* Officiell tråd - Epson EH-TW5000/3800 *
585 svar till detta ämne
#501
Postad 11 August 2009 - 19:38
Fredrik HL
  • Fredrik HL
  • 980 inlägg
TW3800 har 20000:1 i kontrast och 6500ub har 75000:1 så det är helt olika projektorer. Antagligen så är 6500ub samma som TW5000.
Läser man på projectorreviews så står det
"where the TW5000, the "international" version of the 7500"
i deras review av 6500UB, antog att 6500UB == TW-3800, 7500UB == TW5000 å 6100 == TW-3000.
#502
Postad 11 August 2009 - 22:03
Bush
  • Bush
  • 469 inlägg
Läser man på projectorreviews så står det i deras review av 6500UB, antog att 6500UB == TW-3800, 7500UB == TW5000 å 6100 == TW-3000.
Hur kan TW3800 vara samma som 6500ub när den har 75000:1 i kontrast och TW3800 har 20000:1?
I så fall är det så här:
TW2800=?
TW3000=6100
TW3800=7100
TW5000=7500/6500
eller:
TW2800=?
TW3000=?
TW3800=7100/6100
TW5000=7500/6500
6100/6500=vit
7100/7500=svart
Det är inte mycket som skiljer mellan 6500 och 7500:
"The Home Cinema 6500UB projector is one of two "flagship" models from Epson. The other is the Pro Cinema 7500UB. They are basically identical except for five things: The 6500UB lacks internal support for an anamorphic lens (you would need an outboard video processor like the DVDO Edge), The 7500UB has internal anamorphic lens support, it has a black casing, instead of the 6500UB's white case. The 7500UB also is ISF Certified (the addition of ISF Day and ISF Night memory modes, and different names for some of the preset modes). Finally, the Pro version comes with a three year warranty instead of two. There is also a difference in terms of where you can buy these projectors: The Home Cinema 6500UB is sold online, and through local dealers while the Pro Cinema 7500UB is local dealer only.
Finally, there is a price difference. The Home Cinema 6500UB is $2999 initially, less a $200 rebate. the Pro Cinema 7500UB is $3999 but comes with a ceiling mount and a spare lamp, which definitely reduces the upfront difference in price, but still ends up more expensive than the 6500UB."
"That's just my take, however. I mention all this, because the Epson projector I have been reviewing has some serious issues with its frame interpolation. I've spent probably 20+ hours looking into these issues, have put out four blogs on it, and have received a lot of good feedback, primarily from folks in the EU, where the TW5000, the "international" version of the 7500UB,is already in the hands of many users. Here in the US, the first shipments are just going out."
http://www.projector...500ub/index.php
Men om TW5000 har allt som ingår i 7500ub vet jag inte.
Redigerat av Bush, 11 August 2009 - 22:04.
#503
Postad 12 August 2009 - 07:01
Unregistered1017
  • Unregistered1017
  • 664 inlägg
7500UB är en variant som innehåller en extra lampa, bättre garanti tror jag och nåt mer, samt en TW5000. Motsvarigheten finns ej i EU vad jag har sett i alla fall. 6500UB är en "vanlig" TW5000.
#504
Postad 12 August 2009 - 07:51
THXcht
  • THXcht
  • 2340 inlägg
Jepp, 7500UB kallas även TW5800. Extra lampa bättre garanti och panelerna skulle vara handplockade för att få den så bra som möjligt.
#505
Postad 12 August 2009 - 08:03
Fredrik HL
  • Fredrik HL
  • 980 inlägg
Satt och jämförde specifikationerna på hemsidorna och det verkar vara som Bush skriver:
TW2800=?
TW3000=?
TW3800=7100/6100
TW5000=7500/6500
6100/6500=vit
7100/7500=svart
#506
Postad 12 August 2009 - 17:00
Unregistered1017
  • Unregistered1017
  • 664 inlägg
Hmm det där med handplockade, är det verifierat? Jag läste på AVS att det rådde lite delade meningar om det hela. Om det är så är det rätt klantigt av Epson att inte leverera lösningen i EU så vi nördar som är perfektionister (som undertecknad) kan få ett exemplar med garanti på funktion. (tw5000 har småproblem med lite konvergens osv). Hade gärna betalat lite mer för en bättre garanti osv.
Men men, man får inte allt här i livet ;)
#507
Postad 12 August 2009 - 17:03
THXcht
  • THXcht
  • 2340 inlägg
Kommer inte ihåg var jag läste det, kan vara i denna tråd...
Samma här, jag hade gärna lagt några kronor till för ett garanterat perfekt exemplar.
#508
Postad 12 August 2009 - 19:31
ljudnisse
  • ljudnisse
  • 2129 inlägg
Fattar inte att ni orkar, häv köpet så att Epson lär sig att man inte kan köra med sin kunder, iaf när det gäller en produkt för 35 lakan !!!
#509
Postad 12 August 2009 - 19:46
THXcht
  • THXcht
  • 2340 inlägg
Problemet då är ju vad man ska välja.
Ska man ha något i samma klass eller bättre så får man ju gå upp en hel del i pengar...
#510
Postad 13 August 2009 - 05:24
JonHolstein
  • JonHolstein
  • 129 inlägg
@THXcht.
Jag läste att du skrev tidigare om reklamation, så gäller det ju produktionsfel, och etersom detta är ett känt fel, så lär ju inte Epson ta strid om du utför en reklamation.
Den killen som svarade dig missade helt en aspekt i det hela... 1 dom får 3 försök på sig att fixa varan, sen har du rätt att häva köpet. Dock så måste du ju rapportera felet inom rimlig tid från det att du upptäckte det. Men hursomhelst, eftersom du får rätten att häva köpet, så försöker ofta återförsäljaren göra ett byte, för det är mer ekonomiskt för dom än att betala fullpris för att köpa tillbaka din begagnade projektor. Det viktiga i sammanhanget är din rätt att häva köpet. Däremot som åtgärder innan du utför reklamationen, så kan dom välja att byta produkten mot en likvärdig som den dagen när du får den har ett listpris som är lägre än vad du betalade för din projektor vid köpetillfället (men om du får en projektor som är lika bra som TW5000 fast utan fokusproblemet, så spelar det ju egentligen ingen roll, eftersom du då får den produkt du ville köpa från början).
Andra anledningar för att få häva ett köp genom reklamation är orimligt lång åtgärdstid av problemet (att produkten är inne på service, eller som i ditt fall, att du rapporterar problemet, men du inte blir erbjuden någon lösning).
Eller att försäljare ljuger, tex om försäljaren säger att problemet inte existerar på modellerna med serienummer efter XX, och man ändå har det problemet. Men det blir ju ett ganska tidigt hävande av affären, man kan ju bara ta hem apparaten och testa, sen får man ju lämna tillbaka den på en gång, men som sagt, säljaren måste ljugit, så det ger inte någon typ av öppet köp. Men hur det ser ut med Defected On Arrival som konsumenträtt har jag inte fulll koll på, alltså rätten att att kräva valrfri åtgärd om produkten är felaktig vid leverans.
(personligen har jag erfarenhet av att säljare ljugit, min mamma skulle köpa en tv, vi var ute och kollade, alltså det var på CRT-tiden, det fanns två modeller som det vägde mellan, den ena var dyrare, men hade S-video in... På ett annat ställe fanns den andra, säljaren hävdade att om man köpte en adapter till scart-kontakten så skulle man kunna koppla in s-video. Sen när tvn ett par år senare skulle kopplas mot en dator, så visade det sig att s-video inte fungerade, en processen att få igenom reklamationen var kanske inte den smidigaste, men det gick, även om det slutade med att min mamma fick ett demo-ex och ny försäkring och allt, och köpet inte direkt hävdes, men detta val gjordes eftersom priserna gått upp vid tiden för reklamationen att det inte längre gick att köpa en CRT-tv av motsvarande storlek för den summan som den ursprungliga tvn inhandlats för)
#511
Postad 13 August 2009 - 07:10
THXcht
  • THXcht
  • 2340 inlägg
Tack för infon...!
#512
Postad 27 August 2009 - 01:31
Jaws86
  • Jaws86
  • 104 inlägg
Hallu!
Har haft min epson 5000 i ca 3 veckor nu!
kollat igenom en stor del blu-ray filmer och spelat en hel del.
första filmen jag såg var Dark Knight måste bara säga att det var en fantastisk upplevelse
med alla detaljer djup mm i filmen (speciellt IMAX scenerna) kändes som en jätte tv ^_^ grymt nöjd
nu några veckor efter mycke tittande, märks det av lite med fokusen!
har satt som i vana att alltid ställa in fokusen när jag sätter på projektorn
sen har det fungerat utmärkt under hela filmen! Visst för en sån här dyr projektor ska
det inte vara sånt skitproblem men vafan den bilden den har är det fan värt det tycker jag!
svårt att säga av dem här på forumet är värre med fokuset än min e ju omöjligt o säga
men jag kan bara uttala om vad min presterar och när den väl är ur fokus så är det fortfarande en bra bild :rolleyes:
Jag är supernöjd!
#513
Postad 27 August 2009 - 16:19
THXcht
  • THXcht
  • 2340 inlägg
Jepp, som sagt det är en ruggigt bra projektor även när den är ur fokus...
Dock så ska man inte behöva ha det problemet för de pengarna.
Så du ställer in fokusen när du startar projektorn, går den inte ur fokus under filmen då?
#514
Postad 27 August 2009 - 17:45
Hemlängtan
  • Hemlängtan
  • 21 inlägg
har nån råkat ut för att TW5000 släcker bilden helt, fläkten går upp på tokvarv (väsnas som f*n) och 2 röda små dioder blinkar på kåpan? (ligger vid on/standby-knappen), så står den ca 1minut innan den går ner i standby.
Detta verkar ske närhelst den känner för det och det verkar alltid ske i samband med nån form av HDMIväxling till 1080p60 men har även skett en gång (har bara haft min TW5000 ett par dar nu) när jag skulle försöka se en blurayfilm i 1080p24. Detta med olika källor via min Onkyo 875a.
Har hänt 5ggr nu på 3 dagar :(
Ungefär vad som hände med min projektor. Efter 2 dagar så slutade min fungera, stendöd förutom två lampor som blinkade. Det visade sig vara moderkortet som gått sönder.
Det har inte varit några direkta problem med focus på min men däremot lens shift som liksom "tappade" positionen (åkte i botten) när jag skruvade på rattarna. Auto iris tyckte jag också lät på tok för högt. Allt detta felanmälde jag. Lens shiften är ungeföär som förut men autiiris blev tystare tycker jag.
Däremot har hag märkt vilken skillnad det är mellan olika filmer hur bra bild det kan bli. Pirates of the caribbean 2 är grymt bra (bilden alltså men filmen är bra också).
Nu har jag fått gröna prickar på bilden som syns när bilden är svart (blank screen eller ingen signal in i projektorn). Jag tror att det är dammkorn men de verkar vara på insidan för det går inte torka linsen. Går det blåsa bort och måste jag öppna kåpan i så fall?
En grym bild när allt stämmer är det i alla fall!
mvh Jon
#515
Postad 27 August 2009 - 18:11
THXcht
  • THXcht
  • 2340 inlägg
Vet ej ifall damm täcks av någon garanti, men det bör det göra så kolla upp det och meddela ifall det täcks. Finns säkert fler som är/kommer att bli drabbade.
#516
Postad 27 August 2009 - 18:43
edtjope
  • edtjope
  • 773 inlägg
Man trodde ju att LCD skulle få ordning med damm på panelerna någon gång, suck. Blir till att fortsätta med DLP då, även om det kan hända också där. Men det är jävligt ovanligt. På LCD verkar det ju vara mer regel än undantag att man råkar ut för det förr eller senare.
#517
Postad 27 August 2009 - 18:56
Hemlängtan
  • Hemlängtan
  • 21 inlägg
Jag får ringa imorgon och reklamera i så fall. Jag trodde att man blåste bort damm själv men det är klart att sitter dammkornet på insidan av linsen så blir det ju knepigt.
Jag återkommer i ämnet.
Hur skyddar man annrs sin projektor mot damm, jag kan ju inte ha det dammigaste biorummet? Eller får man leva med dammkorn på linsen?
#518
Postad 27 August 2009 - 21:39
THXcht
  • THXcht
  • 2340 inlägg
Damm på linsens utsida är ju något vi alla får leva med och är ju inte så svårt att ta bort. Dock på insidan har jag själv aldrig varit med om, men det kräver ju rätt mycket större ingrepp att fixa. Man får se till att rengöra sina filter med jämna mellanrum, och sedan är det nog inte mycket mer man kan göra för att skydda sig mot det.
#519
Postad 27 August 2009 - 22:50
Jaws86
  • Jaws86
  • 104 inlägg
sett ett antal filmer e väl uppe i 60 timmar nu, och har inte en ända gång inte vad jag märkt iaf !
märks bara just när jag sätter på den, då blir det lite finjustering :D
#520
Postad 27 August 2009 - 23:43
lirsa
  • lirsa
  • 1022 inlägg
Otroligt att Epson inte fått ordning på fokusproblemet, dessutom när man varit väldigt medvetna om det. Men jag tror att många andra projektorer lider av exakt samma sak, bara det att användarna inte vet om det och därför inte reagerar :D.
Men nu har ju Epson haft stora problem vad jag har förstått. Personligen skulle jag aldrig stå ut med/gå med på att behöva ställa in fokus varje gång du sätter på projektorn. Inte ens på min HD750 som har en motoriserad fokus.
#521
Postad 28 August 2009 - 22:10
Hemlängtan
  • Hemlängtan
  • 21 inlägg
Jag ringde Netonnet idag och han som jag pratade med sa att damm på insidan av linsen täcks av garantin så länge jag inte gjort ngn åverkan/försökt öppna el dyl. Epson har ju en egen kundtjänst som man hänvisas till så jag får ringa dit efter helgen.
Jag har tagit för vana att alltid pausa filmen efter ett tag och justera focus. Nu kollade jag på en dvd-film och då spelar det ju ingen roll om det är exakt focus eller inte. Men bara för skoj skull så justerade jag skärpan genom att ta upp projektorns meny när projektorn var "kall" och jämförde när filmen var slut och då var så klart bilden ur focus (när jag tog upp menyn). Jag får felanmäla det också när jag ändå håller på :)
#522
Postad 31 August 2009 - 20:50
Unregisteredfec72d49
  • Unregisteredfec72d49
  • 384 inlägg
Har beställt en TW3800 med 104" motorskärm från Netonnet. får se om jag sällar mig till skaran som får focus problem.
en annan sak. jag är oskuld när det gäller projektor och funderar lite på om 104" blir för stort, jag kommer att sitta ganska exakt 4m från duken. går det att skala ner bilden om man upplever den för stor ?
hur blir den om man monterar duken i taket, finns det marginal på duken på höjden så att man kan få ner bilden en bit från taket ?
tänkte ha den i taket och dra ner framför tv:n, har ju inget dedikerat biorum men vill givetvis bli med storbild iaf ;) var först inne på att köpa Samsungs nya 55" LED LCD, men insåg att jag kunde få en helt ok Samsung 50" plasma och TW3800 med duk för samma pengar. kolla på rapport duger gott på en 50" men se en häftig film på en 55" är ingen direkt bio känsla. kommer ihåg när jag såg sagan om ringen på bio, vyerna m.m. var helt mäktiga och jag pratade lyrsikt om det när jag kom hem, när jag sen såg den på min 44" bakprojje så fanns inget av den känslan, hoppas kunna uppnå lite av det med projjen.
Redigerat av Unregisteredfec72d49, 31 August 2009 - 20:53.
#523
Postad 31 August 2009 - 21:19
50plus
  • 50plus
  • 745 inlägg
"...jag är oskuld när det gäller projektor och funderar lite på om 104" blir för stort, jag kommer att sitta ganska exakt 4m från duken..."
Precis det förhållandet, storlek/avstånd, fungerar utmärkt för mig.
Lycka till! :)
#524
Postad 31 August 2009 - 21:57
  • 384 inlägg
Lycka till! ;)
Gott å höra :)
Vet du hur det är med marginal på höjden på duken ?
#525
Postad 01 September 2009 - 09:46
50plus
  • 50plus
  • 745 inlägg
...marginal?? :)
Jag har iofs en helt annan proj och annan duk men förhållandet dukstorlek/tittavstånd är detsamma.
#526
Postad 01 September 2009 - 11:16
THXcht
  • THXcht
  • 2340 inlägg
Gott å höra :)
Många dukar är maskerade med svart som en ram och en hel del upptill...
#527
Postad 02 September 2009 - 19:28
  • 384 inlägg
ok, hoppas jag får en sån, ser ut så på bilden på netonnet.
lite avis på ditt biorum, dags att leta hus med källare :)
#528
Postad 03 September 2009 - 17:14
THXcht
  • THXcht
  • 2340 inlägg
Nästa vecka ska Epson visa upp sina nya projektorer därav ersättaren till denna. Ska bli intressant att se vad de presterar samt ifall den lider av samma problem som TW5000 har. För min del så kommer jag att kräva ut den nya då de fortfarande inte har löst mitt problem (reklamationrätt...)
#529
Postad 03 September 2009 - 19:43
  • 384 inlägg
tänker du begära att få en nyare modell ?
#530
Postad 03 September 2009 - 20:20
THXcht
  • THXcht
  • 2340 inlägg
Helt klart, ifall de inte har fått rätt på en snart ett år gammal projektor så lär de inte fixa till dem efter att de nya har kommit.
Ersättaren till TW5000 ska ju bli TW5500 som då ska vara en jämförbar produkt.
#531
Postad 03 September 2009 - 21:53
  • 384 inlägg
lycka till, hoppas att du fixar det, glöm inte att skriva hur det går.
jag hoppas att min 3800 inte strular, orkar inte hålla på å tjafsa med service å dyl, är den kass så får dom tebaks den.
#532
Postad 14 September 2009 - 17:34
HemmaHosSaga
  • HemmaHosSaga
  • 23 inlägg
Har jag missat ngt eller har prisdumpningen nyss börjat gällande TW5000, ser att man finner den för 25.000 nu. Vet att ny modell är på ingång men raset var ändå osedvanligt snabbt. måste väl anses som mkt prisvärt?
#533
Postad 14 September 2009 - 18:44
THXcht
  • THXcht
  • 2340 inlägg
Dock är det ju så att alla som har den för mellan 25-27000kr inte har den i lager... men ja det är prisvärt ifall man får tag på den för det priset.
#534
Postad 14 September 2009 - 20:15
HemmaHosSaga
  • HemmaHosSaga
  • 23 inlägg
Det är sant, dock förklarar det inte prisskillnaden gentemot de fysiska butikerna som tar 25 % mer. Flera av dessa butiker har dem heller inte i lager utan endast en demoprodukt.
Har det kommit ngn prisindikation på kommande modell ännu?
#535
Postad 14 September 2009 - 20:42
Unregisterede6970ea2
  • Unregisterede6970ea2
  • 1141 inlägg
Funderar på en TW3800 som uppgradering för min trasig projektor men om priset på TW5000 droppar lite mer så är man väl inte sämre än man ändrar sig. :P
#536
Postad 14 September 2009 - 20:57
THXcht
  • THXcht
  • 2340 inlägg
Epson lär ju inte tillverka fler TW5000 så att de skulle få dem i lager tror jag inte mycket på.
Sen tror jag inte heller att Epson riskerar att få ut fler på marknaden som kan ha fel på sig, och då behöver reklameras och allt jobb som det innebär...
Inte ens de butiker som brukar ha dem i lager har ju dem i lager just nu.
#537
Postad 14 September 2009 - 21:02
HemmaHosSaga
  • HemmaHosSaga
  • 23 inlägg
Du kan ha rätt även om jag blivit lovad en med lev-tid på 10 dagar, vi får se.
Menar du att Epson inte levererar fler 5000 ?
#538
Postad 14 September 2009 - 21:10
THXcht
  • THXcht
  • 2340 inlägg
Då TW5500 inte är allt för långt borta och med de problem som TW5000 har haft så är jag tveksam till att de lägger ner någon mer krut på att tillverka fler.
Varifrån blev du lovad 10 dagars leverans?
#539
Postad 14 September 2009 - 21:15
HemmaHosSaga
  • HemmaHosSaga
  • 23 inlägg
MT DATA
#540
Postad 14 September 2009 - 21:20
  • 1141 inlägg
Gratulerar det där låter som ett kanonpris. Hoppas att de håller leveranstiden.
#541
Postad 14 September 2009 - 21:23
THXcht
  • THXcht
  • 2340 inlägg
Vi får hoppas att du får en, lycka till..
#542
Postad 18 September 2009 - 21:08
HemmaHosSaga
  • HemmaHosSaga
  • 23 inlägg
Dessvärre fick du rätt. De ville daqgen efter justera priset med 5000:- vilket nu också syns på Prisjakt
Bara att invänta hösten mao, suck
#543
Postad 18 September 2009 - 22:15
THXcht
  • THXcht
  • 2340 inlägg
Det var ju tråkigt att höra...
Lycka till med att leta vidare!
#544
Postad 22 September 2009 - 16:32
FromHelll
  • FromHelll
  • 117 inlägg
kan man få en tw-5000 utan fokusproblem? eller är det så att de som är nöjda inte märker/inte orkar bry sig?
#545
Postad 06 October 2009 - 13:51
frederik
  • frederik
  • 76 inlägg
Min epson eh-tw5000 har "grusig" bild?? dock inget fokus probem! har köpt den i andrahand.
någon som har erfarenhet av detta? kan det vara en inställning?
SNÄLLA HJÄLP!!
mvh Fredrik
#546
Postad 16 October 2009 - 17:08
Hemlängtan
  • Hemlängtan
  • 21 inlägg
Jag vill bara rapportera lite om min projektor som varit in för andra gången. Första gången dog den bara och dom bytte nått kretskort. Den här gången för dammkorn på insidan av linsen och så klart focusproblem. Kontentan av det hela var att Epson bytte "optical engine" och nu är skärpan bra och dammkornen borta.
Heder till Netonnet som hela tiden följde upp ärendet.
Trevlig helg på er!
Redigerat av Hemlängtan, 16 October 2009 - 17:09.
#547
Postad 25 December 2009 - 20:06
alfahelix
  • alfahelix
  • 111 inlägg
Såg att NetOnNet säljer TW5000 för 21.900:-. Det känns som ett riktigt kap med tanke på att efterföljaren verkar hamna runt 35 tusen. Har Epson kommit till rätta med fokusproblemet ännu? Är det här ett riktigt klipp eller köper man sig bara en massa problem? Någon som vet?
/Patrik
#548
Postad 25 December 2009 - 23:37
Lomen
  • Lomen
  • 143 inlägg
/Patrik
Mitt tipps är att köpa Panasonic 4000 ifrån Usa istället. Den ÄR bättre en epsons gammla plus att du slipper focusproblemen. Du får dessutom hem den får 18500-20000kr klappat och klart ifrån staterna :(
#549
Postad 26 December 2009 - 11:41
urskog
  • urskog
  • 468 inlägg
Mitt tipps är att köpa Panasonic 4000 ifrån Usa istället. Den ÄR bättre en epsons gammla plus att du slipper focusproblemen. Du får dessutom hem den får 18500-20000kr klappat och klart ifrån staterna :D
Detta är förstås en jättebra idé ända tills den dagen den ev. behöver reparation, då blir idén helt plötsligt mindre bra :(
#550
Postad 26 December 2009 - 13:20
sportbilsentusiasten
  • sportbilsentusiasten
  • 459 inlägg
Har du jämfört pana4000 med TW5000? Fler som har?
Är lite tvivlande på att 4000 verkligen är bättre efter att demat den i 3 olika affärer med olika projjar - dock inte mot TW5000.
