* Officiell tråd - Denon AVR-3806 *
411 svar till detta ämne
Postad 22 July 2005 - 21:22
scenic
  • scenic
  • 1066 inlägg
Denon AVR-3806
Available in Black & Silver
HDMI Switching (High-Definition Multimedia Interface)
i.link digital input for DVD-Audio & SACD
Dolby Digital and DTS decoding
Dolby Digital EX, Pro Logic IIx decoding with Cinema and Music Modes
DTS-ES Matrix & Discrete 6.1 decoding
DTS Neo:6 96/24 Cinema & Music Surround decoding • DTS 96/24 5.1 decoding
HDCD decoding
New DDSC-Digital featuring Analog Devices HammerHead SHARC 32 bit floating point DSP processor
New Auto-Setup and Room EQ function with microphone supplied
7 Channels equal power amplifier section
120 watts per channel (8 ohms, 20 Hz-20 kHz, <.05%THD) •
16 Burr-Brown PCM-1791 24 bit, 192 kHz high resolution DACs on all eight channels, in differential configuration
Real 24 bit, 192 kHz Digital Interface Receiver
24 bit, 192 kHz A/D conversion (Burr-Brown PCM-1804) on all Stereo analog inputs (Not EXT. Inputs)
Pure Direct mode, features 4 DACs per audio channel in dual-differential configuration (2 Channel Sources)
ALPHA 24 Processing Plus (AL24+) on all channels
Adjustable High and Low Pass Crossover (40/60/80/100/120/150/200/250Hz)
3 Assignable Component Video inputs (100MHz Bandwidth), with On-Screen Display
Video Conversion of Composite to S-Video and/or to Component, with on-screen display
7.1 external wide bandwidth (100 kHz) inputs for multi-channel formats, such as DVD-Audio and Super Audio CD
5/7 Channel Stereo
Digitally regulated volume control with .5dB increment adjustments and step range of -80 to +15
Audio Delay adjustment to match audio signals with video signals(0-200ms)
DENON Link 3rd (Super Audio CD & DVD-Audio) compatible digital input
7 assignable digital inputs (5 Optical, 2 Coaxial)
Built-in RDS AM/FM tuner
3 Source, 3 Multizone functionality with Discrete Power, Source Select and Volume control for each zone
Multi-Zone stereo pre-amp level audio outputs, fixed or variable level (Zone 3 fixed only)
Multi-Zone Composite Video output
Power Amplifier Assign function, lets you assign 2 of the 7 amp channels to drive Zone 2 or 3 speakers directly
New EL backlighting pre-programmed/learning remote
RS-232C Port for Third Party Control Systems
Remote I/O ports
Assignable +12v triggers (2)
Full System Setup/Parameter control on front panel, with feedback on front panel display (Monitor is not needed for setup)
Redigerat av Martin.M, 16 January 2006 - 00:27.
Postad 22 July 2005 - 21:35
ktd
  • ktd
  • 1662 inlägg
Hmmm... Helt klart en kandidat till min efterträdare av min Denon 2800...
Måste ha en stärkare med audio delay nu när man har skaffat plasma...
Postad 22 July 2005 - 21:38
Unregisteredd8265939
  • Unregisteredd8265939
  • 117 inlägg
i.Link & HDMI som största förändringarna på pappret jämfört med 3805:an
ser likadan ut dessutom!
INte värt att uppgradera frpn 3805:an då mao. :)
Postad 22 July 2005 - 23:31
Audiovector
  • Audiovector
  • 4885 inlägg
Det framgår inte om den kan köras bi-ampat på ett enklare sätt än 3805 va? Typ Pioneer 1014 eller Marantz 7500...
Postad 01 August 2005 - 09:51
hdmi växel är vad jag har gått och väntat på iaf ... så nu blir det väl byte igen framåt hösten trots att jag lovat mig själv att inte byta igen ;)
Postad 01 August 2005 - 10:13
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Jag har varit inne på att handla 3805 men det här är ju ännu bättre. Nu får man en ny och färsk förstärkare. Hoppas priset blir ungefär samma som 3805.
Kommer det en uppdatering av den tillhörande DVDspelare 3910 ochså?
Redigerat av Blind Guardian, 01 August 2005 - 11:13.
Postad 01 August 2005 - 10:40
BioBerra
  • BioBerra
  • 5776 inlägg
Undra om den har samma snygga fjärrkontroll som 3805, eller kanske till och med ännu snyggare ;)
Postad 01 August 2005 - 11:23
Blind Guardian
  • Blind Guardian
  • 335 inlägg
kollade lite på denons amerikanska hemsida där det har dykt upp en 4806 och en 5806 samt en DVDspelare vid namn 5910.
http://www.usa.denon...cts.asp?l=1&c=2
Jag undrar ifall dessa kommer till europa ochså.
Det står dock inget om 3806, var hittade du informationen förresten?
Postad 01 August 2005 - 12:19
Horrabin
  • Horrabin
  • 402 inlägg
@Blind Guardian: 4806 och 5806 motsvaras i Sverige av AVC-A11XV respektive AVC-A1XV och båda modellerna finns att köpa på Hifiklubben.
Postad 01 August 2005 - 15:31
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Tack Horra, jag anade nästan det. Konstigt att man döper om de till en den europeiska marknaden, tycker att beteckningarna i usa låter vettigare. jaja, skitsamma. Nån som vet nåt om framtiden för DVDspelaren 3910?
Postad 01 August 2005 - 19:45
ALLaNoN_80
  • ALLaNoN_80
  • 460 inlägg
Nååå nu blev man ju så där köpsugen igen ;)
Postad 03 August 2005 - 01:52
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Hoppas att de har fixat alla småproblem som bi-amp läget och kvaliteten på micken som delvis var rätt taskig.
Någon som vet när denna är planerad att släppas?
Postad 03 August 2005 - 13:49
Tråden är nu * Officiell *
Postad 04 August 2005 - 21:22
Unregistered2811108e
  • Unregistered2811108e
  • 159 inlägg
Läste på HiFi klubbens forum:
"Derudover arbejder Denon på en AVR3806 som de håber på kan lanceres omkring Oktober/November"
Postad 06 August 2005 - 10:07
mailpoman
  • mailpoman
  • 86 inlägg
Enligt följande länk verkar det som om 3806 inte kommer ha i.link.
http://www.audioholi...306receiver.php
//Ola
Postad 07 August 2005 - 14:55
Om det stämmer det som står på Audioholics så kommer jag byta min Marantz till denna vilken dag som helst..
Audyssey MultEQxt Room EQ
För er som inte vet vad detta är så kan jag berätta att det är en funktion som gör det möjligt att kallibrera in perfekt ljud för flera sittplatser... samtidigt!!
Funkar suveränt bra tycker jag. Lyssnade på det på high-end 05 på denons flaggskepp.
Den ulitmata funktionen enligt mig ;)
Kopierar in lite info från hifiklubben om Audessey från deras flaggskepp AVC-A1XV
Audessey-rumskorrektion och Auto Set-up
En annan av de riktigt stora nyheterna är det extremt avancerade Audessey-rumskorrektionssystemet. Ljudet i en hemmabio påverkas i hög grad av rummets akustik. Vid några frekvenser kan det till exempel bli för mycket bas och vid andra kan det bli för lite. Det ojämna frekvensomfånget kan ibland förstöra ljudet. System som korrigerar rumsakustiken är ingen nyhet, men de nuvarande systemen har bara kunnat korrigera ljudet vid ett visst ställe i rummet. De som sitter på andra platser har inte kunnat dra nytta av rumskorrektionen.
AVC-A1XV är den första förstärkaren i världen som använder ett nytt och revolutionerande system från Audessey som kallas MultEQ XT. Med detta använder du den medföljande mikrofonen för att mäta ljudet på 8 olika platser i rummet. Förstärkaren använder sedan sina mycket kraftiga DSP-processorer så att ljudet i det närmaste blir helt perfekt på alla 8 platserna – samtidigt! Det låter kanske som en omöjlighet, men det fungerar faktiskt. Korrigeringen utförs inte genom att värdena från de olika mätningarna läggs samman, utan genom en unik beräkning för varje plats. Otroligt effektivt!
Postad 07 August 2005 - 15:54
sonyman
  • sonyman
  • 1560 inlägg
Undrar vad denna tingest kommer hamna på. Meen, nu blev det ju svårt, kanske ska avakta mitt receiverköp ett tag, 3806 e ju hyffsat framtidssäker med hdmi, precis vad jag letat efter.
Vill ha!!
Postad 07 August 2005 - 17:03
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Synd att den först kommer i oktober/november, skulle behöva den just nu faktiskt. Men den som väntar på nåt gott...
Postad 07 August 2005 - 17:09
Unregistereda0ef723f
  • Unregistereda0ef723f
  • 3439 inlägg
Köper denna så fort den kommer ut om det stämmer att den har Audyssey MultEQxt Room EQ. ;)
Undrar vilket pris den kommer hamna på i sverige?
Saknar "Personal Memory Plus" med min nuvarande Marantz SR7500. Det har AVR-3806 och det hade jag på min tidigare AVR-3803. Guld värt för mig som är kalibreringstok. :rolleyes:
Postad 07 August 2005 - 21:36
  • 159 inlägg
Hoppas 3806 kommer ha "Source Function Renaming" ..
Och vad är 4306???
Postad 08 August 2005 - 08:44
  • 159 inlägg
Bilder på svart Denon 3806 fram-baksida o fjärr på Avforum.no
Redigerat av Unregistered2811108e, 08 August 2005 - 09:06.
Postad 08 August 2005 - 13:22
Blind Guardian
  • Blind Guardian
  • 335 inlägg
Det stod ju 4306 på lådan och inte 3806... Är det norska varianten eller :)
Postad 08 August 2005 - 17:14
Freddie73
  • Freddie73
  • 58 inlägg
Ja, lite skumt. Men det står ju 3806 på klisterlappen på baksidan. En hybrid :P
Blir ju grymt sugen på att byta ut 3805:an. All nyheter är ju godsaker.
Postad 08 August 2005 - 19:09
4306 är modellen över 3806, den har bland annat dessa funktioner utöver dom som 3806 har:
iPod Terminal and USB port (AVR-4306)
IEEE 1394 (AVR-4306)
Analogue to HDMI upconversion (AVR-4306)
PC Setup and Control capability via RJ45 port (AVR-4306)
130 watt istället för 120 per kanal
Annan dsp processor ...
Kolla länken till audioholics längre upp för fulla specifikationer.
Postad 15 August 2005 - 21:43
BioBerra
  • BioBerra
  • 5776 inlägg
Låter nästan som att man vill ha 4306 ännu mera än 3806, speciellt med tanke på analogue to HDMI upconversion, perfekt för Xbox360 som bara kommer köra med komponent som det verkar.
Bara att börja spara! :)
Vad tror ni för prisnivå?
15.000 för 4306 och 10.000 för 3806 eller blir det dyrare ??
Postad 16 August 2005 - 10:18
Blind Guardian
  • Blind Guardian
  • 335 inlägg
nog dyrare, skulle gissa på minst 12.000 för 3806...
4306 vet jag inte, kanske runt 15.000.
Postad 16 August 2005 - 13:58
BioBerra
  • BioBerra
  • 5776 inlägg
Lär kosta 19.000 här om man ska följa standarden om att man bara lägger på en nolla från det amerikanska priset. $1999 för 4306 känns lite saftigt men den lär nog räcka några år iaf. Förhoppningsvis sjunker priset lika fort som på alla andra prylar idag.
Postad 17 August 2005 - 08:23
Efny
  • Efny
  • 176 inlägg
4306 -- 17000:-
Enligt svenskt nyhetsbrev...
Postad 17 August 2005 - 15:58
BioBerra
  • BioBerra
  • 5776 inlägg
3806 har man ju defintivt råd med att kolla in, 4306 kanske blir en julklapp till mig själv :) om jag nu får sålt mina gamla förstärkare. Känns ju helt klart motiverat att köpa den bättre versionen av dessa 2, 4306 känns som en het kandidat i ett framtida receiverbyte!
Postad 17 August 2005 - 16:01
pear
  • pear
  • 508 inlägg
3806  --  12000:-
4306  --  17000:-
Enligt vilket svenskt nyhetsbrev?
Postad 18 August 2005 - 03:31
vantechmag
  • vantechmag
  • 115 inlägg
Jag trodde att "AVC" var för förstärkar-varianterna utan tuner...
Denon har föresten just släppte en AVC-1920 med room EQ :)
Postad 24 August 2005 - 20:51
Peter B
  • Peter B
  • 283 inlägg
Är det någon som jämfört specifikationerna för Denon AVR-3806 med Pioneer AX4AVi. Man kan undra om det finns någon vinnare. Denon finns i svart om man gillar det.
Postad 24 August 2005 - 22:10
Denon har Audessey rumskorrektion, allt jag behöver veta för att köpa en :(
Postad 24 August 2005 - 23:48
Unregistered1cf0517b
  • Unregistered1cf0517b
  • 98 inlägg
Dessa system funkar sällan bra, på 3805 var det tämligen kasst och det kommer troligen att vara det även nu. Akustikproblem åtgärdar man inte med en processor som inte kan separera rumsbidraget från högtalarens direktljud och sedan justerar på den adderade slutprodukten istället för på ingående parametrar. Bara en tanke...
Postad 25 August 2005 - 07:35
  • 3439 inlägg
olof_b: Rumskalibreringen i AVR-3805 jämfört med den i 3806 är spelar inte ens på samma planhalva. Du skriver att den "troligen kommer vara kass även på AVR-3806".
Ja, du kanske missade Martins Audessey-ord i hans text. Hela namnet är Audessey MultEQ XT. Rätt så testat system vid detta laget och det fungerar över förväntan. Även i problematiska rum. Läs om denna teknik på internet. :( * no offense *
Redigerat av Unregistereda0ef723f, 25 August 2005 - 07:44.
Postad 25 August 2005 - 09:15
Unregisteredf2a7f9fd
  • Unregisteredf2a7f9fd
  • 3989 inlägg
Ngn som vet när denna kommer.
Vill göra slag i saken snart på Marantz 7500 eller denna men vill inte vänta fööör länge, och vet ngn ungefär vad priset kommer ligga på.
Postad 25 August 2005 - 09:39
bjornsva
  • bjornsva
  • 1330 inlägg
3806  --  12000:-
4306  --  17000:-
Har har du priserna iaf. Inte slutgiltiga vad jag vet men dom är vettiga.
Postad 25 August 2005 - 10:01
  • 98 inlägg
Läs om denna teknik på internet.  * no offense *
none taken
Det spelar mindre roll i mina öron eftersom att förstärkaren inte vet hur högtalaren är beskaffad utan endast summan av högtalare och rum. Ta tex tact som också är "rätt testat vid det här laget", det blir inte bättre för det. Vissa saker kanske förbättras men i regel så får man en massa fel på köpet. Bäst torde ändå canton digital 1 vara på den fronten då eftersom mjukvara och hårdvara är anpassade efter varandra. Hela problematiken med korrigeringssystem är att man åtgärdar inte felkällan utan försöker dölja den med ett ännu större fel. Ingenjören i mig tycker detta verkar dumt.
Postad 25 August 2005 - 10:14
  • 3989 inlägg
3806  --  12000:-
4306  --  17000:-
Låter som bra pris, då återstår frågan när kommer den...?
Postad 25 August 2005 - 12:11
Jag lyssnade på Audessey av/på med olika sittplatser på high-end 05. Skillnaden var verkligen stor. Suveränt att alla i bion kan få kanonljud samtidigt.
Sen om det är dumt eller inte gör mig mindre så länge det låter bättre :(
Postad 25 August 2005 - 13:53
Unregistereda19cb1e5
  • Unregistereda19cb1e5
  • 353 inlägg
Är det bekräftat att 3806 kommer att ha samma form av Audessey MultEQ XT som de största modellerna? Eller kommer det bara vara en version som hämtat teknik från den?
mvh / Ante
Postad 25 August 2005 - 13:56
Det ska vara samma med 8 sittplatsers kallibrering :(
Postad 25 August 2005 - 18:17
Unregistered42205
  • Unregistered42205
  • 842 inlägg
Vad innebär eq Audessey egentligen? Måste vara himla bra om man ska köpa en 3806 pg a den funktionen.
Postad 25 August 2005 - 20:54
  • 98 inlägg
Det var lite min tanke när jag ställd mig på tvären från början. Det framstår som att det är guds gåva till mänskligheten när det egentligen kan var precis tvärt om
Postad 25 August 2005 - 22:36
Se detta inlägg längre upp i tråden klick
Postad 25 August 2005 - 22:51
  • 98 inlägg
det låter ju naturligtvis väldigt bra på papper men jag reserverar mig fortfarande då det egentligen inte står vad den här maskinen gör. I regel handlar det om korrigeringar i amplitud och inte justering i tidsdomän. Påstående i citatet är inte helt verklighetsförankrat heller då man påstår att ljudet blir närmast perfekt överallt vilket är en fysikalisk omöjlighet. Det kommer aldrig låta likadant om jag står mot bakre väggen som om jag står mitt i rummet, det är fundamental våglära.
Postad 25 August 2005 - 23:02
Du får åka och testa hos hifiklubben, förhoppningsvis har man ju inte heller sittplats mitt i rummet samt vid bakre väggen.
Läs mer om hur det funkar på dessa sidor:
http://www.audyssey.com
http://www.audioholi...ysseyMultEQ.php
Det är inte direkt några nybörjare och päron som utvecklad denna tekniken.
Här med och utan audyssey på 6 sittplatser.
Utan
Med
Redigerat av Martin.M, 25 August 2005 - 23:55.
Postad 26 August 2005 - 09:17
  • 3989 inlägg
Har fått svar från hifiklubben nu som sa att den beräknas komma in under november till ett pris på 11.998:-
Fan då måste man vänta ytterligare en månad :-(
Postad 26 August 2005 - 10:10
hifiidiot
  • hifiidiot
  • 332 inlägg
Jag var också och lyssnade på Audessey på high-end 05. Blev riktigt imponerad. Om nu nya 3806 har det så verkar det faktiskt högintressant.
Tänkte ett slag slå till på en ny 3805 för 9 papp, men jag tror nog 3806 kan vara värd 3 tusen extra... kanske.
Är dock fortfarande lite skeptisk till hur 3805/3806 är så lämplig till mina högtare som är 4 ohm. 2105 var ingen höjdare iaf... lite för 'klen/stömsvag'. Hur är 38XX rörande strömstyrka jämfört med 2105?
Postad 26 August 2005 - 22:49
Lamander
  • Lamander
Enligt Hifi-klubben kommer inte 4306:an att säljas i Sverige :) utan bara i Japan och USA.
Vi får hoppas att killen jag pratade med inte var helt uppdaterad.
  • XBox Halo Edition
    2026-07-29 08:14:23
