Sony BDP-S1E
244 svar till detta ämne
Sony BDP-S1 Region A (Blu-ray & DVD-spelare) 1 8.333332 (2) Inga priser
Sony BDP-S1E (Blu-ray & DVD-spelare) 1 8.142856 (6) Inga priser
Sony BDP-S300 (Blu-ray & DVD-spelare) 1 7.854166 (47) Inga priser
4 relaterade trådar
Postad 22 May 2006 - 08:24
  • Audio Code 3
  • 12561 inlägg
Preliminär lansering under 15 Augusti för en dryga 999,95$
Blu-ray Disc / DVD Playback
Video Codec Format : MPEG2/MPEG4-AVC/VC-1
Full HD 1080p Video Output through HDMI connection
DVD Upscaling to 1080p
Picture Mode Settings
Uncompressed Multi Channel Linear PCM Output
Dolby® Digital Plus(Dolby® Digital audio stream only), Dolby® TrueHD (Dolby® Digital audio stream only) dts®-HD --- (dts audio stream only) Digital Out and decoding capability
Dolby® Digital and dts® 5.1channel Output
Multi Channel 192KHz/24bit Audio D/A Converters
Rigid Beam Construction
Separated Audio Circuit Board
Highly Tuned Audio Parts
Drive Bracket for stability of drive system
Individual Speaker Setting
Off Center Insulator Feet
BD-Java Interactive Capability
Pop up Menu
Quick Set Up
FL Off/Dimmer Mode
Screen Saver
MP3 and JPEG Playback from DVD Media
Parental Control
IR In
Multi Brand TV Control Remote
Sophisticated Box Design with blue glass front
Specifikationer
Inputs and Outputs
HDMI™ Connection1 Output(s): 1 (Rear)
Component Video (Y/Pb/Pr) Output(s): 1 (Rear)
S-Video Output(s): 1 (Rear)
Composite Audio Output(s): 1 (Rear)
Optical Audio Output(s): 1 (Rear)
Coaxial Audio Digital Output(s): 1 (Rear)
Analog Audio Output(s): 5.1 ch; 1 (Rear)
Analog Audio Output(s): 2 ch; 1 (Rear)
IR Input(s): 1 (Rear)
Dimensions (W x H x D)
16.9" x 4.1" x 13.9" (430mm x 105mm x 355mm)
The new BDP-S1 Blu-ray Disc home player from Sony offers a host of new high-definition entertainment possibilities. The BDP-S1 features 1920 x 1080p output, the highest HD signal output currently available through a HDMI™ connection. If your HD-capable television does not have an HDMI connection, you can still get the Blu-ray experience - the 1080i analog output allows for HD-capable televisions without HDMI to enjoy Blu-ray Disc features. The BDP-S1 is also compatible with standard DVDs with the added feature of 1080p upscaling through HDMI, which gives new life to existing DVDs libraries. BD-Java interactivity will further enhance the BD entertainment experience, allowing for development of advanced interactive features. Its sophisticated design, with blue glass front, will compliment any decor. Bring your home entertainment experience to a new level with the BDP-S1 Blu-ray Disc home player.
Postad 22 May 2006 - 19:58
cwp
  • cwp
  • 716 inlägg
Undrar bara när de kommer hit (och vad de kommer att kosta här!?!).
Postad 01 November 2006 - 21:00
  • Audio Code 3
  • 12561 inlägg
Som några redan vet har Sony skjutit upp släpp datumet till december, (och filmbolagen är skit förbannade över bl.a detta, men det hör till en annan tråd -men var bara tvungen att nämna det)
Priset är dock detsamma, tror jag :huh:
Postad 02 November 2006 - 19:10
scenic
  • scenic
  • 1066 inlägg
Vad e det för bildomvandlare i Blue-Ray spelare?
12, 14 bit??
Postad 28 November 2006 - 17:58
Addex
  • Addex
  • 1902 inlägg
Släpps 5 dec i staterna, den har HDMI 1.3!
Källa
Postad 29 November 2006 - 18:35
Unregisteredf7bba9d7
  • Unregisteredf7bba9d7
  • 1113 inlägg
Usch upp till 90 sekunder innan filmen startar värre en Toshiba HD-DVD spelare hd-a1 som tar ca 60 sekunder!!!
Den enda vettiga Blu Ray spelare att köpa utan att det kostar skjortan är PS3.
Denna spelare får Sony behålla det verkar som Samsungen har lika bra bild som BDP-S1.
Ni kan få denna info i trådar på avsforum.com...
Postad 29 November 2006 - 19:00
Likvid
  • Likvid
  • 421 inlägg
Heh...man kan inte ens spela vanliga musik CDs i Sonys spelare.
Vilken skit... :)
Postad 29 November 2006 - 19:02
Don H (BDP-S1 ägare):
How are the response times? Loading disks, menus etc...?
15 sec from close to picture. (FBI warning)
2 sec to dvd menue.
raptorxx>> Var hittade du 90 sek?
Och ja, ingen CD-spelar funktion är ju bra sunkigt. Men 1080p24 verkar rocka på iaf. :)
scenic>> Varför frågar du? Hade du tänkt köra analog komponent eller? (och även då är 12 vs 14 bit inte relevant)
edit: glömde länk
Redigerat av pacman, 29 November 2006 - 19:28.
Postad 29 November 2006 - 19:22
Addex
  • Addex
  • 1902 inlägg
Posta alltid en källa efter en sådan kommentar. Annars är det bara ren FUD! :)
Postad 29 November 2006 - 19:29
LeTheMan
  • LeTheMan
  • 1014 inlägg
Vilken skit... :)
Jag ska inte försvara spelaren men jag har haft min dvd-spelare i 5år snart, kan gissa att jag har använt cd-skivor i den max tio gånger...
  • Audio Code 3
  • 12561 inlägg
Oj, några har vaknat till :) Tycker fortfarande spelaren är för dyr.
Postad 29 November 2006 - 19:35
  • 1113 inlägg
Det går att söka fram denna info. Du kan väl använda sökfunktionen?
http://www.avsforum....ad.php?t=758995
inlägg 14, 20 och 21.
Spelaren har ingen resume funktion heller. Det verkar var så att denna spelare är ett nedköp!
Postad 30 November 2006 - 16:24
YOU
  • YOU
  • 475 inlägg
Hittar ingen info om spelaren när jag söker på sony.com/se
Men enl pricerunner.com fixar den iaf MP3 på dvd :angry:
Postad 30 November 2006 - 20:28
Pistvakten
  • Pistvakten
  • 143 inlägg
Just det här med resume funktion på BD är ju synd, det är något som dom borde kunna fixa i en senare firmware. (finns prat ang. detta på AVS, läste det på jobbet tidigare idag. Men jag hittar inte tråden nu...) Men helt klart lite B:igt att det inte finns "Out Of The Box".
Postad 12 December 2006 - 13:20
Unregisterede45e3982
  • Unregisterede45e3982
  • 209 inlägg
Den nya spelaren kommer att lanseras i Sverige i april nästa år och Sony estimerar att prislappen kommer att ligga mellan 12 000 och 13 000 kronor.
-Vår spelare är för dem som vill ha det bästa i ljud och bild, det är en high-end-spelare. PlayStation3 är mer för gemene man, det är olika målgrupper som vi vänder oss till, förklarade Jon Grundström, produktchef på Sony.
Och i japan har Sony lanserat en blu-ray-inspelare med en hårddisk på 500GB.
Sonys BDZ-V9 började säljas i Japan i fredags med en prislapp på hela 300 000 yen, cirka 17 700 kronor. Det var inte billigt!!
Men en blu-ray inspelare står högt upp på min önskelista
Redigerat av Unregisterede45e3982, 12 December 2006 - 14:42.
Postad 13 December 2006 - 01:54
Unregisteredf64a5233
  • Unregisteredf64a5233
  • 14825 inlägg
Pressrelease.
Sony satsar på Blu-ray – nästa generation av DVD-format
Blu-ray – nästa generation av DVD-format – kan lagra upp till 50 GB, och inom en framtid ända upp till 200 GB. Det öppnar helt nya möjligheter att spela upp och spela in filmer i full HD-kvalitet (1080p), lagra stora mängder data och utveckla nya och mer realistiska spel.
Sony är ett av de drivande företagen bakom Blu-ray och kommer att använda det nya formatet i en rad olika typer av produkter.
Den ”gamla” DVD-tekniken är idag nästan tio år gammal. Frånsett introduktionen av dual-layer-tekniken för några år sedan och bättre avspelningsmöjligheter, har formatet varit i stort sett oförändrat sedan starten. Utvecklingen har emellertid sprungit ifrån DVD-formatet, då framför allt High Definition-tekniken (HDTV) ställer betydligt större krav på både lagrings- och överföringskapacitet.
Med Blu-Ray tar utvecklingen ett stort steg framåt. Där det gamla DVD-formatet maximalt klarar 8,5 GB, har Blu-ray idag en kapacitet på 50 GB med dual layer. Tekniken klarar dock upp till åtta lager på skivorna, vilket ger en lagringskapacitet på hela 200 GB.
Den stora lagringskapaciteten behövs för att kunna hantera ”Full HD” 1080p, vilket är den högsta kvalitetsnivån inom HDTV. En vanlig DVD-skiva rymmer inte mer än drygt 30 minuter HD-material. Dessutom krävs den mycket höga överföringshastighet som Blu-ray har, den gamla DVD-tekniken orkar inte med så stora datamängder.
Blu-ray gör det också möjligt att spela upp 7.1 surround-ljud helt digitalt utan några kvalitetsförsämringar. Formatet klarar såväl Dolby TrueHD och Dolby Digital Plus som DTS HD. Tekniken innebär dessutom att man kan få bildskärmsmenyer i flera lager, så att det går att bläddra i menyer eller ta del av ytterligare information samtidigt som man tittar på en film eller ett tv-program.
Blu-ray är bakåtkompatibelt med det gamla DVD-formatet. Det innebär att alla Blu-ray-spelare också kan spela upp vanliga DVD-skivor.
Tekniken bygger på blått laserljus, istället för den gamla teknikens röda laser. Blå laser har högre frekvens och smalare fokus, villket ger möjligheten att packa data tätare på skivorna.
Blu-ray gör det också möjligt att utveckla spel i HD-kvalitet. Det nya formatet är kärnan i nya Sony PlayStation 3.
Jämfört med den konkurrerande blålasertekniken HD-DVD kan Blu-Ray lagra ca 65 procent mer per skiva – 25 GB på en single layer-skiva och 50 GB på en dual layer-skiva. HD-DVD klarar 15 respektive 30 GB. Blu-ray har också dubbelt så hög överföringshastighet som HD-DVD: 72 Mbit/sek jämfört med 36 Mbit/s. Det är en egenskap som framför allt är viktig vid inspelning av HD-material
Blu-ray har fått ett mycket brett stöd, både i underhållningsbranschen och bland hemelektroniktillverkarna. Sju av åtta filmstudior i USA har beslutat sig för att satsa på Blu-ray-formatet för distribution av sina filmer till konsumenterna. Det innebär att ca 90 procent av alla filmer kommer att släppas på Blu-ray-media. Branschorganisationen Blu-ray Disc Association omfattar idag över 170 företag, bland dem Apple, Dell, Hewlett Packard, Hitachi, LG Electronics, Mitsubishi, Panasonic, Pioneer, Philips, Samsung, Sharp, Sony, TDK och Thomson.
Sony kommer att använda Blu-ray inom många produktkategorier – hemmaunderhållningssystem, datorer, spelkonsoler och mycket annat. Under 2007 lanserar Sony flera modeller av Blu-ray-spelare i olika prisklasser. Den första är en high-end-modell som kommer under våren 2007.
http://www.newsonlin...82399&comid=125
Postad 12 January 2007 - 16:46
Pistvakten
  • Pistvakten
  • 143 inlägg
Igår fick jag hem min spelare, och så här initialt så är jag kanooon nöjd med maskinen.
AeonFlux, Gone In 60 Seconds och SWAT ser kalas fint ut i 720p. Lite grynighet i SWAT som är synbart, men detta kan säkert även vara en inställnings sak (jag har bara kalibrerings skiva i reg. 2). Hur som helst så verkar det vara en kanooon spelare.
Hur många är vi som köpt en BDP-S1 ? Och vad tycker ni om maskinen ?
Postad 12 January 2007 - 17:11
mikee
  • mikee
  • 1638 inlägg
Hello Pistvakten.
Funderar att byta min panasonic BD mot just Sonyn.
Vart köpte du den ifrån.
Har du möjligtvis sett panasonicen och har du några Pros and cons för de båda?
Mvh Mikee
Postad 12 January 2007 - 18:45
Pistvakten
  • Pistvakten
  • 143 inlägg
Jag köpte den från DVDirect.
Jag har inte sett Panasonicen så jag kan tyvärr inte yttra mig. Däremot så av vad jag har läst på AVS så verkar ljudet ut ur Panasonicen vara ett strå vassare än Sonyn.
Postad 12 January 2007 - 18:49
  • 1113 inlägg
Tyvärr så får man leva med lite mera grynighet p.g.a. att MPEG2 används. Hoppas att Blu Ray skrotar MPEG2 och går över till en annan codec....
Postad 12 January 2007 - 19:36
random111
  • random111
  • 922 inlägg
Hur många gånger har jag hört detta från raptorxx???
Grynigheten beror på mastern, inte codecen.
Att Blu-ray filmerna som har recenserats av High-Def Digest, DVD Talk och Home Theater Spot under de senaste 3,5 månaderna har i genomsnitt bättre bildkvalité än HD DVD "trots" att drygt hälften av Blu-ray filmerna använder MPEG2 säger en hel del.
Postad 12 January 2007 - 20:04
mikee
  • mikee
  • 1638 inlägg
Tycker inte vi behöver dra detta i denna tråden också :) .
Postad 12 January 2007 - 20:21
  • 1113 inlägg
Det är bara att ge upp. Ifall man ger ut en 25GB skiva med MPEG2 så får kvaliten lida av det....
Postad 12 January 2007 - 20:24
mikee
  • mikee
  • 1638 inlägg
The Covenant 25Gb mpeg2 (om jag inte missminner mig). En AV DET BÄSTA TRANSFERS jag sett... :) .
Så man skall aldrig säga aldrig ;) .
Jag är i alla fall av den skaran sombetsämt mig för att köra med BÅDA formaten större utbud av filmer då :angry:
mvh mikee
Postad 12 January 2007 - 20:39
  • 1113 inlägg
mvh mikee
Håller med dig kommer att köpa PS3 för att kunna köpa Blu Ray filmer också...
Men jag är inte nöjd att Blu Ray ger ut en uråldrig codec som MPEG2 utgiven på 25GB skiva när det finns 50GB skivor som Blu Ray skryter över.
Ifall jag får välja så tar jag en film som har 30GB skiva med VC1 istället för en film med 25GB med MPEG2, tror att alla som inte är helt blåögda håller med mig....
Postad 12 January 2007 - 22:19
Pistvakten
  • Pistvakten
  • 143 inlägg
Med hjälp av "Easter-Egg" menyn på Sony discarna så fick jag bilden betydligt bättre. Aeon är inte alls lika grynig längre. Men en riktig kalibrerings skiva skulle inte skada !
Postad 12 January 2007 - 22:35
hd-fan
  • hd-fan
  • 480 inlägg
Hur är det med regionskodningen på denna, som du köpte på DVDirect ? :D
B)
Redigerat av hd-fan, 12 January 2007 - 22:48.
Postad 13 January 2007 - 11:12
  • 1113 inlägg
Har själv funderat på att köpa denna spelare från DVDirect men tycker att priset är lite högt 9795 kr inkl. frakt. Spelaren klarar av Region A ochr regionsfria Blu Ray filmer.
Tyvärr kan den ej spela upp Blu Ray filmer region B som säljs i Europa ej heller dvdfilmer med region 2.
Tror nog att spelaren är helt okey, hoppas Sony släpper ett firmware som gör att spelaren klarar de nya ljudformaten...
Såg nyss att det har kommit en uppdatering till denna spelare:
Sony firmware
Ni som har spelaren kan ju ladda ner och installera firmwaret...
Redigerat av Unregisteredf7bba9d7, 13 January 2007 - 11:31.
Postad 13 January 2007 - 11:31
Pistvakten
  • Pistvakten
  • 143 inlägg
B)
Precis som raptor skrev så är det Reg A och fria BD samt Reg 1 DVD.
Har dock köpt Hostel från Play UK och denna fungerar (uppenbarligen fri). Fantastic Four från Discshop har jag inte provat ännu. Men denna ska enligt uppgift inte fungera. Alla FOX titlar verkar vara reg skyddade oavsett om det är nysläpp eller katalog titlar.
PCM spåret på Hostel var för övrigt kalas fint bitvis.
Postad 13 January 2007 - 11:34
  • 1113 inlägg
B)
Här får du en länk som du kan ha nytta av när du beställer Blu Ray filmer:
Blu Ray
Postad 13 January 2007 - 22:03
Pistvakten
  • Pistvakten
  • 143 inlägg
Ja, nu har jag haft lite mer tid att "leka" med spelaren. Och jag måste säga åter igen att jag är ruskigt nöjd.
Jag trodde på förhand att jag skulle ha problem med fjärren, jag har nämligen bara haft Pioneer DVD-spelare genom åren. Men fjärren känns bättre och bättre för varje gång jag tar i den. Knapparna bra placerade och lagomt stora. Dessutom är det lite "tyngd" i den vilket gör att den känns lite mer exklusiv. En del av Pioneer fjärrarna kan ju kännas lite plastiga.
Ska försöka få tid att skala DVD imorgon för att se hur det resultatet blir.
Tittade nyss på Superman Returns....bäst bild än så länge.
Postad 06 February 2007 - 23:46
khalnur
  • khalnur
  • 1668 inlägg
Vilken bildvisare har du?
Postad 07 February 2007 - 16:31
Pistvakten
  • Pistvakten
  • 143 inlägg
SONY 40" LCD (40V2000, 1366x768)
Postad 07 February 2007 - 16:46
Unregistered4b026b86
  • Unregistered4b026b86
  • 1292 inlägg
Mikee, är du nöjd med din??
Kommentarer please.
Postad 07 February 2007 - 18:30
mikee
  • mikee
  • 1638 inlägg
Jag kommer beskriva lite mer någon dag vad jag tycker om Sonyn, men jág kan säga att den är klockren så här långt :angry:
Postad 08 February 2007 - 18:02
khalnur
  • khalnur
  • 1668 inlägg
Är det någon som kört denna spelare mot Pioneer plasma och i så fall över 1080p@24?
Postad 12 February 2007 - 23:10
  • Audio Code 3
  • 12561 inlägg
Ok Min Hembio har hittat en sida där S1 är testad med medioker resultat. Nyhets sidan
Postad 12 February 2007 - 23:15
LeTheMan
  • LeTheMan
  • 1014 inlägg
Medioker skulle jag inte sagt. Den är sämre på dvd och klarar inte återskrivningsbara BD-skivor. Dessa två - påverkar fortfarande inte filmspelande med BD-skivor...det är väl det som är målet?
Postad 12 February 2007 - 23:34
Packetloss
  • Packetloss
  • 1886 inlägg
Stämmer bra, den är tyvärr inte så bra i standardupplösningarna 480/576.
Just det, det påverkar inte när du spelar BD diskar eftersom du kör 1080 rakt ut och där är den kristallklar i den blåa bilden med Blu-ray loggan.
Annars har spelaren en mycket hög kvalite och inget klaga på egentligen förutom min första mening ovan.
Postad 12 February 2007 - 23:38
LeTheMan
  • LeTheMan
  • 1014 inlägg
Det förstår jag mycket väl Morlock. Har aldrig tvekat på Sony när det gäller kvalitet...
Postad 13 February 2007 - 08:37
Medioker för de med en display med kass deinterlace/uppskalning av SD ja. Rätt många som har bra displayer numera. Tex Sony Pearl, Mitsu HC5000, Pioneer-plasma etc etc...
Sony borde ha nobelpris för att de introducerat SD-interlace direkt från disc, tänk om alla kunde ha det...hade man sluppit den halvkassa bildbehandlingen alla andra kör med.
Postad 13 February 2007 - 19:35
mikee
  • mikee
  • 1638 inlägg
Har min S1a ute för försäljning......
Skynda och fynda :)
Postad 13 February 2007 - 22:29
  • Audio Code 3
  • 12561 inlägg
Skynda och fynda :)
Vad nu då? Är den billig? :)
Postad 17 February 2007 - 11:31
Unregisteredf2c3ef7e
  • Unregisteredf2c3ef7e
  • 333 inlägg
Skrivs lite här jämfört med Hd E1:ans tråd samt HD A1:ans, hur kan det komma sig?
Skriv gärna mer intryck här och era bildvisare m,m. Hur är ljudet? bilden och dom olika tittlarna.
Postad 18 February 2007 - 11:27
Pistvakten
  • Pistvakten
  • 143 inlägg
Så här drygt en månad efter att jag fick hem min spelare är jag fortfarande riktigt nöjd med den. Jag kan inte klaga på någonting faktiskt. Som jag har skrivit tidigare i tråden trodde jag att fjärren skulle störa mig, men inte ens det.
En del personer på AVS har ju skrivit om att en del titlar inte bootar som dom ska på Sonyn. Dvs. dom lär "stoppa i filmen" flera gånger innan dom lyckas. Inga problem på den fronten heller. Jag har köpt ca. 30st, tittat på ca. 20st men alla har bootat upp som dom ska.
Vad det gäller filmer av dom jag har sett än så länge tycker jag att Crank och Superman Returns är bäst både vad det gäller bild och ljud. Crank var väl kanske ett lite strå vassare. Annars ser allting riktigt bra ut. Naturligtvis ser inte Entrapment lika bra ut som X-Men 3 men det kan man ju inte riktigt begära heller. Den enda filmen som jag är missnöjd med bilden på måste jag säga är American Psycho, inte i närheten av HD kvalite.
Postad 18 February 2007 - 13:35
Packetloss
  • Packetloss
  • 1886 inlägg
Av alla 40 BD filmer jag har sett så är Black Hawk Down överlägset bäst i kvalitet.
Postad 18 February 2007 - 14:58
Pistvakten
  • Pistvakten
  • 143 inlägg
Jag har inte sett BHD på BD, men i början på nästa vecka borde min Reign Of Fire "dimpa ner i lådan". Den ska ju tydligen vara ganska vass den oxå. Väntar fortfarande på Departed....restad.
@Packetloss...Vart köper du film ?
Postad 26 February 2007 - 09:59
cezar
  • cezar
  • 660 inlägg
Sugen på denna att beställa ifrån USA.
http://cgi.ebay.com/...1QQcmdZViewItem
Undrar bara om den går att koda om till regionsfri?
Nu är det Region 1: US, Canada på den.
Postad 14 March 2007 - 02:40
Packetloss
  • Packetloss
  • 1886 inlägg
Axelmusic samt Movietyme, men Movietyme har jag skippat på senare tid med anledning att deras postgång suger något otroligt, kan ta tre veckor innan filmen dimper ner i brevlådan.
Postad 14 March 2007 - 02:42
Packetloss
  • Packetloss
  • 1886 inlägg
Då har man uppdaterat firmwaren till 1.55 som kom ut den 12 Mars.
Verkar snabbare i responsen och uppstart.
    2026-05-20 17:06:21
    2026-05-20 17:04:36
    2026-05-20 17:03:16
    2026-05-20 17:02:29
