Sony VPL-VW1000ES
(Projektorer)
Rapporterad
4
(2)
Inga priser | |
Acer K750
(Projektorer)
6
(1)
Inga priser |
Sony VPL-VW500ES ny 4k projektor (121 inlägg)
7 år sedan |
Sony VPL-VW1000ES (104 inlägg)
12 år sedan |
Postad 14 July 2012 - 19:25
Postad 11 August 2012 - 19:01
Källa: http://www.cinemotio...-et-DLA-X95.htm
Översatt: http://translate.goo...X95.htm&act=url
Postad 11 August 2012 - 19:24
Det är Europas största hemelektronikmässa: http://b2b.ifa-berlin.com/en/
Postad 12 August 2012 - 04:45
JVC exclusive e-Shift technology for upconverted 3840 x 2160 (4K) precision JVC and Japan's NHK Service Engineering, Inc. have collaborated to develop the world's first projection system that uses e-Shift technology. Using e-Shift, the original 1920 x 1080 signal is processed with a correlation detection algorithm to uncover detail that can be enhanced on a 4K display. This enhancement improves edge transitions, eliminates aliasing and stair-stepping, and increases contrast in detailed areas. New sub pixels are generated based on this detection and a 3840 x 2160 frame is created. This frame is then temporally separated into subframes 1920 x 1080 pixels each and projected using the D-ILA optical system and through the e-Shift device. This device utilizes a property of liquid crystals called birefringence and can switch between straight light and refracted light by 0.5 pixel both vertically and horizontally. It has no moving parts. The result is an image with 4 times the pixel density of the original content.Nu börjar det dyka upp lite nyheter, JVC släpper 4 nya maskiner i höst till skillnad från 3 förra året. Instegsmodellen X35 verkar inte få 4K uppskalning som jag uppfattar det utan det blir bara på de större modellerna X55, X75 & X95.
Full HD Blu-ray content looks more natural and film-like absent of any stair stepping or artifacts in diagonal lines. Upconversion to 4K is not available when viewing 3D programs.
http://alienryderflex.com/e-shift/
Postad 12 August 2012 - 08:12
Skall man gissa att X35 är efterföljaren till X30 och att X55 är en X35 med 4K-skalning (e-shift) och lite högre pris medan de två större är direkta efterföljare till X70 och X90?
Postad 12 August 2012 - 11:49
Dags att pensionera glödlampan tycker jag.
Postad 12 August 2012 - 11:56
Dlp projjar med led+laser som ljuskälla verkar ju vara på g från flera håll, en intressant utveckling.
Onekligen spännande men jag skulle tro att det tar ett par år till innan modeller med den tekniken konkurrerar i segmentet 50k och billigare...
Eller?
Postad 12 August 2012 - 14:44
Ja, skulle tro det. Det intressanta blir att se hur prissättningen kommer att se ut på X55an. Om JVC nu verkligen kommer satsa stort på 4k skalning tekniken så borde dom ju också vilja nå en större kundgrupp, X30n fick ju en väldigt attraktiv prissättning och det skulle ju vara trevligt om X55an hamnar i ungefär samma prisklass. Lite dyrare kommer den säkert bli än X30 men låt säga att den hamnar kring 35-40k. Då tror jag den kommer att bli mycket intressant för en bredare grupp köpare.
Postad 12 August 2012 - 14:46
Postad 12 August 2012 - 15:31
Vad innebär 4k idag? när vi kör blu ray
Bilden kan skalas upp från 2k (Blu-ray). Man måste nog ha skarp syn för att uppskatta det på normalt tittavstånd.
Postad 12 August 2012 - 15:38
Postad 12 August 2012 - 15:44
Postad 12 August 2012 - 15:51
Troligtvis kommer det 4k-filmer på Blu-rayskivor framöver och spelare som kan spela upp dem. 4K-bildvisare är det ont om. Det finns ett par 4k-monitorer (vi har en 55" på jobbet t.ex) och så Sony VPL-VW1000 förstås.
JVC:s e-shiftprojektorer kan inte ta emot och visa äkta 4k utan de skalar bara upp lägre upplöst material till fejk-4k med sin e-shiftteknik.
Sony VPL-VW1000 kostar väl 178k så det är väl minst sagt troligt att det finns äkta 4k-projjar på marknade för under 4k inom kort?Jag tror inte vi får se några äkta 4k projjar under 150.000kr.Utbudet är för litet ännu på något år.
Postad 12 August 2012 - 15:57
Redigerat av hassesolo, 12 August 2012 - 15:57.
Postad 12 August 2012 - 16:08
Det finns ju ändå knappt inget material att spela upp i den högre upplösningen så känns lite onödigt att skaffa äkta 4k proj nu..blir nog fejk 4k + 3D ytterligare nåt år tills filmer börjar lagras i det nya formatet och spelare börjar dyka upp på marknaden innan priserna kan sjunka.
E-shift är en intressant teknik, undrar hur konkurrenternas kommer att se ut?
Postad 12 August 2012 - 16:16
Postad 12 August 2012 - 16:20
JVC har haft färdiga 4k projjar för proffsmarknaden i 5 år redan: https://www.minhembi...howtopic=249615Kanske inte, men jag tror att det finns inom ett år. Vem vet? JVC kanske tar steget till äkta 4k i sina toppmodeller? De borde ha 4k D-ILA-chip under utveckling i alla fall (?)
Postad 12 August 2012 - 16:24
Folk tror ju att det är bra att deras mobilkamera har 8 megapixlar (trots att bilderna inte blir bättre och minneskorten fylls upp) och då kommer de vilja ha 4k-projjar också, oavsett om det går att se skillnad på normalt tittavstånd eller ej....
Postad 12 August 2012 - 22:42
Så Blu-ray är förberett för högre upplösning redan från början? Det är alltså samma typ av format som idag, fast högre upplöst? Får vi vänja oss vid Blu-rayHD? Jag såg att nya Yamaha RX-V773 recivern hade stöd för 4K upplösning, men borde inte det innebära en ny Hdmi version?
Postad 12 August 2012 - 22:45
Länk till AVS tråden: http://www.avsforum....0#post_22270091
Darbee off / e-eshift off
Darbee on (35%) / e-shift off
Darbee on / eshift on
Darbee on / eshift off
Darbeee on / eshift on
Darbee + e-shift
Postad 13 August 2012 - 08:32
Men har det inte kommit ut några nyheter redan sharp XV-Z30000 : http://www.projector..._story_1715.htm
Redigerat av Unregistered39429, 13 August 2012 - 08:39.
Postad 13 August 2012 - 19:54
Ha ha ,ja man vet inte riktigt med dom men dom brukar ju annonsera kommande modeller på IFA mässan så vi får väl se kring månadskiftet...Är det dax för nya från epson eller väntar dem tills 2013?
men vilka modeller är det som hitintills har kommit ut under år 2012 förutom Sharp XV-Z30000 och BenQ W7000?
Postad 13 August 2012 - 19:57
Historiskt har de ju släppt nytt varje år (så långt tillbaka jag kan erinra mig just nu iaf), men däremot har de inte alltid bytt ut hela produktionslinjen på en gång och ersatt alla modeller.
Postad 13 August 2012 - 20:16
Epson TW-EH9000 kom innan jul i fjol.NY ersättare kommer eventuellt på IFA-mässan nu...När släpptes 9000 vilken ersatte denna?
Postad 13 August 2012 - 20:27
Den ersatte väl TW5500. Med 3D i tillägg då så att säga...
Postad 13 August 2012 - 21:47
Sony VPL-VW1000
är ju ny för i år oxå!
Nja, jo eller nä
Postad 13 August 2012 - 21:57
Ok va de så de va,jag bad dom plocka bort den klistrade länken...högst upp.Nja, jo eller nä
den presenterades på IFA förra året men dom lyckades få ut den först i januari, men man får nog säga att det var förra årets modell.
Postad 14 August 2012 - 09:13
Postad 14 August 2012 - 21:37
Postad 14 August 2012 - 22:04
hoppas ni kan ge mig råd vad jag ska köpa eller inte?har ett mörkt rum nere i källaren utan fönster,rummet är 18 kvadrat ,jag har canaldigital max hd, så jag ser det mesta från sport till film ,och även koppla in bärbar dator,men hadde inte tänkt lägga så mycket pengar ja typ 4000-7000 ska jag lägga det på en projektor och duk eller tv ? har en vägg som är 2,00meter bred och 1,95 i höjd,som jag tänkde ha duken manuelt, hjälp mig att tänka vad som är rätt,får man plocka bort sin gammla tv som tar plats,
Du bör nog ta bort detta inlägg o starta en ny tråd i ämnet.. denna tråd handlar om vilka nya projar som kan tänkas komma iår
Postad 15 August 2012 - 00:56
Läste detta gällande Cedia och antar att samma gäller för IFA mässan. Någon som hört mer om detta?
Postad 15 August 2012 - 01:26
Postad 15 August 2012 - 06:35
Postad 15 August 2012 - 06:40
inte om alla är lika illa)
Postad 18 August 2012 - 00:41
http://translate.goo...d-94-12276.html
Postad 18 August 2012 - 01:03
Acer har något nytt på g:
7 aug 2012
Acer Debuts World's First 1080p Hybrid LED-Laser Projector - Unique mercury-free technology improves brightness, color, and light-source lifetime
Bioggio
The Acer K750 is the world's first 1080p projector equipped with a hybrid laser-LED light technology, improving color saturation by 55% to deliver outstanding, energy efficient projection.
The K750 projector uses both LED and laser light sources, which is not only hazardous substances free - like mercury of halogen gases – but also significantly improves color brightness when compared to high-pressure mercury lamps. This technology also increases the light-source lifetime to 20,000 hours in ExtremeECO mode and enables as much as 90% power savings, helping to reduce TCO over its life, thus positioning the K750 as one of the most environmental friendly projectors.
What’s more, this innovative hybrid light-source technology enables flexible color settings and a wider color gamut to deliver better color saturation up to 85% NTSC and offers superior color fidelity through a system of three independent color lighting sources.
With a brightness of up to 1,500 lumens and a contrast ratio up to 100,000:1 projects perfect and crispy content, while the 1080p Full HD resolution allows enjoying HDTV and watching Blu-ray movies in fantastic clarity and detail.
The HDMI® port delivers uncompressed digital signals and multi-channel audio, providing easy connectivity to high-definition presentation and entertainment. In addition to it, the K750 projector is equipped with at least two connectors for multiple-PC source input, including D-Sub and HDMI®, offering more flexible connectivity and instant switching.
In order to empower usability, the K750 features instant on/off capability, which means no cool-down period is needed after turning the projector off. This is an important productivity feature especially in the business and education world. Moreover, the Acer SmartFormat technology instantly synchronizes with wide-format displays without any resolution adjustments from the notebook, while supporting multi-format for instant projection.
This projector sports an elegant gray-and-white portable design: the control pad is embedded on the sleek gray and metal surface, reflecting Acer's premium craftsmanship; the sculpted lines on the ventilation grill add sophistication to the design, while the smooth, rounded contours provide a comfortable touch.
Källa: http://www.acercompu...ress/2012/42131
Postad 21 August 2012 - 10:51
4
86 bilder
1544 filmer
