Onkyo år 2013: TX-NR929 & TX-NR828.
32 svar till detta ämne
Postad 26 May 2013 - 05:27
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Ser att Onkyo TX-NR929 samt lillebrorsan TX-NR828 redan finns listade på både Idealo & Skinflint.Det borde betyda att dom även är på gång in i dom svenska butikerna så småningom.Det blir spännande att se hur dom står sig emot sina konkurrenter!
Specifikationer Onkyo TX-NR929: http://www.se.onkyo....atasheet_EN.pdf
Specifikationer Onkyo TX-NR828:http://www.se.onkyo....atasheet_EN.pdf
Postad 26 May 2013 - 05:42
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Onkyo TX-NR929:
Technical DetailsFeature
THX® Select2 Plus™ Certified
  • 4K Passthrough and Upscaling from Source Devices via HDMI®
  • Built-in Wi-Fi-Certified Wireless LAN Capability
  • Onboard Bluetooth Audio Streaming Technology
  • Three-Stage Inverted Darlington Circuitry on All Channels
  • HDMI Video Upscaling to 4K with Qdeo™ Technology by Marvell
  • ISF (Imaging Science Foundation) Image Calibration for Assignable Video Inputs
  • Zone 2 HDMI Output for HD Video in a Second Room
  • MHL™ (Mobile High-Definition Link) for 1080p Smartphone Media on HDTV
  • Internet Radio and Music Streaming Service Connectivity (TuneIn Radio, Last.fm, Spotify, AUPEO!, and Simfy)*1
  • Playback of Audio Files Over the Wireless Home Network (MP3, WMA, WMA Lossless, FLAC, WAV, Ogg Vorbis, AAC, Apple Lossless, DSD, LPCM*2, and Dolby® TrueHD)
  • Supports Onkyo Remote Apps for iPod touch/iPhone*3 and Android Devices*4 for Housewide System Control
  • Whole House Mode for Synchronized Housewide Audio
  • DTS Neo:X™, Audyssey DSX®, Dolby® Pro Logic® IIz Upmixing
  • Audyssey MultEQ® XT32 Room Acoustic Correction
  • Powered Zone 2 and Zone 3, and Zone 2/3 Line-Outs for Housewide Audio Distribution
  • Digital Processing Crossover Network for Optimal Bi-Amping
  • 11.2 Multichannel Pre-Outs
  • Picture-in-Picture Video Preview with InstaPrevue™ Technology
  • Phase-Matching Bass Boost
*1 Availability of services depends on region. Some services may require a subscription and a firmware update. *2 LPCM playback via DLNA only *3 Compatible with iPod touch (3rd generation or later) and iPhone 3GS or later. All models require iOS 4.2 or later. *4 Requires Android OS 2.1 or later.
AMPLIFIER FEATURES
  • 185 W/Ch (6 Ω, 1 kHz, 1% THD, 1 Channel Driven, IEC);
  • WRAT (Wide Range Amplifier Technology)
  • H.C.P.S. (High Current Power Supply) Massive High Power Transformer
  • Discrete Output Stage Circuitry
  • Optimum Gain Volume Circuitry
  • PLL (Phase Locked Loop) Jitter-Cleaning Circuit Technology
PROCESSING FEATURES
  • HDMI Support for 3D, 4K, Audio Return Channel, DeepColor™, x.v.Color™, LipSync, Dolby® TrueHD, DTS-HD Master Audio™, DVD-Audio, Super Audio CD, Multichannel PCM, and CEC
  • TI Burr-Brown 192 kHz/24-Bit 8-Channel DAC (x1), TI Burr-Brown 192 kHz/24-Bit 2-Channel DAC (x2)
  • Differential DAC Mode (Front Channels)
  • Advanced 32-Bit Processing DSP Chip
  • 4 DSP Modes for Gaming: Rock, Sports, Action, and RPG
  • Advanced Music Optimizer for Compressed Digital Music Files
  • Theater-Dimensional Virtual Surround Function
  • Direct Mode and Pure Audio Mode
  • Double Bass Function
  • Non-Scaling Configuration
  • A-Form Listening Mode Memory
CONNECTION FEATURES
  • 9 HDMI Inputs (1 Front/8 Rear) and 2 Outputs
  • 1 USB Port (Front)
  • Mass Storage Class USB Memory Playback
  • 2 Component Video Inputs and 1 Output
  • 5 Composite Video Inputs and 1 Output
  • 6 Digital Audio Inputs (3 Optical and 3 Coaxial)
  • 7 Analog Audio Inputs (1 Front/6 Rear)
  • Phono Input for Turntable Connection
  • RS232 Port
  • Analog RGB Video Input (D-sub, 15 pin) for PC
  • IR Input/Output and 12 V Trigger Outs (Zone 2/Zone 3)
  • Color-Coded, Banana Plug-Compatible Speaker Posts
  • Headphone Jack
OTHER FEATURES
  • Audyssey Dynamic EQ® for Loudness Correction
  • Audyssey Dynamic Volume® Listening Level Adjustment
  • Overlaid On-Screen Display (OSD) with Quick Set-Up and Home Menu
  • Independent Crossover Adjustment for Each Channel (40/50/60/70/80/90/100/120/150/200 Hz)
  • A/V Sync Control (Up to 800 ms in 5 ms Steps)
  • Tone Control (Bass/Treble) for Front L/R Channels
  • Display Dimmer (Normal/Dim/Dimmer, Volume Knob LED: On/Off)*
  • RDS (PS/RT/PTY/TP) (European Model Only)
  • 40 FM/AM Random Presets
  • Certified with DLNA Version 1.5
  • Firmware Updates via Network and USB
  • Aluminum Front Panel and Volume Control Knob
  • Compatible with RI Dock for iPod/iPhone and AirPlay (DS-A5)
  • RIHD (Remote Interactive over HDMI) for System Control
  • Bi-Directional, Preprogrammed, and Customizable RI Remote Control with Macro Presets for Four Activities
*Note: Volume knob LED is always off when display is dimmed
THX® Select2 Plus™ for Cinema-Reference Sound
To be awarded THX Select2 Plus certification—the most rigorous performance benchmark for this type of product—the A/V receiver must play at cinema reference volume levels with minimal distortion. Select2 Plus is specified for screen-to-seat distances of three to four meters and room volumes of about 56 cubic meters.
Onboard Wi-Fi and Bluetooth Streaming Technology
The TX-NR929 connects to the wireless home network without LAN cables or adapters. Send a range of hi-res, lossless, and compressed files to your home cinema from smartphone, PC, tablet, NAS, and online sources using our remote control app. Or pair devices for quality wireless streaming using the built-in Bluetooth technology.
Music Streaming and Internet Radio Services
The TX-NR929 comes preloaded with popular music streaming and internet radio services including Spotify, Last.fm, and TuneIn Radio. They’re easily selectable using the receiver’s GUI or the remote control app. Explore more than 10,000 radio stations and enjoy albums and playlists with reference-level sound.
Note: Availability of services depends on region. Some services may require a subscription and a firmware update. Availability of services advertised here is accurate at the time of publication, but may be subject to change without notice.
HDMI® for High-Resolution Playback
The TX-NR929 features nine HDMI inputs to accept hi-res content from your media players and gaming consoles. HDMI enables Dolby® TrueHD and DTS-HD Master Audio™ audio formats, and supports 3D video. Two HDMI outputs are included for high-definition video in two separate zones.
Supports 4K Video Content
With 4K televisions, media players, and projectors hitting the market, it’s reassuring to know your A/V receiver is compatible with this new technology. Passthrough of native 4K from source devices to an appropriate display is fully supported.
4K Video Upscaling via Qdeo™ Technology
The TX-NR929 uses class-leading Qdeo technology from Marvell to upscale standard video sources to brilliantly smooth 1080p (for regular HDTVs) and to an incredible 4K on compatible displays.
MHL™ for Mobile Phones and Tablets
A frontside HDMI/MHL terminal is included to connect smartphones and other electronic devices. MHL allows you to display 1080p video and other media on your HDTV with 7.1-channel surround sound.
Quick and Easy Remote App Control
Remote apps for iPhone and Android devices offer a convenient way to control your housewide entertainment from anywhere within wireless range. The app offers a clear interface for managing content and settings across multiple zones.
Hassle-Free Video Switching
Switching between games, movies, and cable TV should be easy. InstaPrevue™ technology names your HDMI devices and displays video thumbnails of available content. Now you can switch sources without having to remember what device is connected where.
Overlaid Menus for Quick Adjustments
Touch the Quick Set-Up button on your remote to overlay menus in-program. You can now access useful settings without interruption to your viewing. The Home Menu, meanwhile, offers simple icons for choosing a media source, and for more detailed system adjustment.
Onkyo Premium Hi-Fi Sound
Onkyo’s WRAT (Wide Range Amp Technology) includes low-negative-feedback amplifiers for punchy, true-to-life sound; closed ground-loop circuits to reduce noise; and high instantaneous current to handle big dynamic gains. With its sophisticated control technology and discrete output stage, Three-Stage Inverted Darlington Circuitry is designed for high-energy output and very low distortion.
Three High Performance Sound Expansion Systems
Audyssey DSX®, Dolby® Pro Logic® IIz, and DTS Neo:X™ expansion systems allow you to choose your preferred speaker setup. Audyssey DSX expands 5.1-channel sources to incorporate Wide or Height channels. Pro Logic IIz adds Height channels with stereo source expansion, while DTS Neo:X offers Wides and Heights and supports 11.1-channel upmixing with the addition of an outboard stereo amp.
Audyssey’s top-flight room correction suite equalizes the sound to suit the acoustics of your listening space. High-res filters are applied to all channels—including subwoofers—based on information collected from more than 10,000 individual control points across eight measurement positions.
High-Definition Video in Two Rooms
Now there’s a way to enjoy your hi-def content on a second TV without having to purchase another Blu-ray player or set-top box. Connect your additional display using the receiver’s Zone 2 HDMI output to enjoy the same program, or two different HD sources, in both rooms.
App-Controllable Multi-Zone Audio
This receiver features Powered Zone 2 and Powered Zone 3 outputs. You can assign surround channels to power audio in two additional rooms equipped with speakers while preserving a 5.2-channel setup in your cinema room. Content is managed via remote app, allowing you to play the same song in all zones using Whole House Mode, or to enjoy a different track in every room.
Should you wish to bi-amp your front speakers, our onboard digital crossover system precisely separates high and low frequencies into two discrete signals and sends them to the appropriate drivers. Used in conjunction with conventional speakers, or with channel-divider-type speakers (which do not contain crossovers), the sophisticated DSP technology reduces frequency overlap at the crossover point for noticeably clearer sound.
Phase-Matching Bass Enhancement
Onkyo’s PM Bass optimizes low frequencies while preserving mid-range clarity. It counters phase shifting (which can affect sound quality) by synchronizing frequency timing. The result is deep, well-defined bass that won’t overwhelm vocals or strings.
Redigerat av Unregistered39429, 26 May 2013 - 14:09.
Postad 26 May 2013 - 07:27
Unregistered1605
  • Unregistered1605
  • 1863 inlägg
Verkar fortfarande ligga efter på Power Supply sidan med sin 'skabbiga' design.
Trist tycker jag.
Postad 26 May 2013 - 07:55
Unregisteredb259d244
  • Unregisteredb259d244
  • 68 inlägg
Dessutom verkar 828 vara ett nerköp jämfört med förra årets modell 818.
Postad 26 May 2013 - 09:23
Meep
  • Meep
  • 47 inlägg
Vad baserar du "nedköp" på?
Fortfarande ingen Airplay i nya serien? Är den licensen verkligen så dyr? Kan man ändå strömma ifrån datorns spotify på något sätt? Det går inte med min 609 annat än att köra den inbyggda spotifyklienten, vilket suger. Har visserligen en airport men det hade vart skönt att ha allt integrerat.
Postad 26 May 2013 - 10:17
  • 68 inlägg
Bl a en enklare version av Audyssey-rumskorrigering.
Postad 26 May 2013 - 10:40
Meep
  • Meep
  • 47 inlägg
Låter ju inget vidare? Stor skillnad? Det är fortfarande Audyssey XT32?
Hur är dessa om man använder front height högtalare? Har hört att Yamaha är i framkant vad gäller detta men Yamaha har ju inge Audyssey, vilket är lite tråkigt.
Postad 26 May 2013 - 11:15
  • 68 inlägg
Nej, bara MultEQ enligt Onkyos hemsida. Sen kan man nog diskutera hur stor skillnaden är i praktiken.
Postad 26 May 2013 - 19:43
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Onkyo TX-NR929 är alltså både THX & ISF certifierad (för bildkalibrering) samt har en bättre inbyggd rumskorrigering för ljudet,vilka fler skillnader hittar vi imellan de två olika modellerna tro?
Postad 26 May 2013 - 20:53
Unregisteredbf364490
  • Unregisteredbf364490
  • 1887 inlägg
828 är egentligen en avskalad 818. 130W istället för 135W. Audyssey MultiEQ istället för X32. 7.2 kanalers pre-out jmfr med 9.2. Ingen diffrentierad DAC Mode för front-kanalerna, ingen isolerad Power-Amp och Pre-Amp Block, 15 kg istället för 18,3 kg. De har också tagit bort Dolby Volume.
Redigerat av Unregisteredbf364490, 26 May 2013 - 20:54.
Postad 26 May 2013 - 21:00
  • 1887 inlägg
929 är mer lik 818. Dolby Volume är dock fortfarande borttaget. Audyssey MultiEQ X32 är tillbaka. 9.2 på 929an också samt 135W. ISFen nämner du ovan. Ytterligare en HDMI-ingång hittar man. Gällande analoga Pre-Outs har den 11.2 jämfört med 828ans 7.2. Kan dock inte hitta om 929an har så att man kan köra olika källor på HDMI 1 resp. 2 (som man kan göra på Onkyo 1010an och uppåt).
Redigerat av Unregisteredbf364490, 26 May 2013 - 21:02.
Postad 26 May 2013 - 21:28
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
OK det var lite skillnader det,vet du om Onkyo kommer med en till modellserie ovanför denna som efterträdare till TX-NR1010,3010 & 5010 från ifjol?
Postad 01 June 2013 - 08:14
Meep
  • Meep
  • 47 inlägg
TX-NR929
TV without having to purchase another Blu-ray player or settop box. Connect your additional display using the receiver’s
http://www.eu.onkyo....atasheet_EN.pdf
Verkar inte gälla 8-serien.
Postad 20 June 2013 - 11:15
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Onkyo's auktoriserade internethandlare inom Sverige 2013: http://www.se.onkyo....yoDealersResult
Postad 23 July 2013 - 10:04
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Användarmanualen till TX-NR929 på Svenska: http://www.uk.onkyo....TX-NR929_Sv.pdf
Postad 23 July 2013 - 13:56
Nattsvart
  • Nattsvart
  • 737 inlägg
Ja, jag tyckte att 818 verkade vara en väldigt prisvärd förstärkare. Man får prestanda och funktioner som man måste upp till 926 för att matcha och för ett mycket lägre pris. Lite tråkigt att de tog bort XT32 för 8-serien i år. Det är nästan som om de försämrade sin produkter jämfört med 2012 så att säga....
Postad 24 July 2013 - 10:17
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
:huh:
Nu åker priserna jojo nere på www.idealo.de Onkyo TX-NR929 har varit nere på 10100kr som lägst hittills i år.Ungefär 38% billigare än i Sverige!.För övrigt håller jag med om att det är 929'an som är mest intressant.
Postad 25 July 2013 - 06:15
OMD28
  • OMD28
  • 3032 inlägg
Hur menar du med " det hade varit skönt att ha allt integrerat " men du vill inte använda den inbyggda klienten ? Vad betyder integrerad för dig?
Om du vill krångla till det med en PC så rekommenderar jag Jamcast så kan du spela upp direkt i ex 609:an via virtuella ljudkortet. http://getjamcast.com/Features.aspx
Personligen tycker jag att den inbyggda klienten funkar bra om man styr från en app.
Postad 30 August 2013 - 17:12
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Är den sämre än dom nya ifrån Denon och Yamaha denna Onkyo TX-NR929?
Postad 28 September 2013 - 18:42
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
http://youtu.be/Cgaxmf8B2-w Nu är den nere i 9500 kr i Tyskland! https://www.prisjakt...p=1908314&c=all
Postad 29 September 2013 - 10:17
Lennart_Myra
  • Lennart_Myra
  • 59 inlägg
Intressant! Någon som jämfört/testat/kan ge input på denna vs Yamaha 3020?
Postad 30 September 2013 - 11:58
Unregistered76636631
  • Unregistered76636631
  • 1029 inlägg
När släpper Onkyo tyngre receivers än 929, för att inte tala om försteget 5509 som släpptes tidigt 2011 ?
Tycker 929 är bra specad men men mycket vill ha mer.
Postad 07 October 2013 - 17:33
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Här finns en länk till onkyo's hemsida för firmware uppgradering utav 929'an och 828'an.Även 616 med flera modeller!
Postad 07 November 2013 - 16:18
Unregistered39429
  • Unregistered39429
  • 3116 inlägg
Rolig läsning! https://www.prisjakt...p=1908314&c=all
Postad 07 November 2013 - 16:20
Unregistered291b229b
  • Unregistered291b229b
  • 1690 inlägg
Tror jag missade det roliga, upplys mig! :P
Postad 02 March 2014 - 03:34
proson rules
  • proson rules
Tycker det verkar som att det är vissa negativa vibbar om onkyo,till er som är besvikna på onkyo kan ju kolla in integra istället som är onkyos motsvarighet till mercedes amg. Jag hade en onkyo tx-sr 707 innan men har beställt Tx-nr 828 och jag är säker på att jag kommer bli nöjd.
Postad 02 March 2014 - 07:52
OMD28
  • OMD28
  • 3032 inlägg
Grejen är att de som är nöjda sällan skriver på ett forum " min Onkyo funkar kanon i dag också "
Under flera års tid var nästa var tredje såld reciever i Sverige en onkyo! och naturligtvis om det säljs 100000 Onkyo och 7000 av fabrikat X så kommer fler Onkyo gå sönder.
Dessutom så har framför allt onkyo 600-serie var extremt populära och varit första recievern för många, och många har som förstagångs köpare kanske inte vetat hur man gör och då blivit kritiska.
Det har varit många nya trådar och inlägg i gamla trådar där kritiken berott på handhavande fel.
Visst har Onkyo haft problem med HDMI kort tidigare, men problemen har inte alls varit så stora som man kan tro när man läser på forum. Det är mängden sålda enheter som avspeglas.
Postad 03 March 2014 - 21:27
nohall
  • nohall
  • 39 inlägg
Halloj!
Jag köpte en tx-nr626 förra veckan.
Helnöjd med receivern, MEN.. Den ger ifrån sig ett extremt irriterande "hummande/brummande" ljud. Ljudet kommer inte från högtalarna utan från självla receivern. Det är som om något vibrerar inne i receivern.
Någon annan som drabbats av detta? Ska jag försöka lämna tillbaka den?
Redigerat av nohall, 03 March 2014 - 21:27.
Postad 07 March 2014 - 22:34
SonySamppa79
  • SonySamppa79
  • 1832 inlägg
Störs du av det i soffan så låter det skumt. Onkyo kör med rätt maffiga nätdelar och fläkt, men jag har inte stört mig på nån av dom jag haft: 607,608,616 och nu 727
Alla har varit och är tysta.
Postad 24 May 2014 - 09:16
baconaboo
  • baconaboo
  • 298 inlägg
Har en Onkyo tx-nr929 som igår lämnades in som sedan ska skickas på service.
Anledningen är följande:
Vid 1 tillfälle har den slagit ifrån allt som har med ljud att göra.
Den kände inte av högtalarna och kunde således inte skicka ut något ljud.
Problemet fortsatte vid källbyte, avstängning/ påsättning av förstärkare.
"Löstes" genom att låta den stå avstängd utan ström in i X antal timmar.
Har på senare tid börjat "läcka" ut ljud trots att alla enheter i anläggningen är avstängda.
Så du kan helt plötsligt börja höra ett brus ur högtalarna trots att förstärkaren är avstängd..
Så ska bli spännande och se ifall det hittas något fel i den.
Är ju mycket tekniska prylar i dagens förstärkare så borde lätt kunna bli fel, men men.
Fick en Yamaha RX-A1030 som låneförstärkare, ska bli kul och prova en modern Yamaha.
Den enda Yamaha jag haft var en 2kanals stärkare från 80talet jag fick från farsan. Den stendog då jag drog på ordentligt med ett par Dynavoice Finalehögtalare :)
Edit:
Hembiobutiken som jag köpt den genom har varit i kontakt med Onkyo som aldrig hört talas om felet.
De ska iaf skicka förstärkaren till Onkyo för felsökning nu. Kan dock tycka de skulle gjort det i ett tidigare skede.
Värt att veta är att felet inte uppstår med låneförstärkaren, så bör inte vara kringprodukterna som orsakar bruset.
Redigerat av baconaboo, 11 June 2014 - 17:11.
Postad 25 May 2014 - 15:25
pellepulare
  • pellepulare
  • 144 inlägg
skrivgärna några rader sen och ge ett omdöme då du jämfört yamahan mot onkyon.
Postad 06 July 2014 - 10:32
baconaboo
  • baconaboo
  • 298 inlägg
Har fått tillbaka min förstärkare efter felsökning.
Svaret jag fick var att det inte är något fel på den med förklaringen att förstärkaren kan aktivera högtalarutgångarna i avstängt läge genom "network on standby" samt via RHID-styrning.
De gjorde även en firmwareuppdatering.
Det bästa är att jag inte nyttjade någon av ovanstående funktioner, men men.
Jag tror mer på att det var en mjukvarubugg då felet inte uppstått sedan jag fick tillbaka den.
Postad 06 July 2014 - 11:42
baconaboo
  • baconaboo
  • 298 inlägg
Här kommer en liten jämförelse mellan min förstärkare och den jag fick på lån.
Värd notis är att jag enbart testat i 2.0 & 2.1 utförande då jag inte har fler högtalare just nu :)
De båda förstärkarna påminner en hel del om varandra.
Liknande uppbyggnad chassimässigt, likvärdiga inkopplingar, frontpaneler, rattar etc.
Så man kände igen sig rent okulärt.
Det första man märke då man kopplade in Yamahan var att den hade snäppet stabilare kontakter på baksidan, kändes som kablarna satt bättre på plats.
Inte så att man går å rycker i dom, men känslan vid inkoppling var bättre än på Onkyon.
Onkyon har i mitt tycke alltid upplevts lite "plastig" på baksidan, mycket har att göra med högtalarkontakterna som är av enklare variant än på deras ytterligare större förstärkare. Tycker denna med sitt höga nypris borde fått de kontakterna utbytta.
Efter inkoppling så vill man bläddra i inställningarna.
Här är jag van med Onkyons upplägg och "grafik" då jag haft Onkyo senaste åren.
Jag tycker att Yamahans menyer var väldigt fula och inte alls lika tydliga och lätthittade som Onkyons är.
Du kommer snabbare igång med musiklyssning/ filmtittning med en Onkyo än med en Yamaha efter ett nyköp.
Det jag mest gjort under lånetiden av Yamahan är att lyssna på musik.
Här märker man att de lagt mer krut än Onkyon, just i stereoläge.
Yamahan har en mycket mer detaljerad och exakt ljudbild som gör att man enklare tar till sig musiken och kan njuta av den på ett avslappnat sätt.
Det låter sedan ännu finare om man aktiverar "pure"-läget som stänger ned allt onödigt och låter förstärkaren koncentrera sig på en sak.
En dålig jämförelse är att A1030 är som en 20år laphroig och 929an är en mehkong vid musiklyssning.
Du får ut lika mycket effekt från mehkongen men inte lika njutbart :)
Om man sedan slår på film så är det helt plötsligt ombytta roller.
Det är här som Onkyon lagt ned sina resurser, att få fram en maskin för hemmabionördar.
Tydligt är att Onkyon har en högre vilja, först och främst på mängden högtalare du kan koppla in. Du har en grund på 9.2 med möjlighet till 11.2 via externa slutsteg, vilket säger att den vill bli placerad i en dedikerad hemmabio och skämma bort en totalt.
Du har dessutom fler hdmi-ingångar på Onkyon, 9 jämfört med 8. Sen om du använder alla är en annan fråga, men möjligheten finns.
Yamahan har istället valt att ge en fler RCA-ingångar, vilket inte är lika intressant i bion.
Bägge förstärkarna har möjlighet till autokalibrering. Kunde inte köra den på Yamahan då jag inte fick med någon mätmick.
Resultatet efter en kalibrering är positiv.
För det första är den enkel att utföra, mätningarna blir exakta om man jämför med självmätning med måttband men framförallt skapar den en "bubbla" du kommer vela ha vid filmtittning.
Från tidigare Onkyoförstärkare jag haft så känner man att kvaliteten i mätningarna har höjts.
Först så har du en gedignare mick, du får bättre mätresultat och resultaten uppfattas snabbare av förstärkaren.
Allt för att det ska vara så enkelt som möjligt att komma igång.
Blev lite längre skrivet än jag tänkt, men sammanfattar med lite +/-.
Onkyo TX-NR929:
+Många inkopplingsmöjligheter för digital användning
+Grymt ljud i filmtittning
+Enkel hantering
+Autokalibrering
-Baksidan motsvarar inte priset
-Trivs inte så bra i stereoläge
Yamaha RX-A1030:
+Riktigt bra i stereoläge för en hemmabioförstärkare
+Ordentlig byggkvalitet
+Spotifyconnect
-Dålig fjärrkontroll
-Fula menyer
Den gången det blir en ny förstärkare kommer jag överväga en Yamaha för att se hur den presterar med en 5.1 uppställning.
Tror inte den når upp till Onkyons filmkvalitet, men vill iaf prova.
Båda förstärkarna är bra, men de riktar sig mot lite olika användningsområden.
