* Officiell Tråd - Denon 3808CI *
587 svar till detta ämne
Postad 11 June 2007 - 20:49
Unregistered659
  • Unregistered659
  • 128 inlägg
Dolby TrueHD, dts-HD Master Audio, and 1080p video
The Denon AVR-3808CI A/V receiver serves as the brains and brawn of your high-definition home theater.
* HDMI 1.3 compatibility, which allows for 1080p signal transfer and decoding of the advanced audio formats used in Blu-ray and HD DVD players
* Analog to HDMI video upconversion, so all your video sources look as good as possible
* 1080p scaling is done with high-performance Faroudja DCDi chip
* XM Radio ready
* PC/Network connectivity provides the option for automatic firmware updates
* Audyssey MultEQ XT audio set-up tailors the receiver for your room’s specific acoustics
The AVR-3808CI continues Denon’s new tradition of stellar CI-designated products, as it’s chock full of the performance and features you require for today’s 1080p HDTV home theaters.
The HDMI connections boast the latest 1.3 specification, meaning they pass a full 1080p video signal — with 36-bit Deep Color for unsurpassed color reproduction on compatible TVs. Also supported, via Denon’s newly developed Dynamic Discrete Surround Circuit-HD, are the new Dolby TrueHD and dts-HD Master Audio surround-sound formats now available on Blu-ray and HD DVD high-definition discs. And your existing 480p DVD collection will look better than ever with 1080p scaling provided by Faroudja’s industry-standard-setting DCDi chip.
Ethernet connectivity, auto set-up, a new GUI and more
With an RJ-45 Ethernet port, the 3808CI makes it easier than ever to integrate you A/V system into your home network. Mac/PC audio streaming gives you access to Internet radio as well as all your digitized music, including MP3, WMA, WMA Lossless and now AAC-iTunes files! There are even USB ports (front and rear) with command and control functionality for portable music players, flash drives, and other devices. And of course the optional Denon dock lets you charge, control and distribute the music from your iPod.
This PC/network connectivity gives you the capability to make easy online firmware upgrades, and allows Denon engineers to remotely access your receiver and diagnose and fix many problems.
Another great feature is Audyssey MultEQ XT audio set-up, which tailors the receiver’s settings for your room’s specific acoustics from six different seating positions! And the new, truly interactive graphic user interface (GUI) for the onscreen set-up menus is much more attractive and intuitive, making it a snap to get your new receiver up and running and performing at its optimum levels.
The 3808CI is XM Radio-ready and “Mini-Tuner” compatible (with the XM Mini-Tuner and the proper dock, you can enjoy XM using your home audio system's buttons, knobs and display).
Multiple sources in multiple rooms!
With 3-source/3-zone capability and an additional remote control included, the 3808CI can easily be the centerpiece of your multi-room system. The RS-232 port allows integration with Denon’s new two-way remote and RF/IR base station as well as third-party remote controllers.
Three independent transformers provide the juice for seven channels of 130WPC amplification, so you’ll have more than enough pristine power to feed even the most demanding speakers. Denon’s AL24+ processing reproduces low-level signals with optimum clarity to bring out all the delicate nuances of your music.
Highlights
* Plug ‘n’ Play functionality lets you enjoy your receiver right out of the box; there is still a broad range of assignable functions available for more advanced users and/or custom installers
* Dynamic Discrete Surround Circuit-HD for state-of-the-art reproduction of high-def disc soundtracks
* HDMI 1.3 repeater function passes the highest quality signals available
* AL24+ processing
* New GIU
* 3-source, 3-zone, Zone2 OSD, Zone remote
* Remote maintenance through Internet connection
* Wi-Fi Network audio and IP control
* 2-way RF remote ready
* XM Radio ready
DENON AVR-3808CI $1,599.00
Quote:
Features and Specs
New front panel design, controls and lettering
Equal power amplifiers: 7-channel
Power output (watts per channel @ 8 ohms, 20hz to 20kHz): 130
All channels rated @ 0.05 THD
Low impedance drive capability
High-current/discrete amplifiers
Independent power transformers: 3
DSP Processors – Analog Devices, SHARC: ADSP 21366 x 1, 21367 x 1
Processor design: 32-bit floating point
Processor circuit sampling frequency: 192kHz
Dolby TrueHD and Dolby Digital+ Decoding, dts-HD Master Audio Decoding
THX Surround EX and Dolby Digital Surround EX decoding
Dolby Pro Logic IIx, with Cinema, Music and Game modes
dts ES Discrete 6.1 and dts ES Matrix 6.1 decoding
dts Neo:6 Stereo-to-Surround Cinema and Music modes
dts 96/24 5.1 for DVD-Video processing
HDCD Decoder
XM-HD 5.1 via Neural Surround decoding
Compressed Audio Restorer for portables/iPods/network audio
Audyssey MultiEQ XT auto setup calibration and room correction for 6 seating positions
Audyssey MultiEQ Pro calibration compatible – “Audyssey Installer Ready”
Auto setup microphone included: New Y/Alum type
AL24+ Processing on all channels
24-bit/192kHz DACs: 2-/8-channel PCM1791A
Analog-to-Digital conversion: 24/192 PCM1804
Variable High/Low Pass crossover points (12/24dB): 40/60/80/100/120/150/200/250
Assignable digital inputs
Digital input: DENON Link 3rd (PCM/DSD) compatible
iPod ready with a Denon D-dock
USB Port for portable music players/flash drives/HDD with command and control functionality
XM Satellite Radio ready – “Mini-Tuner” compatible
Multi-source/Zone discrete tuner select function – AM/FM/XM
HDMI 1.3a Repeater Inputs/Outputs – supports 1080p, 36-bit Deep Color, xvYCC Color Space, Auto Lip Sync correction, 7.1 uncompressed 24/96 Audio, SACD
Analog to HDMI Video Conversion/Scaling: 480p/720p/1080i/1080p
Faroudja DCDi Video Processing and Scaling (FLI02310)
Main Zone Video Encoder: Analog Devices ADV7320 12-bit
Main Zone Video Decoder: Analog Devices ADV7403 12-bit
NSV – Noise Shaped Video processing
Digital Inputs: 3 coaxial, 4 optical
Digital Outputs: 2 optical (assignable)
Digital-to-Analog REC Out
Analog Audio Inputs (including Tuner): 11
Phono Input
Analog Record Outputs: 3
Front Panel A/V Inputs w/Cover: Composite, S-Video and Optical
Independent Video Conversion: S-Video to Composite for Zone 2
Composite Video Inputs: 7
Composite Video Outputs: 3
S-Video Inputs: 7
S-Video Outputs: 3
Component Video Inputs x bandwidth (assignable): 3 x 100
Component Video Outputs (parallel main zone): 2
Discrete second zone Component Video Outputs
Dual surround mode speaker selector
All new Graphic User Interface (GUI)
RS-232 Port for third-party controllers and new Denon 2-way Remote Control and RF/IR Base Station
RJ-45 Ethernet Port: Third-party controllers, Mac/PC audio streaming, Internet radio and Web browser function, enhanced for WMA Lossless/AAC-iTunes and album art
PC setup and control capability via Ethernet
Remote/off-site diagnosis, correction, update and upgrade compatible
3-source, 3-zone capability
D/A conversion for multi-zone outputs (Optical, Coaxial and PCM signal only)
Discrete Multi-zone Video Outputs with OSD for Meta-data from iPod/XM/HD
Radio/Ethernet streaming: Composite
Enhanced Power Amplifier assign for multi-zone or bi-amping: 9 modes
Compatible with optional RC-7000/7001CI IR/RF 2-way Remote/Base Station
Dimensions (W x H x D): 17.1 x 6.7 x 16.9 = 434x 170 x 429 (mm)
Weight: 35.6 = 16,2 kg
(identiska mått med 3806)
Den här maskinen kommer förmodligen bli en riktig "snackis" tar tillfället att redan nu utlysa den här tråden som den officiella.
//Loofy
Redigerat av Unregistered659, 29 June 2007 - 12:15.
Postad 11 June 2007 - 22:18
Schumi
  • Schumi
  • 309 inlägg
Såg riktig bra ut. :lol:
Postad 14 June 2007 - 09:43
Unregistered659
  • Unregistered659
  • 128 inlägg
Mmm. Gillar designen. Får nog bli en sån här rackare. Lite synd att den bara har 1 HDMI ut men det går ju att lösa på andra sätt!
Postad 15 June 2007 - 14:02
Nahaz
  • Nahaz
  • 1349 inlägg
Någon på hifiklubben som skulle kunna uttala sig om ett preliminärt datum?
Jag avvaktar med 2807 köpet för denna ser onekligen mer lockande ut.
Postad 15 June 2007 - 15:48
Hankyman
  • Hankyman
  • 40 inlägg
Riktigt nice! Men jag håller med dig jonten123. Varför envisas som med bara 1 hdmi port ut? Tycker att det är dags att införa två ut i denna prisklass och med dom stora tillverkarna... eller? Håller ni inte med?
Postad 17 June 2007 - 01:10
Prism
  • Prism
  • 856 inlägg
Denna kommer verkligen att bli en storsäljare, synd bara att dom inte släpper ett försteg i samma prisklass....
Postad 17 June 2007 - 08:45
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
mm... Kanske skall prova den här som försteg mot min RSP-1066:a vad det lider. :S
Alltså fråga:
  • Wi-Fi Network audio and IP control
Någon som har en uppgift om vilka format ovan specifikation kommer stödja?
Edit:
hehe svaret var närmare än man trodde.. hmm skummade bara igenom första inlägget :wub:
Svar:
//Loofy
Redigerat av Unregistered42611, 17 June 2007 - 13:06.
Postad 17 June 2007 - 08:51
Unregistered1022
  • Unregistered1022
  • 5433 inlägg
ja synd att det inte finns andra återförsäljare som säljer den då skulle det bli lite konkurrens
Postad 17 June 2007 - 13:38
  • 12526 inlägg
Inte lite funktioner de har lyckats trycka in i den.
Angående WIFI, kan man ha en mapp utdelad i windows och komma åt den i receiverns onscreen
meny? Är det bara de större modellerna som stödjer Flac?
USB-port är ju kanon med, speciellt om man kan koppla in en extern hårddisk.
Postad 18 June 2007 - 16:49
Unregistered659
  • Unregistered659
  • 128 inlägg
Interview with Jeff Talmadge, Denon's Director of Product Development
and Systems Integration
http://www.listenup....on/Talmadge.php
Postad 24 June 2007 - 14:32
Unregistered0d88e7f5
  • Unregistered0d88e7f5
  • 143 inlägg
Sjukt intressant, men jag förstår inte varför dom inte kan trycka in 2 HDMI-utgångar? Jag kan ju inte vara ensam om att ha både projektor och TV
Postad 25 June 2007 - 11:16
Leven
  • Leven
  • 461 inlägg
Absolut, fast det jag stör mig på mest är att dom fortfarande envisar med att trycka dit 28st s-video & komposit på varje reciver!
Om man nu handlar reciver för 10-15k så kör man väl inte komposit för sina videoprylar!
bättre att lämna utrymmet tomt om inte annat..
Postad 25 June 2007 - 20:51
beke
  • beke
  • 155 inlägg
Ja det är verkligen knepigt att de kladdar på med alla dessa Composite och s-video, de kostar väl antagligen inget längre att implementera dem i produkten.
Hdmi utgångarna känns det som att de håller hårt i för o ha nåt o locka med till de större modellerna, först var det ingångarna, nu e det utgångarna de håller inne med...
Såg att 2807 ha droppat till 650Eur i tyskland, ska bli intressant o se vad 4306 landar?
Postad 26 June 2007 - 14:25
Unregistered28144
  • Unregistered28144
  • 175 inlägg
Nu när de har uppdaterat OSD:n/GUI:n så får man väl hoppas att det går att köra dessa genom HDMI/komponent också. Det funkar inte på 3806:an....
Men jag hade hellre sett att de satsat mer på ljudet än alla dessa funktioner.... :)
Postad 26 June 2007 - 20:22
  • 143 inlägg
Frågan är väl om det egentligen har hänt så mycket på ljudsidan förutom "HD-ljudformaten".. HDMI hit och dit och Ethernet finns det ju fortfarande en hel del att jobba med.
Postad 26 June 2007 - 20:30
Unregistered28144
  • Unregistered28144
  • 175 inlägg
Tror inte det hänt ett dyft. Förväntar mig ingen ljudförbättring gentemot 3806:an.....
Postad 27 June 2007 - 07:55
Unregistered40880
  • Unregistered40880
  • 865 inlägg
Ja. Verkar som det i flerkanalsvärden idag snarare talas om videoscaling, genomkoppling av bildkällor, Version på Hdmi:n osv. Inte mycket om vad de gjort för nya versionen gällande ljudkvalitet.
Tråkigt :(
Postad 27 June 2007 - 08:12
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
Fördelen med denonmaskinerna tycker jag är att de håller trotsallt en mycket högkvalitét på sina försteg.
//Loofy
Postad 27 June 2007 - 09:37
Unregistered28144
  • Unregistered28144
  • 175 inlägg
//Loofy
Ja, allt är ju relativt... :)
Postad 27 June 2007 - 10:03
skrotfot
  • skrotfot
  • 1201 inlägg
Weight: 35.6
Någon som vet vad denna vikt blir i Kilo?
Postad 27 June 2007 - 11:40
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
mattiasan: Japps mycket. Allt beror ju på vad man jämför med. Skulle vara kul om du kunde räkna upp 5 märken som generellt sätt har bättre(opåverkad signal, i respektive prisklass) försteg (med prioritet på 2 kanaler) i sina försteg relativt Denon.
Själv skall jag plocka hem den så fort jag får syn på den och jämföra med min Rotel RSP-1066 som jag tycker är helt ok - men som sagt relativt sparsmakad på funktioner i övrigt.
//Loofy
Postad 27 June 2007 - 12:11
Unregistered28144
  • Unregistered28144
  • 175 inlägg
//Loofy
Tycker ingen flerkanalsreceiver erbjuder särskilt mycket välljud i 2-kanal, så jag kan inte räkna upp några märken där. Men vad jag kan säga är att jag hade hemma en Nuforce AVP16, och den var hästlängder bättre i 2 kanal, dock en rejäl bedrövelse i handhavande.
Om man jämför 3806:an mot min gamla Yamaha A2, så är skillnaden marginell vid tvåkanalsljud. Däremot så blev det ett lyft vid biotittande med Denonmaskinen.
Sedan kan man ju spekulera i hur mycket känsligare maskinen blir när man trycker in mer elektronik/funktioner i apparaten... Det kanske till och med blir ett nedköp i ljud om man jämför med 3806:an... Vad vet jag?
Postad 27 June 2007 - 12:33
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
Må så vara och håller nog med dig till viss del. Själv är jag lite småsugen på en Squeezebox och ser en liiten fördel om man kan få den biten i Recievern. Frågan är dock hur just den här funktionen står sig jämför mot Squeezeboxen?
Min plan ligger i: (eventuellt)
Nuvarande uppsättning:
Rotel RSP-1066 + RB991 + RB993.
Första funderingen: Hur står sig 3808:ans försteg mot min processor i 2 vs. multikanal.
Andra funderingen: Om jag även byter RB993 mot ett 2 kanalsförsteg som jag hänger efter Denonförsteget (bypassas i multikanal) Skulle slutstegen i 3808:an klara av att driva exempelvis en B&W HTM3:a?
Som sagt frågan är vilken den bästa kompromissen är.
//Loofy
Postad 27 June 2007 - 14:15
Min 3806 slår allt jag har prövat, men sen är jag också Ino-frälst :)
Postad 27 June 2007 - 14:23
Unregistered28144
  • Unregistered28144
  • 175 inlägg
Min 3806 slår allt jag har prövat, men sen är jag också Ino-frälst :(
Är 3806:an godkänd av INO/LTS? Trodde bara det var föregångaren som var det... :)
Postad 27 June 2007 - 18:16
2105 är väl den enda som dom testat. Vet dock att Öhman kommer att byta/har bytt sin 2105 till en Denon 1907.
Postad 29 June 2007 - 18:02
SteNo
  • SteNo
  • 138 inlägg
Ang. 2 HDMI ut, kolla här http://www.avland.co...08/avr-3808.htm
Någon som kan ge klart besked vad som kommer <_<
Har den 2 HDMI ut, så är det här min starkaste kandidat vid en uppgradering (Denon-idiot som man är). :)
Var precis inne på HiFi-klubbens hemsida och 3806 finns inte längre med i prislistan.
Betyder det att 3808 är på väg in? (och till vilket pris i så fall).
Postad 29 June 2007 - 19:44
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
Någon som kan ge klart besked vad som kommer :)
Jag kan inte ge något klart besked men jag har hittat en skillnad på baksidan i modellbeteckningen. Se bild.
//Loofy
Postad 29 June 2007 - 20:49
SteNo
  • SteNo
  • 138 inlägg
Jag såg också skillnaden när man jämförde dom båda modellerna lite mer noga.
Finns lite fler än bara HDMI-utgången.
Vilken modell blir aktuell för sverige, kan man fråga sig?
Postad 30 June 2007 - 01:14
Unregistered249e2560
  • Unregistered249e2560
  • 137 inlägg
Ingen av dessa lär nå oss. Den ena är en 100v maskin och den andra en 120v. Alltså en japansk och en amerikansk apparat.
Postad 30 June 2007 - 11:17
SteNo
  • SteNo
  • 138 inlägg
Vad trött jag blir....
Trodde i min enfald att vi som skriver och söker info här, är så pass införstådda inom det tekniska att det varken blir 100V eller 120V apparater som vi får till Sverige.
Om jag förtydligar mig då; Vilken av de båda apparaterna får vi se i butikerna när dom kommer ( i 220V utförande).
Hmmm....Undrar vad England får för variant :D
Postad 30 June 2007 - 19:16
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
Har snackat med en snubbe nu. Den som heter CI är den som är för USA. Så det lutar jug m.a.o. åt den de har på avland :D
//Loofy
Postad 30 June 2007 - 19:35
  • 137 inlägg
Hmmm....Undrar vad England får för variant B)
Trist att du blev trött. :D
Men läser du noga ser du att jag skriver att det är en japansk och en amerikansk model. Det betyder att det mycket väl kan finnas en både tredje och fjärde version beroende på bl.a. radiodelar, nätuttag, tv-system, etc som gör att det inte går att säga vilken som landar här oavsett hur bilderna ser ut i övrigt.
Postad 01 July 2007 - 08:52
SteNo
  • SteNo
  • 138 inlägg
//Loofy
Tack Loofy, äntligen någon som förstår.
Har du möjligtvis koll på om den får två HDMI ut? Har ganska hög prio på det. Enligt den här https://www.minhembi...t=0&searchtime= får den bara en ut (USA-modellen?). För övrigt tror jag att det är en alldeles utmärkt apparat som kommer att fylla mina behov och krav.
Postad 01 July 2007 - 09:49
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
Jag vet inte mer på den frågan. Men jag hoppas ju givetvis :wub:. Jag hoppas dessutom att de inte ändrar något på designen från den som är på bilden ovan - lite i stil med Denons Tvåkanalare som är riktigt läckra (tycker jag ... ffa i svart.)
//Loofy
Postad 01 July 2007 - 15:18
SteNo
  • SteNo
  • 138 inlägg
Jag kan bara hålla med dig Loofy, riktigt läcker i svart och med den lite rundade designen.
Vill vi se lite nya bilder? (som sagt, hoppas Denon inte ändrar på utseendet).
Bifogad fil  avr3808lrg.jpg   35.64K   177 Antal nerladdningar
Bifogad fil  avr3808sideonlrg.jpg   19.04K   4 Antal nerladdningar
Postad 05 July 2007 - 07:04
t93pan
  • t93pan
  • 1117 inlägg
Men som jag förstod det kommer den inte klara av .flac?
Då faller ju "Squeezebox-funktionaliteten" ganska mycket.
Postad 05 July 2007 - 07:43
Unregistered42611
  • Unregistered42611
  • 4120 inlägg
t93pan: Kolla länken som finns i inlägg #10 i den här tråden.
//Loofy
Postad 05 July 2007 - 07:48
FiRREN
  • FiRREN
  • 444 inlägg
Jag ställer samma fråga här som i 4608 tråden, vilken stärkare låter bäst, AVC-A11XVA eller denna 3808/4608? Kan vara svårt att svara på kanske då ingen här har hört denna, men om man ser till pris och hur komponenterna i den borde vara mot AVC-A11XVA?
Postad 05 July 2007 - 08:22
joakim99
  • joakim99
  • 3433 inlägg
Hur långt är ett snöre? B)
Jag tror att du får ge dig till tåls tills dess folk har lyssnat på den. Annars blir det mest imho meningslöst tyckande baserat kring specar.
Postad 05 July 2007 - 09:27
FiRREN
  • FiRREN
  • 444 inlägg
Hur långt är ett snöre? :D
Mjo, förstod att jag skulle få det svaret men jag är så otålig B)
Postad 05 July 2007 - 09:51
Damp
  • Damp
  • 2750 inlägg
Tycker inte ni det ser lite fjantigt ut med alla beteckningar på fronten?
Är också sjukt otålig på denna modell!
Postad 05 July 2007 - 11:07
  • 143 inlägg
Ska komma i aug enl HiFi-klubben i Sundsvall..
Postad 05 July 2007 - 21:30
FiRREN
  • FiRREN
  • 444 inlägg
Absolut! Det blir lite plottrigt. Skulle vara bättre att inte ha några alls, riktigt stilrent.
Fatta om det fortsätter så här, hela maskinerna kommer vara fyllda med loggor :)
Postad 05 July 2007 - 22:14
coolbud
  • coolbud
Läste på idg.se att priset på 3808 skulle bli 16000:- och 4308:an 25000:-
Se länken: http://m3.idg.se/2.1022/1.96635
Redigerat av coolbud, 05 July 2007 - 22:17.
Postad 06 July 2007 - 09:37
Nahaz
  • Nahaz
  • 1349 inlägg
Jag räknade med runt 12000, om det blir 16 får det bli en 2807 från tyskland istället.
Nytt gränssnitt och nätverksport är inte värt 10000 för mig.
Det lär ju bli en uppgradering till innan dom nya ljudformaten har tagit plats i vardagsrummet ändå.
Postad 06 July 2007 - 09:57
Unregistereda689fd5c
  • Unregistereda689fd5c
  • 64 inlägg
Ja känslan är att priserna genom hela serigen höjs ett hack
Postad 06 July 2007 - 22:50
Unregistered63946e69
  • Unregistered63946e69
  • 337 inlägg
Alltså fråga:
Edit:
hehe svaret var närmare än man trodde.. hmm skummade bara igenom första inlägget :D
Svar:
//Loofy
Har också en RSP-1066. Är nyfiken på när man kan få en renodlad processor utan inbyggt steg med DD True HD samt DTS HD Master Audio.
Kan någon svara på om det går att förbikoppla förstärkaren i 3808:an, och använda separata steg till front/center/surround?
Postad 07 July 2007 - 01:10
Unregistered28144
  • Unregistered28144
  • 175 inlägg
Alltså fråga:
Edit:
Svar:
//Loofy
Det går. Jag har kört en 3806:a på det sättet, och 3808:an bör fungera på samma sätt... Kan inte tänka mig annat.
Postad 08 July 2007 - 15:16
Unregistered3992e2e8
  • Unregistered3992e2e8
  • 376 inlägg
Nja...det går väl inte att koppla bort de interna slutstegen? Man kan använda separata slutsteg, men de interna är alltid inkopplade...eller?
Gillade tiden när recivrarna hade Pre-out/Main-in och en liten bygel imellan, så man kunde använda slutstegen precis som man önskade. ;) (Vissa äldre NAD, Marantz och H/K)
