 December 2004 - 14:52
  • 2665 inlägg
du får sluta nu megalomaniac ;) Man velar fram och tillbaka hela tiden..
Och sen kommer du med dina tankar och då blir man än mer förvirrad ;)
Postad 16 December 2004 - 02:10
amcsthlm
  • amcsthlm
  • 106 inlägg
Någon maskin från något annat märke som kan slåss mot Marantz i samma prisklass som SR7500 ?
Postad 16 December 2004 - 07:37
  • 2665 inlägg
Jag skulle säga Denon 3805,men tror inte den är bättre. Bra ljud i den maskinen
Postad 16 December 2004 - 12:15
amcsthlm
  • amcsthlm
  • 106 inlägg
Hello guys!
Hmm nu är jag nere på tre maskiner här. Har läst lite om Pioneer som tydligen är bra. Dessa är kandidaterna:
Marantz SR7500
Pioneer VSX-AX3
Denon 3805
Yamaha RX-V2500
Vilken tror ni spöar skiten ur den andra. Jag är inne på att marantzen vinner, men efter att ha kollat denon så verkar den rätt bra. Tack Dragon Lord :)
Så vilken tror ni har mest fördelar?
Postad 16 December 2004 - 12:17
amcsthlm
  • amcsthlm
  • 106 inlägg
Inte för att vara oartig på något sätt, men vad pröjsar du för en SR7500? Nyfiken... :)
Postad 16 December 2004 - 12:34
  • 2665 inlägg
Vet inte om ja kan säga exact vad jag pröjsar. men det handlar om 1000 lappar billigare
Denon är i sig en underbar maskin och väldigt kompetent. men den är inte så kraftig anser ajg...
Inte om man jämför med en HK 8500 iaf hehe
Redigerat av Unregisteredc27b1e79, 16 December 2004 - 12:35.
Postad 16 December 2004 - 13:19
amcsthlm
  • amcsthlm
  • 106 inlägg
Oj!? Tusenlappar? Är dom snodda..hehe. :) Var hittar man dom så billigt?..., billigaste jag sätt hittills är på Reference för 9990...lär ju droppa snart i pris dock.
Postad 16 December 2004 - 13:27
  • 2665 inlägg
tror inte de droppar i pris om jag ska vara ärlig.
nämner ja priset och var någonstans så kommer nog säljaren gå under hehe.. tror inte personen i fråga tjänar något på affären.
du kan ju annars kolla i tyskland där får du den för runt 8000
Postad 16 December 2004 - 17:06
amcsthlm
  • amcsthlm
  • 106 inlägg
Ok hehe, ja troligen så kanske han gör det. Men du och jag kanske kan göra en deal :)
Tack på förslaget om tyskland.
Men då lägger jag nog vad den kostar i sverige istället, så är det lättare att klaga...
:P
Postad 17 December 2004 - 12:41
  • 2416 inlägg
Har möjligen tänkt om lite. Tänker som så att om man endast ska ha en receiver att driva sin hemanläggning med, av någon anledning, så tror jag 8500 blir väldigt ensam i sin majestät. Men om man däremot vet med sig att man absolut ska ha en extern förstärkare för att få det där sista som inte receivers mäktar frambringa, ja då är det nog som de flesta andra redan har räknat ut, det lär inte bli en skillnad mellan 75-85 som berättigar merpriset på 5000,-. (50%>)
Surroundljudet är uppenbarligen riktigt bra på 7500 och förstegsdelen lär inte vara betydligt bättre på 8500 även om slutstegsdelen troligtvis är det, och även om då 2 kanals-ljudet överlag är bättre via 8500.
Därför borde 7500 och extern förstärkare vara den melodi som ger klart mest och bäst för pengarna, om man inte är i desperat behov av DVI switch och/eller HDCD alltså...
DVI är redan en döende standard och inget som man "måste" ha idag då HDMI är framtiden (förstår inte varför dom inte kör med HDMI då deras DVD:er är stoppade i lanseringen för installation av HDMI-2 ??!!).
Skulle jag köpa Marantz DV7500 sedan så kan jag ju ändå köra HDMI-DVI (dvd-proj) och köra resten via komponentväxel till projen då receivern ju ändå inte växlar upp till DVI ut... (synd)
HDCD får man ju redan i vissa, om än långt ifrån alla, DVD:spelare som vår käre Dragon Lord har övertygat mig om, och sedan är det så att även om det är en väldigt bra grej så har jag sammalagt 1 (!) skiva med nyss nämnda HDCD...
EDIT: HDCD gör att alla CD, med och utan HDCD, låter bättre... värt att nämna och jag kom på det precis som jag tröck iväg inlägget...
Nä, det är lite förvånande att det är så pass få skillnader (beror på vad man söker!) mellan 7500 och 8500 till en så stor prismässig skillnad, det är nästan så att dom har gjort bort sig lite. Hade 8500 haft HDMI och uppkonvertering, ja då hade läget sett lite annorlunda ut.
Jag säger inte att 8500 inte är värd vad den kostar för jag är övertygad om att den kommer att äga 15000,- segmentet, men däremot tror jag att de flesta kommer att välja 7500 som nog är ett sju****s bra köp... trots att 8500 har dubbla chassi,skärmat med koppar, handmatchade och bättre kvalitet på komponenter, större kondingar osv... så är nog 7500 ett bättre köp för gemene man, allra helst om man kör med extern slutsteg...
Jag måste nog fundera på att eventuellt inhandla 7-serien istället för 8-serien ser det ut som... och då kan jag lägga de resterande 5000,- på DV7500!! heureka!
Redigerat av Unregisteredb38af287, 17 December 2004 - 12:43.
Postad 17 December 2004 - 12:54
  • 2665 inlägg
Så du börjar alltså tvivla min lilla vän?
låter intressant det du skriver och dina tankar, ska åka iväg och checka läget idag :blink:
Postad 17 December 2004 - 14:01
amcsthlm
  • amcsthlm
  • 106 inlägg
Tjena
Var och lyssnade på en 7500 och en H/K 430 med Dynaudio 42or idag. Måste ändå säga att H/K lät bättre på dom högtalarna. Mer detaljerat, kanske beror på att h/k har ett mer hårt ljud. Däremot så såg jag en del nackdelar med 430, mycket att den inte omvandlar bildkällan + att 7500 har mer fördelar för bild. Där tror jag 7500 är bättre. Vill nämligen koppla in så mycket som möjligt via förstärkaren, digitaltv, xbox, dvd m.m. så man kan styra allt via en fjärr. Skönt då kanske man kan slippa 4 fjärrar i fortsättningen...
Även fast det var lite bättre ljud med 430 och dynaudiorna, så var dom fånigt lika varandra. 7500 har varmare ljud. Lättare att byta till ett par andra högtalare ifall man vill. Sen så tycker jag att 7500 är mycket snyggare, mer classic. Som sagt tidigare så tror jag man tröttnar på H/K look.
:blink:
Postad 17 December 2004 - 14:24
  • 2665 inlägg
Tja nu har jag beställt en marantz 7500 . leverans på tisdag till veckan!
Postad 21 December 2004 - 07:16
  • 2416 inlägg
Idag är det tisdag, jag håller tummarna för dig (oss) Dragon... och till er andra vill jag berätta att jag var och kände lite på 7500 igår och den var stor, fet och jättefin. Säljaren sa att den var ett stort lyft upp gentemot 7400 och bekräftade att det primärt var 2 kanalsdelen av ljudet som skulle få sig en rejäl uppdatering gentemot 8500.
Dom hade inte kalibrerat in den osv, så jag orkade inte insistera på att få den spelad. Jag får ju förhoppningsvis också min 7500 idag eller imorrn, så jag kan vänta =)
Postad 21 December 2004 - 10:10
  • 2665 inlägg
Om de nu bara är 2 kanals biten så får sig ett lyft me 8500 så kan ja skatta mig lycklig. blir ju ett separat slutsteg till det så smånigom...
Postad 21 December 2004 - 13:39
Unregistered26101
  • Unregistered26101
Nu vill jag ha recensioner!!! Jag hade nästan bestämt mig för en 7400 men nu när jag läst lite om 7500 så är jag inte säker. Men för mig är 2kanals väldigt viktigt och då jag läser att 8500 ska vara mycket bättre i detta så är då 7500 dålig? Hur förhåller sig 7500 mot 7400 i 2kanals samt hur skiljer sig den mot andra i samma prisklass?
Postad 21 December 2004 - 13:54
Hinken74
  • Hinken74
  • 2346 inlägg
Ja det blir inte så billigt efter omräkning 8435.9698. Visst är det lite billigare men ej värt besväret. Förövrigt tycker jag den är rätt snygg.
Postad 21 December 2004 - 14:47
  • 2665 inlägg
tror att den kommer krossa 7400 i 2 kanal
Postad 21 December 2004 - 19:20
Tomas L
  • Tomas L
  • 1561 inlägg
Huvudet på spiken! Väntar på första receiver med HDMI-switchning i rimlig prisklass, vilket för mig är <15 tkr. Hade 8500 haft det så hade den definitivt varit kung i receiver-klassen under 20 tkr för ett bra tag framöver. Denon, Onkyos och Pioneers kommande slagskepp med HDMI-switchning går ju på 40-50 tkr... :)
Postad 21 December 2004 - 23:56
Scaramanga
  • Scaramanga
  • 131 inlägg
De är ju fan, inte får man känna sig nöjd med sitt nya inköp länge inte :)
Fast jag är väldigt nöjd över 7400´n iaf, får väll ge fan i att uppsöka någon 7500/8500 för demo bara, så kanske det håller i sig ett tag till :)
Har svårt att tro att någon blir missnöjd med sin nya pjäs iaf.. Blir roligt att höra vad ni tycker när de börjar trilla in hos er!
Postad 22 December 2004 - 00:59
Robin.S
  • Robin.S
hej
Är också riktigt intresserad av den där vackra skapelsen, men undrar om den skulle funka bra till mina högtalare? :)
Mina högtalare är: front xtz 99w2mt
center jmlab chorus cc700s
bak jmlab chorus 705s
SÅ vad tror ni, kommer dom att fungera bra tillsammans. Tacksam för svar :)
mvh
Postad 22 December 2004 - 09:08
  • 2416 inlägg
8500 lär låta som mycket få receivrar i samma segment eller del på världskartan, skulle jag gissa. Speciellt då på just 2 kanalsljudet där den konkurrerar ut 7500 iom en rad förbättringar som ger resultat på just 2 kanalsljudet, men även surroundljudet i form av kraftigare nätdel osv.
7500 ska låta mycket bättre än 7400 enligt vissa källor, 2 kanalsmässigt, och den ska låta brutalt bra på surround enligt vissa som testat, även ganska erfarna testare.
Kan de verkligen vara så bra pga att dom är så billiga? är pris/prestanda i fas? - Ja det kan man ju undra. men jag har hört på flera håll (bla. av handlare med hyfsad koll) att dom dels har flyttat produktionen från Japan till Kina och därmed sparar en rejäl slant. Dels så har dom tappat en del marknadsandelar de senaste åren och vill åtgärda det genom att ge-mer-för-pengarna om man säger så... trevligt trevligt då det tillkommer oss köpare/användare!
