* Officiell Tråd - Panasonic PT-AE4000 *
811 svar till detta ämne
Postad 03 September 2009 - 19:13
Über-Guru
10397 inlägg
Nu är den på g. länk
11799_9984ae3000angle_1_.jpg 40.37K
3 Antal nerladdningarWe're not in the habit of handing out full marks and Editor's Choice Awards all that often, but the Panasonic PT-AE3000 we reviewed in February got just that treatment and it now has a successor, the PT-AE4000 - which if we go by the product number alone, should be about 1,000 times better! If you examine the pictures you'll see the PT-AE4000 is cut from the same cloth as its predecessor, so the differences are more fundamental than a new lick of paint. These include the second iteration of Panasonic's Lens Memory technology, which aims to eliminate the Cinemascope issue and offer a true 2.35:1 aspect cinema experience. Aside from this the main difference between the two is a new 'red rich lamp' and dynamic iris, which supposedly boosts the contrast ratio of the projector from 60,000:1 to an incrementally better 80,000:1. Other specs include the obligatory 1,920 x 1,080 (Full HD) resolution and 1,600 ANSI Lumens brightness, both of which are unchanged. Connectivity is also unchanged, comprising three v1.3 HDMI input, two component video inputs, composite video, S-Video, a serial port, D-SUB and an RS-232 input. Riyad was recently treated to a demo of the PT-AE4000 and says it "looked pretty sweet". However, if that nugget of feedback isn't enough to justify a £2,000 projector purchase (exact pricing is to be confirmed), then expect a review in the not too distant future, with the projector itself going on sale from the end of October.
Postad 03 September 2009 - 19:52
Unregistered39429
Unregistered39429
3116 inlägg
 Då har den fjärde generationens Full HD 1080p hemmabio projektor Panasonic PT-AE4000 siktats på deras globala hemsida för projektorer (se länken nedan),detta verkar vara en flexibilitets projektor utav sällan skådat slag.Bra kastförhållande,bra zoomomfång,vertikal samt horisontell lensshift funktion som ju betyder att den är installationsvänlig & placeringsflexibel och alltså enkelt lär kunna fylla filmdukar av tillräckligt stora mått även om man har ett mindre hemmabiorum.Den klarar alltså utav att projicera upp en tillräckligt stor&mäktig bild på förhållandevis kort kastavstånd (lins-filmduk).Dessutom tycks den vara fullständigt kompatibel med alla de filmer som är inspelade i det extra breda så kallade 2.35:1 formatet som ju tex är dominerande på dagens Blu-ray filmer.Den har dessutom ett förbättrat linsminne som automatiskt känner utav vilket format den aktuella filmen som spelas upp har och anpassar sig alltså automatiskt efter det och filmduken,som i denna modells fall alltså bör kompletteras med en extra bred så kallad 2.35:1 duk.Åtminstone om den är tänkt att spela ihop med en Blu-ray spelare. Den verkar även ha ett Color Managment System med vissa individuella justeringsmöjligheter för 6 olika primär & sekundär färger och dess nyans,luminans samt färgmättnad för att helt enkelt kunna få till en vettig balans i färgspektrumet och därmed en jämnare filmbild vad gäller färgerna alltså.Samt justeringsmöjligheter för att anpassa gammakurvan efter bildsignal och rumsmiljö när man finjusterar bilden med hjälp utav tex kalibreringskivan DVE HD Basics eller kanske till och med en profesionell ISF kalibrering?.Kontrasten uppges vara 90000:1 (maximalt on/off) och sen lite lägre när den dynamiska Irisen jobbar på högvarv i samspel med elektroniken som känner utav ljusinnehållet i den aktuella filmscenen som för tillfället visas på filmduken och automatiskt justerar ljusstyrkan därefter.Denna projje förtjänar att bli placerad i en omtänkt rumsmiljö så dess potential får bästa förutsättningar till att brilljera! Här finns en klickbar länk till en fullständig och djupare presentation utav Panasonic PT-AE4000 på deras hemsida. 5 minuters intervjuv med produktmanagern ifrån panasonic!http://youtu.be/rUnG1yCE8vs Ser vi den under november månad tro?
Redigerat av Unregistered39429, 10 February 2012 - 18:50.
Postad 03 September 2009 - 20:38
chrillebn
chrillebn
697 inlägg
Mmmm, vill ha!!!!!
Postad 03 September 2009 - 21:29
Unregistered39429
Unregistered39429
3116 inlägg
Som en liten hint om den äkta användbara ljusstyrkan och dess lumens i en anpassad rumsmiljö i just det specifika bildläget Cinema1 hos PT-AE4000,kan det nämnas att Cine4home.de precis har kollat lite på denna projje och mätt upp följande värden (på deras exemplar): Cinema1 läget @D6500 kelvin lampa i Normal läge 680 lumens Cinema1 läget @D6500 kelvin lampa i Eco läget 533 lumens Så nog bör den kanske kunna fylla åtminstone en ~266 centimeter bred 2.35:1 filmduk med dom rekomenderade 16 footlambert som sällskapet SMPTE rekomenderar helt utan problem i Cinema1 läget.(Maximalt lyckades dom pressa upp den i 1620 obalanserade Lumens).
Postad 03 September 2009 - 21:56
Unregistered39429
Unregistered39429
3116 inlägg
AVForums.com visar även ett TV reportage om Panasonic PT-AE4000 på deras hemsida Här Klicka,Klicka
Postad 03 September 2009 - 22:22
Unregistered39429
Unregistered39429
3116 inlägg
För den som eventuellt är vidare intresserad av ämnet Rumsmiljö och dess betydelse för den totala bildkvaliten som en liten fördjupning i ämnet innan PT-AE4000 anländer till butikerna,kan kanske en sökning på Google efter denna fullständigt briljanta text skriven av en mycket vis man rekomenderas: The Importance of Viewing Environment Conditions in Reference Display Systems
Postad 03 September 2009 - 23:17
Micke_L
Micke_L
1199 inlägg
Verkar superb. Fast då var det ju det där med att zoomen fortfarande "bara" är 2x. Måste vara nåt fel på mig som tycker mig behöva mer.
Postad 03 September 2009 - 23:21
19825 inlägg
Jag slog ihop de två trådar som startades igår, hassesolo drog dock första strået och var några minuter snabbare
Postad 03 September 2009 - 23:30
Unregistered39429
Unregistered39429
3116 inlägg
Postad 04 September 2009 - 06:32
Unregistered08511788
233 inlägg
Ska bli intressant och titta på denna nu i höst och jag hoppas den inte spränger budgeten bara, det vara kanske bra av flera anledningar att man inte inhandlade projektor nu för 1 månad sedan.
Redigerat av Unregistered08511788, 04 September 2009 - 06:33.
Postad 04 September 2009 - 07:47
ekon
ekon
5779 inlägg
Mycket möjligt att det blir ny projektor i höst =)
Postad 04 September 2009 - 13:58
K-Man
K-Man
106 inlägg
Är det bara jag som tycker detta stinker besvikelse? PT-AE3100 skulle vara ett mer passande namn. Panasonic har varit världsledande på projektorer i denna prisklass imånga år nu och varje år överaskat alla med förbättringar på alla fronter samt helt nya features. Nu verkar de snarast fixat några buggar sedan förra året... Men man får väl avvakta till de första testerna åtminstone. Åtminstone Epson ser ju på pappret ut att dra ifrån... Snackar om kontrastsiffror på 150000-200000:1. Jag hoppas mycket på övriga märken nu.
Postad 04 September 2009 - 14:47
Über-Guru
22892 inlägg
De första testerna (Cine4Home) har redan visat på ganska betydande prestandaförbättringar, plus att viss funktionalitet har tillkommit. Att önska sig mer är väl ganska orealistiskt.
Postad 04 September 2009 - 15:09
K-Man
K-Man
106 inlägg
De första testerna (Cine4Home) har redan visat på ganska betydande prestandaförbättringar, plus att viss funktionalitet har tillkommit. Att önska sig mer är väl ganska orealistiskt. Hur menar du orealistiskt? Det är väl fullt naturligt att utvecklingen går framåt och prestandan blir bättre även på pappret? Jämförelse PT-AE1000/2000/3000/4000: Ljusstyrka: 1100 / 1500 / 1600 / 1600 Kontrast: 11000:1 / 16000:1 / 60000:1 / 80000:1 Vi får se hur mycket de förbättrat frame creation och zoomfunktionen för 2.35:1 men det var ju annars fjolårets nyheter...
Postad 04 September 2009 - 15:22
Mars
Mars
752 inlägg
Jo, men ibland känns det som den snabbaste utvecklingen sker på specen.
Vore roligt om de gick ett riktigt kliv på native-kontrasten.
Postad 04 September 2009 - 15:27
Über-Guru
22892 inlägg
Tjaa, utvecklingen har ju alldeles uppenbarligen gått framåt i det här fallet. Som det verkar så är det kanske orealistiskt att tro att det skulle hända så fasligt mkt mer än vad det verkar ha gjort. Möjligen att man kanske kunnat önska att native CR gått upp lite mer.
Men ja, önskar man sig större förändringar på pappret så kanske denna proj är en besvikelse och den besvikelsen kan man kanske inte kalla orealistisk nej, bara konstig, eller nått.
Redigerat av pacman, 04 September 2009 - 15:28.
Postad 04 September 2009 - 16:13
K-Man
K-Man
106 inlägg
Om inte siffrorna ändras så är ju inte utveckling uppenbar... Jag vet att inte siffror är allt men när dom inte ens vågar höja sina siffror så börjar man undra om det hänt något alls... Det blir ju löjligt sånt här men vi snackar ju ändå marketing. Dom har ju haft ett år på sig att komma fram till nya features och förbättringar liksom. Vad jag hade hoppats på var mer konkreta förändringar som t ex något av följande: * Avsevärt mindre och lättare. * Ny och snyggare design. * WLAN och kanske DLNA-support * Implementering av en ny videoprocessor som t ex HQV Vida med förbättra uppskalning mm * Tystare och energisnålare * Möjligtvis ett radikalt lägre pris (vilket återstår att se) * Märbart bättre svärta/kontrast/ljustyrka och allt det vanliga... Min besvikelse kommer sig av att Panasonic varit ledande när det gäller förbättringar och innovationer de senaste åren men detta år verkar de inte ha något "stort" att komma med. Kanske hade jag för höga förväntningar men inte särskilt konstiga eller orealistiska tycker jag själv.
Postad 04 September 2009 - 17:10
Hybe
Hybe
1429 inlägg
Har en känsla att du kommer bli besviken på projektornyheterna i år då.  Priset tror iaf inte jag kommer vara lägre än vad AE3000 kostar idag. Tror inte Panasonics AE4000 måste vara en besvikelse jämfört med tex. Sony HW15 och Epson TW5500, om man ser till vad som är förbättrat jämfört med fjolårets modeller. Tillverkarna gör nog allt för att få det där lilla försprånget före sina konkurenter. Förra året var det ju Sanyo som hamna på efterkälken...., om det blir Panasonic i år återstår att se!
Postad 04 September 2009 - 17:36
edtjope
edtjope
773 inlägg
Sanyo har väl varit på efterkälken ganska länge nu..
Postad 04 September 2009 - 18:58
Hybe
Hybe
1429 inlägg
Var inte Z5 konkuranskraftik när den kom? När jag köpte projje sist var Sanyo iaf med i matchen med Z4, då jag köpte Epson TW600.
Postad 04 September 2009 - 23:08
Hifimatte
Hifimatte
938 inlägg
Är färgerna bättre än 3000an?
Postad 05 September 2009 - 14:06
Hybe
Hybe
1429 inlägg
Enligt förhandstitten så ska färgerna vara bättre i den nya modellen. En ny lampa som ska åtege färgen röd på ett bättre sätt och samtidigt höja ljusstyrkan ska finnas i AE4000
Postad 05 September 2009 - 14:15
Hifimatte
Hifimatte
938 inlägg
Thanks
Postad 05 September 2009 - 17:39
edtjope
edtjope
773 inlägg
Det är väl bara att kolla vilken av Z5:an och TW700 som är populärast. Dom är från samma generation och näe, Sanyo hade inte mycket att hämta där. Så Z4:an var nog senast dom var med i matchen.
Postad 06 September 2009 - 06:37
peppelito
peppelito
2261 inlägg
Att en produkt är populärare än en annan betyder ju inte automatiskt att den är bättre. Kolla de "seriösa" testsidorna på nätet så ser man att Z5 visst kunde/kan mäta sig med exempelvis TW700. Däremot är de kanske lämpade för lite olika förhållanden... S orry för OT. //P
Postad 08 October 2009 - 22:11
K-Man
K-Man
106 inlägg
Postad 08 October 2009 - 22:22
Nahaz
Nahaz
1349 inlägg
1995 dollar säger dom i den texten.
Då borde svenska priserna hamna närmare 20000:- än 30000:- som dom ligger på just nu.
Postad 08 October 2009 - 23:07
dnlar
dnlar
562 inlägg
Äntligen en utförlig test:
www.projectorcentral.com/panasonic_ae4000_projector_review.htm
oh my... bättre på nästan allt....? hoppas projectorreviews lägger upp sin snart.. med jämförelser mot de andra nykomlingarna.
Postad 09 October 2009 - 03:36
Unregistered68eeb4be
518 inlägg
2000 dollar, OMG är ju bara 14000:-(låter ju lite för otroligt för att vara sant) isf tar jag 2
Postad 09 October 2009 - 08:29
Unregistered93acb259
134 inlägg
1995 dollar säger dom i den texten. Då borde svenska priserna hamna närmare 20000:- än 30000:- som dom ligger på just nu.
Och gör de inte det så får det bli en resa till USA, helt klart!
Postad 09 October 2009 - 10:40
lobo
lobo
2842 inlägg
Man ska väl åtminstone lägga till 25% moms på det där priset för att kunna jämföra det med svneska riktpriser till konsument. I praktiken blir det väl lite mer. Men låt oss drömma på ett pris runt 20000kr inom en inte alltför avlägsen framtid :-) Det borde betyda att priset på AE3000 skulle kunna börja rasa nu tycker jag.
Tittar man på priset på 3000 i USA så har det letat sig ner kring 1500$ vilket gör 500$ mot 4000.
Postad 09 October 2009 - 13:50
Damocles
Damocles
1200 inlägg
Det enda som är lite vanskligt och som får mig att tänka två gånger på att uppgradera är den totalt obefintliga servicen panasonic har på projektorer. Går något fel, så är du på egen hand. Har försökt få service totalt 4 gånger under sista året för IRIS-problemet på PT-AE100, och man ringer, och de ska återkomma, händer inget. Bara tyst. Och butikerna hänvisar ju direkt till panasonic. Ska försöka ringa en femte gång, sedan blir det ARN. Under sommaren har det fungerat dugligt, men nu när det börjar bli kallt så kommer IRIS-problemet som på posten.
Vad gäller PT-AE4000 och även 3000 så verkar den riktigt bra. Men jag gillar inte de preliminära priserna här på prisjakt. 30 lök liksom.
Redigerat av Damocles, 09 October 2009 - 13:51.
Postad 09 October 2009 - 17:30
dnlar
dnlar
562 inlägg
Såvitt jag kan se släpptes denna 2002, hur kan du ha garanti kvar på den?
Postad 09 October 2009 - 19:51
Nahaz
Nahaz
1349 inlägg
Jag har kollat överallt på nätet nu och jag tror dom missuppfattat priset i reviewn ovan. Det enda jag kan tänka mig är att det är 2000 pund dom fått till 2000 dollar.
Det är alltså fortfarande ett pris mellan 25 och 30 tusen som gäller för svenska marknaden.
Postad 09 October 2009 - 20:29
KJE
KJE
1076 inlägg
Tror han menar AX100
Postad 11 October 2009 - 01:24
Damocles
Damocles
1200 inlägg
Ja, jag slant lite. Och även om jag inte har garanti kvar, den är bara 1 år, så i sverige gäller fortfarande 3 år reklamationsrätt mot fabrikationsfel. Men att man ska behöva sitta av och till i månader och månader och få höra... "det är min kollega som hanterar ärenden för sverige, han återkommer till dig" eller "vi mailar ett formulär till dig". Och när man ringer så hamnar man såklart i den rullande supportdesken, 2 ggr har jag hamnat i indien, en gång i england, en gång i sverige. Inte ett mail eller en tillbakaringning så långt ögat når. Men det är väl klart, om man aldrig skapar ett supportärende och bara väntar på att kunden ska tröttna så blir man nog av med många fel i längden, och många kunder. Hade inte rört mig i ryggen om det inte samtidigt vore så att deras saker är skitbra så länge de fungerar.
Postad 15 October 2009 - 09:27
Unregistered47481920
139 inlägg
Jag ser at AE4000 har kommet opp med pris, på noen norska netshops, for cirka SEK 23600 med dagens SEK/NOK kurs.
Redigerat av kompo, 15 October 2009 - 09:28.
Postad 15 October 2009 - 14:57
Nahaz
Nahaz
1349 inlägg
Import relaterade inlägg hänvisas till https://www.minhembi...howtopic=245221Så håller vi oss till prestanda, upplevelse intryck och relevanta frågor om produkten i denna tråd.
Postad 16 October 2009 - 19:34
Damocles
Damocles
1200 inlägg
Hmm, DHL var och hämtade upp min AX100 så nu är den på väg till cardiff, på garanti. De sa 3 år när jag pratade med dem i telefon. Iofs kan de har förväxlat garanti och reklamationsrätt, men när det är fabrikationsfel så är det inte mycket som skiljer praktiskt.
Så på 5e försöket fick jag hjälp, så det verkar bara vara att få tag i rätt person som gäller typ. Men nog tusan blir jag sugen på en AE4000 när den börjar droppa in. Bara den håller sig under 25K så.
Postad 16 October 2009 - 22:21
Hifimatte
Hifimatte
938 inlägg
AE3000 var trevlig förutom färgerna och har dom blivit bättre + bättre svärta så låter det som en vinnare för mig som vill ha 2.35 duk
Postad 18 October 2009 - 08:59
Unregistered659
Unregistered659
128 inlägg
Hur bra är Fi:n på panasonicen? Har för mig att cine4home berömde just interpoleringen på ae3000. Finns det ett läge som fungerar bra utan att det ser artificiellt ut?
Postad 20 October 2009 - 10:59
MagPau
MagPau
3 inlägg
Projektorn ska finnas på Malmömässan enligt uppgift från Hificenter...
Håller tummarna för det.
Postad 23 October 2009 - 20:51
dnlar
dnlar
562 inlägg
Postad 27 October 2009 - 18:32
Damocles
Damocles
1200 inlägg
Intressant vändning vad gäller supporten ovan. Projektorn kom till cardiff den 19e, den lämnade cardiff den 20e, dhl försökte levera 21 då jag var på jobbet, och först idag, 27e så dimper DHL's lapp ned om att de har legat på paketet. Nu ska de leverera i morgon. Är nu bara AX100an fixad så måste jag säga att Panasonics support var snabb, vändande post. Så när väl hjälpen kommer är det med råge. Synd att DHL inte ringer innan bara...
Postad 30 October 2009 - 15:20
Unregistered70fd4719
272 inlägg
Jag sitter med fingret på knappen för att beställa denna projektor, men har ett par funderingar.
1. Funderar på att skaffa en PS3 som BD spelare. Vet att det var ett bra alternativ för något år sedan som BD till projektor, men har inte hängt med i utvecklingen på senare tid. Är denna fortfarande ett bra alternativ, och specifikt till PT-AE4000?
2. Är det en markant fördröjning av bilden i denna typ av projektor pga bildbehandling? Eftersom ingen testat AE4000 än kanske någon med erfarenhet av AE3000 kan svara. Har en Onkyo 605a som jag vill minnas har Lip Sync möjligheter, så det kanske inte blir några problem.
Till att börja med blir det att projecera bilden på väggen innan jag bestämmer storlek och typ av duk. Har möjlighet att mörklägga mitt rum helt, men väggarna är hyfsat ljusa. Målning står på listan över saker att göra...
Postad 30 October 2009 - 15:31
Lomen
Lomen
143 inlägg
1. Funderar på att skaffa en PS3 som BD spelare. Vet att det var ett bra alternativ för något år sedan som BD till projektor, men har inte hängt med i utvecklingen på senare tid. Är denna fortfarande ett bra alternativ, och specifikt till PT-AE4000? 2. Är det en markant fördröjning av bilden i denna typ av projektor pga bildbehandling? Eftersom ingen testat AE4000 än kanske någon med erfarenhet av AE3000 kan svara. Har en Onkyo 605a som jag vill minnas har Lip Sync möjligheter, så det kanske inte blir några problem.
Hej, om du har vita väggar så refflekterar ju dom ljuset. I ditt fall så skulle jag sattsa på en Euroscreen React. Jag har sett pt-ae 3000 med react och det fungerade klockrent. Jag har en 104" Reactduk själv och är mer än nöjd.
Postad 31 October 2009 - 02:37
Damocles
Damocles
1200 inlägg
Test finns på projectorcentral för de som vill läsa kan man ju tillägga.
Postad 31 October 2009 - 08:10
Über-Guru
10397 inlägg
PS3 är bra med massor av plus men den har även ett par minus: Ganska dyr. Det finns billigare spelare som är bra. Har man otur kan man få ett högljudt exemplar. Vill man ha en helt tyst skall man satsa på en annan. Ingen display. Kan vara lurigt om man vill spela musik utan att sätta på projektorn. Bara bluetouthfjärr. Om man vill styra med en multifjärr går det att lösa med ett tillbehör (men bara med Harmony).
Postad 31 October 2009 - 20:23
272 inlägg
Tack för en bra sammafattning. Multifjärr och ingen display ser jag inte som några problem för mig, kommer bara kolla på film. Priset på nya PS3 här borta i USA är endast $299, vilket jag tycker är helt ok med tanke på att man även får en spelkosoll på köptet. Högt ljud låter däremot sådär. Får nog läsa igenom PS3 tråden för att se om det är ett markant problem på den senaste Slim-modellen.
Postad 31 October 2009 - 20:36
Unregisteredce93e47d
841 inlägg
inte speciellt lurigt alls, bara att aktivera att ps3an ska spela skiva vid inmatning. Men visst, är ju svårt att se vilken låt osv. som spelar men det är inte hela världen enligt mig.
Projektorer
Tonewinner 7300
Perlisten R18s
Philips Discoverer
Ny projektor!
